root/radiance/ray/src/px/pinterp.c
Revision: 1.33
Committed: Thu Apr 18 14:35:26 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.32: +13 -4 lines
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Interpolate and extrapolate pictures with different view parameters.
7 *
8 * Greg Ward 09Dec89
9 */
10
11 #include "standard.h"
12
13 #include <fcntl.h>
14
15 #include "view.h"
16
17 #include "color.h"
18
19 #ifndef BSD
20 #define vfork fork
21 #endif
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 42 /* calculation packet size */
30
31 #define RTCOM "rtrace -h -ovl -fff %s"
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fillo = F_FORE|F_BACK; /* selected fill options */
50 int fillsamp = 0; /* sample separation (0 == inf) */
51 extern int backfill(), rcalfill(); /* fill functions */
52 int (*fillfunc)() = backfill; /* selected fill function */
53 COLR backcolr = BLKCOLR; /* background color */
54 double backz = 0.0; /* background z value */
55 int normdist = 1; /* normalized distance? */
56 double ourexp = -1; /* output picture exposure */
57
58 VIEW theirview = STDVIEW; /* input view */
59 int gotview; /* got input view? */
60 int wrongformat = 0; /* input in another format? */
61 int thresolu, tvresolu; /* input resolution */
62 double theirexp; /* input picture exposure */
63 double theirs2ours[4][4]; /* transformation matrix */
64 int hasmatrix = 0; /* has transformation matrix */
65
66 int childpid = -1; /* id of fill process */
67 FILE *psend, *precv; /* pipes to/from fill calculation */
68 int queue[PACKSIZ][2]; /* pending pixels */
69 int queuesiz; /* number of pixels pending */
70
71
72 main(argc, argv) /* interpolate pictures */
73 int argc;
74 char *argv[];
75 {
76 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
77 extern double atof();
78 int gotvfile = 0;
79 char *zfile = NULL;
80 char *err;
81 int i, rval;
82
83 progname = argv[0];
84
85 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
86 rval = getviewopt(&ourview, argc-i, argv+i);
87 if (rval >= 0) {
88 i += rval;
89 continue;
90 }
91 switch (argv[i][1]) {
92 case 't': /* threshold */
93 check(2,1);
94 zeps = atof(argv[++i]);
95 break;
96 case 'n': /* dist. normalized? */
97 check(2,0);
98 normdist = !normdist;
99 break;
100 case 'f': /* fill type */
101 switch (argv[i][2]) {
102 case '0': /* none */
103 check(3,0);
104 fillo = 0;
105 break;
106 case 'f': /* foreground */
107 check(3,0);
108 fillo = F_FORE;
109 break;
110 case 'b': /* background */
111 check(3,0);
112 fillo = F_BACK;
113 break;
114 case 'a': /* all */
115 check(3,0);
116 fillo = F_FORE|F_BACK;
117 break;
118 case 's': /* sample */
119 check(3,1);
120 fillsamp = atoi(argv[++i]);
121 break;
122 case 'c': /* color */
123 check(3,3);
124 fillfunc = backfill;
125 setcolr(backcolr, atof(argv[i+1]),
126 atof(argv[i+2]), atof(argv[i+3]));
127 i += 3;
128 break;
129 case 'z': /* z value */
130 check(3,1);
131 fillfunc = backfill;
132 backz = atof(argv[++i]);
133 break;
134 case 'r': /* rtrace */
135 check(3,1);
136 fillfunc = rcalfill;
137 calstart(RTCOM, argv[++i]);
138 break;
139 default:
140 goto badopt;
141 }
142 break;
143 case 'z': /* z file */
144 check(2,1);
145 zfile = argv[++i];
146 break;
147 case 'x': /* x resolution */
148 check(2,1);
149 hresolu = atoi(argv[++i]);
150 break;
151 case 'y': /* y resolution */
152 check(2,1);
153 vresolu = atoi(argv[++i]);
154 break;
155 case 'p': /* pixel aspect */
156 check(2,1);
157 pixaspect = atof(argv[++i]);
158 break;
159 case 'v': /* view file */
160 if (argv[i][2] != 'f')
161 goto badopt;
162 check(3,1);
163 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
164 if (gotvfile < 0) {
165 perror(argv[i]);
166 exit(1);
167 } else if (gotvfile == 0) {
168 fprintf(stderr, "%s: bad view file\n",
169 argv[i]);
170 exit(1);
171 }
172 break;
173 default:
174 badopt:
175 fprintf(stderr, "%s: command line error at '%s'\n",
176 progname, argv[i]);
177 goto userr;
178 }
179 }
180 /* check arguments */
181 if ((argc-i)%2)
182 goto userr;
183 /* set view */
184 if (err = setview(&ourview)) {
185 fprintf(stderr, "%s: %s\n", progname, err);
186 exit(1);
187 }
188 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
189 /* allocate frame */
190 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
191 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
192 if (ourpict == NULL || ourzbuf == NULL)
193 syserror();
194 /* get input */
195 for ( ; i < argc; i += 2)
196 addpicture(argv[i], argv[i+1]);
197 /* fill in spaces */
198 if (fillo&F_BACK)
199 backpicture(fillfunc, fillsamp);
200 else
201 fillpicture(fillfunc);
202 /* close calculation */
203 caldone();
204 /* add to header */
205 printargs(argc, argv, stdout);
206 if (gotvfile) {
207 fputs(VIEWSTR, stdout);
208 fprintview(&ourview, stdout);
209 putc('\n', stdout);
210 }
211 if (pixaspect < .99 || pixaspect > 1.01)
212 fputaspect(pixaspect, stdout);
213 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
214 fputexpos(ourexp, stdout);
215 fputformat(COLRFMT, stdout);
216 putc('\n', stdout);
217 /* write picture */
218 writepicture();
219 /* write z file */
220 if (zfile != NULL)
221 writedistance(zfile);
222
223 exit(0);
224 userr:
225 fprintf(stderr,
226 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
227 progname);
228 exit(1);
229 #undef check
230 }
231
232
233 headline(s) /* process header string */
234 char *s;
235 {
236 static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL};
237 register char **an;
238 char fmt[32];
239
240 if (isformat(s)) {
241 formatval(fmt, s);
242 wrongformat = strcmp(fmt, COLRFMT);
243 return;
244 }
245 putc('\t', stdout);
246 fputs(s, stdout);
247
248 if (isexpos(s)) {
249 theirexp *= exposval(s);
250 return;
251 }
252 for (an = altname; *an != NULL; an++)
253 if (!strncmp(*an, s, strlen(*an))) {
254 if (sscanview(&theirview, s+strlen(*an)) > 0)
255 gotview++;
256 break;
257 }
258 }
259
260
261 addpicture(pfile, zspec) /* add picture to output */
262 char *pfile, *zspec;
263 {
264 extern double atof();
265 FILE *pfp;
266 int zfd;
267 char *err;
268 COLR *scanin;
269 float *zin;
270 struct position *plast;
271 int y;
272 /* open picture file */
273 if ((pfp = fopen(pfile, "r")) == NULL) {
274 perror(pfile);
275 exit(1);
276 }
277 /* get header with exposure and view */
278 theirexp = 1.0;
279 gotview = 0;
280 printf("%s:\n", pfile);
281 getheader(pfp, headline, NULL);
282 if (wrongformat || !gotview ||
283 fgetresolu(&thresolu, &tvresolu, pfp) != (YMAJOR|YDECR)) {
284
285 fprintf(stderr, "%s: picture format error\n", pfile);
286 exit(1);
287 }
288 if (ourexp <= 0)
289 ourexp = theirexp;
290 else if (ABS(theirexp-ourexp) > .01*ourexp)
291 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
292 if (err = setview(&theirview)) {
293 fprintf(stderr, "%s: %s\n", pfile, err);
294 exit(1);
295 }
296 /* compute transformation */
297 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
298 /* allocate scanlines */
299 scanin = (COLR *)malloc(thresolu*sizeof(COLR));
300 zin = (float *)malloc(thresolu*sizeof(float));
301 plast = (struct position *)calloc(thresolu, sizeof(struct position));
302 if (scanin == NULL || zin == NULL || plast == NULL)
303 syserror();
304 /* get z specification or file */
305 if ((zfd = open(zspec, O_RDONLY)) == -1) {
306 double zvalue;
307 register int x;
308 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
309 perror(zspec);
310 exit(1);
311 }
312 for (x = 0; x < thresolu; x++)
313 zin[x] = zvalue;
314 }
315 /* load image */
316 for (y = tvresolu-1; y >= 0; y--) {
317 if (freadcolrs(scanin, thresolu, pfp) < 0) {
318 fprintf(stderr, "%s: read error\n", pfile);
319 exit(1);
320 }
321 if (zfd != -1 && read(zfd,(char *)zin,thresolu*sizeof(float))
322 < thresolu*sizeof(float)) {
323 fprintf(stderr, "%s: read error\n", zspec);
324 exit(1);
325 }
326 addscanline(y, scanin, zin, plast);
327 }
328 /* clean up */
329 free((char *)scanin);
330 free((char *)zin);
331 free((char *)plast);
332 fclose(pfp);
333 if (zfd != -1)
334 close(zfd);
335 }
336
337
338 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
339 register double xfmat[4][4];
340 register VIEW *vw1, *vw2;
341 {
342 double m4t[4][4];
343
344 if (vw1->type != VT_PER && vw1->type != VT_PAR)
345 return(0);
346 if (vw2->type != VT_PER && vw2->type != VT_PAR)
347 return(0);
348 setident4(xfmat);
349 xfmat[0][0] = vw1->hvec[0];
350 xfmat[0][1] = vw1->hvec[1];
351 xfmat[0][2] = vw1->hvec[2];
352 xfmat[1][0] = vw1->vvec[0];
353 xfmat[1][1] = vw1->vvec[1];
354 xfmat[1][2] = vw1->vvec[2];
355 xfmat[2][0] = vw1->vdir[0];
356 xfmat[2][1] = vw1->vdir[1];
357 xfmat[2][2] = vw1->vdir[2];
358 xfmat[3][0] = vw1->vp[0];
359 xfmat[3][1] = vw1->vp[1];
360 xfmat[3][2] = vw1->vp[2];
361 setident4(m4t);
362 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
363 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
364 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
365 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
366 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
367 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
368 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
369 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
370 m4t[0][2] = vw2->vdir[0];
371 m4t[1][2] = vw2->vdir[1];
372 m4t[2][2] = vw2->vdir[2];
373 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
374 multmat4(xfmat, xfmat, m4t);
375 return(1);
376 }
377
378
379 addscanline(y, pline, zline, lasty) /* add scanline to output */
380 int y;
381 COLR *pline;
382 float *zline;
383 struct position *lasty; /* input/output */
384 {
385 extern double sqrt();
386 FVECT pos;
387 struct position lastx, newpos;
388 register int x;
389
390 lastx.z = 0;
391 for (x = thresolu-1; x >= 0; x--) {
392 pos[0] = (x+.5)/thresolu;
393 pos[1] = (y+.5)/tvresolu;
394 pos[2] = zline[x];
395 if (movepixel(pos) < 0) {
396 lasty[x].z = lastx.z = 0; /* mark invalid */
397 continue;
398 }
399 newpos.x = pos[0] * hresolu;
400 newpos.y = pos[1] * vresolu;
401 newpos.z = zline[x];
402 /* add pixel to our image */
403 if (pos[0] >= 0 && newpos.x < hresolu
404 && pos[1] >= 0 && newpos.y < vresolu) {
405 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
406 lasty[x].x = lastx.x = newpos.x;
407 lasty[x].y = lastx.y = newpos.y;
408 lasty[x].z = lastx.z = newpos.z;
409 } else
410 lasty[x].z = lastx.z = 0; /* mark invalid */
411 }
412 }
413
414
415 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
416 struct position *p0, *p1, *p2;
417 COLR pix;
418 double z;
419 {
420 double zt = 2.*zeps*p0->z; /* threshold */
421 int s1x, s1y, s2x, s2y; /* step sizes */
422 int l1, l2, c1, c2; /* side lengths and counters */
423 int p1isy; /* p0p1 along y? */
424 int x1, y1; /* p1 position */
425 register int x, y; /* final position */
426
427 /* compute vector p0p1 */
428 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
429 s1x = p1->x - p0->x;
430 s1y = p1->y - p0->y;
431 l1 = ABS(s1x);
432 if (p1isy = (ABS(s1y) > l1))
433 l1 = ABS(s1y);
434 } else {
435 l1 = s1x = s1y = 1;
436 p1isy = -1;
437 }
438 /* compute vector p0p2 */
439 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
440 s2x = p2->x - p0->x;
441 s2y = p2->y - p0->y;
442 if (p1isy == 1)
443 l2 = ABS(s2x);
444 else {
445 l2 = ABS(s2y);
446 if (p1isy != 0 && ABS(s2x) > l2)
447 l2 = ABS(s2x);
448 }
449 } else
450 l2 = s2x = s2y = 1;
451 /* fill the parallelogram */
452 for (c1 = l1; c1-- > 0; ) {
453 x1 = p0->x + c1*s1x/l1;
454 y1 = p0->y + c1*s1y/l1;
455 for (c2 = l2; c2-- > 0; ) {
456 x = x1 + c2*s2x/l2;
457 if (x < 0 || x >= hresolu)
458 continue;
459 y = y1 + c2*s2y/l2;
460 if (y < 0 || y >= vresolu)
461 continue;
462 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
463 > zeps*zscan(y)[x]) {
464 zscan(y)[x] = z;
465 copycolr(pscan(y)[x], pix);
466 }
467 }
468 }
469 }
470
471
472 movepixel(pos) /* reposition image point */
473 FVECT pos;
474 {
475 FVECT pt, direc;
476
477 if (pos[2] <= 0) /* empty pixel */
478 return(-1);
479 if (hasmatrix) {
480 pos[0] += theirview.hoff - .5;
481 pos[1] += theirview.voff - .5;
482 if (theirview.type == VT_PER) {
483 if (normdist) /* adjust for eye-ray distance */
484 pos[2] /= sqrt( 1.
485 + pos[0]*pos[0]*theirview.hn2
486 + pos[1]*pos[1]*theirview.vn2 );
487 pos[0] *= pos[2];
488 pos[1] *= pos[2];
489 }
490 multp3(pos, pos, theirs2ours);
491 if (pos[2] <= 0)
492 return(-1);
493 if (ourview.type == VT_PER) {
494 pos[0] /= pos[2];
495 pos[1] /= pos[2];
496 }
497 pos[0] += .5 - ourview.hoff;
498 pos[1] += .5 - ourview.voff;
499 return(0);
500 }
501 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
502 return(-1);
503 pt[0] += direc[0]*pos[2];
504 pt[1] += direc[1]*pos[2];
505 pt[2] += direc[2]*pos[2];
506 viewpixel(&pos[0], &pos[1], &pos[2], &ourview, pt);
507 if (pos[2] <= 0)
508 return(-1);
509 return(0);
510 }
511
512
513 backpicture(fill, samp) /* background fill algorithm */
514 int (*fill)();
515 int samp;
516 {
517 int *yback, xback;
518 int y;
519 register int x, i;
520 /* get back buffer */
521 yback = (int *)malloc(hresolu*sizeof(int));
522 if (yback == NULL)
523 syserror();
524 for (x = 0; x < hresolu; x++)
525 yback[x] = -2;
526 /*
527 * Xback and yback are the pixel locations of suitable
528 * background values in each direction.
529 * A value of -2 means unassigned, and -1 means
530 * that there is no suitable background in this direction.
531 */
532 /* fill image */
533 for (y = 0; y < vresolu; y++) {
534 xback = -2;
535 for (x = 0; x < hresolu; x++)
536 if (zscan(y)[x] <= 0) { /* empty pixel */
537 /*
538 * First, find background from above or below.
539 * (farthest assigned pixel)
540 */
541 if (yback[x] == -2) {
542 for (i = y+1; i < vresolu; i++)
543 if (zscan(i)[x] > 0)
544 break;
545 if (i < vresolu
546 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
547 yback[x] = i;
548 else
549 yback[x] = y-1;
550 }
551 /*
552 * Next, find background from left or right.
553 */
554 if (xback == -2) {
555 for (i = x+1; i < hresolu; i++)
556 if (zscan(y)[i] > 0)
557 break;
558 if (i < hresolu
559 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
560 xback = i;
561 else
562 xback = x-1;
563 }
564 /*
565 * If we have no background for this pixel,
566 * use the given fill function.
567 */
568 if (xback < 0 && yback[x] < 0)
569 goto fillit;
570 /*
571 * Compare, and use the background that is
572 * farther, unless one of them is next to us.
573 * If the background is too distant, call
574 * the fill function.
575 */
576 if ( yback[x] < 0
577 || (xback >= 0 && ABS(x-xback) <= 1)
578 || ( ABS(y-yback[x]) > 1
579 && zscan(yback[x])[x]
580 < zscan(y)[xback] ) ) {
581 if (samp > 0 && ABS(x-xback) >= samp)
582 goto fillit;
583 copycolr(pscan(y)[x],pscan(y)[xback]);
584 zscan(y)[x] = zscan(y)[xback];
585 } else {
586 if (samp > 0 && ABS(y-yback[x]) > samp)
587 goto fillit;
588 copycolr(pscan(y)[x],pscan(yback[x])[x]);
589 zscan(y)[x] = zscan(yback[x])[x];
590 }
591 continue;
592 fillit:
593 (*fill)(x,y);
594 if (fill == rcalfill) { /* use it */
595 clearqueue();
596 xback = x;
597 yback[x] = y;
598 }
599 } else { /* full pixel */
600 yback[x] = -2;
601 xback = -2;
602 }
603 }
604 free((char *)yback);
605 }
606
607
608 fillpicture(fill) /* paint in empty pixels using fill */
609 int (*fill)();
610 {
611 register int x, y;
612
613 for (y = 0; y < vresolu; y++)
614 for (x = 0; x < hresolu; x++)
615 if (zscan(y)[x] <= 0)
616 (*fill)(x,y);
617 }
618
619
620 writepicture() /* write out picture */
621 {
622 int y;
623
624 fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout);
625 for (y = vresolu-1; y >= 0; y--)
626 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
627 syserror();
628 }
629
630
631 writedistance(fname) /* write out z file */
632 char *fname;
633 {
634 extern double sqrt();
635 int donorm = normdist && ourview.type == VT_PER;
636 int fd;
637 int y;
638 float *zout;
639
640 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
641 perror(fname);
642 exit(1);
643 }
644 if (donorm
645 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
646 syserror();
647 for (y = vresolu-1; y >= 0; y--) {
648 if (donorm) {
649 double vx, yzn2;
650 register int x;
651 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
652 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
653 for (x = 0; x < hresolu; x++) {
654 vx = (x+.5)/hresolu + ourview.hoff - .5;
655 zout[x] = zscan(y)[x]
656 * sqrt(vx*vx*ourview.hn2 + yzn2);
657 }
658 } else
659 zout = zscan(y);
660 if (write(fd, (char *)zout, hresolu*sizeof(float))
661 < hresolu*sizeof(float)) {
662 perror(fname);
663 exit(1);
664 }
665 }
666 if (donorm)
667 free((char *)zout);
668 close(fd);
669 }
670
671
672 isfloat(s) /* see if string is floating number */
673 register char *s;
674 {
675 for ( ; *s; s++)
676 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
677 && *s != 'e' && *s != 'E' && *s != '+')
678 return(0);
679 return(1);
680 }
681
682
683 backfill(x, y) /* fill pixel with background */
684 int x, y;
685 {
686 register BYTE *dest = pscan(y)[x];
687
688 copycolr(dest, backcolr);
689 zscan(y)[x] = backz;
690 }
691
692
693 calstart(prog, args) /* start fill calculation */
694 char *prog, *args;
695 {
696 char combuf[512];
697 int p0[2], p1[2];
698
699 if (childpid != -1) {
700 fprintf(stderr, "%s: too many calculations\n", progname);
701 exit(1);
702 }
703 sprintf(combuf, prog, args);
704 if (pipe(p0) < 0 || pipe(p1) < 0)
705 syserror();
706 if ((childpid = vfork()) == 0) { /* fork calculation */
707 close(p0[1]);
708 close(p1[0]);
709 if (p0[0] != 0) {
710 dup2(p0[0], 0);
711 close(p0[0]);
712 }
713 if (p1[1] != 1) {
714 dup2(p1[1], 1);
715 close(p1[1]);
716 }
717 execl("/bin/sh", "sh", "-c", combuf, 0);
718 perror("/bin/sh");
719 _exit(127);
720 }
721 if (childpid == -1)
722 syserror();
723 close(p0[0]);
724 close(p1[1]);
725 if ((psend = fdopen(p0[1], "w")) == NULL)
726 syserror();
727 if ((precv = fdopen(p1[0], "r")) == NULL)
728 syserror();
729 queuesiz = 0;
730 }
731
732
733 caldone() /* done with calculation */
734 {
735 int pid;
736
737 if (childpid == -1)
738 return;
739 clearqueue();
740 fclose(psend);
741 fclose(precv);
742 while ((pid = wait(0)) != -1 && pid != childpid)
743 ;
744 childpid = -1;
745 }
746
747
748 rcalfill(x, y) /* fill with ray-calculated pixel */
749 int x, y;
750 {
751 if (queuesiz >= PACKSIZ) /* flush queue if needed */
752 clearqueue();
753 /* add position to queue */
754 queue[queuesiz][0] = x;
755 queue[queuesiz][1] = y;
756 queuesiz++;
757 }
758
759
760 clearqueue() /* process queue */
761 {
762 FVECT orig, dir;
763 float fbuf[6];
764 register int i;
765
766 for (i = 0; i < queuesiz; i++) {
767 viewray(orig, dir, &ourview,
768 (queue[i][0]+.5)/hresolu,
769 (queue[i][1]+.5)/vresolu);
770 fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2];
771 fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2];
772 fwrite((char *)fbuf, sizeof(float), 6, psend);
773 }
774 /* flush output and get results */
775 fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */
776 fwrite((char *)fbuf, sizeof(float), 6, psend);
777 if (fflush(psend) == EOF)
778 syserror();
779 for (i = 0; i < queuesiz; i++) {
780 if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) {
781 fprintf(stderr, "%s: read error in clearqueue\n",
782 progname);
783 exit(1);
784 }
785 if (ourexp > 0 && ourexp != 1.0) {
786 fbuf[0] *= ourexp;
787 fbuf[1] *= ourexp;
788 fbuf[2] *= ourexp;
789 }
790 setcolr(pscan(queue[i][1])[queue[i][0]],
791 fbuf[0], fbuf[1], fbuf[2]);
792 zscan(queue[i][1])[queue[i][0]] = fbuf[3];
793 }
794 queuesiz = 0;
795 }
796
797
798 syserror() /* report error and exit */
799 {
800 perror(progname);
801 exit(1);
802 }
