--- ray/src/px/pinterp.c 1990/01/03 12:52:30 1.9 +++ ray/src/px/pinterp.c 1990/03/06 15:45:31 1.27 @@ -10,17 +10,35 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" +#include + #include "view.h" #include "color.h" -#define pscan(y) (ourpict+(y)*ourview.hresolu) -#define zscan(y) (ourzbuf+(y)*ourview.hresolu) +#ifndef BSD +#define vfork fork +#endif +#define pscan(y) (ourpict+(y)*hresolu) +#define zscan(y) (ourzbuf+(y)*hresolu) + +#define F_FORE 1 /* fill foreground */ +#define F_BACK 2 /* fill background */ + +#define PACKSIZ 42 /* calculation packet size */ + +#define RTCOM "rtrace -h -ovl -fff %s" + #define ABS(x) ((x)>0?(x):-(x)) -VIEW ourview = STDVIEW(512); /* desired view */ +struct position {int x,y; float z;}; +VIEW ourview = STDVIEW; /* desired view */ +int hresolu = 512; /* horizontal resolution */ +int vresolu = 512; /* vertical resolution */ +double pixaspect = 1.0; /* pixel aspect ratio */ + double zeps = .02; /* allowed z epsilon */ COLR *ourpict; /* output picture */ @@ -28,126 +46,183 @@ float *ourzbuf; /* corresponding z-buffer */ char *progname; -VIEW theirview = STDVIEW(512); /* input view */ -int gotview; /* got input view? */ +int fillo = F_FORE|F_BACK; /* selected fill options */ +int fillsamp = 0; /* sample separation (0 == inf) */ +extern int backfill(), rcalfill(); /* fill functions */ +int (*fillfunc)() = backfill; /* selected fill function */ +COLR backcolr = BLKCOLR; /* background color */ +double backz = 0.0; /* background z value */ +int normdist = 1; /* normalized distance? */ +double ourexp = -1; /* output picture exposure */ +VIEW theirview = STDVIEW; /* input view */ +int gotview; /* got input view? */ +int thresolu, tvresolu; /* input resolution */ +double theirexp; /* input picture exposure */ double theirs2ours[4][4]; /* transformation matrix */ +int childpid = -1; /* id of fill process */ +FILE *psend, *precv; /* pipes to/from fill calculation */ +int queue[PACKSIZ][2]; /* pending pixels */ +int queuesiz; /* number of pixels pending */ + main(argc, argv) /* interpolate pictures */ int argc; char *argv[]; { #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt + extern double atof(); int gotvfile = 0; + char *zfile = NULL; char *err; - int i; + int i, rval; progname = argv[0]; - for (i = 1; i < argc && argv[i][0] == '-'; i++) + for (i = 1; i < argc && argv[i][0] == '-'; i++) { + rval = getviewopt(&ourview, argc-i, argv+i); + if (rval >= 0) { + i += rval; + continue; + } switch (argv[i][1]) { case 't': /* threshold */ check(2,1); zeps = atof(argv[++i]); break; - case 'x': /* x resolution */ - check(2,1); - ourview.hresolu = atoi(argv[++i]); + case 'n': /* dist. normalized? */ + check(2,0); + normdist = !normdist; break; - case 'y': /* y resolution */ - check(2,1); - ourview.vresolu = atoi(argv[++i]); - break; - case 'v': /* view */ + case 'f': /* fill type */ switch (argv[i][2]) { - case 't': /* type */ - check(4,0); - ourview.type = argv[i][3]; + case '0': /* none */ + check(3,0); + fillo = 0; break; - case 'p': /* point */ - check(3,3); - ourview.vp[0] = atof(argv[++i]); - ourview.vp[1] = atof(argv[++i]); - ourview.vp[2] = atof(argv[++i]); + case 'f': /* foreground */ + check(3,0); + fillo = F_FORE; break; - case 'd': /* direction */ - check(3,3); - ourview.vdir[0] = atof(argv[++i]); - ourview.vdir[1] = atof(argv[++i]); - ourview.vdir[2] = atof(argv[++i]); + case 'b': /* background */ + check(3,0); + fillo = F_BACK; break; - case 'u': /* up */ - check(3,3); - ourview.vup[0] = atof(argv[++i]); - ourview.vup[1] = atof(argv[++i]); - ourview.vup[2] = atof(argv[++i]); + case 'a': /* all */ + check(3,0); + fillo = F_FORE|F_BACK; break; - case 'h': /* horizontal */ + case 's': /* sample */ check(3,1); - ourview.horiz = atof(argv[++i]); + fillsamp = atoi(argv[++i]); break; - case 'v': /* vertical */ + case 'c': /* color */ + check(3,3); + fillfunc = backfill; + setcolr(backcolr, atof(argv[i+1]), + atof(argv[i+2]), atof(argv[i+3])); + i += 3; + break; + case 'z': /* z value */ check(3,1); - ourview.vert = atof(argv[++i]); + fillfunc = backfill; + backz = atof(argv[++i]); break; - case 'f': /* file */ + case 'r': /* rtrace */ check(3,1); - gotvfile = viewfile(argv[++i], &ourview); - if (gotvfile < 0) { - perror(argv[i]); - exit(1); - } else if (gotvfile == 0) { - fprintf(stderr, "%s: bad view file\n", - argv[i]); - exit(1); - } + fillfunc = rcalfill; + calstart(RTCOM, argv[++i]); break; default: goto badopt; } break; + case 'z': /* z file */ + check(2,1); + zfile = argv[++i]; + break; + case 'x': /* x resolution */ + check(2,1); + hresolu = atoi(argv[++i]); + break; + case 'y': /* y resolution */ + check(2,1); + vresolu = atoi(argv[++i]); + break; + case 'p': /* pixel aspect */ + check(2,1); + pixaspect = atof(argv[++i]); + break; + case 'v': /* view file */ + if (argv[i][2] != 'f') + goto badopt; + check(3,1); + gotvfile = viewfile(argv[++i], &ourview, 0, 0); + if (gotvfile < 0) { + perror(argv[i]); + exit(1); + } else if (gotvfile == 0) { + fprintf(stderr, "%s: bad view file\n", + argv[i]); + exit(1); + } + break; default: badopt: - fprintf(stderr, "%s: unknown option '%s'\n", + fprintf(stderr, "%s: command line error at '%s'\n", progname, argv[i]); - exit(1); + goto userr; } - /* check arguments */ - if (argc-i < 2 || (argc-i)%2) { - fprintf(stderr, "Usage: %s [view args] pfile zfile ..\n", - progname); - exit(1); } + /* check arguments */ + if ((argc-i)%2) + goto userr; /* set view */ if (err = setview(&ourview)) { fprintf(stderr, "%s: %s\n", progname, err); exit(1); } + normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu); /* allocate frame */ - ourpict = (COLR *)calloc(ourview.hresolu*ourview.vresolu,sizeof(COLR)); - ourzbuf = (float *)calloc(ourview.hresolu*ourview.vresolu,sizeof(float)); - if (ourpict == NULL || ourzbuf == NULL) { - perror(progname); - exit(1); - } + ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR)); + ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float)); + if (ourpict == NULL || ourzbuf == NULL) + syserror(); /* get input */ for ( ; i < argc; i += 2) addpicture(argv[i], argv[i+1]); /* fill in spaces */ - fillpicture(); + if (fillo&F_BACK) + backpicture(fillfunc, fillsamp); + else + fillpicture(fillfunc); + /* close calculation */ + caldone(); /* add to header */ printargs(argc, argv, stdout); if (gotvfile) { - printf(VIEWSTR); + fputs(VIEWSTR, stdout); fprintview(&ourview, stdout); - printf("\n"); + putc('\n', stdout); } - printf("\n"); - /* write output */ + if (pixaspect < .99 || pixaspect > 1.01) + fputaspect(pixaspect, stdout); + if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005)) + fputexpos(ourexp, stdout); + putc('\n', stdout); + /* write picture */ writepicture(); + /* write z file */ + if (zfile != NULL) + writedistance(zfile); exit(0); +userr: + fprintf(stderr, + "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n", + progname); + exit(1); #undef check } @@ -155,47 +230,55 @@ char *argv[]; headline(s) /* process header string */ char *s; { - static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL}; + static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL}; register char **an; - printf("\t%s", s); + putc('\t', stdout); + fputs(s, stdout); + if (isexpos(s)) { + theirexp *= exposval(s); + return; + } for (an = altname; *an != NULL; an++) if (!strncmp(*an, s, strlen(*an))) { - if (sscanview(&theirview, s+strlen(*an)) == 0) + if (sscanview(&theirview, s+strlen(*an)) > 0) gotview++; break; } } -addpicture(pfile, zfile) /* add picture to output */ -char *pfile, *zfile; +addpicture(pfile, zspec) /* add picture to output */ +char *pfile, *zspec; { - FILE *pfp, *zfp; + extern double atof(); + FILE *pfp; + int zfd; char *err; COLR *scanin; - float *zin, *zlast; - int *plast; + float *zin; + struct position *plast; int y; - /* open input files */ + /* open picture file */ if ((pfp = fopen(pfile, "r")) == NULL) { perror(pfile); exit(1); } - if ((zfp = fopen(zfile, "r")) == NULL) { - perror(zfile); - exit(1); - } - /* get header and view */ - printf("%s:\n", pfile); + /* get header with exposure and view */ + theirexp = 1.0; gotview = 0; + printf("%s:\n", pfile); getheader(pfp, headline); - if (!gotview || fgetresolu(&theirview.hresolu, &theirview.vresolu, pfp) + if (!gotview || fgetresolu(&thresolu, &tvresolu, pfp) != (YMAJOR|YDECR)) { fprintf(stderr, "%s: picture view error\n", pfile); exit(1); } + if (ourexp <= 0) + ourexp = theirexp; + else if (ABS(theirexp-ourexp) > .01*ourexp) + fprintf(stderr, "%s: different exposure (warning)\n", pfile); if (err = setview(&theirview)) { fprintf(stderr, "%s: %s\n", pfile, err); exit(1); @@ -203,34 +286,42 @@ char *pfile, *zfile; /* compute transformation */ pixform(theirs2ours, &theirview, &ourview); /* allocate scanlines */ - scanin = (COLR *)malloc(theirview.hresolu*sizeof(COLR)); - zin = (float *)malloc(theirview.hresolu*sizeof(float)); - zlast = (float *)calloc(theirview.hresolu, sizeof(float)); - plast = (int *)calloc(theirview.hresolu, sizeof(int)); - if (scanin == NULL || zin == NULL || zlast == NULL || plast == NULL) { - perror(progname); - exit(1); + scanin = (COLR *)malloc(thresolu*sizeof(COLR)); + zin = (float *)malloc(thresolu*sizeof(float)); + plast = (struct position *)calloc(thresolu, sizeof(struct position)); + if (scanin == NULL || zin == NULL || plast == NULL) + syserror(); + /* get z specification or file */ + if ((zfd = open(zspec, O_RDONLY)) == -1) { + double zvalue; + register int x; + if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) { + perror(zspec); + exit(1); + } + for (x = 0; x < thresolu; x++) + zin[x] = zvalue; } /* load image */ - for (y = theirview.vresolu-1; y >= 0; y--) { - if (freadcolrs(scanin, theirview.hresolu, pfp) < 0) { + for (y = tvresolu-1; y >= 0; y--) { + if (freadcolrs(scanin, thresolu, pfp) < 0) { fprintf(stderr, "%s: read error\n", pfile); exit(1); } - if (fread(zin, sizeof(float), theirview.hresolu, zfp) - < theirview.hresolu) { - fprintf(stderr, "%s: read error\n", zfile); + if (zfd != -1 && read(zfd,(char *)zin,thresolu*sizeof(float)) + < thresolu*sizeof(float)) { + fprintf(stderr, "%s: read error\n", zspec); exit(1); } - addscanline(y, scanin, zin, plast, zlast); + addscanline(y, scanin, zin, plast); } /* clean up */ free((char *)scanin); free((char *)zin); free((char *)plast); - free((char *)zlast); fclose(pfp); - fclose(zfp); + if (zfd != -1) + close(zfd); } @@ -241,12 +332,12 @@ register VIEW *vw1, *vw2; double m4t[4][4]; setident4(xfmat); - xfmat[0][0] = vw1->vhinc[0]; - xfmat[0][1] = vw1->vhinc[1]; - xfmat[0][2] = vw1->vhinc[2]; - xfmat[1][0] = vw1->vvinc[0]; - xfmat[1][1] = vw1->vvinc[1]; - xfmat[1][2] = vw1->vvinc[2]; + xfmat[0][0] = vw1->hvec[0]; + xfmat[0][1] = vw1->hvec[1]; + xfmat[0][2] = vw1->hvec[2]; + xfmat[1][0] = vw1->vvec[0]; + xfmat[1][1] = vw1->vvec[1]; + xfmat[1][2] = vw1->vvec[2]; xfmat[2][0] = vw1->vdir[0]; xfmat[2][1] = vw1->vdir[1]; xfmat[2][2] = vw1->vdir[2]; @@ -254,14 +345,14 @@ register VIEW *vw1, *vw2; xfmat[3][1] = vw1->vp[1]; xfmat[3][2] = vw1->vp[2]; setident4(m4t); - m4t[0][0] = vw2->vhinc[0]/vw2->vhn2; - m4t[1][0] = vw2->vhinc[1]/vw2->vhn2; - m4t[2][0] = vw2->vhinc[2]/vw2->vhn2; - m4t[3][0] = -DOT(vw2->vp,vw2->vhinc)/vw2->vhn2; - m4t[0][1] = vw2->vvinc[0]/vw2->vvn2; - m4t[1][1] = vw2->vvinc[1]/vw2->vvn2; - m4t[2][1] = vw2->vvinc[2]/vw2->vvn2; - m4t[3][1] = -DOT(vw2->vp,vw2->vvinc)/vw2->vvn2; + m4t[0][0] = vw2->hvec[0]/vw2->hn2; + m4t[1][0] = vw2->hvec[1]/vw2->hn2; + m4t[2][0] = vw2->hvec[2]/vw2->hn2; + m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2; + m4t[0][1] = vw2->vvec[0]/vw2->vn2; + m4t[1][1] = vw2->vvec[1]/vw2->vn2; + m4t[2][1] = vw2->vvec[2]/vw2->vn2; + m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2; m4t[0][2] = vw2->vdir[0]; m4t[1][2] = vw2->vdir[1]; m4t[2][2] = vw2->vdir[2]; @@ -270,104 +361,123 @@ register VIEW *vw1, *vw2; } -addscanline(y, pline, zline, lasty, lastyz) /* add scanline to output */ +addscanline(y, pline, zline, lasty) /* add scanline to output */ int y; COLR *pline; float *zline; -int *lasty; /* input/output */ -float *lastyz; /* input/output */ +struct position *lasty; /* input/output */ { - extern double sqrt(), fabs(); + extern double sqrt(); double pos[3]; - int lastx = 0; - double lastxz = 0; - double zt; - int xpos, ypos; + struct position lastx, newpos; register int x; - for (x = theirview.hresolu-1; x >= 0; x--) { - pos[0] = x - .5*(theirview.hresolu-1); - pos[1] = y - .5*(theirview.vresolu-1); + lastx.z = 0; + for (x = thresolu-1; x >= 0; x--) { + pos[0] = (x+.5)/thresolu + theirview.hoff - .5; + pos[1] = (y+.5)/tvresolu + theirview.voff - .5; pos[2] = zline[x]; if (theirview.type == VT_PER) { - /* - * The following (single) statement can go - * if z is along the view direction rather - * than an eye ray. - */ - pos[2] /= sqrt( 1. - + pos[0]*pos[0]*theirview.vhn2 - + pos[1]*pos[1]*theirview.vvn2 ); + if (normdist) /* adjust for eye-ray distance */ + pos[2] /= sqrt( 1. + + pos[0]*pos[0]*theirview.hn2 + + pos[1]*pos[1]*theirview.vn2 ); pos[0] *= pos[2]; pos[1] *= pos[2]; } multp3(pos, pos, theirs2ours); - if (pos[2] <= 0) + if (pos[2] <= 0) { + lasty[x].z = lastx.z = 0; /* mark invalid */ continue; + } if (ourview.type == VT_PER) { pos[0] /= pos[2]; pos[1] /= pos[2]; } - pos[0] += .5*ourview.hresolu; - pos[1] += .5*ourview.vresolu; - if (pos[0] < 0 || (xpos = pos[0]) >= ourview.hresolu - || pos[1] < 0 || (ypos = pos[1]) >= ourview.vresolu) - continue; + pos[0] += .5 - ourview.hoff; + pos[1] += .5 - ourview.voff; + newpos.x = pos[0] * hresolu; + newpos.y = pos[1] * vresolu; + newpos.z = zline[x]; /* add pixel to our image */ - zt = 2.*zeps*zline[x]; - addpixel(xpos, ypos, - (fabs(zline[x]-lastxz) <= zt) ? lastx - xpos : 1, - (fabs(zline[x]-lastyz[x]) <= zt) ? lasty[x] - ypos : 1, - pline[x], pos[2]); - lastx = xpos; - lasty[x] = ypos; - lastxz = lastyz[x] = zline[x]; + if (pos[0] >= 0 && newpos.x < hresolu + && pos[1] >= 0 && newpos.y < vresolu) { + addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]); + lasty[x].x = lastx.x = newpos.x; + lasty[x].y = lastx.y = newpos.y; + lasty[x].z = lastx.z = newpos.z; + } else + lasty[x].z = lastx.z = 0; /* mark invalid */ } } -addpixel(xstart, ystart, width, height, pix, z) /* fill in area for pixel */ -int xstart, ystart; -int width, height; +addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */ +struct position *p0, *p1, *p2; COLR pix; double z; { - register int x, y; - /* make width and height positive */ - if (width < 0) { - width = -width; - xstart = xstart-width+1; - } else if (width == 0) - width = 1; - if (height < 0) { - height = -height; - ystart = ystart-height+1; - } else if (height == 0) - height = 1; - /* fill pixel(s) within rectangle */ - for (y = ystart; y < ystart+height; y++) - for (x = xstart; x < xstart+width; x++) - if (zscan(y)[x] <= 0 - || zscan(y)[x]-z > zeps*zscan(y)[x]) { + double zt = 2.*zeps*p0->z; /* threshold */ + int s1x, s1y, s2x, s2y; /* step sizes */ + int l1, l2, c1, c2; /* side lengths and counters */ + int p1isy; /* p0p1 along y? */ + int x1, y1; /* p1 position */ + register int x, y; /* final position */ + + /* compute vector p0p1 */ + if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) { + s1x = p1->x - p0->x; + s1y = p1->y - p0->y; + l1 = ABS(s1x); + if (p1isy = (ABS(s1y) > l1)) + l1 = ABS(s1y); + } else { + l1 = s1x = s1y = 1; + p1isy = -1; + } + /* compute vector p0p2 */ + if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) { + s2x = p2->x - p0->x; + s2y = p2->y - p0->y; + if (p1isy == 1) + l2 = ABS(s2x); + else { + l2 = ABS(s2y); + if (p1isy != 0 && ABS(s2x) > l2) + l2 = ABS(s2x); + } + } else + l2 = s2x = s2y = 1; + /* fill the parallelogram */ + for (c1 = l1; c1-- > 0; ) { + x1 = p0->x + c1*s1x/l1; + y1 = p0->y + c1*s1y/l1; + for (c2 = l2; c2-- > 0; ) { + x = x1 + c2*s2x/l2; + y = y1 + c2*s2y/l2; + if (zscan(y)[x] <= 0 || zscan(y)[x]-z + > zeps*zscan(y)[x]) { zscan(y)[x] = z; copycolr(pscan(y)[x], pix); } + } + } } -fillpicture() /* fill in empty spaces */ +backpicture(fill, samp) /* background fill algorithm */ +int (*fill)(); +int samp; { int *yback, xback; int y; COLR pfill; register int x, i; /* get back buffer */ - yback = (int *)malloc(ourview.hresolu*sizeof(int)); - if (yback == NULL) { - perror(progname); - return; - } - for (x = 0; x < ourview.hresolu; x++) + yback = (int *)malloc(hresolu*sizeof(int)); + if (yback == NULL) + syserror(); + for (x = 0; x < hresolu; x++) yback[x] = -2; /* * Xback and yback are the pixel locations of suitable @@ -376,19 +486,19 @@ fillpicture() /* fill in empty spaces */ * that there is no suitable background in this direction. */ /* fill image */ - for (y = 0; y < ourview.vresolu; y++) { + for (y = 0; y < vresolu; y++) { xback = -2; - for (x = 0; x < ourview.hresolu; x++) + for (x = 0; x < hresolu; x++) if (zscan(y)[x] <= 0) { /* empty pixel */ /* * First, find background from above or below. * (farthest assigned pixel) */ if (yback[x] == -2) { - for (i = y+1; i < ourview.vresolu; i++) + for (i = y+1; i < vresolu; i++) if (zscan(i)[x] > 0) break; - if (i < ourview.vresolu + if (i < vresolu && (y <= 0 || zscan(y-1)[x] < zscan(i)[x])) yback[x] = i; else @@ -398,27 +508,50 @@ fillpicture() /* fill in empty spaces */ * Next, find background from left or right. */ if (xback == -2) { - for (i = x+1; x < ourview.hresolu; i++) + for (i = x+1; i < hresolu; i++) if (zscan(y)[i] > 0) break; - if (i < ourview.hresolu + if (i < hresolu && (x <= 0 || zscan(y)[x-1] < zscan(y)[i])) xback = i; else xback = x-1; } + /* + * If we have no background for this pixel, + * use the given fill function. + */ if (xback < 0 && yback[x] < 0) - continue; /* no background */ + goto fillit; /* * Compare, and use the background that is * farther, unless one of them is next to us. + * If the background is too distant, call + * the fill function. */ - if (yback[x] < 0 || ABS(x-xback) <= 1 + if ( yback[x] < 0 + || (xback >= 0 && ABS(x-xback) <= 1) || ( ABS(y-yback[x]) > 1 - && zscan(yback[x])[x] < zscan(y)[xback] )) + && zscan(yback[x])[x] + < zscan(y)[xback] ) ) { + if (samp > 0 && ABS(x-xback) >= samp) + goto fillit; copycolr(pscan(y)[x],pscan(y)[xback]); - else + zscan(y)[x] = zscan(y)[xback]; + } else { + if (samp > 0 && ABS(y-yback[x]) > samp) + goto fillit; copycolr(pscan(y)[x],pscan(yback[x])[x]); + zscan(y)[x] = zscan(yback[x])[x]; + } + continue; + fillit: + (*fill)(x,y); + if (fill == rcalfill) { /* use it */ + clearqueue(); + xback = x; + yback[x] = y; + } } else { /* full pixel */ yback[x] = -2; xback = -2; @@ -428,14 +561,198 @@ fillpicture() /* fill in empty spaces */ } +fillpicture(fill) /* paint in empty pixels using fill */ +int (*fill)(); +{ + register int x, y; + + for (y = 0; y < vresolu; y++) + for (x = 0; x < hresolu; x++) + if (zscan(y)[x] <= 0) + (*fill)(x,y); +} + + writepicture() /* write out picture */ { int y; - fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, stdout); - for (y = ourview.vresolu-1; y >= 0; y--) - if (fwritecolrs(pscan(y), ourview.hresolu, stdout) < 0) { - perror(progname); + fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout); + for (y = vresolu-1; y >= 0; y--) + if (fwritecolrs(pscan(y), hresolu, stdout) < 0) + syserror(); +} + + +writedistance(fname) /* write out z file */ +char *fname; +{ + extern double sqrt(); + int donorm = normdist && ourview.type == VT_PER; + int fd; + int y; + float *zout; + + if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) { + perror(fname); + exit(1); + } + if (donorm + && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL) + syserror(); + for (y = vresolu-1; y >= 0; y--) { + if (donorm) { + double vx, yzn2; + register int x; + yzn2 = y - .5*(vresolu-1); + yzn2 = 1. + yzn2*yzn2*ourview.vn2; + for (x = 0; x < hresolu; x++) { + vx = x - .5*(hresolu-1); + zout[x] = zscan(y)[x] + * sqrt(vx*vx*ourview.hn2 + yzn2); + } + } else + zout = zscan(y); + if (write(fd, (char *)zout, hresolu*sizeof(float)) + < hresolu*sizeof(float)) { + perror(fname); exit(1); } + } + if (donorm) + free((char *)zout); + close(fd); +} + + +isfloat(s) /* see if string is floating number */ +register char *s; +{ + for ( ; *s; s++) + if ((*s < '0' || *s > '9') && *s != '.' && *s != '-' + && *s != 'e' && *s != 'E' && *s != '+') + return(0); + return(1); +} + + +backfill(x, y) /* fill pixel with background */ +int x, y; +{ + register BYTE *dest = pscan(y)[x]; + + copycolr(dest, backcolr); + zscan(y)[x] = backz; +} + + +calstart(prog, args) /* start fill calculation */ +char *prog, *args; +{ + char combuf[512]; + int p0[2], p1[2]; + + if (childpid != -1) { + fprintf(stderr, "%s: too many calculations\n", progname); + exit(1); + } + sprintf(combuf, prog, args); + if (pipe(p0) < 0 || pipe(p1) < 0) + syserror(); + if ((childpid = vfork()) == 0) { /* fork calculation */ + close(p0[1]); + close(p1[0]); + if (p0[0] != 0) { + dup2(p0[0], 0); + close(p0[0]); + } + if (p1[1] != 1) { + dup2(p1[1], 1); + close(p1[1]); + } + execl("/bin/sh", "sh", "-c", combuf, 0); + perror("/bin/sh"); + _exit(127); + } + if (childpid == -1) + syserror(); + close(p0[0]); + close(p1[1]); + if ((psend = fdopen(p0[1], "w")) == NULL) + syserror(); + if ((precv = fdopen(p1[0], "r")) == NULL) + syserror(); + queuesiz = 0; +} + + +caldone() /* done with calculation */ +{ + int pid; + + if (childpid == -1) + return; + clearqueue(); + fclose(psend); + fclose(precv); + while ((pid = wait(0)) != -1 && pid != childpid) + ; + childpid = -1; +} + + +rcalfill(x, y) /* fill with ray-calculated pixel */ +int x, y; +{ + if (queuesiz >= PACKSIZ) /* flush queue if needed */ + clearqueue(); + /* add position to queue */ + queue[queuesiz][0] = x; + queue[queuesiz][1] = y; + queuesiz++; +} + + +clearqueue() /* process queue */ +{ + FVECT orig, dir; + float fbuf[6]; + register int i; + + for (i = 0; i < queuesiz; i++) { + viewray(orig, dir, &ourview, + (queue[i][0]+.5)/hresolu, + (queue[i][1]+.5)/vresolu); + fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2]; + fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2]; + fwrite((char *)fbuf, sizeof(float), 6, psend); + } + /* flush output and get results */ + fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */ + fwrite((char *)fbuf, sizeof(float), 6, psend); + if (fflush(psend) == EOF) + syserror(); + for (i = 0; i < queuesiz; i++) { + if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) { + fprintf(stderr, "%s: read error in clearqueue\n", + progname); + exit(1); + } + if (ourexp > 0 && ourexp != 1.0) { + fbuf[0] *= ourexp; + fbuf[1] *= ourexp; + fbuf[2] *= ourexp; + } + setcolr(pscan(queue[i][1])[queue[i][0]], + fbuf[0], fbuf[1], fbuf[2]); + zscan(queue[i][1])[queue[i][0]] = fbuf[3]; + } + queuesiz = 0; +} + + +syserror() /* report error and exit */ +{ + perror(progname); + exit(1); }
