| 1 |
/* Copyright (c) 1991 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* Interpolate and extrapolate pictures with different view parameters.
| 9 |
| 10 |
* Greg Ward 09Dec89
| 11 |
| 12 |
| 13 |
#include "standard.h"
| 14 |
| 15 |
#include <ctype.h>
| 16 |
| 17 |
#include "view.h"
| 18 |
| 19 |
#include "color.h"
| 20 |
| 21 |
#include "resolu.h"
| 22 |
| 23 |
#ifndef BSD
| 24 |
#define vfork fork
| 25 |
#endif
| 26 |
| 27 |
#define pscan(y) (ourpict+(y)*hresolu)
| 28 |
#define zscan(y) (ourzbuf+(y)*hresolu)
| 29 |
| 30 |
#define F_FORE 1 /* fill foreground */
| 31 |
#define F_BACK 2 /* fill background */
| 32 |
| 33 |
#define PACKSIZ 256 /* max. calculation packet size */
| 34 |
| 35 |
#define RTCOM "rtrace -h- -ovl -fff "
| 36 |
| 37 |
#define ABS(x) ((x)>0?(x):-(x))
| 38 |
| 39 |
struct position {int x,y; float z;};
| 40 |
| 41 |
VIEW ourview = STDVIEW; /* desired view */
| 42 |
int hresolu = 512; /* horizontal resolution */
| 43 |
int vresolu = 512; /* vertical resolution */
| 44 |
double pixaspect = 1.0; /* pixel aspect ratio */
| 45 |
| 46 |
double zeps = .02; /* allowed z epsilon */
| 47 |
| 48 |
COLR *ourpict; /* output picture */
| 49 |
float *ourzbuf; /* corresponding z-buffer */
| 50 |
| 51 |
char *progname;
| 52 |
| 53 |
int fillo = F_FORE|F_BACK; /* selected fill options */
| 54 |
int fillsamp = 0; /* sample separation (0 == inf) */
| 55 |
extern int backfill(), rcalfill(); /* fill functions */
| 56 |
int (*fillfunc)() = backfill; /* selected fill function */
| 57 |
COLR backcolr = BLKCOLR; /* background color */
| 58 |
double backz = 0.0; /* background z value */
| 59 |
int normdist = 1; /* normalized distance? */
| 60 |
double ourexp = -1; /* output picture exposure */
| 61 |
| 62 |
VIEW theirview = STDVIEW; /* input view */
| 63 |
int gotview; /* got input view? */
| 64 |
int wrongformat = 0; /* input in another format? */
| 65 |
RESOLU tresolu; /* input resolution */
| 66 |
double theirexp; /* input picture exposure */
| 67 |
double theirs2ours[4][4]; /* transformation matrix */
| 68 |
int hasmatrix = 0; /* has transformation matrix */
| 69 |
| 70 |
int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
| 71 |
#define childpid (PDesc[2])
| 72 |
unsigned short queue[PACKSIZ][2]; /* pending pixels */
| 73 |
int packsiz; /* actual packet size */
| 74 |
int queuesiz; /* number of pixels pending */
| 75 |
| 76 |
| 77 |
main(argc, argv) /* interpolate pictures */
| 78 |
int argc;
| 79 |
char *argv[];
| 80 |
| 81 |
#define check(ol,al) if (argv[i][ol] || \
| 82 |
badarg(argc-i-1,argv+i+1,al)) \
| 83 |
goto badopt
| 84 |
int gotvfile = 0;
| 85 |
char *zfile = NULL;
| 86 |
char *err;
| 87 |
int i, rval;
| 88 |
| 89 |
progname = argv[0];
| 90 |
| 91 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) {
| 92 |
rval = getviewopt(&ourview, argc-i, argv+i);
| 93 |
if (rval >= 0) {
| 94 |
i += rval;
| 95 |
continue;
| 96 |
| 97 |
switch (argv[i][1]) {
| 98 |
case 't': /* threshold */
| 99 |
check(2,"f");
| 100 |
zeps = atof(argv[++i]);
| 101 |
break;
| 102 |
case 'n': /* dist. normalized? */
| 103 |
check(2,NULL);
| 104 |
normdist = !normdist;
| 105 |
break;
| 106 |
case 'f': /* fill type */
| 107 |
switch (argv[i][2]) {
| 108 |
case '0': /* none */
| 109 |
check(3,NULL);
| 110 |
fillo = 0;
| 111 |
break;
| 112 |
case 'f': /* foreground */
| 113 |
check(3,NULL);
| 114 |
fillo = F_FORE;
| 115 |
break;
| 116 |
case 'b': /* background */
| 117 |
check(3,NULL);
| 118 |
fillo = F_BACK;
| 119 |
break;
| 120 |
case 'a': /* all */
| 121 |
check(3,NULL);
| 122 |
| 123 |
break;
| 124 |
case 's': /* sample */
| 125 |
check(3,"i");
| 126 |
fillsamp = atoi(argv[++i]);
| 127 |
break;
| 128 |
case 'c': /* color */
| 129 |
check(3,"fff");
| 130 |
fillfunc = backfill;
| 131 |
setcolr(backcolr, atof(argv[i+1]),
| 132 |
atof(argv[i+2]), atof(argv[i+3]));
| 133 |
i += 3;
| 134 |
break;
| 135 |
case 'z': /* z value */
| 136 |
check(3,"f");
| 137 |
| 138 |
backz = atof(argv[++i]);
| 139 |
break;
| 140 |
case 'r': /* rtrace */
| 141 |
check(3,"s");
| 142 |
fillfunc = rcalfill;
| 143 |
calstart(RTCOM, argv[++i]);
| 144 |
break;
| 145 |
default:
| 146 |
goto badopt;
| 147 |
| 148 |
break;
| 149 |
case 'z': /* z file */
| 150 |
check(2,"s");
| 151 |
zfile = argv[++i];
| 152 |
break;
| 153 |
case 'x': /* x resolution */
| 154 |
check(2,"i");
| 155 |
hresolu = atoi(argv[++i]);
| 156 |
break;
| 157 |
case 'y': /* y resolution */
| 158 |
check(2,"i");
| 159 |
vresolu = atoi(argv[++i]);
| 160 |
break;
| 161 |
case 'p': /* pixel aspect */
| 162 |
if (argv[i][2] != 'a')
| 163 |
goto badopt;
| 164 |
check(3,"f");
| 165 |
pixaspect = atof(argv[++i]);
| 166 |
break;
| 167 |
case 'v': /* view file */
| 168 |
if (argv[i][2] != 'f')
| 169 |
goto badopt;
| 170 |
check(3,"s");
| 171 |
gotvfile = viewfile(argv[++i], &ourview, 0, 0);
| 172 |
if (gotvfile < 0) {
| 173 |
perror(argv[i]);
| 174 |
exit(1);
| 175 |
} else if (gotvfile == 0) {
| 176 |
fprintf(stderr, "%s: bad view file\n",
| 177 |
argv[i]);
| 178 |
exit(1);
| 179 |
| 180 |
break;
| 181 |
default:
| 182 |
badopt:
| 183 |
fprintf(stderr, "%s: command line error at '%s'\n",
| 184 |
progname, argv[i]);
| 185 |
goto userr;
| 186 |
| 187 |
| 188 |
/* check arguments */
| 189 |
if ((argc-i)%2)
| 190 |
goto userr;
| 191 |
if (fillsamp == 1)
| 192 |
fillo &= ~F_BACK;
| 193 |
/* set view */
| 194 |
if (err = setview(&ourview)) {
| 195 |
fprintf(stderr, "%s: %s\n", progname, err);
| 196 |
exit(1);
| 197 |
| 198 |
normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
| 199 |
/* allocate frame */
| 200 |
ourpict = (COLR *)bmalloc(hresolu*vresolu*sizeof(COLR));
| 201 |
ourzbuf = (float *)bmalloc(hresolu*vresolu*sizeof(float));
| 202 |
if (ourpict == NULL || ourzbuf == NULL)
| 203 |
syserror();
| 204 |
bzero((char *)ourzbuf, hresolu*vresolu*sizeof(float));
| 205 |
/* get input */
| 206 |
for ( ; i < argc; i += 2)
| 207 |
addpicture(argv[i], argv[i+1]);
| 208 |
/* fill in spaces */
| 209 |
if (fillo&F_BACK)
| 210 |
backpicture(fillfunc, fillsamp);
| 211 |
else
| 212 |
fillpicture(fillfunc);
| 213 |
/* close calculation */
| 214 |
caldone();
| 215 |
/* add to header */
| 216 |
printargs(argc, argv, stdout);
| 217 |
if (gotvfile) {
| 218 |
fputs(VIEWSTR, stdout);
| 219 |
fprintview(&ourview, stdout);
| 220 |
putc('\n', stdout);
| 221 |
| 222 |
if (pixaspect < .99 || pixaspect > 1.01)
| 223 |
fputaspect(pixaspect, stdout);
| 224 |
if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
| 225 |
fputexpos(ourexp, stdout);
| 226 |
fputformat(COLRFMT, stdout);
| 227 |
putc('\n', stdout);
| 228 |
/* write picture */
| 229 |
writepicture();
| 230 |
/* write z file */
| 231 |
if (zfile != NULL)
| 232 |
writedistance(zfile);
| 233 |
| 234 |
exit(0);
| 235 |
userr:
| 236 |
fprintf(stderr,
| 237 |
"Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
| 238 |
progname);
| 239 |
exit(1);
| 240 |
#undef check
| 241 |
| 242 |
| 243 |
| 244 |
headline(s) /* process header string */
| 245 |
char *s;
| 246 |
| 247 |
char fmt[32];
| 248 |
| 249 |
if (isformat(s)) {
| 250 |
formatval(fmt, s);
| 251 |
wrongformat = strcmp(fmt, COLRFMT);
| 252 |
return;
| 253 |
| 254 |
putc('\t', stdout);
| 255 |
fputs(s, stdout);
| 256 |
| 257 |
if (isexpos(s)) {
| 258 |
theirexp *= exposval(s);
| 259 |
return;
| 260 |
| 261 |
if (isview(s) && sscanview(&theirview, s) > 0)
| 262 |
gotview++;
| 263 |
| 264 |
| 265 |
| 266 |
addpicture(pfile, zspec) /* add picture to output */
| 267 |
char *pfile, *zspec;
| 268 |
| 269 |
FILE *pfp;
| 270 |
int zfd;
| 271 |
char *err;
| 272 |
COLR *scanin;
| 273 |
float *zin;
| 274 |
struct position *plast;
| 275 |
int y;
| 276 |
/* open picture file */
| 277 |
if ((pfp = fopen(pfile, "r")) == NULL) {
| 278 |
perror(pfile);
| 279 |
exit(1);
| 280 |
| 281 |
/* get header with exposure and view */
| 282 |
theirexp = 1.0;
| 283 |
gotview = 0;
| 284 |
printf("%s:\n", pfile);
| 285 |
getheader(pfp, headline, NULL);
| 286 |
if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
| 287 |
fprintf(stderr, "%s: picture format error\n", pfile);
| 288 |
exit(1);
| 289 |
| 290 |
if (ourexp <= 0)
| 291 |
ourexp = theirexp;
| 292 |
else if (ABS(theirexp-ourexp) > .01*ourexp)
| 293 |
fprintf(stderr, "%s: different exposure (warning)\n", pfile);
| 294 |
if (err = setview(&theirview)) {
| 295 |
fprintf(stderr, "%s: %s\n", pfile, err);
| 296 |
exit(1);
| 297 |
| 298 |
/* compute transformation */
| 299 |
hasmatrix = pixform(theirs2ours, &theirview, &ourview);
| 300 |
/* allocate scanlines */
| 301 |
scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
| 302 |
zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
| 303 |
plast = (struct position *)calloc(scanlen(&tresolu),
| 304 |
sizeof(struct position));
| 305 |
if (scanin == NULL || zin == NULL || plast == NULL)
| 306 |
syserror();
| 307 |
/* get z specification or file */
| 308 |
if ((zfd = open(zspec, O_RDONLY)) == -1) {
| 309 |
double zvalue;
| 310 |
register int x;
| 311 |
if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
| 312 |
perror(zspec);
| 313 |
exit(1);
| 314 |
| 315 |
for (x = scanlen(&tresolu); x-- > 0; )
| 316 |
zin[x] = zvalue;
| 317 |
| 318 |
/* load image */
| 319 |
for (y = 0; y < numscans(&tresolu); y++) {
| 320 |
if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
| 321 |
fprintf(stderr, "%s: read error\n", pfile);
| 322 |
exit(1);
| 323 |
| 324 |
if (zfd != -1 && read(zfd,(char *)zin,
| 325 |
| 326 |
< scanlen(&tresolu)*sizeof(float)) {
| 327 |
fprintf(stderr, "%s: read error\n", zspec);
| 328 |
exit(1);
| 329 |
| 330 |
addscanline(y, scanin, zin, plast);
| 331 |
| 332 |
/* clean up */
| 333 |
free((char *)scanin);
| 334 |
free((char *)zin);
| 335 |
free((char *)plast);
| 336 |
fclose(pfp);
| 337 |
if (zfd != -1)
| 338 |
close(zfd);
| 339 |
| 340 |
| 341 |
| 342 |
pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
| 343 |
register double xfmat[4][4];
| 344 |
register VIEW *vw1, *vw2;
| 345 |
| 346 |
double m4t[4][4];
| 347 |
| 348 |
if (vw1->type != VT_PER && vw1->type != VT_PAR)
| 349 |
return(0);
| 350 |
if (vw2->type != VT_PER && vw2->type != VT_PAR)
| 351 |
return(0);
| 352 |
setident4(xfmat);
| 353 |
xfmat[0][0] = vw1->hvec[0];
| 354 |
xfmat[0][1] = vw1->hvec[1];
| 355 |
xfmat[0][2] = vw1->hvec[2];
| 356 |
xfmat[1][0] = vw1->vvec[0];
| 357 |
xfmat[1][1] = vw1->vvec[1];
| 358 |
xfmat[1][2] = vw1->vvec[2];
| 359 |
xfmat[2][0] = vw1->vdir[0];
| 360 |
xfmat[2][1] = vw1->vdir[1];
| 361 |
xfmat[2][2] = vw1->vdir[2];
| 362 |
xfmat[3][0] = vw1->vp[0];
| 363 |
xfmat[3][1] = vw1->vp[1];
| 364 |
xfmat[3][2] = vw1->vp[2];
| 365 |
setident4(m4t);
| 366 |
m4t[0][0] = vw2->hvec[0]/vw2->hn2;
| 367 |
m4t[1][0] = vw2->hvec[1]/vw2->hn2;
| 368 |
m4t[2][0] = vw2->hvec[2]/vw2->hn2;
| 369 |
m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
| 370 |
m4t[0][1] = vw2->vvec[0]/vw2->vn2;
| 371 |
m4t[1][1] = vw2->vvec[1]/vw2->vn2;
| 372 |
m4t[2][1] = vw2->vvec[2]/vw2->vn2;
| 373 |
m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
| 374 |
m4t[0][2] = vw2->vdir[0];
| 375 |
m4t[1][2] = vw2->vdir[1];
| 376 |
m4t[2][2] = vw2->vdir[2];
| 377 |
m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
| 378 |
multmat4(xfmat, xfmat, m4t);
| 379 |
return(1);
| 380 |
| 381 |
| 382 |
| 383 |
addscanline(y, pline, zline, lasty) /* add scanline to output */
| 384 |
int y;
| 385 |
COLR *pline;
| 386 |
float *zline;
| 387 |
struct position *lasty; /* input/output */
| 388 |
| 389 |
extern double sqrt();
| 390 |
FVECT pos;
| 391 |
struct position lastx, newpos;
| 392 |
register int x;
| 393 |
| 394 |
lastx.z = 0;
| 395 |
for (x = scanlen(&tresolu); x-- > 0; ) {
| 396 |
pix2loc(pos, &tresolu, x, y);
| 397 |
pos[2] = zline[x];
| 398 |
if (movepixel(pos) < 0) {
| 399 |
lasty[x].z = lastx.z = 0; /* mark invalid */
| 400 |
continue;
| 401 |
| 402 |
newpos.x = pos[0] * hresolu;
| 403 |
newpos.y = pos[1] * vresolu;
| 404 |
newpos.z = zline[x];
| 405 |
/* add pixel to our image */
| 406 |
if (pos[0] >= 0 && newpos.x < hresolu
| 407 |
&& pos[1] >= 0 && newpos.y < vresolu) {
| 408 |
addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
| 409 |
lasty[x].x = lastx.x = newpos.x;
| 410 |
lasty[x].y = lastx.y = newpos.y;
| 411 |
lasty[x].z = lastx.z = newpos.z;
| 412 |
} else
| 413 |
| 414 |
| 415 |
| 416 |
| 417 |
| 418 |
addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
| 419 |
struct position *p0, *p1, *p2;
| 420 |
COLR pix;
| 421 |
double z;
| 422 |
| 423 |
double zt = 2.*zeps*p0->z; /* threshold */
| 424 |
int s1x, s1y, s2x, s2y; /* step sizes */
| 425 |
int l1, l2, c1, c2; /* side lengths and counters */
| 426 |
int p1isy; /* p0p1 along y? */
| 427 |
int x1, y1; /* p1 position */
| 428 |
register int x, y; /* final position */
| 429 |
| 430 |
/* compute vector p0p1 */
| 431 |
if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
| 432 |
s1x = p1->x - p0->x;
| 433 |
s1y = p1->y - p0->y;
| 434 |
l1 = ABS(s1x);
| 435 |
if (p1isy = (ABS(s1y) > l1))
| 436 |
l1 = ABS(s1y);
| 437 |
} else {
| 438 |
l1 = s1x = s1y = 1;
| 439 |
p1isy = -1;
| 440 |
| 441 |
/* compute vector p0p2 */
| 442 |
if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
| 443 |
s2x = p2->x - p0->x;
| 444 |
s2y = p2->y - p0->y;
| 445 |
if (p1isy == 1)
| 446 |
l2 = ABS(s2x);
| 447 |
else {
| 448 |
l2 = ABS(s2y);
| 449 |
if (p1isy != 0 && ABS(s2x) > l2)
| 450 |
l2 = ABS(s2x);
| 451 |
| 452 |
} else
| 453 |
l2 = s2x = s2y = 1;
| 454 |
/* fill the parallelogram */
| 455 |
for (c1 = l1; c1-- > 0; ) {
| 456 |
x1 = p0->x + c1*s1x/l1;
| 457 |
y1 = p0->y + c1*s1y/l1;
| 458 |
for (c2 = l2; c2-- > 0; ) {
| 459 |
x = x1 + c2*s2x/l2;
| 460 |
if (x < 0 || x >= hresolu)
| 461 |
continue;
| 462 |
y = y1 + c2*s2y/l2;
| 463 |
if (y < 0 || y >= vresolu)
| 464 |
continue;
| 465 |
if (zscan(y)[x] <= 0 || zscan(y)[x]-z
| 466 |
> zeps*zscan(y)[x]) {
| 467 |
zscan(y)[x] = z;
| 468 |
copycolr(pscan(y)[x], pix);
| 469 |
| 470 |
| 471 |
| 472 |
| 473 |
| 474 |
| 475 |
movepixel(pos) /* reposition image point */
| 476 |
FVECT pos;
| 477 |
| 478 |
FVECT pt, direc;
| 479 |
| 480 |
if (pos[2] <= 0) /* empty pixel */
| 481 |
return(-1);
| 482 |
if (hasmatrix) {
| 483 |
pos[0] += theirview.hoff - .5;
| 484 |
pos[1] += theirview.voff - .5;
| 485 |
if (theirview.type == VT_PER) {
| 486 |
if (normdist) /* adjust for eye-ray distance */
| 487 |
pos[2] /= sqrt( 1.
| 488 |
+ pos[0]*pos[0]*theirview.hn2
| 489 |
+ pos[1]*pos[1]*theirview.vn2 );
| 490 |
pos[0] *= pos[2];
| 491 |
pos[1] *= pos[2];
| 492 |
| 493 |
multp3(pos, pos, theirs2ours);
| 494 |
if (pos[2] <= 0)
| 495 |
return(-1);
| 496 |
if (ourview.type == VT_PER) {
| 497 |
pos[0] /= pos[2];
| 498 |
pos[1] /= pos[2];
| 499 |
| 500 |
pos[0] += .5 - ourview.hoff;
| 501 |
pos[1] += .5 - ourview.voff;
| 502 |
return(0);
| 503 |
| 504 |
if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
| 505 |
return(-1);
| 506 |
pt[0] += direc[0]*pos[2];
| 507 |
pt[1] += direc[1]*pos[2];
| 508 |
pt[2] += direc[2]*pos[2];
| 509 |
viewloc(pos, &ourview, pt);
| 510 |
if (pos[2] <= 0)
| 511 |
return(-1);
| 512 |
return(0);
| 513 |
| 514 |
| 515 |
| 516 |
backpicture(fill, samp) /* background fill algorithm */
| 517 |
int (*fill)();
| 518 |
int samp;
| 519 |
| 520 |
int *yback, xback;
| 521 |
int y;
| 522 |
register int x, i;
| 523 |
/* get back buffer */
| 524 |
yback = (int *)malloc(hresolu*sizeof(int));
| 525 |
if (yback == NULL)
| 526 |
syserror();
| 527 |
for (x = 0; x < hresolu; x++)
| 528 |
yback[x] = -2;
| 529 |
| 530 |
* Xback and yback are the pixel locations of suitable
| 531 |
* background values in each direction.
| 532 |
* A value of -2 means unassigned, and -1 means
| 533 |
* that there is no suitable background in this direction.
| 534 |
| 535 |
/* fill image */
| 536 |
for (y = 0; y < vresolu; y++) {
| 537 |
xback = -2;
| 538 |
| 539 |
if (zscan(y)[x] <= 0) { /* empty pixel */
| 540 |
| 541 |
* First, find background from above or below.
| 542 |
* (farthest assigned pixel)
| 543 |
| 544 |
if (yback[x] == -2) {
| 545 |
for (i = y+1; i < vresolu; i++)
| 546 |
if (zscan(i)[x] > 0)
| 547 |
break;
| 548 |
if (i < vresolu
| 549 |
&& (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
| 550 |
yback[x] = i;
| 551 |
else
| 552 |
yback[x] = y-1;
| 553 |
| 554 |
| 555 |
* Next, find background from left or right.
| 556 |
| 557 |
if (xback == -2) {
| 558 |
for (i = x+1; i < hresolu; i++)
| 559 |
if (zscan(y)[i] > 0)
| 560 |
break;
| 561 |
if (i < hresolu
| 562 |
&& (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
| 563 |
xback = i;
| 564 |
else
| 565 |
xback = x-1;
| 566 |
| 567 |
| 568 |
* If we have no background for this pixel,
| 569 |
* use the given fill function.
| 570 |
| 571 |
if (xback < 0 && yback[x] < 0)
| 572 |
goto fillit;
| 573 |
| 574 |
* Compare, and use the background that is
| 575 |
* farther, unless one of them is next to us.
| 576 |
* If the background is too distant, call
| 577 |
* the fill function.
| 578 |
| 579 |
if ( yback[x] < 0
| 580 |
|| (xback >= 0 && ABS(x-xback) <= 1)
| 581 |
|| ( ABS(y-yback[x]) > 1
| 582 |
&& zscan(yback[x])[x]
| 583 |
< zscan(y)[xback] ) ) {
| 584 |
if (samp > 0 && ABS(x-xback) >= samp)
| 585 |
goto fillit;
| 586 |
copycolr(pscan(y)[x],pscan(y)[xback]);
| 587 |
zscan(y)[x] = zscan(y)[xback];
| 588 |
} else {
| 589 |
if (samp > 0 && ABS(y-yback[x]) > samp)
| 590 |
goto fillit;
| 591 |
copycolr(pscan(y)[x],pscan(yback[x])[x]);
| 592 |
zscan(y)[x] = zscan(yback[x])[x];
| 593 |
| 594 |
continue;
| 595 |
fillit:
| 596 |
(*fill)(x,y);
| 597 |
if (fill == rcalfill) { /* use it */
| 598 |
clearqueue();
| 599 |
xback = x;
| 600 |
yback[x] = y;
| 601 |
| 602 |
} else { /* full pixel */
| 603 |
yback[x] = -2;
| 604 |
xback = -2;
| 605 |
| 606 |
| 607 |
free((char *)yback);
| 608 |
| 609 |
| 610 |
| 611 |
fillpicture(fill) /* paint in empty pixels using fill */
| 612 |
int (*fill)();
| 613 |
| 614 |
register int x, y;
| 615 |
| 616 |
| 617 |
| 618 |
| 619 |
(*fill)(x,y);
| 620 |
| 621 |
| 622 |
| 623 |
writepicture() /* write out picture */
| 624 |
| 625 |
int y;
| 626 |
| 627 |
fprtresolu(hresolu, vresolu, stdout);
| 628 |
for (y = vresolu-1; y >= 0; y--)
| 629 |
if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
| 630 |
syserror();
| 631 |
| 632 |
| 633 |
| 634 |
writedistance(fname) /* write out z file */
| 635 |
char *fname;
| 636 |
| 637 |
| 638 |
int donorm = normdist && ourview.type == VT_PER;
| 639 |
int fd;
| 640 |
int y;
| 641 |
float *zout;
| 642 |
| 643 |
if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
| 644 |
perror(fname);
| 645 |
exit(1);
| 646 |
| 647 |
if (donorm
| 648 |
&& (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
| 649 |
syserror();
| 650 |
for (y = vresolu-1; y >= 0; y--) {
| 651 |
if (donorm) {
| 652 |
double vx, yzn2;
| 653 |
register int x;
| 654 |
yzn2 = (y+.5)/vresolu + ourview.voff - .5;
| 655 |
yzn2 = 1. + yzn2*yzn2*ourview.vn2;
| 656 |
for (x = 0; x < hresolu; x++) {
| 657 |
vx = (x+.5)/hresolu + ourview.hoff - .5;
| 658 |
zout[x] = zscan(y)[x]
| 659 |
* sqrt(vx*vx*ourview.hn2 + yzn2);
| 660 |
| 661 |
} else
| 662 |
zout = zscan(y);
| 663 |
if (write(fd, (char *)zout, hresolu*sizeof(float))
| 664 |
< hresolu*sizeof(float)) {
| 665 |
perror(fname);
| 666 |
exit(1);
| 667 |
| 668 |
| 669 |
if (donorm)
| 670 |
free((char *)zout);
| 671 |
close(fd);
| 672 |
| 673 |
| 674 |
| 675 |
isfloat(s) /* see if string is floating number */
| 676 |
register char *s;
| 677 |
| 678 |
for ( ; *s; s++)
| 679 |
if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
| 680 |
&& *s != 'e' && *s != 'E' && *s != '+')
| 681 |
return(0);
| 682 |
return(1);
| 683 |
| 684 |
| 685 |
| 686 |
backfill(x, y) /* fill pixel with background */
| 687 |
int x, y;
| 688 |
| 689 |
register BYTE *dest = pscan(y)[x];
| 690 |
| 691 |
copycolr(dest, backcolr);
| 692 |
zscan(y)[x] = backz;
| 693 |
| 694 |
| 695 |
| 696 |
calstart(prog, args) /* start fill calculation */
| 697 |
char *prog, *args;
| 698 |
| 699 |
char combuf[512];
| 700 |
char *argv[64];
| 701 |
int rval;
| 702 |
register char **wp, *cp;
| 703 |
| 704 |
if (childpid != -1) {
| 705 |
fprintf(stderr, "%s: too many calculations\n", progname);
| 706 |
exit(1);
| 707 |
| 708 |
strcpy(combuf, prog);
| 709 |
strcat(combuf, args);
| 710 |
cp = combuf;
| 711 |
wp = argv;
| 712 |
for ( ; ; ) {
| 713 |
while (isspace(*cp)) cp++;
| 714 |
if (!*cp) break;
| 715 |
*wp++ = cp;
| 716 |
while (!isspace(*cp))
| 717 |
if (!*cp++) goto done;
| 718 |
*cp++ = '\0';
| 719 |
| 720 |
done:
| 721 |
*wp = NULL;
| 722 |
/* start process */
| 723 |
if ((rval = open_process(PDesc, argv)) < 0)
| 724 |
syserror();
| 725 |
if (rval == 0) {
| 726 |
fprintf(stderr, "%s: command not found\n", argv[0]);
| 727 |
exit(1);
| 728 |
| 729 |
packsiz = rval/(6*sizeof(float)) - 1;
| 730 |
if (packsiz > PACKSIZ)
| 731 |
packsiz = PACKSIZ;
| 732 |
queuesiz = 0;
| 733 |
| 734 |
| 735 |
| 736 |
caldone() /* done with calculation */
| 737 |
| 738 |
if (childpid == -1)
| 739 |
return;
| 740 |
clearqueue();
| 741 |
close_process(PDesc);
| 742 |
childpid = -1;
| 743 |
| 744 |
| 745 |
| 746 |
rcalfill(x, y) /* fill with ray-calculated pixel */
| 747 |
int x, y;
| 748 |
| 749 |
if (queuesiz >= packsiz) /* flush queue if needed */
| 750 |
clearqueue();
| 751 |
/* add position to queue */
| 752 |
queue[queuesiz][0] = x;
| 753 |
queue[queuesiz][1] = y;
| 754 |
queuesiz++;
| 755 |
| 756 |
| 757 |
| 758 |
clearqueue() /* process queue */
| 759 |
| 760 |
FVECT orig, dir;
| 761 |
float fbuf[6*(PACKSIZ+1)];
| 762 |
register float *fbp;
| 763 |
register int i;
| 764 |
| 765 |
fbp = fbuf;
| 766 |
for (i = 0; i < queuesiz; i++) {
| 767 |
viewray(orig, dir, &ourview,
| 768 |
(queue[i][0]+.5)/hresolu,
| 769 |
(queue[i][1]+.5)/vresolu);
| 770 |
*fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
| 771 |
*fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
| 772 |
| 773 |
/* mark end and get results */
| 774 |
bzero((char *)fbp, 6*sizeof(float));
| 775 |
if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
| 776 |
6*sizeof(float)*(queuesiz+1)) !=
| 777 |
4*sizeof(float)*queuesiz) {
| 778 |
fprintf(stderr, "%s: error reading from rtrace process\n",
| 779 |
progname);
| 780 |
exit(1);
| 781 |
| 782 |
fbp = fbuf;
| 783 |
| 784 |
if (ourexp > 0 && ourexp != 1.0) {
| 785 |
fbp[0] *= ourexp;
| 786 |
fbp[1] *= ourexp;
| 787 |
fbp[2] *= ourexp;
| 788 |
| 789 |
setcolr(pscan(queue[i][1])[queue[i][0]],
| 790 |
fbp[0], fbp[1], fbp[2]);
| 791 |
zscan(queue[i][1])[queue[i][0]] = fbp[3];
| 792 |
fbp += 4;
| 793 |
| 794 |
queuesiz = 0;
| 795 |
| 796 |
| 797 |
| 798 |
syserror() /* report error and exit */
| 799 |
| 800 |
perror(progname);
| 801 |
exit(1);
| 802 |
