1 |
#ifndef lint |
2 |
static char SCCSid[] = "$SunId$ LBL"; |
3 |
#endif |
4 |
5 |
6 |
* Interpolate and extrapolate pictures with different view parameters. |
7 |
8 |
* Greg Ward 09Dec89 |
9 |
10 |
11 |
#include "standard.h" |
12 |
13 |
#include <sys/fcntl.h> |
14 |
15 |
#include "view.h" |
16 |
17 |
#include "color.h" |
18 |
19 |
#ifndef BSD |
20 |
#define vfork fork |
21 |
#endif |
22 |
23 |
#define pscan(y) (ourpict+(y)*hresolu) |
24 |
#define zscan(y) (ourzbuf+(y)*hresolu) |
25 |
26 |
#define F_FORE 1 /* fill foreground */ |
27 |
#define F_BACK 2 /* fill background */ |
28 |
29 |
#define PACKSIZ 42 /* calculation packet size */ |
30 |
31 |
#define RTCOM "rtrace -h -ovl -fff -x %d %s" |
32 |
33 |
#define ABS(x) ((x)>0?(x):-(x)) |
34 |
35 |
struct position {int x,y; float z;}; |
36 |
37 |
VIEW ourview = STDVIEW; /* desired view */ |
38 |
int hresolu = 512; /* horizontal resolution */ |
39 |
int vresolu = 512; /* vertical resolution */ |
40 |
double pixaspect = 1.0; /* pixel aspect ratio */ |
41 |
42 |
double zeps = .02; /* allowed z epsilon */ |
43 |
44 |
COLR *ourpict; /* output picture */ |
45 |
float *ourzbuf; /* corresponding z-buffer */ |
46 |
47 |
char *progname; |
48 |
49 |
int fill = F_FORE|F_BACK; /* selected fill algorithm */ |
50 |
extern int backfill(), rcalfill(); /* fill functions */ |
51 |
int (*deffill)() = backfill; /* selected fill function */ |
52 |
COLR backcolr = BLKCOLR; /* background color */ |
53 |
double backz = 0.0; /* background z value */ |
54 |
int normdist = 1; /* normalized distance? */ |
55 |
double ourexp = -1; /* output picture exposure */ |
56 |
57 |
VIEW theirview = STDVIEW; /* input view */ |
58 |
int gotview; /* got input view? */ |
59 |
int thresolu, tvresolu; /* input resolution */ |
60 |
double theirexp; /* input picture exposure */ |
61 |
double theirs2ours[4][4]; /* transformation matrix */ |
62 |
63 |
int childpid = -1; /* id of fill process */ |
64 |
FILE *psend, *precv; /* pipes to/from fill calculation */ |
65 |
int queue[PACKSIZ][2]; /* pending pixels */ |
66 |
int queuesiz; /* number of pixels pending */ |
67 |
68 |
69 |
main(argc, argv) /* interpolate pictures */ |
70 |
int argc; |
71 |
char *argv[]; |
72 |
73 |
#define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt |
74 |
extern double atof(); |
75 |
int gotvfile = 0; |
76 |
char *zfile = NULL; |
77 |
char *err; |
78 |
int i, rval; |
79 |
80 |
progname = argv[0]; |
81 |
82 |
for (i = 1; i < argc && argv[i][0] == '-'; i++) { |
83 |
rval = getviewopt(&ourview, argc-i, argv+i); |
84 |
if (rval >= 0) { |
85 |
i += rval; |
86 |
continue; |
87 |
88 |
switch (argv[i][1]) { |
89 |
case 't': /* threshold */ |
90 |
check(2,1); |
91 |
zeps = atof(argv[++i]); |
92 |
break; |
93 |
case 'n': /* dist. normalized? */ |
94 |
check(2,0); |
95 |
normdist = !normdist; |
96 |
break; |
97 |
case 'f': /* fill type */ |
98 |
switch (argv[i][2]) { |
99 |
case '0': /* none */ |
100 |
check(3,0); |
101 |
fill = 0; |
102 |
break; |
103 |
case 'f': /* foreground */ |
104 |
check(3,0); |
105 |
fill = F_FORE; |
106 |
break; |
107 |
case 'b': /* background */ |
108 |
check(3,0); |
109 |
fill = F_BACK; |
110 |
break; |
111 |
case 'a': /* all */ |
112 |
check(3,0); |
113 |
fill = F_FORE|F_BACK; |
114 |
break; |
115 |
case 'c': /* color */ |
116 |
check(3,3); |
117 |
deffill = backfill; |
118 |
setcolr(backcolr, atof(argv[i+1]), |
119 |
atof(argv[i+2]), atof(argv[i+3])); |
120 |
i += 3; |
121 |
break; |
122 |
case 'z': /* z value */ |
123 |
check(3,1); |
124 |
125 |
backz = atof(argv[++i]); |
126 |
break; |
127 |
case 'r': /* rtrace */ |
128 |
check(3,1); |
129 |
deffill = rcalfill; |
130 |
calstart(RTCOM, argv[++i]); |
131 |
break; |
132 |
default: |
133 |
goto badopt; |
134 |
135 |
break; |
136 |
case 'z': /* z file */ |
137 |
check(2,1); |
138 |
zfile = argv[++i]; |
139 |
break; |
140 |
case 'x': /* x resolution */ |
141 |
check(2,1); |
142 |
hresolu = atoi(argv[++i]); |
143 |
break; |
144 |
case 'y': /* y resolution */ |
145 |
check(2,1); |
146 |
vresolu = atoi(argv[++i]); |
147 |
break; |
148 |
case 'p': /* pixel aspect */ |
149 |
check(2,1); |
150 |
pixaspect = atof(argv[++i]); |
151 |
break; |
152 |
case 'v': /* view file */ |
153 |
if (argv[i][2] != 'f') |
154 |
goto badopt; |
155 |
check(3,1); |
156 |
gotvfile = viewfile(argv[++i], &ourview, 0, 0); |
157 |
if (gotvfile < 0) { |
158 |
perror(argv[i]); |
159 |
exit(1); |
160 |
} else if (gotvfile == 0) { |
161 |
fprintf(stderr, "%s: bad view file\n", |
162 |
argv[i]); |
163 |
exit(1); |
164 |
165 |
break; |
166 |
default: |
167 |
badopt: |
168 |
fprintf(stderr, "%s: command line error at '%s'\n", |
169 |
progname, argv[i]); |
170 |
goto userr; |
171 |
172 |
173 |
/* check arguments */ |
174 |
if ((argc-i)%2) |
175 |
goto userr; |
176 |
/* set view */ |
177 |
if (err = setview(&ourview)) { |
178 |
fprintf(stderr, "%s: %s\n", progname, err); |
179 |
exit(1); |
180 |
181 |
normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu); |
182 |
/* allocate frame */ |
183 |
ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR)); |
184 |
ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float)); |
185 |
if (ourpict == NULL || ourzbuf == NULL) |
186 |
syserror(); |
187 |
/* get input */ |
188 |
for ( ; i < argc; i += 2) |
189 |
addpicture(argv[i], argv[i+1]); |
190 |
/* fill in spaces */ |
191 |
if (fill&F_BACK) |
192 |
backpicture(); |
193 |
else |
194 |
fillpicture(); |
195 |
/* close calculation */ |
196 |
caldone(); |
197 |
/* add to header */ |
198 |
printargs(argc, argv, stdout); |
199 |
if (gotvfile) { |
200 |
printf(VIEWSTR); |
201 |
fprintview(&ourview, stdout); |
202 |
printf("\n"); |
203 |
204 |
if (pixaspect < .99 || pixaspect > 1.01) |
205 |
fputaspect(pixaspect, stdout); |
206 |
if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005)) |
207 |
fputexpos(ourexp, stdout); |
208 |
printf("\n"); |
209 |
/* write picture */ |
210 |
writepicture(); |
211 |
/* write z file */ |
212 |
if (zfile != NULL) |
213 |
writedistance(zfile); |
214 |
215 |
exit(0); |
216 |
userr: |
217 |
fprintf(stderr, |
218 |
"Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n", |
219 |
progname); |
220 |
exit(1); |
221 |
#undef check |
222 |
223 |
224 |
225 |
headline(s) /* process header string */ |
226 |
char *s; |
227 |
228 |
static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL}; |
229 |
register char **an; |
230 |
231 |
printf("\t%s", s); |
232 |
233 |
if (isexpos(s)) { |
234 |
theirexp *= exposval(s); |
235 |
return; |
236 |
237 |
for (an = altname; *an != NULL; an++) |
238 |
if (!strncmp(*an, s, strlen(*an))) { |
239 |
if (sscanview(&theirview, s+strlen(*an)) > 0) |
240 |
gotview++; |
241 |
break; |
242 |
243 |
244 |
245 |
246 |
addpicture(pfile, zspec) /* add picture to output */ |
247 |
char *pfile, *zspec; |
248 |
249 |
250 |
FILE *pfp; |
251 |
int zfd; |
252 |
char *err; |
253 |
COLR *scanin; |
254 |
float *zin; |
255 |
struct position *plast; |
256 |
int y; |
257 |
/* open picture file */ |
258 |
if ((pfp = fopen(pfile, "r")) == NULL) { |
259 |
perror(pfile); |
260 |
exit(1); |
261 |
262 |
/* get header with exposure and view */ |
263 |
theirexp = 1.0; |
264 |
gotview = 0; |
265 |
printf("%s:\n", pfile); |
266 |
getheader(pfp, headline); |
267 |
if (!gotview || fgetresolu(&thresolu, &tvresolu, pfp) |
268 |
!= (YMAJOR|YDECR)) { |
269 |
fprintf(stderr, "%s: picture view error\n", pfile); |
270 |
exit(1); |
271 |
272 |
if (ourexp <= 0) |
273 |
ourexp = theirexp; |
274 |
else if (ABS(theirexp-ourexp) > .01*ourexp) |
275 |
fprintf(stderr, "%s: different exposure (warning)\n", pfile); |
276 |
if (err = setview(&theirview)) { |
277 |
fprintf(stderr, "%s: %s\n", pfile, err); |
278 |
exit(1); |
279 |
280 |
/* compute transformation */ |
281 |
pixform(theirs2ours, &theirview, &ourview); |
282 |
/* allocate scanlines */ |
283 |
scanin = (COLR *)malloc(thresolu*sizeof(COLR)); |
284 |
zin = (float *)malloc(thresolu*sizeof(float)); |
285 |
plast = (struct position *)calloc(thresolu, sizeof(struct position)); |
286 |
if (scanin == NULL || zin == NULL || plast == NULL) |
287 |
syserror(); |
288 |
/* get z specification or file */ |
289 |
if ((zfd = open(zspec, O_RDONLY)) == -1) { |
290 |
double zvalue; |
291 |
register int x; |
292 |
if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) { |
293 |
perror(zspec); |
294 |
exit(1); |
295 |
296 |
for (x = 0; x < thresolu; x++) |
297 |
zin[x] = zvalue; |
298 |
299 |
/* load image */ |
300 |
for (y = tvresolu-1; y >= 0; y--) { |
301 |
if (freadcolrs(scanin, thresolu, pfp) < 0) { |
302 |
fprintf(stderr, "%s: read error\n", pfile); |
303 |
exit(1); |
304 |
305 |
if (zfd != -1 && read(zfd,zin,thresolu*sizeof(float)) |
306 |
< thresolu*sizeof(float)) { |
307 |
fprintf(stderr, "%s: read error\n", zspec); |
308 |
exit(1); |
309 |
310 |
addscanline(y, scanin, zin, plast); |
311 |
312 |
/* clean up */ |
313 |
free((char *)scanin); |
314 |
free((char *)zin); |
315 |
free((char *)plast); |
316 |
fclose(pfp); |
317 |
if (zfd != -1) |
318 |
close(zfd); |
319 |
320 |
321 |
322 |
pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */ |
323 |
register double xfmat[4][4]; |
324 |
register VIEW *vw1, *vw2; |
325 |
326 |
double m4t[4][4]; |
327 |
328 |
setident4(xfmat); |
329 |
xfmat[0][0] = vw1->hvec[0]; |
330 |
xfmat[0][1] = vw1->hvec[1]; |
331 |
xfmat[0][2] = vw1->hvec[2]; |
332 |
xfmat[1][0] = vw1->vvec[0]; |
333 |
xfmat[1][1] = vw1->vvec[1]; |
334 |
xfmat[1][2] = vw1->vvec[2]; |
335 |
xfmat[2][0] = vw1->vdir[0]; |
336 |
xfmat[2][1] = vw1->vdir[1]; |
337 |
xfmat[2][2] = vw1->vdir[2]; |
338 |
xfmat[3][0] = vw1->vp[0]; |
339 |
xfmat[3][1] = vw1->vp[1]; |
340 |
xfmat[3][2] = vw1->vp[2]; |
341 |
setident4(m4t); |
342 |
m4t[0][0] = vw2->hvec[0]/vw2->hn2; |
343 |
m4t[1][0] = vw2->hvec[1]/vw2->hn2; |
344 |
m4t[2][0] = vw2->hvec[2]/vw2->hn2; |
345 |
m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2; |
346 |
m4t[0][1] = vw2->vvec[0]/vw2->vn2; |
347 |
m4t[1][1] = vw2->vvec[1]/vw2->vn2; |
348 |
m4t[2][1] = vw2->vvec[2]/vw2->vn2; |
349 |
m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2; |
350 |
m4t[0][2] = vw2->vdir[0]; |
351 |
m4t[1][2] = vw2->vdir[1]; |
352 |
m4t[2][2] = vw2->vdir[2]; |
353 |
m4t[3][2] = -DOT(vw2->vp,vw2->vdir); |
354 |
multmat4(xfmat, xfmat, m4t); |
355 |
356 |
357 |
358 |
addscanline(y, pline, zline, lasty) /* add scanline to output */ |
359 |
int y; |
360 |
COLR *pline; |
361 |
float *zline; |
362 |
struct position *lasty; /* input/output */ |
363 |
364 |
extern double sqrt(); |
365 |
double pos[3]; |
366 |
struct position lastx, newpos; |
367 |
register int x; |
368 |
369 |
lastx.z = 0; |
370 |
for (x = thresolu-1; x >= 0; x--) { |
371 |
pos[0] = (x+.5)/thresolu + theirview.hoff - .5; |
372 |
pos[1] = (y+.5)/tvresolu + theirview.voff - .5; |
373 |
pos[2] = zline[x]; |
374 |
if (theirview.type == VT_PER) { |
375 |
if (normdist) /* adjust for eye-ray distance */ |
376 |
pos[2] /= sqrt( 1. |
377 |
+ pos[0]*pos[0]*theirview.hn2 |
378 |
+ pos[1]*pos[1]*theirview.vn2 ); |
379 |
pos[0] *= pos[2]; |
380 |
pos[1] *= pos[2]; |
381 |
382 |
multp3(pos, pos, theirs2ours); |
383 |
if (pos[2] <= 0) { |
384 |
lasty[x].z = lastx.z = 0; /* mark invalid */ |
385 |
continue; |
386 |
387 |
if (ourview.type == VT_PER) { |
388 |
pos[0] /= pos[2]; |
389 |
pos[1] /= pos[2]; |
390 |
391 |
pos[0] += .5 - ourview.hoff; |
392 |
pos[1] += .5 - ourview.voff; |
393 |
newpos.x = pos[0] * hresolu; |
394 |
newpos.y = pos[1] * vresolu; |
395 |
newpos.z = zline[x]; |
396 |
/* add pixel to our image */ |
397 |
if (pos[0] >= 0 && newpos.x < hresolu |
398 |
&& pos[1] >= 0 && newpos.y < vresolu) { |
399 |
addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]); |
400 |
lasty[x].x = lastx.x = newpos.x; |
401 |
lasty[x].y = lastx.y = newpos.y; |
402 |
lasty[x].z = lastx.z = newpos.z; |
403 |
} else |
404 |
405 |
406 |
407 |
408 |
409 |
addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */ |
410 |
struct position *p0, *p1, *p2; |
411 |
COLR pix; |
412 |
double z; |
413 |
414 |
double zt = 2.*zeps*p0->z; /* threshold */ |
415 |
int s1x, s1y, s2x, s2y; /* step sizes */ |
416 |
int l1, l2, c1, c2; /* side lengths and counters */ |
417 |
int p1isy; /* p0p1 along y? */ |
418 |
int x1, y1; /* p1 position */ |
419 |
register int x, y; /* final position */ |
420 |
421 |
/* compute vector p0p1 */ |
422 |
if (fill&F_FORE && ABS(p1->z-p0->z) <= zt) { |
423 |
s1x = p1->x - p0->x; |
424 |
s1y = p1->y - p0->y; |
425 |
l1 = ABS(s1x); |
426 |
if (p1isy = (ABS(s1y) > l1)) |
427 |
l1 = ABS(s1y); |
428 |
} else { |
429 |
l1 = s1x = s1y = 1; |
430 |
p1isy = -1; |
431 |
432 |
/* compute vector p0p2 */ |
433 |
if (fill&F_FORE && ABS(p2->z-p0->z) <= zt) { |
434 |
s2x = p2->x - p0->x; |
435 |
s2y = p2->y - p0->y; |
436 |
if (p1isy == 1) |
437 |
l2 = ABS(s2x); |
438 |
else { |
439 |
l2 = ABS(s2y); |
440 |
if (p1isy != 0 && ABS(s2x) > l2) |
441 |
l2 = ABS(s2x); |
442 |
443 |
} else |
444 |
l2 = s2x = s2y = 1; |
445 |
/* fill the parallelogram */ |
446 |
for (c1 = l1; c1-- > 0; ) { |
447 |
x1 = p0->x + c1*s1x/l1; |
448 |
y1 = p0->y + c1*s1y/l1; |
449 |
for (c2 = l2; c2-- > 0; ) { |
450 |
x = x1 + c2*s2x/l2; |
451 |
y = y1 + c2*s2y/l2; |
452 |
if (zscan(y)[x] <= 0 || zscan(y)[x]-z |
453 |
> zeps*zscan(y)[x]) { |
454 |
zscan(y)[x] = z; |
455 |
copycolr(pscan(y)[x], pix); |
456 |
457 |
458 |
459 |
460 |
461 |
462 |
backpicture() /* background fill algorithm */ |
463 |
464 |
int *yback, xback; |
465 |
int y; |
466 |
COLR pfill; |
467 |
register int x, i; |
468 |
/* get back buffer */ |
469 |
yback = (int *)malloc(hresolu*sizeof(int)); |
470 |
if (yback == NULL) |
471 |
syserror(); |
472 |
for (x = 0; x < hresolu; x++) |
473 |
yback[x] = -2; |
474 |
475 |
* Xback and yback are the pixel locations of suitable |
476 |
* background values in each direction. |
477 |
* A value of -2 means unassigned, and -1 means |
478 |
* that there is no suitable background in this direction. |
479 |
480 |
/* fill image */ |
481 |
for (y = 0; y < vresolu; y++) { |
482 |
xback = -2; |
483 |
484 |
if (zscan(y)[x] <= 0) { /* empty pixel */ |
485 |
486 |
* First, find background from above or below. |
487 |
* (farthest assigned pixel) |
488 |
489 |
if (yback[x] == -2) { |
490 |
for (i = y+1; i < vresolu; i++) |
491 |
if (zscan(i)[x] > 0) |
492 |
break; |
493 |
if (i < vresolu |
494 |
&& (y <= 0 || zscan(y-1)[x] < zscan(i)[x])) |
495 |
yback[x] = i; |
496 |
else |
497 |
yback[x] = y-1; |
498 |
499 |
500 |
* Next, find background from left or right. |
501 |
502 |
if (xback == -2) { |
503 |
for (i = x+1; i < hresolu; i++) |
504 |
if (zscan(y)[i] > 0) |
505 |
break; |
506 |
if (i < hresolu |
507 |
&& (x <= 0 || zscan(y)[x-1] < zscan(y)[i])) |
508 |
xback = i; |
509 |
else |
510 |
xback = x-1; |
511 |
512 |
513 |
* Check to see if we have no background for |
514 |
* this pixel. If not, use background color. |
515 |
516 |
if (xback < 0 && yback[x] < 0) { |
517 |
(*deffill)(x,y); |
518 |
continue; |
519 |
520 |
521 |
* Compare, and use the background that is |
522 |
* farther, unless one of them is next to us. |
523 |
524 |
if ( yback[x] < 0 |
525 |
|| (xback >= 0 && ABS(x-xback) <= 1) |
526 |
|| ( ABS(y-yback[x]) > 1 |
527 |
&& zscan(yback[x])[x] |
528 |
< zscan(y)[xback] ) ) { |
529 |
copycolr(pscan(y)[x],pscan(y)[xback]); |
530 |
zscan(y)[x] = zscan(y)[xback]; |
531 |
} else { |
532 |
copycolr(pscan(y)[x],pscan(yback[x])[x]); |
533 |
zscan(y)[x] = zscan(yback[x])[x]; |
534 |
535 |
} else { /* full pixel */ |
536 |
yback[x] = -2; |
537 |
xback = -2; |
538 |
539 |
540 |
free((char *)yback); |
541 |
542 |
543 |
544 |
fillpicture() /* paint in empty pixels with default */ |
545 |
546 |
register int x, y; |
547 |
548 |
for (y = 0; y < vresolu; y++) |
549 |
550 |
if (zscan(y)[x] <= 0) |
551 |
(*deffill)(x,y); |
552 |
553 |
554 |
555 |
writepicture() /* write out picture */ |
556 |
557 |
int y; |
558 |
559 |
fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout); |
560 |
for (y = vresolu-1; y >= 0; y--) |
561 |
if (fwritecolrs(pscan(y), hresolu, stdout) < 0) |
562 |
syserror(); |
563 |
564 |
565 |
566 |
writedistance(fname) /* write out z file */ |
567 |
char *fname; |
568 |
569 |
570 |
int donorm = normdist && ourview.type == VT_PER; |
571 |
int fd; |
572 |
int y; |
573 |
float *zout; |
574 |
575 |
if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) { |
576 |
perror(fname); |
577 |
exit(1); |
578 |
579 |
if (donorm |
580 |
&& (zout = (float *)malloc(hresolu*sizeof(float))) == NULL) |
581 |
syserror(); |
582 |
for (y = vresolu-1; y >= 0; y--) { |
583 |
if (donorm) { |
584 |
double vx, yzn2; |
585 |
register int x; |
586 |
yzn2 = y - .5*(vresolu-1); |
587 |
yzn2 = 1. + yzn2*yzn2*ourview.vn2; |
588 |
for (x = 0; x < hresolu; x++) { |
589 |
vx = x - .5*(hresolu-1); |
590 |
zout[x] = zscan(y)[x] |
591 |
* sqrt(vx*vx*ourview.hn2 + yzn2); |
592 |
593 |
} else |
594 |
zout = zscan(y); |
595 |
if (write(fd, zout, hresolu*sizeof(float)) |
596 |
< hresolu*sizeof(float)) { |
597 |
perror(fname); |
598 |
exit(1); |
599 |
600 |
601 |
if (donorm) |
602 |
free((char *)zout); |
603 |
close(fd); |
604 |
605 |
606 |
607 |
isfloat(s) /* see if string is floating number */ |
608 |
register char *s; |
609 |
610 |
for ( ; *s; s++) |
611 |
if ((*s < '0' || *s > '9') && *s != '.' && *s != '-' |
612 |
&& *s != 'e' && *s != 'E' && *s != '+') |
613 |
return(0); |
614 |
return(1); |
615 |
616 |
617 |
618 |
backfill(x, y) /* fill pixel with background */ |
619 |
int x, y; |
620 |
621 |
register BYTE *dest = pscan(y)[x]; |
622 |
623 |
copycolr(dest, backcolr); |
624 |
zscan(y)[x] = backz; |
625 |
626 |
627 |
628 |
calstart(prog, args) /* start fill calculation */ |
629 |
char *prog, *args; |
630 |
631 |
char combuf[512]; |
632 |
int p0[2], p1[2]; |
633 |
634 |
if (childpid != -1) { |
635 |
fprintf(stderr, "%s: too many calculations\n", progname); |
636 |
exit(1); |
637 |
638 |
sprintf(combuf, prog, PACKSIZ, args); |
639 |
if (pipe(p0) < 0 || pipe(p1) < 0) |
640 |
syserror(); |
641 |
if ((childpid = vfork()) == 0) { /* fork calculation */ |
642 |
close(p0[1]); |
643 |
close(p1[0]); |
644 |
if (p0[0] != 0) { |
645 |
dup2(p0[0], 0); |
646 |
close(p0[0]); |
647 |
648 |
if (p1[1] != 1) { |
649 |
dup2(p1[1], 1); |
650 |
close(p1[1]); |
651 |
652 |
execl("/bin/sh", "sh", "-c", combuf, 0); |
653 |
perror("/bin/sh"); |
654 |
_exit(127); |
655 |
656 |
if (childpid == -1) |
657 |
syserror(); |
658 |
close(p0[0]); |
659 |
close(p1[1]); |
660 |
if ((psend = fdopen(p0[1], "w")) == NULL) |
661 |
syserror(); |
662 |
if ((precv = fdopen(p1[0], "r")) == NULL) |
663 |
syserror(); |
664 |
queuesiz = 0; |
665 |
666 |
667 |
668 |
caldone() /* done with calculation */ |
669 |
670 |
int pid; |
671 |
672 |
673 |
return; |
674 |
clearqueue(1); |
675 |
while ((pid = wait(0)) != -1 && pid != childpid) |
676 |
677 |
childpid = -1; |
678 |
679 |
680 |
681 |
rcalfill(x, y) /* fill with ray-calculated pixel */ |
682 |
int x, y; |
683 |
684 |
if (queuesiz >= PACKSIZ) /* flush queue if needed */ |
685 |
clearqueue(0); |
686 |
/* add position to queue */ |
687 |
queue[queuesiz][0] = x; |
688 |
queue[queuesiz][1] = y; |
689 |
queuesiz++; |
690 |
691 |
692 |
693 |
clearqueue(done) /* process queue */ |
694 |
int done; |
695 |
696 |
FVECT orig, dir; |
697 |
float fbuf[6]; |
698 |
register int i; |
699 |
700 |
for (i = 0; i < queuesiz; i++) { |
701 |
viewray(orig, dir, &ourview, |
702 |
(queue[i][0]+.5)/hresolu, |
703 |
(queue[i][1]+.5)/vresolu); |
704 |
fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2]; |
705 |
fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2]; |
706 |
fwrite(fbuf, sizeof(float), 6, psend); |
707 |
708 |
if ((done ? fclose(psend) : fflush(psend)) == EOF) |
709 |
syserror(); |
710 |
711 |
if (fread(fbuf, sizeof(float), 4, precv) < 4) { |
712 |
fprintf(stderr, "%s: read error in clearqueue\n", |
713 |
progname); |
714 |
exit(1); |
715 |
716 |
if (ourexp > 0 && ourexp != 1.0) { |
717 |
fbuf[0] *= ourexp; |
718 |
fbuf[1] *= ourexp; |
719 |
fbuf[2] *= ourexp; |
720 |
721 |
setcolr(pscan(queue[i][1])[queue[i][0]], |
722 |
fbuf[0], fbuf[1], fbuf[2]); |
723 |
zscan(queue[i][1])[queue[i][0]] = fbuf[3]; |
724 |
725 |
if (done) |
726 |
fclose(precv); |
727 |
queuesiz = 0; |
728 |
729 |
730 |
731 |
syserror() /* report error and exit */ |
732 |
733 |
perror(progname); |
734 |
exit(1); |
735 |
