--- ray/src/px/pinterp.c 1989/12/13 12:41:25 1.4 +++ ray/src/px/pinterp.c 1990/01/03 15:33:44 1.10 @@ -21,7 +21,7 @@ static char SCCSid[] = "$SunId$ LBL"; VIEW ourview = STDVIEW(512); /* desired view */ -double zeps = 0.001; /* allowed z epsilon */ +double zeps = .02; /* allowed z epsilon */ COLR *ourpict; /* output picture */ float *ourzbuf; /* corresponding z-buffer */ @@ -31,7 +31,10 @@ char *progname; VIEW theirview = STDVIEW(512); /* input view */ int gotview; /* got input view? */ +double theirs2ours[4][4]; /* transformation matrix */ +int regdist = 0; /* regular distance? */ + main(argc, argv) /* interpolate pictures */ int argc; char *argv[]; @@ -49,6 +52,18 @@ char *argv[]; check(2,1); zeps = atof(argv[++i]); break; + case 'r': /* regular distance */ + check(2,0); + regdist = !regdist; + break; + case 'x': /* x resolution */ + check(2,1); + ourview.hresolu = atoi(argv[++i]); + break; + case 'y': /* y resolution */ + check(2,1); + ourview.vresolu = atoi(argv[++i]); + break; case 'v': /* view */ switch (argv[i][2]) { case 't': /* type */ @@ -99,16 +114,13 @@ char *argv[]; break; default: badopt: - fprintf(stderr, "%s: unknown option '%s'\n", + fprintf(stderr, "%s: command line error at '%s'\n", progname, argv[i]); - exit(1); + goto userr; } /* check arguments */ - if (argc-i < 2 || (argc-i)%2) { - fprintf(stderr, "Usage: %s [view args] pfile zfile ..\n", - progname); - exit(1); - } + if (argc-i < 2 || (argc-i)%2) + goto userr; /* set view */ if (err = setview(&ourview)) { fprintf(stderr, "%s: %s\n", progname, err); @@ -138,6 +150,11 @@ char *argv[]; writepicture(); exit(0); +userr: + fprintf(stderr, + "Usage: %s [view opts][-t zthresh][-r] pfile zspec ..\n", + progname); + exit(1); #undef check } @@ -159,97 +176,198 @@ char *s; } -addpicture(pfile, zfile) /* add picture to output */ -char *pfile, *zfile; +addpicture(pfile, zspec) /* add picture to output */ +char *pfile, *zspec; { + extern double atof(); FILE *pfp, *zfp; - COLR *scanin; - float *zin; char *err; - int xres, yres; + COLR *scanin; + float *zin, *zlast; + int *plast; int y; - /* open input files */ + /* open picture file */ if ((pfp = fopen(pfile, "r")) == NULL) { perror(pfile); exit(1); } - if ((zfp = fopen(zfile, "r")) == NULL) { - perror(zfile); - exit(1); - } /* get header and view */ printf("%s:\n", pfile); gotview = 0; getheader(pfp, headline); - if (!gotview || fgetresolu(&xres, &yres, pfp) != (YMAJOR|YDECR)) { + if (!gotview || fgetresolu(&theirview.hresolu, &theirview.vresolu, pfp) + != (YMAJOR|YDECR)) { fprintf(stderr, "%s: picture view error\n", pfile); exit(1); } - theirview.hresolu = xres; - theirview.vresolu = yres; if (err = setview(&theirview)) { fprintf(stderr, "%s: %s\n", pfile, err); exit(1); } + /* compute transformation */ + pixform(theirs2ours, &theirview, &ourview); /* allocate scanlines */ - scanin = (COLR *)malloc(xres*sizeof(COLR)); - zin = (float *)malloc(xres*sizeof(float)); - if (scanin == NULL || zin == NULL) { + scanin = (COLR *)malloc(theirview.hresolu*sizeof(COLR)); + zin = (float *)malloc(theirview.hresolu*sizeof(float)); + plast = (int *)calloc(theirview.hresolu, sizeof(int)); + zlast = (float *)calloc(theirview.hresolu, sizeof(float)); + if (scanin == NULL || zin == NULL || plast == NULL || zlast == NULL) { perror(progname); exit(1); } + /* get z specification or file */ + if ((zfp = fopen(zspec, "r")) == NULL) { + double zvalue; + register int x; + if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) { + perror(zspec); + exit(1); + } + for (x = 0; x < theirview.hresolu; x++) + zin[x] = zvalue; + } /* load image */ - for (y = yres-1; y >= 0; y--) { - if (freadcolrs(scanin, xres, pfp) < 0) { + for (y = theirview.vresolu-1; y >= 0; y--) { + if (freadcolrs(scanin, theirview.hresolu, pfp) < 0) { fprintf(stderr, "%s: read error\n", pfile); exit(1); } - if (fread(zin, sizeof(float), xres, zfp) < xres) { - fprintf(stderr, "%s: read error\n", zfile); + if (zfp != NULL + && fread(zin,sizeof(float),theirview.hresolu,zfp) + < theirview.hresolu) { + fprintf(stderr, "%s: read error\n", zspec); exit(1); } - addscanline(y, scanin, zin); + addscanline(y, scanin, zin, plast, zlast); } /* clean up */ free((char *)scanin); free((char *)zin); + free((char *)plast); + free((char *)zlast); fclose(pfp); - fclose(zfp); + if (zfp != NULL) + fclose(zfp); } -addscanline(y, pline, zline) /* add scanline to output */ +pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */ +register double xfmat[4][4]; +register VIEW *vw1, *vw2; +{ + double m4t[4][4]; + + setident4(xfmat); + xfmat[0][0] = vw1->vhinc[0]; + xfmat[0][1] = vw1->vhinc[1]; + xfmat[0][2] = vw1->vhinc[2]; + xfmat[1][0] = vw1->vvinc[0]; + xfmat[1][1] = vw1->vvinc[1]; + xfmat[1][2] = vw1->vvinc[2]; + xfmat[2][0] = vw1->vdir[0]; + xfmat[2][1] = vw1->vdir[1]; + xfmat[2][2] = vw1->vdir[2]; + xfmat[3][0] = vw1->vp[0]; + xfmat[3][1] = vw1->vp[1]; + xfmat[3][2] = vw1->vp[2]; + setident4(m4t); + m4t[0][0] = vw2->vhinc[0]/vw2->vhn2; + m4t[1][0] = vw2->vhinc[1]/vw2->vhn2; + m4t[2][0] = vw2->vhinc[2]/vw2->vhn2; + m4t[3][0] = -DOT(vw2->vp,vw2->vhinc)/vw2->vhn2; + m4t[0][1] = vw2->vvinc[0]/vw2->vvn2; + m4t[1][1] = vw2->vvinc[1]/vw2->vvn2; + m4t[2][1] = vw2->vvinc[2]/vw2->vvn2; + m4t[3][1] = -DOT(vw2->vp,vw2->vvinc)/vw2->vvn2; + m4t[0][2] = vw2->vdir[0]; + m4t[1][2] = vw2->vdir[1]; + m4t[2][2] = vw2->vdir[2]; + m4t[3][2] = -DOT(vw2->vp,vw2->vdir); + multmat4(xfmat, xfmat, m4t); +} + + +addscanline(y, pline, zline, lasty, lastyz) /* add scanline to output */ int y; COLR *pline; float *zline; +int *lasty; /* input/output */ +float *lastyz; /* input/output */ { - FVECT p, dir; - double xnew, ynew, znew; + extern double sqrt(), fabs(); + double pos[3]; + int lastx = 0; + double lastxz = 0; + double zt; + int xpos, ypos; register int x; - register int xpos, ypos; - for (x = 0; x < theirview.hresolu; x++) { - rayview(p, dir, &theirview, x+.5, y+.5); - p[0] += zline[x]*dir[0]; - p[1] += zline[x]*dir[1]; - p[2] += zline[x]*dir[2]; - pixelview(&xnew, &ynew, &znew, &ourview, p); - if (znew <= 0.0 || xnew < 0 || xnew > ourview.hresolu - || ynew < 0 || ynew > ourview.vresolu) + for (x = theirview.hresolu-1; x >= 0; x--) { + pos[0] = x - .5*(theirview.hresolu-1); + pos[1] = y - .5*(theirview.vresolu-1); + pos[2] = zline[x]; + if (theirview.type == VT_PER) { + if (!regdist) /* adjust for eye-ray distance */ + pos[2] /= sqrt( 1. + + pos[0]*pos[0]*theirview.vhn2 + + pos[1]*pos[1]*theirview.vvn2 ); + pos[0] *= pos[2]; + pos[1] *= pos[2]; + } + multp3(pos, pos, theirs2ours); + if (pos[2] <= 0) continue; - /* check current value at position */ - xpos = xnew; - ypos = ynew; - if (zscan(ypos)[xpos] <= 0.0 - || zscan(ypos)[xpos] - znew - > zeps*zscan(ypos)[xpos]) { - zscan(ypos)[xpos] = znew; - copycolr(pscan(ypos)[xpos], pline[x]); + if (ourview.type == VT_PER) { + pos[0] /= pos[2]; + pos[1] /= pos[2]; } + pos[0] += .5*ourview.hresolu; + pos[1] += .5*ourview.vresolu; + if (pos[0] < 0 || (xpos = pos[0]) >= ourview.hresolu + || pos[1] < 0 || (ypos = pos[1]) >= ourview.vresolu) + continue; + /* add pixel to our image */ + zt = 2.*zeps*zline[x]; + addpixel(xpos, ypos, + (fabs(zline[x]-lastxz) <= zt) ? lastx - xpos : 1, + (fabs(zline[x]-lastyz[x]) <= zt) ? lasty[x] - ypos : 1, + pline[x], pos[2]); + lastx = xpos; + lasty[x] = ypos; + lastxz = lastyz[x] = zline[x]; } } +addpixel(xstart, ystart, width, height, pix, z) /* fill in area for pixel */ +int xstart, ystart; +int width, height; +COLR pix; +double z; +{ + register int x, y; + /* make width and height positive */ + if (width < 0) { + width = -width; + xstart = xstart-width+1; + } else if (width == 0) + width = 1; + if (height < 0) { + height = -height; + ystart = ystart-height+1; + } else if (height == 0) + height = 1; + /* fill pixel(s) within rectangle */ + for (y = ystart; y < ystart+height; y++) + for (x = xstart; x < xstart+width; x++) + if (zscan(y)[x] <= 0 + || zscan(y)[x]-z > zeps*zscan(y)[x]) { + zscan(y)[x] = z; + copycolr(pscan(y)[x], pix); + } +} + + fillpicture() /* fill in empty spaces */ { int *yback, xback; @@ -264,14 +382,24 @@ fillpicture() /* fill in empty spaces */ } for (x = 0; x < ourview.hresolu; x++) yback[x] = -2; + /* + * Xback and yback are the pixel locations of suitable + * background values in each direction. + * A value of -2 means unassigned, and -1 means + * that there is no suitable background in this direction. + */ /* fill image */ for (y = 0; y < ourview.vresolu; y++) { xback = -2; for (x = 0; x < ourview.hresolu; x++) - if (zscan(y)[x] <= 0.0) { /* empty pixel */ + if (zscan(y)[x] <= 0) { /* empty pixel */ + /* + * First, find background from above or below. + * (farthest assigned pixel) + */ if (yback[x] == -2) { for (i = y+1; i < ourview.vresolu; i++) - if (zscan(i)[x] > 0.0) + if (zscan(i)[x] > 0) break; if (i < ourview.vresolu && (y <= 0 || zscan(y-1)[x] < zscan(i)[x])) @@ -279,9 +407,12 @@ fillpicture() /* fill in empty spaces */ else yback[x] = y-1; } + /* + * Next, find background from left or right. + */ if (xback == -2) { for (i = x+1; x < ourview.hresolu; i++) - if (zscan(y)[i] > 0.0) + if (zscan(y)[i] > 0) break; if (i < ourview.hresolu && (x <= 0 || zscan(y)[x-1] < zscan(y)[i])) @@ -290,7 +421,11 @@ fillpicture() /* fill in empty spaces */ xback = x-1; } if (xback < 0 && yback[x] < 0) - continue; + continue; /* no background */ + /* + * Compare, and use the background that is + * farther, unless one of them is next to us. + */ if (yback[x] < 0 || ABS(x-xback) <= 1 || ( ABS(y-yback[x]) > 1 && zscan(yback[x])[x] < zscan(y)[xback] )) @@ -316,4 +451,15 @@ writepicture() /* write out picture */ perror(progname); exit(1); } +} + + +isfloat(s) /* see if string is floating number */ +register char *s; +{ + for ( ; *s; s++) + if ((*s < '0' || *s > '9') && *s != '.' && *s != '-' + && *s != 'e' && *s != 'E' && *s != '+') + return(0); + return(1); }
