root/Development/ray/src/px/pmapgen.c
Revision: 2.3
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 8 months ago) by greg
Changes since 2.2: +1 -4 lines
5 * pmapgen.c: general routines for 2-D perspective mappings.
6 * These routines are independent of the poly structure,
7 * so we do not think in terms of texture and screen space.
8 *
9 * Paul Heckbert 5 Nov 85, 12 Dec 85
10 */
11
12 static char rcsid[] = "$Header: pmapgen.c,v 2.0 88/10/12 21:58:33 ph Locked $";
13 #include <stdio.h>
14 #include "pmap.h"
15 #include "mx3.h"
16
17 #define TOLERANCE 1e-13
18 #define ZERO(x) ((x)<TOLERANCE && (x)>-TOLERANCE)
19
20 #define X(i) qdrl[i][0] /* quadrilateral x and y */
21 #define Y(i) qdrl[i][1]
22
23 /*
24 * pmap_quad_rect: find mapping between quadrilateral and rectangle.
25 * The correspondence is:
26 *
27 * qdrl[0] --> (u0,v0)
28 * qdrl[1] --> (u1,v0)
29 * qdrl[2] --> (u1,v1)
30 * qdrl[3] --> (u0,v1)
31 *
32 * This method of computing the adjoint numerically is cheaper than
33 * computing it symbolically.
34 */
35
36 pmap_quad_rect(u0, v0, u1, v1, qdrl, QR)
37 double u0, v0, u1, v1; /* bounds of rectangle */
38 double qdrl[4][2]; /* vertices of quadrilateral */
39 double QR[3][3]; /* qdrl->rect transform (returned) */
40 {
41 int ret;
42 double du, dv;
43 double RQ[3][3]; /* rect->qdrl transform */
44
45 du = u1-u0;
46 dv = v1-v0;
47 if (du==0. || dv==0.) {
48 fprintf(stderr, "pmap_quad_rect: null rectangle\n");
49 return PMAP_BAD;
50 }
51
52 /* first find mapping from unit uv square to xy quadrilateral */
53 ret = pmap_square_quad(qdrl, RQ);
54 if (ret==PMAP_BAD) return PMAP_BAD;
55
56 /* concatenate transform from uv rectangle (u0,v0,u1,v1) to unit square */
57 RQ[0][0] /= du;
58 RQ[1][0] /= dv;
59 RQ[2][0] -= RQ[0][0]*u0 + RQ[1][0]*v0;
60 RQ[0][1] /= du;
61 RQ[1][1] /= dv;
62 RQ[2][1] -= RQ[0][1]*u0 + RQ[1][1]*v0;
63 RQ[0][2] /= du;
64 RQ[1][2] /= dv;
65 RQ[2][2] -= RQ[0][2]*u0 + RQ[1][2]*v0;
66
67 /* now RQ is transform from uv rectangle to xy quadrilateral */
68 /* QR = inverse transform, which maps xy to uv */
69 if (mx3d_adjoint(RQ, QR)==0.)
70 fprintf(stderr, "pmap_quad_rect: warning: determinant=0\n");
71 return ret;
72 }
73
74 /*
75 * pmap_square_quad: find mapping between unit square and quadrilateral.
76 * The correspondence is:
77 *
78 * (0,0) --> qdrl[0]
79 * (1,0) --> qdrl[1]
80 * (1,1) --> qdrl[2]
81 * (0,1) --> qdrl[3]
82 */
83
84 pmap_square_quad(qdrl, SQ)
85 register double qdrl[4][2]; /* vertices of quadrilateral */
86 register double SQ[3][3]; /* square->qdrl transform */
87 {
88 double px, py;
89
90 px = X(0)-X(1)+X(2)-X(3);
91 py = Y(0)-Y(1)+Y(2)-Y(3);
92
93 if (ZERO(px) && ZERO(py)) { /* affine */
94 SQ[0][0] = X(1)-X(0);
95 SQ[1][0] = X(2)-X(1);
96 SQ[2][0] = X(0);
97 SQ[0][1] = Y(1)-Y(0);
98 SQ[1][1] = Y(2)-Y(1);
99 SQ[2][1] = Y(0);
100 SQ[0][2] = 0.;
101 SQ[1][2] = 0.;
102 SQ[2][2] = 1.;
103 return PMAP_LINEAR;
104 }
105 else { /* perspective */
106 double dx1, dx2, dy1, dy2, del;
107
108 dx1 = X(1)-X(2);
109 dx2 = X(3)-X(2);
110 dy1 = Y(1)-Y(2);
111 dy2 = Y(3)-Y(2);
112 del = DET2(dx1,dx2, dy1,dy2);
113 if (del==0.) {
114 fprintf(stderr, "pmap_square_quad: bad mapping\n");
115 return PMAP_BAD;
116 }
117 SQ[0][2] = DET2(px,dx2, py,dy2)/del;
118 SQ[1][2] = DET2(dx1,px, dy1,py)/del;
119 SQ[2][2] = 1.;
120 SQ[0][0] = X(1)-X(0)+SQ[0][2]*X(1);
121 SQ[1][0] = X(3)-X(0)+SQ[1][2]*X(3);
122 SQ[2][0] = X(0);
123 SQ[0][1] = Y(1)-Y(0)+SQ[0][2]*Y(1);
124 SQ[1][1] = Y(3)-Y(0)+SQ[1][2]*Y(3);
125 SQ[2][1] = Y(0);
126 return PMAP_PERSP;
127 }
128 }
