root/radiance/ray/src/px/psign.c
Revision: 2.3
Committed: Sat Jun 6 07:40:51 1992 UTC (33 years, 1 month ago) by greg
Changes since 2.2: +25 -63 lines
initial move of getfont to separate routine
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * psign.c - produce picture from text.
9 *
10 * 7/1/87
11 */
12
13 #include "standard.h"
14
15 #include "color.h"
16
17 #include "font.h"
18
19 #define MAXLINE 512 /* longest allowable line */
20
21 #ifndef DEFPATH
22 #define DEFPATH ":/usr/local/lib/ray"
23 #endif
24 #ifndef ULIBVAR
25 #define ULIBVAR "RAYPATH"
26 #endif
27
28 char *fontfile = "helvet.fnt"; /* our font file */
29
30 COLR bgcolr = WHTCOLR; /* background color */
31 COLR fgcolr = BLKCOLR; /* foreground color */
32
33 int direct = 'r'; /* direction (right, up, left, down) */
34
35 int cheight = 32; /* character height */
36 double aspect = 1.67; /* height/width character aspect */
37 int cwidth; /* computed character width */
38
39 unsigned char *ourbitmap; /* our output bitmap */
40 int xsiz, ysiz; /* bitmap dimensions */
41 int xdim; /* size of horizontal scan (bytes) */
42
43 #define bitop(x,y,op) (ourbitmap[(y)*xdim+((x)>>3)] op (1<<((x)&7)))
44 #define tstbit(x,y) bitop(x,y,&)
45 #define setbit(x,y) bitop(x,y,|=)
46 #define clrbit(x,y) bitop(x,y,&=~)
47 #define tglbit(x,y) bitop(x,y,^=)
48
49 typedef unsigned char GLYPH;
50
51 FONT *ourfont; /* our font */
52
53 char *libpath; /* library search path */
54
55 typedef struct line {
56 char *s; /* line w/o LF */
57 struct line *next; /* next line up */
58 } LINE;
59
60 LINE *ourtext; /* our text */
61 int nlines, maxline; /* text dimensions */
62
63 extern char *getenv();
64 extern char *malloc(), *calloc();
65
66
67 main(argc, argv)
68 int argc;
69 char *argv[];
70 {
71 int an;
72
73 for (an = 1; an < argc && argv[an][0] == '-'; an++)
74 switch (argv[an][1]) {
75 case 'c': /* color */
76 switch (argv[an][2]) {
77 case 'f': /* foreground */
78 setcolr(fgcolr, atof(argv[an+1]),
79 atof(argv[an+2]),
80 atof(argv[an+3]));
81 an += 3;
82 break;
83 case 'b': /* background */
84 setcolr(bgcolr, atof(argv[an+1]),
85 atof(argv[an+2]),
86 atof(argv[an+3]));
87 an += 3;
88 break;
89 default:
90 goto unkopt;
91 }
92 break;
93 case 'f': /* font */
94 fontfile = argv[++an];
95 break;
96 case 'd': /* direction */
97 switch (argv[an][2]) {
98 case 'r': /* right */
99 case 'u': /* up */
100 case 'l': /* left */
101 case 'd': /* down */
102 direct = argv[an][2];
103 break;
104 default:
105 goto unkopt;
106 }
107 break;
108 case 'h': /* height of characters */
109 cheight = atoi(argv[++an]);
110 break;
111 case 'a': /* aspect ratio */
112 aspect = atof(argv[++an]);
113 break;
114 default:;
115 unkopt:
116 fprintf(stderr, "%s: unknown option: %s\n",
117 argv[0], argv[an]);
118 exit(1);
119 }
120 /* get text */
121 if (an == argc)
122 gettext(stdin);
123 else
124 arg_text(argc-an, argv+an);
125
126 /* create bit map */
127 makemap();
128 /* load font file */
129 if ((libpath = getenv(ULIBVAR)) == NULL)
130 libpath = DEFPATH;
131 ourfont = getfont(fontfile);
132 /* convert text to bitmap */
133 maptext();
134 /* print header */
135 printargs(argc, argv, stdout);
136 fputformat(COLRFMT, stdout);
137 putchar('\n');
138 /* write out bitmap */
139 writemap(stdout);
140
141 exit(0);
142 }
143
144
145 makemap() /* create the bit map */
146 {
147 cwidth = cheight/aspect + 0.5;
148 if (direct == 'r' || direct == 'l') {
149 xsiz = maxline*cwidth;
150 ysiz = nlines*cheight;
151 } else { /* reverse orientation */
152 xsiz = nlines*cheight;
153 ysiz = maxline*cwidth;
154 }
155 xdim = (xsiz+7)/8;
156 ourbitmap = (BYTE *)calloc(ysiz, xdim);
157 if (ourbitmap == NULL) {
158 fprintf(stderr, "out of memory in makemap\n");
159 exit(1);
160 }
161 }
162
163
164 gettext(fp) /* get text from a file */
165 FILE *fp;
166 {
167 char *fgets();
168 char buf[MAXLINE];
169 register LINE *curl;
170 int len;
171
172 maxline = 0;
173 nlines = 0;
174 while (fgets(buf, MAXLINE, fp) != NULL) {
175 curl = (LINE *)malloc(sizeof(LINE));
176 if (curl == NULL)
177 goto memerr;
178 len = strlen(buf);
179 curl->s = malloc(len--);
180 if (curl->s == NULL)
181 goto memerr;
182 strncpy(curl->s, buf, len);
183 curl->s[len] = '\0';
184 curl->next = ourtext;
185 ourtext = curl;
186 if (len > maxline)
187 maxline = len;
188 nlines++;
189 }
190 return;
191 memerr:
192 fprintf(stderr, "out of memory in gettext\n");
193 exit(1);
194 }
195
196
197 arg_text(ac, av) /* get text from arguments */
198 int ac;
199 char *av[];
200 {
201 register char *cp;
202
203 ourtext = (LINE *)malloc(sizeof(LINE));
204 if (ourtext == NULL)
205 goto memerr;
206 ourtext->s = malloc(MAXLINE);
207 if (ourtext->s == NULL)
208 goto memerr;
209 for (cp = ourtext->s; ac-- > 0; av++) {
210 strcpy(cp, *av);
211 cp += strlen(*av);
212 *cp++ = ' ';
213 }
214 *--cp = '\0';
215 ourtext->next = NULL;
216 maxline = strlen(ourtext->s);
217 nlines = 1;
218 return;
219 memerr:
220 fprintf(stderr, "out of memory in arg_text\n");
221 exit(1);
222 }
223
224
225 maptext() /* map our text */
226 {
227 register LINE *curl;
228 int l;
229 register int c;
230
231 for (l = 0, curl = ourtext; curl != NULL; l++, curl = curl->next)
232 for (c = strlen(curl->s)-1; c >= 0; c--)
233 mapglyph(ourfont->fg[curl->s[c]&0xff], c, l);
234 }
235
236
237 mapglyph(gl, tx0, ty0) /* convert a glyph */
238 GLYPH *gl;
239 int tx0, ty0;
240 {
241 int n;
242 register GORD *gp;
243 int p0[2], p1[2];
244
245 if (gl == NULL)
246 return;
247
248 tx0 <<= 8; ty0 <<= 8;
249 n = gl->nverts;
250 gp = gvlist(gl);
251 mapcoord(p0, gp[2*n-2]+tx0, gp[2*n-1]+ty0);
252 while (n--) {
253 mapcoord(p1, gp[0]+tx0, gp[1]+ty0);
254 mapedge(p0[0], p0[1], p1[0]-p0[0], p1[1]-p0[1]);
255 p0[0] = p1[0]; p0[1] = p1[1];
256 gp += 2;
257 }
258 }
259
260
261 mapcoord(p, tx, ty) /* map text to picture coordinates */
262 int p[2], tx, ty;
263 {
264 tx = (long)tx*cwidth >> 8;
265 ty = (long)ty*cheight >> 8;
266
267 switch (direct) {
268 case 'r': /* right */
269 p[0] = tx;
270 p[1] = ty;
271 return;
272 case 'u': /* up */
273 p[0] = xsiz-1-ty;
274 p[1] = tx;
275 return;
276 case 'l': /* left */
277 p[0] = xsiz-1-tx;
278 p[1] = ysiz-1-ty;
279 return;
280 case 'd': /* down */
281 p[0] = ty;
282 p[1] = ysiz-1-tx;
283 return;
284 }
285 }
286
287
288 mapedge(x, y, run, rise) /* map an edge */
289 register int x, y;
290 int run, rise;
291 {
292 int xstep;
293 int rise2, run2;
294 int n;
295
296 if (rise == 0)
297 return;
298 /* always draw up */
299 if (rise < 0) {
300 x += run;
301 y += rise;
302 rise = -rise;
303 run = -run;
304 }
305 if (run < 0) {
306 xstep = -1;
307 run = -run;
308 } else
309 xstep = 1;
310 n = rise;
311 run2 = rise2 = 0;
312 while (n)
313 if (rise2 >= run2) {
314 tglbit(x, y);
315 n--;
316 y++;
317 run2 += run;
318 } else {
319 x += xstep;
320 rise2 += rise;
321 }
322 }
323
324
325 writemap(fp) /* write out bitmap */
326 FILE *fp;
327 {
328 COLR *scanout;
329 int y;
330 register int x;
331 register int inglyph;
332
333 fprintf(fp, "-Y %d +X %d\n", ysiz, xsiz);
334
335 scanout = (COLR *)malloc(xsiz*sizeof(COLR));
336 if (scanout == NULL) {
337 fprintf(stderr, "out of memory in writemap\n");
338 exit(1);
339 }
340 for (y = ysiz-1; y >= 0; y--) {
341 inglyph = 0;
342 for (x = 0; x < xsiz; x++) {
343 if (tstbit(x, y))
344 inglyph ^= 1;
345 if (inglyph)
346 copycolr(scanout[x], fgcolr);
347 else
348 copycolr(scanout[x], bgcolr);
349 }
350 if (fwritecolrs(scanout, xsiz, fp) < 0) {
351 fprintf(stderr, "write error in writemap\n");
352 exit(1);
353 }
354 }
355 free((char *)scanout);
356 }
