root/radiance/ray/src/px/psign.c
Revision: 2.4
Committed: Tue Jun 16 15:34:47 1992 UTC (32 years, 11 months ago) by greg
Changes since 2.3: +30 -16 lines
initial fixes to getfont move
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * psign.c - produce picture from text.
9 *
10 * 7/1/87
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "font.h"
18
19 #define SSS 2 /* super-sample size */
20
21 #define MAXLINE 512 /* longest allowable line */
22
23 #ifndef DEFPATH
24 #define DEFPATH ":/usr/local/lib/ray"
25 #endif
26 #ifndef ULIBVAR
27 #define ULIBVAR "RAYPATH"
28 #endif
29
30 char *fontfile = "helvet.fnt"; /* our font file */
31
32 COLR bgcolr = WHTCOLR; /* background color */
33 COLR fgcolr = BLKCOLR; /* foreground color */
34
35 int direct = 'r'; /* direction (right, up, left, down) */
36
37 int cheight = 32; /* character height */
38 double aspect = 1.67; /* height/width character aspect */
39 int cwidth; /* computed character width */
40
41 unsigned char *ourbitmap; /* our output bitmap */
42 int xsiz, ysiz; /* bitmap dimensions */
43 int xdim; /* size of horizontal scan (bytes) */
44
45 #define bitop(x,y,op) (ourbitmap[(y)*xdim+((x)>>3)] op (1<<((x)&7)))
46 #define tstbit(x,y) bitop(x,y,&)
47 #define setbit(x,y) bitop(x,y,|=)
48 #define clrbit(x,y) bitop(x,y,&=~)
49 #define tglbit(x,y) bitop(x,y,^=)
50
51 FONT *ourfont; /* our font */
52
53 char *libpath; /* library search path */
54
55 typedef struct line {
56 char *s; /* line w/o LF */
57 short *sp; /* character spacing */
58 struct line *next; /* next line up */
59 } LINE;
60
61 LINE *ourtext; /* our text */
62 int nlines, maxline; /* text dimensions */
63 int maxwidth; /* maximum line width (dvi) */
64
65 extern char *getenv();
66 extern char *malloc(), *calloc();
67
68
69 main(argc, argv)
70 int argc;
71 char *argv[];
72 {
73 int an;
74
75 for (an = 1; an < argc && argv[an][0] == '-'; an++)
76 switch (argv[an][1]) {
77 case 'c': /* color */
78 switch (argv[an][2]) {
79 case 'f': /* foreground */
80 setcolr(fgcolr, atof(argv[an+1]),
81 atof(argv[an+2]),
82 atof(argv[an+3]));
83 an += 3;
84 break;
85 case 'b': /* background */
86 setcolr(bgcolr, atof(argv[an+1]),
87 atof(argv[an+2]),
88 atof(argv[an+3]));
89 an += 3;
90 break;
91 default:
92 goto unkopt;
93 }
94 break;
95 case 'f': /* font */
96 fontfile = argv[++an];
97 break;
98 case 'd': /* direction */
99 switch (argv[an][2]) {
100 case 'r': /* right */
101 case 'u': /* up */
102 case 'l': /* left */
103 case 'd': /* down */
104 direct = argv[an][2];
105 break;
106 default:
107 goto unkopt;
108 }
109 break;
110 case 'h': /* height of characters */
111 cheight = atoi(argv[++an]);
112 break;
113 case 'a': /* aspect ratio */
114 aspect = atof(argv[++an]);
115 break;
116 default:;
117 unkopt:
118 fprintf(stderr, "%s: unknown option: %s\n",
119 argv[0], argv[an]);
120 exit(1);
121 }
122 /* load font file */
123 if ((libpath = getenv(ULIBVAR)) == NULL)
124 libpath = DEFPATH;
125 ourfont = getfont(fontfile);
126 /* get text */
127 if (an == argc)
128 gettext(stdin);
129 else
130 arg_text(argc-an, argv+an);
131
132 /* create bit map */
133 makemap();
134 /* convert text to bitmap */
135 maptext();
136 /* print header */
137 printargs(argc, argv, stdout);
138 fputformat(COLRFMT, stdout);
139 putchar('\n');
140 /* write out bitmap */
141 writemap(stdout);
142
143 exit(0);
144 }
145
146
147 makemap() /* create the bit map */
148 {
149 cwidth = cheight/aspect + 0.5;
150 if (direct == 'r' || direct == 'l') {
151 xsiz = maxline*cwidth;
152 ysiz = nlines*cheight;
153 } else { /* reverse orientation */
154 xsiz = nlines*cheight;
155 ysiz = maxline*cwidth;
156 }
157 xdim = (xsiz+7)/8;
158 ourbitmap = (BYTE *)calloc(ysiz, xdim);
159 if (ourbitmap == NULL) {
160 fprintf(stderr, "out of memory in makemap\n");
161 exit(1);
162 }
163 }
164
165
166 gettext(fp) /* get text from a file */
167 FILE *fp;
168 {
169 char *fgets();
170 char buf[MAXLINE];
171 register LINE *curl;
172 int len;
173
174 maxline = 0;
175 maxwidth = 0;
176 nlines = 0;
177 while (fgets(buf, MAXLINE, fp) != NULL) {
178 curl = (LINE *)malloc(sizeof(LINE));
179 if (curl == NULL)
180 goto memerr;
181 len = strlen(buf);
182 curl->s = malloc(len);
183 curl->sp = (short *)malloc(sizeof(short)*len--);
184 if (curl->s == NULL | curl->sp == NULL)
185 goto memerr;
186 if (len > maxline)
187 maxline = len;
188 strncpy(curl->s, buf, len);
189 curl->s[len] = '\0';
190 len = uniftext(curl->sp, curl->s, ourfont);
191 if (len > maxwidth)
192 maxwidth = len;
193 curl->next = ourtext;
194 ourtext = curl;
195 nlines++;
196 }
197 return;
198 memerr:
199 fprintf(stderr, "out of memory in gettext\n");
200 exit(1);
201 }
202
203
204 arg_text(ac, av) /* get text from arguments */
205 int ac;
206 char *av[];
207 {
208 register char *cp;
209
210 ourtext = (LINE *)malloc(sizeof(LINE));
211 if (ourtext == NULL)
212 goto memerr;
213 ourtext->s = malloc(MAXLINE);
214 if (ourtext->s == NULL)
215 goto memerr;
216 for (cp = ourtext->s; ac-- > 0; av++) {
217 strcpy(cp, *av);
218 cp += strlen(*av);
219 *cp++ = ' ';
220 }
221 *--cp = '\0';
222 ourtext->next = NULL;
223 maxline = strlen(ourtext->s);
224 ourtext->sp = (short *)malloc(sizeof(short)*(maxline+1));
225 if (ourtext->sp == NULL)
226 goto memerr;
227 maxwidth = uniftext(ourtext->sp, ourtext->s, ourfont);
228 nlines = 1;
229 return;
230 memerr:
231 fprintf(stderr, "out of memory in arg_text\n");
232 exit(1);
233 }
234
235
236 maptext() /* map our text */
237 {
238 register LINE *curl;
239 int l, len;
240 register int i, c;
241
242 for (l = 0, curl = ourtext; curl != NULL; l += 256, curl = curl->next) {
243 len = strlen(curl->s); c = 0;
244 for (i = 0; i < len; i++) {
245 c += curl->sp[i];
246 mapglyph(ourfont->fg[curl->s[i]&0xff], c, l);
247 }
248 }
249 }
250
251
252 mapglyph(gl, tx0, ty0) /* convert a glyph */
253 GLYPH *gl;
254 int tx0, ty0;
255 {
256 int n;
257 register GORD *gp;
258 int p0[2], p1[2];
259
260 if (gl == NULL)
261 return;
262
263 n = gl->nverts;
264 gp = gvlist(gl);
265 mapcoord(p0, gp[2*n-2]+tx0, gp[2*n-1]+ty0);
266 while (n--) {
267 mapcoord(p1, gp[0]+tx0, gp[1]+ty0);
268 mapedge(p0[0], p0[1], p1[0]-p0[0], p1[1]-p0[1]);
269 p0[0] = p1[0]; p0[1] = p1[1];
270 gp += 2;
271 }
272 }
273
274
275 mapcoord(p, tx, ty) /* map text to picture coordinates */
276 int p[2], tx, ty;
277 {
278 tx = (long)tx*cwidth >> 8;
279 ty = (long)ty*cheight >> 8;
280
281 switch (direct) {
282 case 'r': /* right */
283 p[0] = tx;
284 p[1] = ty;
285 return;
286 case 'u': /* up */
287 p[0] = xsiz-1-ty;
288 p[1] = tx;
289 return;
290 case 'l': /* left */
291 p[0] = xsiz-1-tx;
292 p[1] = ysiz-1-ty;
293 return;
294 case 'd': /* down */
295 p[0] = ty;
296 p[1] = ysiz-1-tx;
297 return;
298 }
299 }
300
301
302 mapedge(x, y, run, rise) /* map an edge */
303 register int x, y;
304 int run, rise;
305 {
306 int xstep;
307 int rise2, run2;
308 int n;
309
310 if (rise == 0)
311 return;
312 /* always draw up */
313 if (rise < 0) {
314 x += run;
315 y += rise;
316 rise = -rise;
317 run = -run;
318 }
319 if (run < 0) {
320 xstep = -1;
321 run = -run;
322 } else
323 xstep = 1;
324 n = rise;
325 run2 = rise2 = 0;
326 while (n)
327 if (rise2 >= run2) {
328 tglbit(x, y);
329 n--;
330 y++;
331 run2 += run;
332 } else {
333 x += xstep;
334 rise2 += rise;
335 }
336 }
337
338
339 writemap(fp) /* write out bitmap */
340 FILE *fp;
341 {
342 COLR *scanout;
343 int y;
344 register int x;
345 register int inglyph;
346
347 fprintf(fp, "-Y %d +X %d\n", ysiz, xsiz);
348
349 scanout = (COLR *)malloc(xsiz*sizeof(COLR));
350 if (scanout == NULL) {
351 fprintf(stderr, "out of memory in writemap\n");
352 exit(1);
353 }
354 for (y = ysiz-1; y >= 0; y--) {
355 inglyph = 0;
356 for (x = 0; x < xsiz; x++) {
357 if (tstbit(x, y))
358 inglyph ^= 1;
359 if (inglyph)
360 copycolr(scanout[x], fgcolr);
361 else
362 copycolr(scanout[x], bgcolr);
363 }
364 if (fwritecolrs(scanout, xsiz, fp) < 0) {
365 fprintf(stderr, "write error in writemap\n");
366 exit(1);
367 }
368 }
369 free((char *)scanout);
370 }
