root/radiance/ray/src/px/pmapgen.c
Revision: 2.4
Committed: Sun Mar 28 20:33:14 2004 UTC (21 years, 1 month ago) by schorsch
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad3R7P2, rad3R7P1, rad4R2, rad4R1, rad4R0, rad3R6, rad3R6P1, rad3R8, rad3R9, rad4R2P1, rad5R3, HEAD
Changes since 2.3: +15 -9 lines
Error occurred while calculating annotation data.
2 static const char RCSid[] = "$Id: pmapgen.c,v 2.3 2003/02/22 02:07:27 greg Exp $";
5 * pmapgen.c: general routines for 2-D perspective mappings.
6 * These routines are independent of the poly structure,
7 * so we do not think in terms of texture and screen space.
8 *
9 * Paul Heckbert 5 Nov 85, 12 Dec 85
10 */
11
12 #include <stdio.h>
13 #include "pmap.h"
14 #include "mx3.h"
15
16 #define TOLERANCE 1e-13
17 #define ZERO(x) ((x)<TOLERANCE && (x)>-TOLERANCE)
18
19 #define X(i) qdrl[i][0] /* quadrilateral x and y */
20 #define Y(i) qdrl[i][1]
21
22 /*
23 * pmap_quad_rect: find mapping between quadrilateral and rectangle.
24 * The correspondence is:
25 *
26 * qdrl[0] --> (u0,v0)
27 * qdrl[1] --> (u1,v0)
28 * qdrl[2] --> (u1,v1)
29 * qdrl[3] --> (u0,v1)
30 *
31 * This method of computing the adjoint numerically is cheaper than
32 * computing it symbolically.
33 */
34
35 extern int
36 pmap_quad_rect(
37 double u0, /* bounds of rectangle */
38 double v0,
39 double u1,
40 double v1,
41 double qdrl[4][2], /* vertices of quadrilateral */
42 double QR[3][3] /* qdrl->rect transform (returned) */
43 )
44 {
45 int ret;
46 double du, dv;
47 double RQ[3][3]; /* rect->qdrl transform */
48
49 du = u1-u0;
50 dv = v1-v0;
51 if (du==0. || dv==0.) {
52 fprintf(stderr, "pmap_quad_rect: null rectangle\n");
53 return PMAP_BAD;
54 }
55
56 /* first find mapping from unit uv square to xy quadrilateral */
57 ret = pmap_square_quad(qdrl, RQ);
58 if (ret==PMAP_BAD) return PMAP_BAD;
59
60 /* concatenate transform from uv rectangle (u0,v0,u1,v1) to unit square */
61 RQ[0][0] /= du;
62 RQ[1][0] /= dv;
63 RQ[2][0] -= RQ[0][0]*u0 + RQ[1][0]*v0;
64 RQ[0][1] /= du;
65 RQ[1][1] /= dv;
66 RQ[2][1] -= RQ[0][1]*u0 + RQ[1][1]*v0;
67 RQ[0][2] /= du;
68 RQ[1][2] /= dv;
69 RQ[2][2] -= RQ[0][2]*u0 + RQ[1][2]*v0;
70
71 /* now RQ is transform from uv rectangle to xy quadrilateral */
72 /* QR = inverse transform, which maps xy to uv */
73 if (mx3d_adjoint(RQ, QR)==0.)
74 fprintf(stderr, "pmap_quad_rect: warning: determinant=0\n");
75 return ret;
76 }
77
78 /*
79 * pmap_square_quad: find mapping between unit square and quadrilateral.
80 * The correspondence is:
81 *
82 * (0,0) --> qdrl[0]
83 * (1,0) --> qdrl[1]
84 * (1,1) --> qdrl[2]
85 * (0,1) --> qdrl[3]
86 */
87
88 extern int
89 pmap_square_quad(
90 register double qdrl[4][2], /* vertices of quadrilateral */
91 register double SQ[3][3] /* square->qdrl transform */
92 )
93 {
94 double px, py;
95
96 px = X(0)-X(1)+X(2)-X(3);
97 py = Y(0)-Y(1)+Y(2)-Y(3);
98
99 if (ZERO(px) && ZERO(py)) { /* affine */
100 SQ[0][0] = X(1)-X(0);
101 SQ[1][0] = X(2)-X(1);
102 SQ[2][0] = X(0);
103 SQ[0][1] = Y(1)-Y(0);
104 SQ[1][1] = Y(2)-Y(1);
105 SQ[2][1] = Y(0);
106 SQ[0][2] = 0.;
107 SQ[1][2] = 0.;
108 SQ[2][2] = 1.;
109 return PMAP_LINEAR;
110 }
111 else { /* perspective */
112 double dx1, dx2, dy1, dy2, del;
113
114 dx1 = X(1)-X(2);
115 dx2 = X(3)-X(2);
116 dy1 = Y(1)-Y(2);
117 dy2 = Y(3)-Y(2);
118 del = DET2(dx1,dx2, dy1,dy2);
119 if (del==0.) {
120 fprintf(stderr, "pmap_square_quad: bad mapping\n");
121 return PMAP_BAD;
122 }
123 SQ[0][2] = DET2(px,dx2, py,dy2)/del;
124 SQ[1][2] = DET2(dx1,px, dy1,py)/del;
125 SQ[2][2] = 1.;
126 SQ[0][0] = X(1)-X(0)+SQ[0][2]*X(1);
127 SQ[1][0] = X(3)-X(0)+SQ[1][2]*X(3);
128 SQ[2][0] = X(0);
129 SQ[0][1] = Y(1)-Y(0)+SQ[0][2]*Y(1);
130 SQ[1][1] = Y(3)-Y(0)+SQ[1][2]*Y(3);
131 SQ[2][1] = Y(0);
132 return PMAP_PERSP;
133 }
134 }
