root/radiance/ray/src/px/psign.c
Fri Nov 19 22:51:31 2021 UTC (3 years, 8 months ago) by greg
Diff to previous 2.27 , to selected 2.18
refactor: made font load errors non-fatal
Fri May 20 02:06:39 2011 UTC (14 years, 2 months ago) by greg
CVS Tags: rad4R1, rad4R2, rad4R2P1, rad4R2P2, rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 2.26 , to selected 2.18
Mon Jan 1 03:03:32 2007 UTC (18 years, 7 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 2.25: +5 -5 lines
Diff to previous 2.25 , to selected 2.18
Rename gettext() to get_text() to avoid name conflict
Sun Mar 28 20:33:14 2004 UTC (21 years, 4 months ago) by schorsch
Changes since 2.24: +52 -21 lines
Diff to previous 2.24 , to selected 2.18
Wed Oct 22 02:06:35 2003 UTC (21 years, 9 months ago) by greg
Diff to previous 2.23 , to selected 2.18
Sun Jul 27 22:12:03 2003 UTC (22 years ago) by schorsch
Diff to previous 2.22 , to selected 2.18
Mon Jun 30 14:59:12 2003 UTC (22 years, 1 month ago) by schorsch
Changes since 2.21: +6 -2 lines
Diff to previous 2.21 , to selected 2.18
Sat Jun 21 15:05:01 2003 UTC (22 years, 1 month ago) by greg
Changes since 2.20: +7 -1 lines
Diff to previous 2.20 , to selected 2.18
Fixed some conflicting definitions
Sun Jun 8 12:03:10 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.19: +2 -1 lines
Diff to previous 2.19 , to selected 2.18
Thu Jun 5 19:29:34 2003 UTC (22 years, 2 months ago) by schorsch
Changes since 2.18: +2 -6 lines
Diff to previous 2.18
Revision 2.18 - (view) (download) (annotate) - [selected]
Sat Feb 22 02:07:27 2003 UTC (22 years, 5 months ago) by greg
Changes since 2.17: +4 -7 lines
Diff to previous 2.17
Thu Apr 14 04:53:54 1994 UTC (31 years, 4 months ago) by greg
Changes since 2.16: +0 -6 lines
Diff to previous 2.16 , to selected 2.18
Mon Feb 28 09:25:31 1994 UTC (31 years, 5 months ago) by greg
Changes since 2.15: +1 -0 lines
Diff to previous 2.15 , to selected 2.18
added newheader() call
Fri Jun 4 17:02:48 1993 UTC (32 years, 2 months ago) by greg
Changes since 2.14: +0 -1 lines
Diff to previous 2.14 , to selected 2.18
Fri Jan 8 13:14:14 1993 UTC (32 years, 7 months ago) by greg
Changes since 2.13: +10 -10 lines
Diff to previous 2.13 , to selected 2.18
removed dangerous rounding that caused right margin to be exceeded
Mon Sep 21 12:14:30 1992 UTC (32 years, 10 months ago) by greg
Changes since 2.12: +15 -13 lines
Diff to previous 2.12 , to selected 2.18
Changes for PC port
Tue Sep 8 10:35:08 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.11: +2 -9 lines
Diff to previous 2.11 , to selected 2.18
portability fixes
Wed Jul 8 13:58:10 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.10: +10 -3 lines
Diff to previous 2.10 , to selected 2.18
made it so just one of -x or -y can be given along with -h
Tue Jul 7 18:24:34 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.9: +12 -2 lines
Diff to previous 2.9 , to selected 2.18
made it so -a option could be zero for absolute -x and -y spec.
Tue Jul 7 17:35:42 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.8: +36 -6 lines
Diff to previous 2.8 , to selected 2.18
added -x and -y options to control output size
Mon Jun 22 13:59:53 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.7 , to selected 2.18
changed large malloc() to bmalloc() call
Thu Jun 18 16:14:43 1992 UTC (33 years, 1 month ago) by greg
Diff to previous 2.6 , to selected 2.18
paranois
Tue Jun 16 16:48:39 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.5: +20 -2 lines
Diff to previous 2.5 , to selected 2.18
added -s option to psign for proportionally spaced text
Tue Jun 16 16:27:37 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.4: +52 -34 lines
Diff to previous 2.4 , to selected 2.18
added super-sampling for anti-aliasing of text
Tue Jun 16 15:34:47 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.3: +30 -16 lines
Diff to previous 2.3 , to selected 2.18
initial fixes to getfont move
Sat Jun 6 07:40:51 1992 UTC (33 years, 2 months ago) by greg
Changes since 2.2: +25 -63 lines
Diff to previous 2.2 , to selected 2.18
initial move of getfont to separate routine
Thu Dec 19 14:52:00 1991 UTC (33 years, 7 months ago) by greg
Diff to previous 2.1 , to selected 2.18
Tue Nov 12 16:04:19 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.3 , to selected 2.18
Thu May 30 08:22:52 1991 UTC (34 years, 2 months ago) by greg
Changes since 1.2: +3 -14 lines
Diff to previous 1.2 , to selected 2.18
added COLRFMT to output
Sat Dec 8 10:12:07 1990 UTC (34 years, 8 months ago) by greg
Changes since 1.1: +5 -4 lines
Diff to previous 1.1 , to selected 2.18
added call to fropen to find font file using RAYPATH variable
Thu Feb 2 10:49:28 1989 UTC (36 years, 6 months ago) by greg
Diff to selected 2.18
