1 |
/* Copyright (c) 1992 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* psign.c - produce picture from text. |
9 |
10 |
* 7/1/87 |
11 |
12 |
13 |
#include "standard.h" |
14 |
15 |
#include "color.h" |
16 |
17 |
#include "font.h" |
18 |
19 |
#ifndef SSS |
20 |
#define SSS 3 /* super-sample size */ |
21 |
#endif |
22 |
23 |
#define MAXLINE 512 /* longest allowable line */ |
24 |
25 |
#ifndef DEFPATH |
26 |
#define DEFPATH ":/usr/local/lib/ray" |
27 |
#endif |
28 |
#ifndef ULIBVAR |
29 |
#define ULIBVAR "RAYPATH" |
30 |
#endif |
31 |
32 |
char *fontfile = "helvet.fnt"; /* our font file */ |
33 |
34 |
COLOR bgcolor = WHTCOLOR; /* background color */ |
35 |
COLOR fgcolor = BLKCOLOR; /* foreground color */ |
36 |
37 |
int direct = 'r'; /* direction (right, up, left, down) */ |
38 |
39 |
int cheight = 32*SSS; /* character height */ |
40 |
double aspect = 1.67; /* height/width character aspect */ |
41 |
double spacing = 0.0; /* character spacing */ |
42 |
int cwidth; /* computed character width */ |
43 |
44 |
unsigned char *ourbitmap; /* our output bitmap */ |
45 |
int xsiz, ysiz; /* bitmap dimensions */ |
46 |
int xdim; /* size of horizontal scan (bytes) */ |
47 |
48 |
#define bitop(x,y,op) (ourbitmap[(y)*xdim+((x)>>3)] op (1<<((x)&7))) |
49 |
#define tstbit(x,y) bitop(x,y,&) |
50 |
#define setbit(x,y) bitop(x,y,|=) |
51 |
#define clrbit(x,y) bitop(x,y,&=~) |
52 |
#define tglbit(x,y) bitop(x,y,^=) |
53 |
54 |
FONT *ourfont; /* our font */ |
55 |
56 |
char *libpath; /* library search path */ |
57 |
58 |
typedef struct line { |
59 |
char *s; /* line w/o LF */ |
60 |
short *sp; /* character spacing */ |
61 |
struct line *next; /* next line up */ |
62 |
} LINE; |
63 |
64 |
LINE *ourtext; /* our text */ |
65 |
int nlines, maxline; /* text dimensions */ |
66 |
int maxwidth; /* maximum line width (dvi) */ |
67 |
68 |
extern char *getenv(); |
69 |
70 |
71 |
main(argc, argv) |
72 |
int argc; |
73 |
char *argv[]; |
74 |
75 |
int an; |
76 |
77 |
for (an = 1; an < argc && argv[an][0] == '-'; an++) |
78 |
switch (argv[an][1]) { |
79 |
case 'c': /* color */ |
80 |
switch (argv[an][2]) { |
81 |
case 'f': /* foreground */ |
82 |
setcolor(fgcolor, atof(argv[an+1]), |
83 |
atof(argv[an+2]), |
84 |
atof(argv[an+3])); |
85 |
an += 3; |
86 |
break; |
87 |
case 'b': /* background */ |
88 |
setcolor(bgcolor, atof(argv[an+1]), |
89 |
atof(argv[an+2]), |
90 |
91 |
an += 3; |
92 |
break; |
93 |
default: |
94 |
goto unkopt; |
95 |
96 |
break; |
97 |
case 'f': /* font */ |
98 |
fontfile = argv[++an]; |
99 |
break; |
100 |
case 'd': /* direction */ |
101 |
102 |
case 'r': /* right */ |
103 |
case 'u': /* up */ |
104 |
case 'l': /* left */ |
105 |
case 'd': /* down */ |
106 |
direct = argv[an][2]; |
107 |
break; |
108 |
default: |
109 |
goto unkopt; |
110 |
111 |
break; |
112 |
case 'x': /* x resolution */ |
113 |
xsiz = atoi(argv[++an])*SSS; |
114 |
break; |
115 |
case 'y': |
116 |
ysiz = atoi(argv[++an])*SSS; |
117 |
break; |
118 |
case 'h': /* height of characters */ |
119 |
cheight = atoi(argv[++an])*SSS; |
120 |
xsiz = xsiz = 0; |
121 |
break; |
122 |
case 'a': /* aspect ratio */ |
123 |
aspect = atof(argv[++an]); |
124 |
break; |
125 |
case 's': /* spacing */ |
126 |
spacing = atof(argv[++an]); |
127 |
break; |
128 |
default:; |
129 |
unkopt: |
130 |
fprintf(stderr, "%s: unknown option: %s\n", |
131 |
argv[0], argv[an]); |
132 |
exit(1); |
133 |
134 |
/* load font file */ |
135 |
if ((libpath = getenv(ULIBVAR)) == NULL) |
136 |
libpath = DEFPATH; |
137 |
ourfont = getfont(fontfile); |
138 |
/* get text */ |
139 |
if (an == argc) |
140 |
gettext(stdin); |
141 |
else |
142 |
arg_text(argc-an, argv+an); |
143 |
144 |
/* create bit map */ |
145 |
makemap(); |
146 |
/* convert text to bitmap */ |
147 |
maptext(); |
148 |
/* print header */ |
149 |
printargs(argc, argv, stdout); |
150 |
fputformat(COLRFMT, stdout); |
151 |
putchar('\n'); |
152 |
/* write out bitmap */ |
153 |
writemap(stdout); |
154 |
155 |
exit(0); |
156 |
157 |
158 |
159 |
makemap() /* create the bit map */ |
160 |
161 |
double pictaspect; |
162 |
163 |
if (direct == 'r' || direct == 'l') { |
164 |
if (xsiz == 0 || ysiz == 0) { |
165 |
cwidth = cheight/aspect + 0.5; |
166 |
xsiz = (long)maxwidth*cwidth >> 8; |
167 |
ysiz = nlines*cheight; |
168 |
} else { |
169 |
pictaspect = 256*nlines*aspect/maxwidth; |
170 |
if (pictaspect*xsiz < ysiz) |
171 |
ysiz = pictaspect*xsiz + 0.5; |
172 |
else |
173 |
xsiz = ysiz/pictaspect + 0.5; |
174 |
cheight = ysiz/nlines; |
175 |
176 |
177 |
} else { /* reverse orientation */ |
178 |
179 |
180 |
xsiz = nlines*cheight; |
181 |
ysiz = (long)maxwidth*cwidth >> 8; |
182 |
} else { |
183 |
pictaspect = maxwidth/(256*nlines*aspect); |
184 |
185 |
186 |
else |
187 |
188 |
cheight = xsiz/nlines; |
189 |
190 |
191 |
192 |
if (xsiz % SSS) |
193 |
xsiz += SSS - xsiz%SSS; |
194 |
if (ysiz % SSS) |
195 |
ysiz += SSS - ysiz%SSS; |
196 |
xdim = (xsiz+7)/8; |
197 |
ourbitmap = (BYTE *)bmalloc(ysiz*xdim); |
198 |
if (ourbitmap == NULL) |
199 |
error(SYSTEM, "Out of memory in makemap"); |
200 |
bzero((char *)ourbitmap, ysiz*xdim); |
201 |
202 |
203 |
204 |
gettext(fp) /* get text from a file */ |
205 |
FILE *fp; |
206 |
207 |
char *fgets(); |
208 |
char buf[MAXLINE]; |
209 |
register LINE *curl; |
210 |
int len; |
211 |
212 |
maxline = 0; |
213 |
maxwidth = 0; |
214 |
nlines = 0; |
215 |
while (fgets(buf, MAXLINE, fp) != NULL) { |
216 |
curl = (LINE *)malloc(sizeof(LINE)); |
217 |
if (curl == NULL) |
218 |
goto memerr; |
219 |
len = strlen(buf); |
220 |
curl->s = malloc(len); |
221 |
curl->sp = (short *)malloc(sizeof(short)*len--); |
222 |
if (curl->s == NULL | curl->sp == NULL) |
223 |
goto memerr; |
224 |
if (len > maxline) |
225 |
maxline = len; |
226 |
strncpy(curl->s, buf, len); |
227 |
curl->s[len] = '\0'; |
228 |
if (spacing < -1./256.) |
229 |
len = squeeztext(curl->sp, curl->s, ourfont, |
230 |
(int)(spacing*-256.0)); |
231 |
else if (spacing > 1./256.) |
232 |
len = proptext(curl->sp, curl->s, ourfont, |
233 |
(int)(spacing*256.0), 3); |
234 |
else |
235 |
len = uniftext(curl->sp, curl->s, ourfont); |
236 |
if (len > maxwidth) |
237 |
maxwidth = len; |
238 |
curl->next = ourtext; |
239 |
ourtext = curl; |
240 |
nlines++; |
241 |
242 |
return; |
243 |
memerr: |
244 |
error(SYSTEM, "Out of memory in gettext"); |
245 |
246 |
247 |
248 |
arg_text(ac, av) /* get text from arguments */ |
249 |
int ac; |
250 |
char *av[]; |
251 |
252 |
register char *cp; |
253 |
254 |
ourtext = (LINE *)malloc(sizeof(LINE)); |
255 |
if (ourtext == NULL) |
256 |
goto memerr; |
257 |
ourtext->s = malloc(MAXLINE); |
258 |
if (ourtext->s == NULL) |
259 |
goto memerr; |
260 |
for (cp = ourtext->s; ac-- > 0; av++) { |
261 |
strcpy(cp, *av); |
262 |
cp += strlen(*av); |
263 |
*cp++ = ' '; |
264 |
265 |
*--cp = '\0'; |
266 |
ourtext->next = NULL; |
267 |
maxline = strlen(ourtext->s); |
268 |
ourtext->sp = (short *)malloc(sizeof(short)*(maxline+1)); |
269 |
if (ourtext->sp == NULL) |
270 |
goto memerr; |
271 |
if (spacing < 0.0) |
272 |
maxwidth = squeeztext(ourtext->sp, ourtext->s, ourfont, |
273 |
274 |
else if (spacing > 0.0) |
275 |
maxwidth = proptext(ourtext->sp, ourtext->s, ourfont, |
276 |
277 |
else |
278 |
maxwidth = uniftext(ourtext->sp, ourtext->s, ourfont); |
279 |
nlines = 1; |
280 |
return; |
281 |
memerr: |
282 |
error(SYSTEM, "Out of memory in arg_text"); |
283 |
284 |
285 |
286 |
maptext() /* map our text */ |
287 |
288 |
289 |
int l, len; |
290 |
register int i, c; |
291 |
292 |
for (l = 0, curl = ourtext; curl != NULL; l += 256, curl = curl->next) { |
293 |
len = strlen(curl->s); c = 0; |
294 |
for (i = 0; i < len; i++) { |
295 |
c += curl->sp[i]; |
296 |
mapglyph(ourfont->fg[curl->s[i]&0xff], c, l); |
297 |
298 |
299 |
300 |
301 |
302 |
mapglyph(gl, tx0, ty0) /* convert a glyph */ |
303 |
GLYPH *gl; |
304 |
int tx0, ty0; |
305 |
306 |
int n; |
307 |
register GORD *gp; |
308 |
int p0[2], p1[2]; |
309 |
310 |
if (gl == NULL) |
311 |
return; |
312 |
313 |
n = gl->nverts; |
314 |
gp = gvlist(gl); |
315 |
mapcoord(p0, gp[2*n-2]+tx0, gp[2*n-1]+ty0); |
316 |
while (n--) { |
317 |
mapcoord(p1, gp[0]+tx0, gp[1]+ty0); |
318 |
mapedge(p0[0], p0[1], p1[0]-p0[0], p1[1]-p0[1]); |
319 |
p0[0] = p1[0]; p0[1] = p1[1]; |
320 |
gp += 2; |
321 |
322 |
323 |
324 |
325 |
mapcoord(p, tx, ty) /* map text to picture coordinates */ |
326 |
int p[2], tx, ty; |
327 |
328 |
tx = (long)tx*cwidth >> 8; |
329 |
ty = (long)ty*cheight >> 8; |
330 |
331 |
switch (direct) { |
332 |
333 |
p[0] = tx; |
334 |
p[1] = ty; |
335 |
return; |
336 |
337 |
p[0] = xsiz-1-ty; |
338 |
p[1] = tx; |
339 |
return; |
340 |
341 |
p[0] = xsiz-1-tx; |
342 |
p[1] = ysiz-1-ty; |
343 |
return; |
344 |
345 |
p[0] = ty; |
346 |
p[1] = ysiz-1-tx; |
347 |
return; |
348 |
349 |
350 |
351 |
352 |
mapedge(x, y, run, rise) /* map an edge */ |
353 |
register int x, y; |
354 |
int run, rise; |
355 |
356 |
int xstep; |
357 |
int rise2, run2; |
358 |
int n; |
359 |
360 |
if (rise == 0) |
361 |
return; |
362 |
/* always draw up */ |
363 |
if (rise < 0) { |
364 |
x += run; |
365 |
y += rise; |
366 |
rise = -rise; |
367 |
run = -run; |
368 |
369 |
if (run < 0) { |
370 |
xstep = -1; |
371 |
run = -run; |
372 |
} else |
373 |
xstep = 1; |
374 |
n = rise; |
375 |
run2 = rise2 = 0; |
376 |
while (n) |
377 |
if (rise2 >= run2) { |
378 |
tglbit(x, y); |
379 |
n--; |
380 |
y++; |
381 |
run2 += run; |
382 |
} else { |
383 |
x += xstep; |
384 |
rise2 += rise; |
385 |
386 |
387 |
388 |
389 |
writemap(fp) /* write out bitmap */ |
390 |
FILE *fp; |
391 |
392 |
COLR pixval[SSS*SSS+1]; /* possible pixel values */ |
393 |
COLOR ctmp0, ctmp1; |
394 |
double d; |
395 |
COLR *scanout; |
396 |
int x, y; |
397 |
register int i, j; |
398 |
int cnt; |
399 |
register int inglyph; |
400 |
401 |
fprintf(fp, "-Y %d +X %d\n", ysiz/SSS, xsiz/SSS); |
402 |
403 |
scanout = (COLR *)malloc(xsiz/SSS*sizeof(COLR)); |
404 |
if (scanout == NULL) |
405 |
error(SYSTEM, "Out of memory in writemap"); |
406 |
for (i = 0; i <= SSS*SSS; i++) { /* compute possible values */ |
407 |
copycolor(ctmp0, fgcolor); |
408 |
d = (double)i/(SSS*SSS); |
409 |
scalecolor(ctmp0, d); |
410 |
copycolor(ctmp1, bgcolor); |
411 |
d = 1.0 - d; |
412 |
scalecolor(ctmp1, d); |
413 |
addcolor(ctmp0, ctmp1); |
414 |
setcolr(pixval[i], colval(ctmp0,RED), |
415 |
colval(ctmp0,GRN), colval(ctmp0,BLU)); |
416 |
417 |
for (y = ysiz/SSS-1; y >= 0; y--) { |
418 |
inglyph = 0; |
419 |
for (x = 0; x < xsiz/SSS; x++) { |
420 |
cnt = 0; |
421 |
for (j = 0; j < SSS; j++) |
422 |
for (i = 0; i < SSS; i++) { |
423 |
if (tstbit(x*SSS+i, y*SSS+j)) |
424 |
inglyph ^= 1<<j; |
425 |
if (inglyph & 1<<j) |
426 |
cnt++; |
427 |
428 |
copycolr(scanout[x], pixval[cnt]); |
429 |
430 |
if (fwritecolrs(scanout, xsiz/SSS, fp) < 0) { |
431 |
fprintf(stderr, "write error in writemap\n"); |
432 |
exit(1); |
433 |
434 |
435 |
free((char *)scanout); |
436 |
