root/radiance/ray/src/px/pinterp.c
Revision: 1.28
Committed: Fri Mar 16 19:19:52 1990 UTC (35 years, 1 month ago) by greg
Changes since 1.27: +4 -0 lines
tightened up constraints in addpixel() (bug fix)
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Interpolate and extrapolate pictures with different view parameters.
7 *
8 * Greg Ward 09Dec89
9 */
10
11 #include "standard.h"
12
13 #include <fcntl.h>
14
15 #include "view.h"
16
17 #include "color.h"
18
19 #ifndef BSD
20 #define vfork fork
21 #endif
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 42 /* calculation packet size */
30
31 #define RTCOM "rtrace -h -ovl -fff %s"
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fillo = F_FORE|F_BACK; /* selected fill options */
50 int fillsamp = 0; /* sample separation (0 == inf) */
51 extern int backfill(), rcalfill(); /* fill functions */
52 int (*fillfunc)() = backfill; /* selected fill function */
53 COLR backcolr = BLKCOLR; /* background color */
54 double backz = 0.0; /* background z value */
55 int normdist = 1; /* normalized distance? */
56 double ourexp = -1; /* output picture exposure */
57
58 VIEW theirview = STDVIEW; /* input view */
59 int gotview; /* got input view? */
60 int thresolu, tvresolu; /* input resolution */
61 double theirexp; /* input picture exposure */
62 double theirs2ours[4][4]; /* transformation matrix */
63
64 int childpid = -1; /* id of fill process */
65 FILE *psend, *precv; /* pipes to/from fill calculation */
66 int queue[PACKSIZ][2]; /* pending pixels */
67 int queuesiz; /* number of pixels pending */
68
69
70 main(argc, argv) /* interpolate pictures */
71 int argc;
72 char *argv[];
73 {
74 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
75 extern double atof();
76 int gotvfile = 0;
77 char *zfile = NULL;
78 char *err;
79 int i, rval;
80
81 progname = argv[0];
82
83 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
84 rval = getviewopt(&ourview, argc-i, argv+i);
85 if (rval >= 0) {
86 i += rval;
87 continue;
88 }
89 switch (argv[i][1]) {
90 case 't': /* threshold */
91 check(2,1);
92 zeps = atof(argv[++i]);
93 break;
94 case 'n': /* dist. normalized? */
95 check(2,0);
96 normdist = !normdist;
97 break;
98 case 'f': /* fill type */
99 switch (argv[i][2]) {
100 case '0': /* none */
101 check(3,0);
102 fillo = 0;
103 break;
104 case 'f': /* foreground */
105 check(3,0);
106 fillo = F_FORE;
107 break;
108 case 'b': /* background */
109 check(3,0);
110 fillo = F_BACK;
111 break;
112 case 'a': /* all */
113 check(3,0);
114 fillo = F_FORE|F_BACK;
115 break;
116 case 's': /* sample */
117 check(3,1);
118 fillsamp = atoi(argv[++i]);
119 break;
120 case 'c': /* color */
121 check(3,3);
122 fillfunc = backfill;
123 setcolr(backcolr, atof(argv[i+1]),
124 atof(argv[i+2]), atof(argv[i+3]));
125 i += 3;
126 break;
127 case 'z': /* z value */
128 check(3,1);
129 fillfunc = backfill;
130 backz = atof(argv[++i]);
131 break;
132 case 'r': /* rtrace */
133 check(3,1);
134 fillfunc = rcalfill;
135 calstart(RTCOM, argv[++i]);
136 break;
137 default:
138 goto badopt;
139 }
140 break;
141 case 'z': /* z file */
142 check(2,1);
143 zfile = argv[++i];
144 break;
145 case 'x': /* x resolution */
146 check(2,1);
147 hresolu = atoi(argv[++i]);
148 break;
149 case 'y': /* y resolution */
150 check(2,1);
151 vresolu = atoi(argv[++i]);
152 break;
153 case 'p': /* pixel aspect */
154 check(2,1);
155 pixaspect = atof(argv[++i]);
156 break;
157 case 'v': /* view file */
158 if (argv[i][2] != 'f')
159 goto badopt;
160 check(3,1);
161 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
162 if (gotvfile < 0) {
163 perror(argv[i]);
164 exit(1);
165 } else if (gotvfile == 0) {
166 fprintf(stderr, "%s: bad view file\n",
167 argv[i]);
168 exit(1);
169 }
170 break;
171 default:
172 badopt:
173 fprintf(stderr, "%s: command line error at '%s'\n",
174 progname, argv[i]);
175 goto userr;
176 }
177 }
178 /* check arguments */
179 if ((argc-i)%2)
180 goto userr;
181 /* set view */
182 if (err = setview(&ourview)) {
183 fprintf(stderr, "%s: %s\n", progname, err);
184 exit(1);
185 }
186 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
187 /* allocate frame */
188 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
189 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
190 if (ourpict == NULL || ourzbuf == NULL)
191 syserror();
192 /* get input */
193 for ( ; i < argc; i += 2)
194 addpicture(argv[i], argv[i+1]);
195 /* fill in spaces */
196 if (fillo&F_BACK)
197 backpicture(fillfunc, fillsamp);
198 else
199 fillpicture(fillfunc);
200 /* close calculation */
201 caldone();
202 /* add to header */
203 printargs(argc, argv, stdout);
204 if (gotvfile) {
205 fputs(VIEWSTR, stdout);
206 fprintview(&ourview, stdout);
207 putc('\n', stdout);
208 }
209 if (pixaspect < .99 || pixaspect > 1.01)
210 fputaspect(pixaspect, stdout);
211 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
212 fputexpos(ourexp, stdout);
213 putc('\n', stdout);
214 /* write picture */
215 writepicture();
216 /* write z file */
217 if (zfile != NULL)
218 writedistance(zfile);
219
220 exit(0);
221 userr:
222 fprintf(stderr,
223 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
224 progname);
225 exit(1);
226 #undef check
227 }
228
229
230 headline(s) /* process header string */
231 char *s;
232 {
233 static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL};
234 register char **an;
235
236 putc('\t', stdout);
237 fputs(s, stdout);
238
239 if (isexpos(s)) {
240 theirexp *= exposval(s);
241 return;
242 }
243 for (an = altname; *an != NULL; an++)
244 if (!strncmp(*an, s, strlen(*an))) {
245 if (sscanview(&theirview, s+strlen(*an)) > 0)
246 gotview++;
247 break;
248 }
249 }
250
251
252 addpicture(pfile, zspec) /* add picture to output */
253 char *pfile, *zspec;
254 {
255 extern double atof();
256 FILE *pfp;
257 int zfd;
258 char *err;
259 COLR *scanin;
260 float *zin;
261 struct position *plast;
262 int y;
263 /* open picture file */
264 if ((pfp = fopen(pfile, "r")) == NULL) {
265 perror(pfile);
266 exit(1);
267 }
268 /* get header with exposure and view */
269 theirexp = 1.0;
270 gotview = 0;
271 printf("%s:\n", pfile);
272 getheader(pfp, headline);
273 if (!gotview || fgetresolu(&thresolu, &tvresolu, pfp)
274 != (YMAJOR|YDECR)) {
275 fprintf(stderr, "%s: picture view error\n", pfile);
276 exit(1);
277 }
278 if (ourexp <= 0)
279 ourexp = theirexp;
280 else if (ABS(theirexp-ourexp) > .01*ourexp)
281 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
282 if (err = setview(&theirview)) {
283 fprintf(stderr, "%s: %s\n", pfile, err);
284 exit(1);
285 }
286 /* compute transformation */
287 pixform(theirs2ours, &theirview, &ourview);
288 /* allocate scanlines */
289 scanin = (COLR *)malloc(thresolu*sizeof(COLR));
290 zin = (float *)malloc(thresolu*sizeof(float));
291 plast = (struct position *)calloc(thresolu, sizeof(struct position));
292 if (scanin == NULL || zin == NULL || plast == NULL)
293 syserror();
294 /* get z specification or file */
295 if ((zfd = open(zspec, O_RDONLY)) == -1) {
296 double zvalue;
297 register int x;
298 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
299 perror(zspec);
300 exit(1);
301 }
302 for (x = 0; x < thresolu; x++)
303 zin[x] = zvalue;
304 }
305 /* load image */
306 for (y = tvresolu-1; y >= 0; y--) {
307 if (freadcolrs(scanin, thresolu, pfp) < 0) {
308 fprintf(stderr, "%s: read error\n", pfile);
309 exit(1);
310 }
311 if (zfd != -1 && read(zfd,(char *)zin,thresolu*sizeof(float))
312 < thresolu*sizeof(float)) {
313 fprintf(stderr, "%s: read error\n", zspec);
314 exit(1);
315 }
316 addscanline(y, scanin, zin, plast);
317 }
318 /* clean up */
319 free((char *)scanin);
320 free((char *)zin);
321 free((char *)plast);
322 fclose(pfp);
323 if (zfd != -1)
324 close(zfd);
325 }
326
327
328 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
329 register double xfmat[4][4];
330 register VIEW *vw1, *vw2;
331 {
332 double m4t[4][4];
333
334 setident4(xfmat);
335 xfmat[0][0] = vw1->hvec[0];
336 xfmat[0][1] = vw1->hvec[1];
337 xfmat[0][2] = vw1->hvec[2];
338 xfmat[1][0] = vw1->vvec[0];
339 xfmat[1][1] = vw1->vvec[1];
340 xfmat[1][2] = vw1->vvec[2];
341 xfmat[2][0] = vw1->vdir[0];
342 xfmat[2][1] = vw1->vdir[1];
343 xfmat[2][2] = vw1->vdir[2];
344 xfmat[3][0] = vw1->vp[0];
345 xfmat[3][1] = vw1->vp[1];
346 xfmat[3][2] = vw1->vp[2];
347 setident4(m4t);
348 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
349 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
350 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
351 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
352 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
353 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
354 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
355 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
356 m4t[0][2] = vw2->vdir[0];
357 m4t[1][2] = vw2->vdir[1];
358 m4t[2][2] = vw2->vdir[2];
359 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
360 multmat4(xfmat, xfmat, m4t);
361 }
362
363
364 addscanline(y, pline, zline, lasty) /* add scanline to output */
365 int y;
366 COLR *pline;
367 float *zline;
368 struct position *lasty; /* input/output */
369 {
370 extern double sqrt();
371 double pos[3];
372 struct position lastx, newpos;
373 register int x;
374
375 lastx.z = 0;
376 for (x = thresolu-1; x >= 0; x--) {
377 pos[0] = (x+.5)/thresolu + theirview.hoff - .5;
378 pos[1] = (y+.5)/tvresolu + theirview.voff - .5;
379 pos[2] = zline[x];
380 if (theirview.type == VT_PER) {
381 if (normdist) /* adjust for eye-ray distance */
382 pos[2] /= sqrt( 1.
383 + pos[0]*pos[0]*theirview.hn2
384 + pos[1]*pos[1]*theirview.vn2 );
385 pos[0] *= pos[2];
386 pos[1] *= pos[2];
387 }
388 multp3(pos, pos, theirs2ours);
389 if (pos[2] <= 0) {
390 lasty[x].z = lastx.z = 0; /* mark invalid */
391 continue;
392 }
393 if (ourview.type == VT_PER) {
394 pos[0] /= pos[2];
395 pos[1] /= pos[2];
396 }
397 pos[0] += .5 - ourview.hoff;
398 pos[1] += .5 - ourview.voff;
399 newpos.x = pos[0] * hresolu;
400 newpos.y = pos[1] * vresolu;
401 newpos.z = zline[x];
402 /* add pixel to our image */
403 if (pos[0] >= 0 && newpos.x < hresolu
404 && pos[1] >= 0 && newpos.y < vresolu) {
405 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
406 lasty[x].x = lastx.x = newpos.x;
407 lasty[x].y = lastx.y = newpos.y;
408 lasty[x].z = lastx.z = newpos.z;
409 } else
410 lasty[x].z = lastx.z = 0; /* mark invalid */
411 }
412 }
413
414
415 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
416 struct position *p0, *p1, *p2;
417 COLR pix;
418 double z;
419 {
420 double zt = 2.*zeps*p0->z; /* threshold */
421 int s1x, s1y, s2x, s2y; /* step sizes */
422 int l1, l2, c1, c2; /* side lengths and counters */
423 int p1isy; /* p0p1 along y? */
424 int x1, y1; /* p1 position */
425 register int x, y; /* final position */
426
427 /* compute vector p0p1 */
428 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
429 s1x = p1->x - p0->x;
430 s1y = p1->y - p0->y;
431 l1 = ABS(s1x);
432 if (p1isy = (ABS(s1y) > l1))
433 l1 = ABS(s1y);
434 } else {
435 l1 = s1x = s1y = 1;
436 p1isy = -1;
437 }
438 /* compute vector p0p2 */
439 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
440 s2x = p2->x - p0->x;
441 s2y = p2->y - p0->y;
442 if (p1isy == 1)
443 l2 = ABS(s2x);
444 else {
445 l2 = ABS(s2y);
446 if (p1isy != 0 && ABS(s2x) > l2)
447 l2 = ABS(s2x);
448 }
449 } else
450 l2 = s2x = s2y = 1;
451 /* fill the parallelogram */
452 for (c1 = l1; c1-- > 0; ) {
453 x1 = p0->x + c1*s1x/l1;
454 y1 = p0->y + c1*s1y/l1;
455 for (c2 = l2; c2-- > 0; ) {
456 x = x1 + c2*s2x/l2;
457 if (x < 0 || x >= hresolu)
458 continue;
459 y = y1 + c2*s2y/l2;
460 if (y < 0 || y >= vresolu)
461 continue;
462 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
463 > zeps*zscan(y)[x]) {
464 zscan(y)[x] = z;
465 copycolr(pscan(y)[x], pix);
466 }
467 }
468 }
469 }
470
471
472 backpicture(fill, samp) /* background fill algorithm */
473 int (*fill)();
474 int samp;
475 {
476 int *yback, xback;
477 int y;
478 COLR pfill;
479 register int x, i;
480 /* get back buffer */
481 yback = (int *)malloc(hresolu*sizeof(int));
482 if (yback == NULL)
483 syserror();
484 for (x = 0; x < hresolu; x++)
485 yback[x] = -2;
486 /*
487 * Xback and yback are the pixel locations of suitable
488 * background values in each direction.
489 * A value of -2 means unassigned, and -1 means
490 * that there is no suitable background in this direction.
491 */
492 /* fill image */
493 for (y = 0; y < vresolu; y++) {
494 xback = -2;
495 for (x = 0; x < hresolu; x++)
496 if (zscan(y)[x] <= 0) { /* empty pixel */
497 /*
498 * First, find background from above or below.
499 * (farthest assigned pixel)
500 */
501 if (yback[x] == -2) {
502 for (i = y+1; i < vresolu; i++)
503 if (zscan(i)[x] > 0)
504 break;
505 if (i < vresolu
506 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
507 yback[x] = i;
508 else
509 yback[x] = y-1;
510 }
511 /*
512 * Next, find background from left or right.
513 */
514 if (xback == -2) {
515 for (i = x+1; i < hresolu; i++)
516 if (zscan(y)[i] > 0)
517 break;
518 if (i < hresolu
519 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
520 xback = i;
521 else
522 xback = x-1;
523 }
524 /*
525 * If we have no background for this pixel,
526 * use the given fill function.
527 */
528 if (xback < 0 && yback[x] < 0)
529 goto fillit;
530 /*
531 * Compare, and use the background that is
532 * farther, unless one of them is next to us.
533 * If the background is too distant, call
534 * the fill function.
535 */
536 if ( yback[x] < 0
537 || (xback >= 0 && ABS(x-xback) <= 1)
538 || ( ABS(y-yback[x]) > 1
539 && zscan(yback[x])[x]
540 < zscan(y)[xback] ) ) {
541 if (samp > 0 && ABS(x-xback) >= samp)
542 goto fillit;
543 copycolr(pscan(y)[x],pscan(y)[xback]);
544 zscan(y)[x] = zscan(y)[xback];
545 } else {
546 if (samp > 0 && ABS(y-yback[x]) > samp)
547 goto fillit;
548 copycolr(pscan(y)[x],pscan(yback[x])[x]);
549 zscan(y)[x] = zscan(yback[x])[x];
550 }
551 continue;
552 fillit:
553 (*fill)(x,y);
554 if (fill == rcalfill) { /* use it */
555 clearqueue();
556 xback = x;
557 yback[x] = y;
558 }
559 } else { /* full pixel */
560 yback[x] = -2;
561 xback = -2;
562 }
563 }
564 free((char *)yback);
565 }
566
567
568 fillpicture(fill) /* paint in empty pixels using fill */
569 int (*fill)();
570 {
571 register int x, y;
572
573 for (y = 0; y < vresolu; y++)
574 for (x = 0; x < hresolu; x++)
575 if (zscan(y)[x] <= 0)
576 (*fill)(x,y);
577 }
578
579
580 writepicture() /* write out picture */
581 {
582 int y;
583
584 fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout);
585 for (y = vresolu-1; y >= 0; y--)
586 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
587 syserror();
588 }
589
590
591 writedistance(fname) /* write out z file */
592 char *fname;
593 {
594 extern double sqrt();
595 int donorm = normdist && ourview.type == VT_PER;
596 int fd;
597 int y;
598 float *zout;
599
600 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
601 perror(fname);
602 exit(1);
603 }
604 if (donorm
605 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
606 syserror();
607 for (y = vresolu-1; y >= 0; y--) {
608 if (donorm) {
609 double vx, yzn2;
610 register int x;
611 yzn2 = y - .5*(vresolu-1);
612 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
613 for (x = 0; x < hresolu; x++) {
614 vx = x - .5*(hresolu-1);
615 zout[x] = zscan(y)[x]
616 * sqrt(vx*vx*ourview.hn2 + yzn2);
617 }
618 } else
619 zout = zscan(y);
620 if (write(fd, (char *)zout, hresolu*sizeof(float))
621 < hresolu*sizeof(float)) {
622 perror(fname);
623 exit(1);
624 }
625 }
626 if (donorm)
627 free((char *)zout);
628 close(fd);
629 }
630
631
632 isfloat(s) /* see if string is floating number */
633 register char *s;
634 {
635 for ( ; *s; s++)
636 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
637 && *s != 'e' && *s != 'E' && *s != '+')
638 return(0);
639 return(1);
640 }
641
642
643 backfill(x, y) /* fill pixel with background */
644 int x, y;
645 {
646 register BYTE *dest = pscan(y)[x];
647
648 copycolr(dest, backcolr);
649 zscan(y)[x] = backz;
650 }
651
652
653 calstart(prog, args) /* start fill calculation */
654 char *prog, *args;
655 {
656 char combuf[512];
657 int p0[2], p1[2];
658
659 if (childpid != -1) {
660 fprintf(stderr, "%s: too many calculations\n", progname);
661 exit(1);
662 }
663 sprintf(combuf, prog, args);
664 if (pipe(p0) < 0 || pipe(p1) < 0)
665 syserror();
666 if ((childpid = vfork()) == 0) { /* fork calculation */
667 close(p0[1]);
668 close(p1[0]);
669 if (p0[0] != 0) {
670 dup2(p0[0], 0);
671 close(p0[0]);
672 }
673 if (p1[1] != 1) {
674 dup2(p1[1], 1);
675 close(p1[1]);
676 }
677 execl("/bin/sh", "sh", "-c", combuf, 0);
678 perror("/bin/sh");
679 _exit(127);
680 }
681 if (childpid == -1)
682 syserror();
683 close(p0[0]);
684 close(p1[1]);
685 if ((psend = fdopen(p0[1], "w")) == NULL)
686 syserror();
687 if ((precv = fdopen(p1[0], "r")) == NULL)
688 syserror();
689 queuesiz = 0;
690 }
691
692
693 caldone() /* done with calculation */
694 {
695 int pid;
696
697 if (childpid == -1)
698 return;
699 clearqueue();
700 fclose(psend);
701 fclose(precv);
702 while ((pid = wait(0)) != -1 && pid != childpid)
703 ;
704 childpid = -1;
705 }
706
707
708 rcalfill(x, y) /* fill with ray-calculated pixel */
709 int x, y;
710 {
711 if (queuesiz >= PACKSIZ) /* flush queue if needed */
712 clearqueue();
713 /* add position to queue */
714 queue[queuesiz][0] = x;
715 queue[queuesiz][1] = y;
716 queuesiz++;
717 }
718
719
720 clearqueue() /* process queue */
721 {
722 FVECT orig, dir;
723 float fbuf[6];
724 register int i;
725
726 for (i = 0; i < queuesiz; i++) {
727 viewray(orig, dir, &ourview,
728 (queue[i][0]+.5)/hresolu,
729 (queue[i][1]+.5)/vresolu);
730 fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2];
731 fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2];
732 fwrite((char *)fbuf, sizeof(float), 6, psend);
733 }
734 /* flush output and get results */
735 fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */
736 fwrite((char *)fbuf, sizeof(float), 6, psend);
737 if (fflush(psend) == EOF)
738 syserror();
739 for (i = 0; i < queuesiz; i++) {
740 if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) {
741 fprintf(stderr, "%s: read error in clearqueue\n",
742 progname);
743 exit(1);
744 }
745 if (ourexp > 0 && ourexp != 1.0) {
746 fbuf[0] *= ourexp;
747 fbuf[1] *= ourexp;
748 fbuf[2] *= ourexp;
749 }
750 setcolr(pscan(queue[i][1])[queue[i][0]],
751 fbuf[0], fbuf[1], fbuf[2]);
752 zscan(queue[i][1])[queue[i][0]] = fbuf[3];
753 }
754 queuesiz = 0;
755 }
756
757
758 syserror() /* report error and exit */
759 {
760 perror(progname);
761 exit(1);
762 }
