root/radiance/ray/src/px/pinterp.c
Revision: 1.34
Committed: Mon Nov 11 14:01:57 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.33: +20 -17 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <fcntl.h>
16
17 #include "view.h"
18
19 #include "color.h"
20
21 #include "resolu.h"
22
23 #ifndef BSD
24 #define vfork fork
25 #endif
26
27 #define pscan(y) (ourpict+(y)*hresolu)
28 #define zscan(y) (ourzbuf+(y)*hresolu)
29
30 #define F_FORE 1 /* fill foreground */
31 #define F_BACK 2 /* fill background */
32
33 #define PACKSIZ 42 /* calculation packet size */
34
35 #define RTCOM "rtrace -h -ovl -fff %s"
36
37 #define ABS(x) ((x)>0?(x):-(x))
38
39 struct position {int x,y; float z;};
40
41 VIEW ourview = STDVIEW; /* desired view */
42 int hresolu = 512; /* horizontal resolution */
43 int vresolu = 512; /* vertical resolution */
44 double pixaspect = 1.0; /* pixel aspect ratio */
45
46 double zeps = .02; /* allowed z epsilon */
47
48 COLR *ourpict; /* output picture */
49 float *ourzbuf; /* corresponding z-buffer */
50
51 char *progname;
52
53 int fillo = F_FORE|F_BACK; /* selected fill options */
54 int fillsamp = 0; /* sample separation (0 == inf) */
55 extern int backfill(), rcalfill(); /* fill functions */
56 int (*fillfunc)() = backfill; /* selected fill function */
57 COLR backcolr = BLKCOLR; /* background color */
58 double backz = 0.0; /* background z value */
59 int normdist = 1; /* normalized distance? */
60 double ourexp = -1; /* output picture exposure */
61
62 VIEW theirview = STDVIEW; /* input view */
63 int gotview; /* got input view? */
64 int wrongformat = 0; /* input in another format? */
65 RESOLU tresolu; /* input resolution */
66 double theirexp; /* input picture exposure */
67 double theirs2ours[4][4]; /* transformation matrix */
68 int hasmatrix = 0; /* has transformation matrix */
69
70 int childpid = -1; /* id of fill process */
71 FILE *psend, *precv; /* pipes to/from fill calculation */
72 int queue[PACKSIZ][2]; /* pending pixels */
73 int queuesiz; /* number of pixels pending */
74
75
76 main(argc, argv) /* interpolate pictures */
77 int argc;
78 char *argv[];
79 {
80 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
81 extern double atof();
82 int gotvfile = 0;
83 char *zfile = NULL;
84 char *err;
85 int i, rval;
86
87 progname = argv[0];
88
89 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
90 rval = getviewopt(&ourview, argc-i, argv+i);
91 if (rval >= 0) {
92 i += rval;
93 continue;
94 }
95 switch (argv[i][1]) {
96 case 't': /* threshold */
97 check(2,1);
98 zeps = atof(argv[++i]);
99 break;
100 case 'n': /* dist. normalized? */
101 check(2,0);
102 normdist = !normdist;
103 break;
104 case 'f': /* fill type */
105 switch (argv[i][2]) {
106 case '0': /* none */
107 check(3,0);
108 fillo = 0;
109 break;
110 case 'f': /* foreground */
111 check(3,0);
112 fillo = F_FORE;
113 break;
114 case 'b': /* background */
115 check(3,0);
116 fillo = F_BACK;
117 break;
118 case 'a': /* all */
119 check(3,0);
120 fillo = F_FORE|F_BACK;
121 break;
122 case 's': /* sample */
123 check(3,1);
124 fillsamp = atoi(argv[++i]);
125 break;
126 case 'c': /* color */
127 check(3,3);
128 fillfunc = backfill;
129 setcolr(backcolr, atof(argv[i+1]),
130 atof(argv[i+2]), atof(argv[i+3]));
131 i += 3;
132 break;
133 case 'z': /* z value */
134 check(3,1);
135 fillfunc = backfill;
136 backz = atof(argv[++i]);
137 break;
138 case 'r': /* rtrace */
139 check(3,1);
140 fillfunc = rcalfill;
141 calstart(RTCOM, argv[++i]);
142 break;
143 default:
144 goto badopt;
145 }
146 break;
147 case 'z': /* z file */
148 check(2,1);
149 zfile = argv[++i];
150 break;
151 case 'x': /* x resolution */
152 check(2,1);
153 hresolu = atoi(argv[++i]);
154 break;
155 case 'y': /* y resolution */
156 check(2,1);
157 vresolu = atoi(argv[++i]);
158 break;
159 case 'p': /* pixel aspect */
160 check(2,1);
161 pixaspect = atof(argv[++i]);
162 break;
163 case 'v': /* view file */
164 if (argv[i][2] != 'f')
165 goto badopt;
166 check(3,1);
167 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
168 if (gotvfile < 0) {
169 perror(argv[i]);
170 exit(1);
171 } else if (gotvfile == 0) {
172 fprintf(stderr, "%s: bad view file\n",
173 argv[i]);
174 exit(1);
175 }
176 break;
177 default:
178 badopt:
179 fprintf(stderr, "%s: command line error at '%s'\n",
180 progname, argv[i]);
181 goto userr;
182 }
183 }
184 /* check arguments */
185 if ((argc-i)%2)
186 goto userr;
187 /* set view */
188 if (err = setview(&ourview)) {
189 fprintf(stderr, "%s: %s\n", progname, err);
190 exit(1);
191 }
192 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
193 /* allocate frame */
194 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
195 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
196 if (ourpict == NULL || ourzbuf == NULL)
197 syserror();
198 /* get input */
199 for ( ; i < argc; i += 2)
200 addpicture(argv[i], argv[i+1]);
201 /* fill in spaces */
202 if (fillo&F_BACK)
203 backpicture(fillfunc, fillsamp);
204 else
205 fillpicture(fillfunc);
206 /* close calculation */
207 caldone();
208 /* add to header */
209 printargs(argc, argv, stdout);
210 if (gotvfile) {
211 fputs(VIEWSTR, stdout);
212 fprintview(&ourview, stdout);
213 putc('\n', stdout);
214 }
215 if (pixaspect < .99 || pixaspect > 1.01)
216 fputaspect(pixaspect, stdout);
217 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
218 fputexpos(ourexp, stdout);
219 fputformat(COLRFMT, stdout);
220 putc('\n', stdout);
221 /* write picture */
222 writepicture();
223 /* write z file */
224 if (zfile != NULL)
225 writedistance(zfile);
226
227 exit(0);
228 userr:
229 fprintf(stderr,
230 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
231 progname);
232 exit(1);
233 #undef check
234 }
235
236
237 headline(s) /* process header string */
238 char *s;
239 {
240 static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL};
241 register char **an;
242 char fmt[32];
243
244 if (isformat(s)) {
245 formatval(fmt, s);
246 wrongformat = strcmp(fmt, COLRFMT);
247 return;
248 }
249 putc('\t', stdout);
250 fputs(s, stdout);
251
252 if (isexpos(s)) {
253 theirexp *= exposval(s);
254 return;
255 }
256 for (an = altname; *an != NULL; an++)
257 if (!strncmp(*an, s, strlen(*an))) {
258 if (sscanview(&theirview, s+strlen(*an)) > 0)
259 gotview++;
260 break;
261 }
262 }
263
264
265 addpicture(pfile, zspec) /* add picture to output */
266 char *pfile, *zspec;
267 {
268 extern double atof();
269 FILE *pfp;
270 int zfd;
271 char *err;
272 COLR *scanin;
273 float *zin;
274 struct position *plast;
275 int y;
276 /* open picture file */
277 if ((pfp = fopen(pfile, "r")) == NULL) {
278 perror(pfile);
279 exit(1);
280 }
281 /* get header with exposure and view */
282 theirexp = 1.0;
283 gotview = 0;
284 printf("%s:\n", pfile);
285 getheader(pfp, headline, NULL);
286 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
287 fprintf(stderr, "%s: picture format error\n", pfile);
288 exit(1);
289 }
290 if (ourexp <= 0)
291 ourexp = theirexp;
292 else if (ABS(theirexp-ourexp) > .01*ourexp)
293 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
294 if (err = setview(&theirview)) {
295 fprintf(stderr, "%s: %s\n", pfile, err);
296 exit(1);
297 }
298 /* compute transformation */
299 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
300 /* allocate scanlines */
301 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
302 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
303 plast = (struct position *)calloc(scanlen(&tresolu),
304 sizeof(struct position));
305 if (scanin == NULL || zin == NULL || plast == NULL)
306 syserror();
307 /* get z specification or file */
308 if ((zfd = open(zspec, O_RDONLY)) == -1) {
309 double zvalue;
310 register int x;
311 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
312 perror(zspec);
313 exit(1);
314 }
315 for (x = scanlen(&tresolu); x-- > 0; )
316 zin[x] = zvalue;
317 }
318 /* load image */
319 for (y = 0; y < numscans(&tresolu); y++) {
320 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
321 fprintf(stderr, "%s: read error\n", pfile);
322 exit(1);
323 }
324 if (zfd != -1 && read(zfd,(char *)zin,
325 scanlen(&tresolu)*sizeof(float))
326 < scanlen(&tresolu)*sizeof(float)) {
327 fprintf(stderr, "%s: read error\n", zspec);
328 exit(1);
329 }
330 addscanline(y, scanin, zin, plast);
331 }
332 /* clean up */
333 free((char *)scanin);
334 free((char *)zin);
335 free((char *)plast);
336 fclose(pfp);
337 if (zfd != -1)
338 close(zfd);
339 }
340
341
342 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
343 register double xfmat[4][4];
344 register VIEW *vw1, *vw2;
345 {
346 double m4t[4][4];
347
348 if (vw1->type != VT_PER && vw1->type != VT_PAR)
349 return(0);
350 if (vw2->type != VT_PER && vw2->type != VT_PAR)
351 return(0);
352 setident4(xfmat);
353 xfmat[0][0] = vw1->hvec[0];
354 xfmat[0][1] = vw1->hvec[1];
355 xfmat[0][2] = vw1->hvec[2];
356 xfmat[1][0] = vw1->vvec[0];
357 xfmat[1][1] = vw1->vvec[1];
358 xfmat[1][2] = vw1->vvec[2];
359 xfmat[2][0] = vw1->vdir[0];
360 xfmat[2][1] = vw1->vdir[1];
361 xfmat[2][2] = vw1->vdir[2];
362 xfmat[3][0] = vw1->vp[0];
363 xfmat[3][1] = vw1->vp[1];
364 xfmat[3][2] = vw1->vp[2];
365 setident4(m4t);
366 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
367 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
368 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
369 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
370 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
371 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
372 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
373 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
374 m4t[0][2] = vw2->vdir[0];
375 m4t[1][2] = vw2->vdir[1];
376 m4t[2][2] = vw2->vdir[2];
377 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
378 multmat4(xfmat, xfmat, m4t);
379 return(1);
380 }
381
382
383 addscanline(y, pline, zline, lasty) /* add scanline to output */
384 int y;
385 COLR *pline;
386 float *zline;
387 struct position *lasty; /* input/output */
388 {
389 extern double sqrt();
390 FVECT pos;
391 struct position lastx, newpos;
392 register int x;
393
394 lastx.z = 0;
395 for (x = scanlen(&tresolu); x-- > 0; ) {
396 pix2loc(pos, &tresolu, x, y);
397 pos[2] = zline[x];
398 if (movepixel(pos) < 0) {
399 lasty[x].z = lastx.z = 0; /* mark invalid */
400 continue;
401 }
402 newpos.x = pos[0] * hresolu;
403 newpos.y = pos[1] * vresolu;
404 newpos.z = zline[x];
405 /* add pixel to our image */
406 if (pos[0] >= 0 && newpos.x < hresolu
407 && pos[1] >= 0 && newpos.y < vresolu) {
408 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
409 lasty[x].x = lastx.x = newpos.x;
410 lasty[x].y = lastx.y = newpos.y;
411 lasty[x].z = lastx.z = newpos.z;
412 } else
413 lasty[x].z = lastx.z = 0; /* mark invalid */
414 }
415 }
416
417
418 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
419 struct position *p0, *p1, *p2;
420 COLR pix;
421 double z;
422 {
423 double zt = 2.*zeps*p0->z; /* threshold */
424 int s1x, s1y, s2x, s2y; /* step sizes */
425 int l1, l2, c1, c2; /* side lengths and counters */
426 int p1isy; /* p0p1 along y? */
427 int x1, y1; /* p1 position */
428 register int x, y; /* final position */
429
430 /* compute vector p0p1 */
431 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
432 s1x = p1->x - p0->x;
433 s1y = p1->y - p0->y;
434 l1 = ABS(s1x);
435 if (p1isy = (ABS(s1y) > l1))
436 l1 = ABS(s1y);
437 } else {
438 l1 = s1x = s1y = 1;
439 p1isy = -1;
440 }
441 /* compute vector p0p2 */
442 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
443 s2x = p2->x - p0->x;
444 s2y = p2->y - p0->y;
445 if (p1isy == 1)
446 l2 = ABS(s2x);
447 else {
448 l2 = ABS(s2y);
449 if (p1isy != 0 && ABS(s2x) > l2)
450 l2 = ABS(s2x);
451 }
452 } else
453 l2 = s2x = s2y = 1;
454 /* fill the parallelogram */
455 for (c1 = l1; c1-- > 0; ) {
456 x1 = p0->x + c1*s1x/l1;
457 y1 = p0->y + c1*s1y/l1;
458 for (c2 = l2; c2-- > 0; ) {
459 x = x1 + c2*s2x/l2;
460 if (x < 0 || x >= hresolu)
461 continue;
462 y = y1 + c2*s2y/l2;
463 if (y < 0 || y >= vresolu)
464 continue;
465 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
466 > zeps*zscan(y)[x]) {
467 zscan(y)[x] = z;
468 copycolr(pscan(y)[x], pix);
469 }
470 }
471 }
472 }
473
474
475 movepixel(pos) /* reposition image point */
476 FVECT pos;
477 {
478 FVECT pt, direc;
479
480 if (pos[2] <= 0) /* empty pixel */
481 return(-1);
482 if (hasmatrix) {
483 pos[0] += theirview.hoff - .5;
484 pos[1] += theirview.voff - .5;
485 if (theirview.type == VT_PER) {
486 if (normdist) /* adjust for eye-ray distance */
487 pos[2] /= sqrt( 1.
488 + pos[0]*pos[0]*theirview.hn2
489 + pos[1]*pos[1]*theirview.vn2 );
490 pos[0] *= pos[2];
491 pos[1] *= pos[2];
492 }
493 multp3(pos, pos, theirs2ours);
494 if (pos[2] <= 0)
495 return(-1);
496 if (ourview.type == VT_PER) {
497 pos[0] /= pos[2];
498 pos[1] /= pos[2];
499 }
500 pos[0] += .5 - ourview.hoff;
501 pos[1] += .5 - ourview.voff;
502 return(0);
503 }
504 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
505 return(-1);
506 pt[0] += direc[0]*pos[2];
507 pt[1] += direc[1]*pos[2];
508 pt[2] += direc[2]*pos[2];
509 viewloc(pos, &ourview, pt);
510 if (pos[2] <= 0)
511 return(-1);
512 return(0);
513 }
514
515
516 backpicture(fill, samp) /* background fill algorithm */
517 int (*fill)();
518 int samp;
519 {
520 int *yback, xback;
521 int y;
522 register int x, i;
523 /* get back buffer */
524 yback = (int *)malloc(hresolu*sizeof(int));
525 if (yback == NULL)
526 syserror();
527 for (x = 0; x < hresolu; x++)
528 yback[x] = -2;
529 /*
530 * Xback and yback are the pixel locations of suitable
531 * background values in each direction.
532 * A value of -2 means unassigned, and -1 means
533 * that there is no suitable background in this direction.
534 */
535 /* fill image */
536 for (y = 0; y < vresolu; y++) {
537 xback = -2;
538 for (x = 0; x < hresolu; x++)
539 if (zscan(y)[x] <= 0) { /* empty pixel */
540 /*
541 * First, find background from above or below.
542 * (farthest assigned pixel)
543 */
544 if (yback[x] == -2) {
545 for (i = y+1; i < vresolu; i++)
546 if (zscan(i)[x] > 0)
547 break;
548 if (i < vresolu
549 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
550 yback[x] = i;
551 else
552 yback[x] = y-1;
553 }
554 /*
555 * Next, find background from left or right.
556 */
557 if (xback == -2) {
558 for (i = x+1; i < hresolu; i++)
559 if (zscan(y)[i] > 0)
560 break;
561 if (i < hresolu
562 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
563 xback = i;
564 else
565 xback = x-1;
566 }
567 /*
568 * If we have no background for this pixel,
569 * use the given fill function.
570 */
571 if (xback < 0 && yback[x] < 0)
572 goto fillit;
573 /*
574 * Compare, and use the background that is
575 * farther, unless one of them is next to us.
576 * If the background is too distant, call
577 * the fill function.
578 */
579 if ( yback[x] < 0
580 || (xback >= 0 && ABS(x-xback) <= 1)
581 || ( ABS(y-yback[x]) > 1
582 && zscan(yback[x])[x]
583 < zscan(y)[xback] ) ) {
584 if (samp > 0 && ABS(x-xback) >= samp)
585 goto fillit;
586 copycolr(pscan(y)[x],pscan(y)[xback]);
587 zscan(y)[x] = zscan(y)[xback];
588 } else {
589 if (samp > 0 && ABS(y-yback[x]) > samp)
590 goto fillit;
591 copycolr(pscan(y)[x],pscan(yback[x])[x]);
592 zscan(y)[x] = zscan(yback[x])[x];
593 }
594 continue;
595 fillit:
596 (*fill)(x,y);
597 if (fill == rcalfill) { /* use it */
598 clearqueue();
599 xback = x;
600 yback[x] = y;
601 }
602 } else { /* full pixel */
603 yback[x] = -2;
604 xback = -2;
605 }
606 }
607 free((char *)yback);
608 }
609
610
611 fillpicture(fill) /* paint in empty pixels using fill */
612 int (*fill)();
613 {
614 register int x, y;
615
616 for (y = 0; y < vresolu; y++)
617 for (x = 0; x < hresolu; x++)
618 if (zscan(y)[x] <= 0)
619 (*fill)(x,y);
620 }
621
622
623 writepicture() /* write out picture */
624 {
625 int y;
626
627 fprtresolu(hresolu, vresolu, stdout);
628 for (y = vresolu-1; y >= 0; y--)
629 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
630 syserror();
631 }
632
633
634 writedistance(fname) /* write out z file */
635 char *fname;
636 {
637 extern double sqrt();
638 int donorm = normdist && ourview.type == VT_PER;
639 int fd;
640 int y;
641 float *zout;
642
643 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
644 perror(fname);
645 exit(1);
646 }
647 if (donorm
648 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
649 syserror();
650 for (y = vresolu-1; y >= 0; y--) {
651 if (donorm) {
652 double vx, yzn2;
653 register int x;
654 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
655 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
656 for (x = 0; x < hresolu; x++) {
657 vx = (x+.5)/hresolu + ourview.hoff - .5;
658 zout[x] = zscan(y)[x]
659 * sqrt(vx*vx*ourview.hn2 + yzn2);
660 }
661 } else
662 zout = zscan(y);
663 if (write(fd, (char *)zout, hresolu*sizeof(float))
664 < hresolu*sizeof(float)) {
665 perror(fname);
666 exit(1);
667 }
668 }
669 if (donorm)
670 free((char *)zout);
671 close(fd);
672 }
673
674
675 isfloat(s) /* see if string is floating number */
676 register char *s;
677 {
678 for ( ; *s; s++)
679 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
680 && *s != 'e' && *s != 'E' && *s != '+')
681 return(0);
682 return(1);
683 }
684
685
686 backfill(x, y) /* fill pixel with background */
687 int x, y;
688 {
689 register BYTE *dest = pscan(y)[x];
690
691 copycolr(dest, backcolr);
692 zscan(y)[x] = backz;
693 }
694
695
696 calstart(prog, args) /* start fill calculation */
697 char *prog, *args;
698 {
699 char combuf[512];
700 int p0[2], p1[2];
701
702 if (childpid != -1) {
703 fprintf(stderr, "%s: too many calculations\n", progname);
704 exit(1);
705 }
706 sprintf(combuf, prog, args);
707 if (pipe(p0) < 0 || pipe(p1) < 0)
708 syserror();
709 if ((childpid = vfork()) == 0) { /* fork calculation */
710 close(p0[1]);
711 close(p1[0]);
712 if (p0[0] != 0) {
713 dup2(p0[0], 0);
714 close(p0[0]);
715 }
716 if (p1[1] != 1) {
717 dup2(p1[1], 1);
718 close(p1[1]);
719 }
720 execl("/bin/sh", "sh", "-c", combuf, 0);
721 perror("/bin/sh");
722 _exit(127);
723 }
724 if (childpid == -1)
725 syserror();
726 close(p0[0]);
727 close(p1[1]);
728 if ((psend = fdopen(p0[1], "w")) == NULL)
729 syserror();
730 if ((precv = fdopen(p1[0], "r")) == NULL)
731 syserror();
732 queuesiz = 0;
733 }
734
735
736 caldone() /* done with calculation */
737 {
738 int pid;
739
740 if (childpid == -1)
741 return;
742 clearqueue();
743 fclose(psend);
744 fclose(precv);
745 while ((pid = wait(0)) != -1 && pid != childpid)
746 ;
747 childpid = -1;
748 }
749
750
751 rcalfill(x, y) /* fill with ray-calculated pixel */
752 int x, y;
753 {
754 if (queuesiz >= PACKSIZ) /* flush queue if needed */
755 clearqueue();
756 /* add position to queue */
757 queue[queuesiz][0] = x;
758 queue[queuesiz][1] = y;
759 queuesiz++;
760 }
761
762
763 clearqueue() /* process queue */
764 {
765 FVECT orig, dir;
766 float fbuf[6];
767 register int i;
768
769 for (i = 0; i < queuesiz; i++) {
770 viewray(orig, dir, &ourview,
771 (queue[i][0]+.5)/hresolu,
772 (queue[i][1]+.5)/vresolu);
773 fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2];
774 fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2];
775 fwrite((char *)fbuf, sizeof(float), 6, psend);
776 }
777 /* flush output and get results */
778 fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */
779 fwrite((char *)fbuf, sizeof(float), 6, psend);
780 if (fflush(psend) == EOF)
781 syserror();
782 for (i = 0; i < queuesiz; i++) {
783 if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) {
784 fprintf(stderr, "%s: read error in clearqueue\n",
785 progname);
786 exit(1);
787 }
788 if (ourexp > 0 && ourexp != 1.0) {
789 fbuf[0] *= ourexp;
790 fbuf[1] *= ourexp;
791 fbuf[2] *= ourexp;
792 }
793 setcolr(pscan(queue[i][1])[queue[i][0]],
794 fbuf[0], fbuf[1], fbuf[2]);
795 zscan(queue[i][1])[queue[i][0]] = fbuf[3];
796 }
797 queuesiz = 0;
798 }
799
800
801 syserror() /* report error and exit */
802 {
803 perror(progname);
804 exit(1);
805 }
