--- ray/src/px/psign.c 1992/06/16 16:27:37 2.5 +++ ray/src/px/psign.c 2007/01/01 03:03:32 2.26 @@ -1,34 +1,28 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: psign.c,v 2.26 2007/01/01 03:03:32 greg Exp $"; #endif - /* * psign.c - produce picture from text. * * 7/1/87 */ -#include "standard.h" +#include "copyright.h" -#include "color.h" +#include +#include "platform.h" +#include "standard.h" +#include "resolu.h" +#include "color.h" #include "font.h" -#ifndef SSS -#define SSS 3 /* super-sample size */ +#ifndef SSS +#define SSS 3 /* super-sample size */ #endif -#define MAXLINE 512 /* longest allowable line */ +#define MAXLINE 512 /* longest allowable line */ -#ifndef DEFPATH -#define DEFPATH ":/usr/local/lib/ray" -#endif -#ifndef ULIBVAR -#define ULIBVAR "RAYPATH" -#endif - char *fontfile = "helvet.fnt"; /* our font file */ COLOR bgcolor = WHTCOLOR; /* background color */ @@ -37,23 +31,28 @@ COLOR fgcolor = BLKCOLOR; /* foreground color */ int direct = 'r'; /* direction (right, up, left, down) */ int cheight = 32*SSS; /* character height */ -double aspect = 1.67; /* height/width character aspect */ +double aspect = 1.67; /* height/width character aspect */ +double spacing = 0.0; /* character spacing */ int cwidth; /* computed character width */ unsigned char *ourbitmap; /* our output bitmap */ int xsiz, ysiz; /* bitmap dimensions */ int xdim; /* size of horizontal scan (bytes) */ -#define bitop(x,y,op) (ourbitmap[(y)*xdim+((x)>>3)] op (1<<((x)&7))) -#define tstbit(x,y) bitop(x,y,&) -#define setbit(x,y) bitop(x,y,|=) -#define clrbit(x,y) bitop(x,y,&=~) -#define tglbit(x,y) bitop(x,y,^=) + /* conflicting def's in param.h */ +#undef tstbit +#undef setbit +#undef clrbit +#undef tglbit +#define bitop(x,y,op) (ourbitmap[(y)*xdim+((x)>>3)] op (1<<((x)&7))) +#define tstbit(x,y) bitop(x,y,&) +#define setbit(x,y) bitop(x,y,|=) +#define clrbit(x,y) bitop(x,y,&=~) +#define tglbit(x,y) bitop(x,y,^=) + FONT *ourfont; /* our font */ -char *libpath; /* library search path */ - typedef struct line { char *s; /* line w/o LF */ short *sp; /* character spacing */ @@ -64,16 +63,24 @@ LINE *ourtext; /* our text */ int nlines, maxline; /* text dimensions */ int maxwidth; /* maximum line width (dvi) */ -extern char *getenv(); -extern char *malloc(), *calloc(); +static void makemap(void); +static void get_text(FILE *fp); +static void arg_text(int ac, char *av[]); +static void maptext(void); +static void mapglyph(GLYPH *gl, int tx0, int ty0); +static void mapcoord(int p[2], int tx, int ty); +static void mapedge(int x, int y, int run, int rise); +static void writemap(FILE *fp); -main(argc, argv) -int argc; -char *argv[]; +int +main( + int argc, + char *argv[] +) { int an; - + SET_FILE_BINARY(stdout); for (an = 1; an < argc && argv[an][0] == '-'; an++) switch (argv[an][1]) { case 'c': /* color */ @@ -109,12 +116,21 @@ char *argv[]; goto unkopt; } break; + case 'x': /* x resolution */ + xsiz = atoi(argv[++an])*SSS; + break; + case 'y': + ysiz = atoi(argv[++an])*SSS; + break; case 'h': /* height of characters */ cheight = atoi(argv[++an])*SSS; break; case 'a': /* aspect ratio */ aspect = atof(argv[++an]); break; + case 's': /* spacing */ + spacing = atof(argv[++an]); + break; default:; unkopt: fprintf(stderr, "%s: unknown option: %s\n", @@ -122,12 +138,10 @@ unkopt: exit(1); } /* load font file */ - if ((libpath = getenv(ULIBVAR)) == NULL) - libpath = DEFPATH; ourfont = getfont(fontfile); /* get text */ if (an == argc) - gettext(stdin); + get_text(stdin); else arg_text(argc-an, argv+an); @@ -136,6 +150,7 @@ unkopt: /* convert text to bitmap */ maptext(); /* print header */ + newheader("RADIANCE", stdout); printargs(argc, argv, stdout); fputformat(COLRFMT, stdout); putchar('\n'); @@ -146,31 +161,75 @@ unkopt: } -makemap() /* create the bit map */ +static void +makemap(void) /* create the bit map */ { - cwidth = cheight/aspect + 0.5; + double pictaspect; + if (direct == 'r' || direct == 'l') { - xsiz = (long)maxwidth*cwidth >> 8; - ysiz = nlines*cheight; + if (xsiz <= 0) { + cwidth = cheight/aspect + 0.5; + xsiz = (long)maxwidth*cwidth >> 8; + ysiz = nlines*cheight; + } else if (aspect > FTINY) { + if (ysiz <= 0) + ysiz = cheight*nlines; + pictaspect = 256*nlines*aspect/maxwidth; + if (pictaspect*xsiz < ysiz) + ysiz = pictaspect*xsiz + 0.5; + else + xsiz = ysiz/pictaspect + 0.5; + cheight = ysiz/nlines; + cwidth = cheight/aspect; + } else { + if (ysiz <= 0) + ysiz = cheight*nlines; + pictaspect = (double)ysiz/xsiz; + aspect = pictaspect*maxwidth/(256*nlines); + cheight = ysiz/nlines; + cwidth = cheight/aspect; + } } else { /* reverse orientation */ - xsiz = nlines*cheight; - ysiz = (long)maxwidth*cwidth >> 8; + if (ysiz <= 0) { + cwidth = cheight/aspect + 0.5; + xsiz = nlines*cheight; + ysiz = (long)maxwidth*cwidth >> 8; + } else if (aspect > FTINY) { + if (xsiz <= 0) + xsiz = cheight*nlines; + pictaspect = maxwidth/(256*nlines*aspect); + if (pictaspect*xsiz < ysiz) + ysiz = pictaspect*xsiz + 0.5; + else + xsiz = ysiz/pictaspect + 0.5; + cheight = xsiz/nlines; + cwidth = cheight/aspect; + } else { + if (xsiz <= 0) + xsiz = cheight*nlines; + pictaspect = (double)ysiz/xsiz; + aspect = maxwidth/(256*nlines*pictaspect); + cheight = xsiz/nlines; + cwidth = cheight/aspect; + } } if (xsiz % SSS) xsiz += SSS - xsiz%SSS; if (ysiz % SSS) ysiz += SSS - ysiz%SSS; xdim = (xsiz+7)/8; - ourbitmap = (BYTE *)calloc(ysiz, xdim); + ourbitmap = (BYTE *)bmalloc(ysiz*xdim); if (ourbitmap == NULL) error(SYSTEM, "Out of memory in makemap"); + memset((char *)ourbitmap, '\0', ysiz*xdim); } -gettext(fp) /* get text from a file */ -FILE *fp; +static void +get_text( /* get text from a file */ + FILE *fp +) { - char *fgets(); char buf[MAXLINE]; register LINE *curl; int len; @@ -183,15 +242,22 @@ FILE *fp; if (curl == NULL) goto memerr; len = strlen(buf); - curl->s = malloc(len); + curl->s = (char *)malloc(len); curl->sp = (short *)malloc(sizeof(short)*len--); - if (curl->s == NULL | curl->sp == NULL) + if ((curl->s == NULL) | (curl->sp == NULL)) goto memerr; if (len > maxline) maxline = len; strncpy(curl->s, buf, len); curl->s[len] = '\0'; -len = uniftext(curl->sp, curl->s, ourfont); + if (spacing < -1./256.) + len = squeeztext(curl->sp, curl->s, ourfont, + (int)(spacing*-256.)); + else if (spacing > 1./256.) + len = proptext(curl->sp, curl->s, ourfont, + (int)(spacing*256.), 3); + else + len = uniftext(curl->sp, curl->s, ourfont); if (len > maxwidth) maxwidth = len; curl->next = ourtext; @@ -200,20 +266,22 @@ len = uniftext(curl->sp, curl->s, ourfont); } return; memerr: - error(SYSTEM, "Out of memory in gettext"); + error(SYSTEM, "Out of memory in get_text"); } -arg_text(ac, av) /* get text from arguments */ -int ac; -char *av[]; +static void +arg_text( /* get text from arguments */ + int ac, + char *av[] +) { register char *cp; ourtext = (LINE *)malloc(sizeof(LINE)); if (ourtext == NULL) goto memerr; - ourtext->s = malloc(MAXLINE); + ourtext->s = (char *)malloc(MAXLINE); if (ourtext->s == NULL) goto memerr; for (cp = ourtext->s; ac-- > 0; av++) { @@ -227,7 +295,14 @@ char *av[]; ourtext->sp = (short *)malloc(sizeof(short)*(maxline+1)); if (ourtext->sp == NULL) goto memerr; -maxwidth = squeeztext(ourtext->sp, ourtext->s, ourfont, 50); + if (spacing < -1./256.) + maxwidth = squeeztext(ourtext->sp, ourtext->s, ourfont, + (int)(spacing*-256.)); + else if (spacing > 1./256.) + maxwidth = proptext(ourtext->sp, ourtext->s, ourfont, + (int)(spacing*256.), 3); + else + maxwidth = uniftext(ourtext->sp, ourtext->s, ourfont); nlines = 1; return; memerr: @@ -235,7 +310,8 @@ memerr: } -maptext() /* map our text */ +static void +maptext(void) /* map our text */ { register LINE *curl; int l, len; @@ -251,9 +327,12 @@ maptext() /* map our text */ } -mapglyph(gl, tx0, ty0) /* convert a glyph */ -GLYPH *gl; -int tx0, ty0; +static void +mapglyph( /* convert a glyph */ + GLYPH *gl, + int tx0, + int ty0 +) { int n; register GORD *gp; @@ -274,8 +353,12 @@ int tx0, ty0; } -mapcoord(p, tx, ty) /* map text to picture coordinates */ -int p[2], tx, ty; +static void +mapcoord( /* map text to picture coordinates */ + int p[2], + int tx, + int ty +) { tx = (long)tx*cwidth >> 8; ty = (long)ty*cheight >> 8; @@ -301,9 +384,13 @@ int p[2], tx, ty; } -mapedge(x, y, run, rise) /* map an edge */ -register int x, y; -int run, rise; +static void +mapedge( /* map an edge */ + register int x, + register int y, + int run, + int rise +) { int xstep; int rise2, run2; @@ -338,12 +425,14 @@ int run, rise; } -writemap(fp) /* write out bitmap */ -FILE *fp; +static void +writemap( /* write out bitmap */ + FILE *fp +) { COLR pixval[SSS*SSS+1]; /* possible pixel values */ COLOR ctmp0, ctmp1; - double d; + double d; COLR *scanout; int x, y; register int i, j; @@ -384,5 +473,5 @@ FILE *fp; exit(1); } } - free((char *)scanout); + free((void *)scanout); }
