root/radiance/ray/src/px/pinterp.c
Revision: 2.2
Committed: Thu Dec 19 14:51:55 1991 UTC (32 years, 4 months ago) by greg
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <fcntl.h>
16
17 #include "view.h"
18
19 #include "color.h"
20
21 #include "resolu.h"
22
23 #ifndef BSD
24 #define vfork fork
25 #endif
26
27 #define pscan(y) (ourpict+(y)*hresolu)
28 #define zscan(y) (ourzbuf+(y)*hresolu)
29
30 #define F_FORE 1 /* fill foreground */
31 #define F_BACK 2 /* fill background */
32
33 #define PACKSIZ 42 /* calculation packet size */
34
35 #define RTCOM "rtrace -h -ovl -fff %s"
36
37 #define ABS(x) ((x)>0?(x):-(x))
38
39 struct position {int x,y; float z;};
40
41 VIEW ourview = STDVIEW; /* desired view */
42 int hresolu = 512; /* horizontal resolution */
43 int vresolu = 512; /* vertical resolution */
44 double pixaspect = 1.0; /* pixel aspect ratio */
45
46 double zeps = .02; /* allowed z epsilon */
47
48 COLR *ourpict; /* output picture */
49 float *ourzbuf; /* corresponding z-buffer */
50
51 char *progname;
52
53 int fillo = F_FORE|F_BACK; /* selected fill options */
54 int fillsamp = 0; /* sample separation (0 == inf) */
55 extern int backfill(), rcalfill(); /* fill functions */
56 int (*fillfunc)() = backfill; /* selected fill function */
57 COLR backcolr = BLKCOLR; /* background color */
58 double backz = 0.0; /* background z value */
59 int normdist = 1; /* normalized distance? */
60 double ourexp = -1; /* output picture exposure */
61
62 VIEW theirview = STDVIEW; /* input view */
63 int gotview; /* got input view? */
64 int wrongformat = 0; /* input in another format? */
65 RESOLU tresolu; /* input resolution */
66 double theirexp; /* input picture exposure */
67 double theirs2ours[4][4]; /* transformation matrix */
68 int hasmatrix = 0; /* has transformation matrix */
69
70 int childpid = -1; /* id of fill process */
71 FILE *psend, *precv; /* pipes to/from fill calculation */
72 int queue[PACKSIZ][2]; /* pending pixels */
73 int queuesiz; /* number of pixels pending */
74
75
76 main(argc, argv) /* interpolate pictures */
77 int argc;
78 char *argv[];
79 {
80 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
81 int gotvfile = 0;
82 char *zfile = NULL;
83 char *err;
84 int i, rval;
85
86 progname = argv[0];
87
88 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
89 rval = getviewopt(&ourview, argc-i, argv+i);
90 if (rval >= 0) {
91 i += rval;
92 continue;
93 }
94 switch (argv[i][1]) {
95 case 't': /* threshold */
96 check(2,1);
97 zeps = atof(argv[++i]);
98 break;
99 case 'n': /* dist. normalized? */
100 check(2,0);
101 normdist = !normdist;
102 break;
103 case 'f': /* fill type */
104 switch (argv[i][2]) {
105 case '0': /* none */
106 check(3,0);
107 fillo = 0;
108 break;
109 case 'f': /* foreground */
110 check(3,0);
111 fillo = F_FORE;
112 break;
113 case 'b': /* background */
114 check(3,0);
115 fillo = F_BACK;
116 break;
117 case 'a': /* all */
118 check(3,0);
119 fillo = F_FORE|F_BACK;
120 break;
121 case 's': /* sample */
122 check(3,1);
123 fillsamp = atoi(argv[++i]);
124 break;
125 case 'c': /* color */
126 check(3,3);
127 fillfunc = backfill;
128 setcolr(backcolr, atof(argv[i+1]),
129 atof(argv[i+2]), atof(argv[i+3]));
130 i += 3;
131 break;
132 case 'z': /* z value */
133 check(3,1);
134 fillfunc = backfill;
135 backz = atof(argv[++i]);
136 break;
137 case 'r': /* rtrace */
138 check(3,1);
139 fillfunc = rcalfill;
140 calstart(RTCOM, argv[++i]);
141 break;
142 default:
143 goto badopt;
144 }
145 break;
146 case 'z': /* z file */
147 check(2,1);
148 zfile = argv[++i];
149 break;
150 case 'x': /* x resolution */
151 check(2,1);
152 hresolu = atoi(argv[++i]);
153 break;
154 case 'y': /* y resolution */
155 check(2,1);
156 vresolu = atoi(argv[++i]);
157 break;
158 case 'p': /* pixel aspect */
159 check(2,1);
160 pixaspect = atof(argv[++i]);
161 break;
162 case 'v': /* view file */
163 if (argv[i][2] != 'f')
164 goto badopt;
165 check(3,1);
166 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
167 if (gotvfile < 0) {
168 perror(argv[i]);
169 exit(1);
170 } else if (gotvfile == 0) {
171 fprintf(stderr, "%s: bad view file\n",
172 argv[i]);
173 exit(1);
174 }
175 break;
176 default:
177 badopt:
178 fprintf(stderr, "%s: command line error at '%s'\n",
179 progname, argv[i]);
180 goto userr;
181 }
182 }
183 /* check arguments */
184 if ((argc-i)%2)
185 goto userr;
186 /* set view */
187 if (err = setview(&ourview)) {
188 fprintf(stderr, "%s: %s\n", progname, err);
189 exit(1);
190 }
191 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
192 /* allocate frame */
193 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
194 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
195 if (ourpict == NULL || ourzbuf == NULL)
196 syserror();
197 /* get input */
198 for ( ; i < argc; i += 2)
199 addpicture(argv[i], argv[i+1]);
200 /* fill in spaces */
201 if (fillo&F_BACK)
202 backpicture(fillfunc, fillsamp);
203 else
204 fillpicture(fillfunc);
205 /* close calculation */
206 caldone();
207 /* add to header */
208 printargs(argc, argv, stdout);
209 if (gotvfile) {
210 fputs(VIEWSTR, stdout);
211 fprintview(&ourview, stdout);
212 putc('\n', stdout);
213 }
214 if (pixaspect < .99 || pixaspect > 1.01)
215 fputaspect(pixaspect, stdout);
216 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
217 fputexpos(ourexp, stdout);
218 fputformat(COLRFMT, stdout);
219 putc('\n', stdout);
220 /* write picture */
221 writepicture();
222 /* write z file */
223 if (zfile != NULL)
224 writedistance(zfile);
225
226 exit(0);
227 userr:
228 fprintf(stderr,
229 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
230 progname);
231 exit(1);
232 #undef check
233 }
234
235
236 headline(s) /* process header string */
237 char *s;
238 {
239 static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL};
240 register char **an;
241 char fmt[32];
242
243 if (isformat(s)) {
244 formatval(fmt, s);
245 wrongformat = strcmp(fmt, COLRFMT);
246 return;
247 }
248 putc('\t', stdout);
249 fputs(s, stdout);
250
251 if (isexpos(s)) {
252 theirexp *= exposval(s);
253 return;
254 }
255 for (an = altname; *an != NULL; an++)
256 if (!strncmp(*an, s, strlen(*an))) {
257 if (sscanview(&theirview, s+strlen(*an)) > 0)
258 gotview++;
259 break;
260 }
261 }
262
263
264 addpicture(pfile, zspec) /* add picture to output */
265 char *pfile, *zspec;
266 {
267 FILE *pfp;
268 int zfd;
269 char *err;
270 COLR *scanin;
271 float *zin;
272 struct position *plast;
273 int y;
274 /* open picture file */
275 if ((pfp = fopen(pfile, "r")) == NULL) {
276 perror(pfile);
277 exit(1);
278 }
279 /* get header with exposure and view */
280 theirexp = 1.0;
281 gotview = 0;
282 printf("%s:\n", pfile);
283 getheader(pfp, headline, NULL);
284 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
285 fprintf(stderr, "%s: picture format error\n", pfile);
286 exit(1);
287 }
288 if (ourexp <= 0)
289 ourexp = theirexp;
290 else if (ABS(theirexp-ourexp) > .01*ourexp)
291 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
292 if (err = setview(&theirview)) {
293 fprintf(stderr, "%s: %s\n", pfile, err);
294 exit(1);
295 }
296 /* compute transformation */
297 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
298 /* allocate scanlines */
299 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
300 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
301 plast = (struct position *)calloc(scanlen(&tresolu),
302 sizeof(struct position));
303 if (scanin == NULL || zin == NULL || plast == NULL)
304 syserror();
305 /* get z specification or file */
306 if ((zfd = open(zspec, O_RDONLY)) == -1) {
307 double zvalue;
308 register int x;
309 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
310 perror(zspec);
311 exit(1);
312 }
313 for (x = scanlen(&tresolu); x-- > 0; )
314 zin[x] = zvalue;
315 }
316 /* load image */
317 for (y = 0; y < numscans(&tresolu); y++) {
318 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
319 fprintf(stderr, "%s: read error\n", pfile);
320 exit(1);
321 }
322 if (zfd != -1 && read(zfd,(char *)zin,
323 scanlen(&tresolu)*sizeof(float))
324 < scanlen(&tresolu)*sizeof(float)) {
325 fprintf(stderr, "%s: read error\n", zspec);
326 exit(1);
327 }
328 addscanline(y, scanin, zin, plast);
329 }
330 /* clean up */
331 free((char *)scanin);
332 free((char *)zin);
333 free((char *)plast);
334 fclose(pfp);
335 if (zfd != -1)
336 close(zfd);
337 }
338
339
340 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
341 register double xfmat[4][4];
342 register VIEW *vw1, *vw2;
343 {
344 double m4t[4][4];
345
346 if (vw1->type != VT_PER && vw1->type != VT_PAR)
347 return(0);
348 if (vw2->type != VT_PER && vw2->type != VT_PAR)
349 return(0);
350 setident4(xfmat);
351 xfmat[0][0] = vw1->hvec[0];
352 xfmat[0][1] = vw1->hvec[1];
353 xfmat[0][2] = vw1->hvec[2];
354 xfmat[1][0] = vw1->vvec[0];
355 xfmat[1][1] = vw1->vvec[1];
356 xfmat[1][2] = vw1->vvec[2];
357 xfmat[2][0] = vw1->vdir[0];
358 xfmat[2][1] = vw1->vdir[1];
359 xfmat[2][2] = vw1->vdir[2];
360 xfmat[3][0] = vw1->vp[0];
361 xfmat[3][1] = vw1->vp[1];
362 xfmat[3][2] = vw1->vp[2];
363 setident4(m4t);
364 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
365 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
366 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
367 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
368 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
369 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
370 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
371 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
372 m4t[0][2] = vw2->vdir[0];
373 m4t[1][2] = vw2->vdir[1];
374 m4t[2][2] = vw2->vdir[2];
375 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
376 multmat4(xfmat, xfmat, m4t);
377 return(1);
378 }
379
380
381 addscanline(y, pline, zline, lasty) /* add scanline to output */
382 int y;
383 COLR *pline;
384 float *zline;
385 struct position *lasty; /* input/output */
386 {
387 extern double sqrt();
388 FVECT pos;
389 struct position lastx, newpos;
390 register int x;
391
392 lastx.z = 0;
393 for (x = scanlen(&tresolu); x-- > 0; ) {
394 pix2loc(pos, &tresolu, x, y);
395 pos[2] = zline[x];
396 if (movepixel(pos) < 0) {
397 lasty[x].z = lastx.z = 0; /* mark invalid */
398 continue;
399 }
400 newpos.x = pos[0] * hresolu;
401 newpos.y = pos[1] * vresolu;
402 newpos.z = zline[x];
403 /* add pixel to our image */
404 if (pos[0] >= 0 && newpos.x < hresolu
405 && pos[1] >= 0 && newpos.y < vresolu) {
406 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
407 lasty[x].x = lastx.x = newpos.x;
408 lasty[x].y = lastx.y = newpos.y;
409 lasty[x].z = lastx.z = newpos.z;
410 } else
411 lasty[x].z = lastx.z = 0; /* mark invalid */
412 }
413 }
414
415
416 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
417 struct position *p0, *p1, *p2;
418 COLR pix;
419 double z;
420 {
421 double zt = 2.*zeps*p0->z; /* threshold */
422 int s1x, s1y, s2x, s2y; /* step sizes */
423 int l1, l2, c1, c2; /* side lengths and counters */
424 int p1isy; /* p0p1 along y? */
425 int x1, y1; /* p1 position */
426 register int x, y; /* final position */
427
428 /* compute vector p0p1 */
429 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
430 s1x = p1->x - p0->x;
431 s1y = p1->y - p0->y;
432 l1 = ABS(s1x);
433 if (p1isy = (ABS(s1y) > l1))
434 l1 = ABS(s1y);
435 } else {
436 l1 = s1x = s1y = 1;
437 p1isy = -1;
438 }
439 /* compute vector p0p2 */
440 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
441 s2x = p2->x - p0->x;
442 s2y = p2->y - p0->y;
443 if (p1isy == 1)
444 l2 = ABS(s2x);
445 else {
446 l2 = ABS(s2y);
447 if (p1isy != 0 && ABS(s2x) > l2)
448 l2 = ABS(s2x);
449 }
450 } else
451 l2 = s2x = s2y = 1;
452 /* fill the parallelogram */
453 for (c1 = l1; c1-- > 0; ) {
454 x1 = p0->x + c1*s1x/l1;
455 y1 = p0->y + c1*s1y/l1;
456 for (c2 = l2; c2-- > 0; ) {
457 x = x1 + c2*s2x/l2;
458 if (x < 0 || x >= hresolu)
459 continue;
460 y = y1 + c2*s2y/l2;
461 if (y < 0 || y >= vresolu)
462 continue;
463 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
464 > zeps*zscan(y)[x]) {
465 zscan(y)[x] = z;
466 copycolr(pscan(y)[x], pix);
467 }
468 }
469 }
470 }
471
472
473 movepixel(pos) /* reposition image point */
474 FVECT pos;
475 {
476 FVECT pt, direc;
477
478 if (pos[2] <= 0) /* empty pixel */
479 return(-1);
480 if (hasmatrix) {
481 pos[0] += theirview.hoff - .5;
482 pos[1] += theirview.voff - .5;
483 if (theirview.type == VT_PER) {
484 if (normdist) /* adjust for eye-ray distance */
485 pos[2] /= sqrt( 1.
486 + pos[0]*pos[0]*theirview.hn2
487 + pos[1]*pos[1]*theirview.vn2 );
488 pos[0] *= pos[2];
489 pos[1] *= pos[2];
490 }
491 multp3(pos, pos, theirs2ours);
492 if (pos[2] <= 0)
493 return(-1);
494 if (ourview.type == VT_PER) {
495 pos[0] /= pos[2];
496 pos[1] /= pos[2];
497 }
498 pos[0] += .5 - ourview.hoff;
499 pos[1] += .5 - ourview.voff;
500 return(0);
501 }
502 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
503 return(-1);
504 pt[0] += direc[0]*pos[2];
505 pt[1] += direc[1]*pos[2];
506 pt[2] += direc[2]*pos[2];
507 viewloc(pos, &ourview, pt);
508 if (pos[2] <= 0)
509 return(-1);
510 return(0);
511 }
512
513
514 backpicture(fill, samp) /* background fill algorithm */
515 int (*fill)();
516 int samp;
517 {
518 int *yback, xback;
519 int y;
520 register int x, i;
521 /* get back buffer */
522 yback = (int *)malloc(hresolu*sizeof(int));
523 if (yback == NULL)
524 syserror();
525 for (x = 0; x < hresolu; x++)
526 yback[x] = -2;
527 /*
528 * Xback and yback are the pixel locations of suitable
529 * background values in each direction.
530 * A value of -2 means unassigned, and -1 means
531 * that there is no suitable background in this direction.
532 */
533 /* fill image */
534 for (y = 0; y < vresolu; y++) {
535 xback = -2;
536 for (x = 0; x < hresolu; x++)
537 if (zscan(y)[x] <= 0) { /* empty pixel */
538 /*
539 * First, find background from above or below.
540 * (farthest assigned pixel)
541 */
542 if (yback[x] == -2) {
543 for (i = y+1; i < vresolu; i++)
544 if (zscan(i)[x] > 0)
545 break;
546 if (i < vresolu
547 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
548 yback[x] = i;
549 else
550 yback[x] = y-1;
551 }
552 /*
553 * Next, find background from left or right.
554 */
555 if (xback == -2) {
556 for (i = x+1; i < hresolu; i++)
557 if (zscan(y)[i] > 0)
558 break;
559 if (i < hresolu
560 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
561 xback = i;
562 else
563 xback = x-1;
564 }
565 /*
566 * If we have no background for this pixel,
567 * use the given fill function.
568 */
569 if (xback < 0 && yback[x] < 0)
570 goto fillit;
571 /*
572 * Compare, and use the background that is
573 * farther, unless one of them is next to us.
574 * If the background is too distant, call
575 * the fill function.
576 */
577 if ( yback[x] < 0
578 || (xback >= 0 && ABS(x-xback) <= 1)
579 || ( ABS(y-yback[x]) > 1
580 && zscan(yback[x])[x]
581 < zscan(y)[xback] ) ) {
582 if (samp > 0 && ABS(x-xback) >= samp)
583 goto fillit;
584 copycolr(pscan(y)[x],pscan(y)[xback]);
585 zscan(y)[x] = zscan(y)[xback];
586 } else {
587 if (samp > 0 && ABS(y-yback[x]) > samp)
588 goto fillit;
589 copycolr(pscan(y)[x],pscan(yback[x])[x]);
590 zscan(y)[x] = zscan(yback[x])[x];
591 }
592 continue;
593 fillit:
594 (*fill)(x,y);
595 if (fill == rcalfill) { /* use it */
596 clearqueue();
597 xback = x;
598 yback[x] = y;
599 }
600 } else { /* full pixel */
601 yback[x] = -2;
602 xback = -2;
603 }
604 }
605 free((char *)yback);
606 }
607
608
609 fillpicture(fill) /* paint in empty pixels using fill */
610 int (*fill)();
611 {
612 register int x, y;
613
614 for (y = 0; y < vresolu; y++)
615 for (x = 0; x < hresolu; x++)
616 if (zscan(y)[x] <= 0)
617 (*fill)(x,y);
618 }
619
620
621 writepicture() /* write out picture */
622 {
623 int y;
624
625 fprtresolu(hresolu, vresolu, stdout);
626 for (y = vresolu-1; y >= 0; y--)
627 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
628 syserror();
629 }
630
631
632 writedistance(fname) /* write out z file */
633 char *fname;
634 {
635 extern double sqrt();
636 int donorm = normdist && ourview.type == VT_PER;
637 int fd;
638 int y;
639 float *zout;
640
641 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
642 perror(fname);
643 exit(1);
644 }
645 if (donorm
646 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
647 syserror();
648 for (y = vresolu-1; y >= 0; y--) {
649 if (donorm) {
650 double vx, yzn2;
651 register int x;
652 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
653 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
654 for (x = 0; x < hresolu; x++) {
655 vx = (x+.5)/hresolu + ourview.hoff - .5;
656 zout[x] = zscan(y)[x]
657 * sqrt(vx*vx*ourview.hn2 + yzn2);
658 }
659 } else
660 zout = zscan(y);
661 if (write(fd, (char *)zout, hresolu*sizeof(float))
662 < hresolu*sizeof(float)) {
663 perror(fname);
664 exit(1);
665 }
666 }
667 if (donorm)
668 free((char *)zout);
669 close(fd);
670 }
671
672
673 isfloat(s) /* see if string is floating number */
674 register char *s;
675 {
676 for ( ; *s; s++)
677 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
678 && *s != 'e' && *s != 'E' && *s != '+')
679 return(0);
680 return(1);
681 }
682
683
684 backfill(x, y) /* fill pixel with background */
685 int x, y;
686 {
687 register BYTE *dest = pscan(y)[x];
688
689 copycolr(dest, backcolr);
690 zscan(y)[x] = backz;
691 }
692
693
694 calstart(prog, args) /* start fill calculation */
695 char *prog, *args;
696 {
697 char combuf[512];
698 int p0[2], p1[2];
699
700 if (childpid != -1) {
701 fprintf(stderr, "%s: too many calculations\n", progname);
702 exit(1);
703 }
704 sprintf(combuf, prog, args);
705 if (pipe(p0) < 0 || pipe(p1) < 0)
706 syserror();
707 if ((childpid = vfork()) == 0) { /* fork calculation */
708 close(p0[1]);
709 close(p1[0]);
710 if (p0[0] != 0) {
711 dup2(p0[0], 0);
712 close(p0[0]);
713 }
714 if (p1[1] != 1) {
715 dup2(p1[1], 1);
716 close(p1[1]);
717 }
718 execl("/bin/sh", "sh", "-c", combuf, 0);
719 perror("/bin/sh");
720 _exit(127);
721 }
722 if (childpid == -1)
723 syserror();
724 close(p0[0]);
725 close(p1[1]);
726 if ((psend = fdopen(p0[1], "w")) == NULL)
727 syserror();
728 if ((precv = fdopen(p1[0], "r")) == NULL)
729 syserror();
730 queuesiz = 0;
731 }
732
733
734 caldone() /* done with calculation */
735 {
736 int pid;
737
738 if (childpid == -1)
739 return;
740 clearqueue();
741 fclose(psend);
742 fclose(precv);
743 while ((pid = wait(0)) != -1 && pid != childpid)
744 ;
745 childpid = -1;
746 }
747
748
749 rcalfill(x, y) /* fill with ray-calculated pixel */
750 int x, y;
751 {
752 if (queuesiz >= PACKSIZ) /* flush queue if needed */
753 clearqueue();
754 /* add position to queue */
755 queue[queuesiz][0] = x;
756 queue[queuesiz][1] = y;
757 queuesiz++;
758 }
759
760
761 clearqueue() /* process queue */
762 {
763 FVECT orig, dir;
764 float fbuf[6];
765 register int i;
766
767 for (i = 0; i < queuesiz; i++) {
768 viewray(orig, dir, &ourview,
769 (queue[i][0]+.5)/hresolu,
770 (queue[i][1]+.5)/vresolu);
771 fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2];
772 fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2];
773 fwrite((char *)fbuf, sizeof(float), 6, psend);
774 }
775 /* flush output and get results */
776 fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */
777 fwrite((char *)fbuf, sizeof(float), 6, psend);
778 if (fflush(psend) == EOF)
779 syserror();
780 for (i = 0; i < queuesiz; i++) {
781 if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) {
782 fprintf(stderr, "%s: read error in clearqueue\n",
783 progname);
784 exit(1);
785 }
786 if (ourexp > 0 && ourexp != 1.0) {
787 fbuf[0] *= ourexp;
788 fbuf[1] *= ourexp;
789 fbuf[2] *= ourexp;
790 }
791 setcolr(pscan(queue[i][1])[queue[i][0]],
792 fbuf[0], fbuf[1], fbuf[2]);
793 zscan(queue[i][1])[queue[i][0]] = fbuf[3];
794 }
795 queuesiz = 0;
796 }
797
798
799 syserror() /* report error and exit */
800 {
801 perror(progname);
802 exit(1);
803 }
