root/radiance/ray/src/px/pinterp.c
Revision: 2.14
Committed: Wed Dec 21 16:59:03 1994 UTC (30 years, 6 months ago) by greg
added -vo and -va fore and aft clipping plane options
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <ctype.h>
16
17 #include "view.h"
18
19 #include "color.h"
20
21 #include "resolu.h"
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 256 /* max. calculation packet size */
30
31 #define RTCOM "rtrace -h- -ovl -fff "
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fillo = F_FORE|F_BACK; /* selected fill options */
50 int fillsamp = 0; /* sample separation (0 == inf) */
51 extern int backfill(), rcalfill(); /* fill functions */
52 int (*fillfunc)() = backfill; /* selected fill function */
53 COLR backcolr = BLKCOLR; /* background color */
54 double backz = 0.0; /* background z value */
55 int normdist = 1; /* normalized distance? */
56 double ourexp = -1; /* output picture exposure */
57
58 VIEW theirview = STDVIEW; /* input view */
59 int gotview; /* got input view? */
60 int wrongformat = 0; /* input in another format? */
61 RESOLU tresolu; /* input resolution */
62 double theirexp; /* input picture exposure */
63 double theirs2ours[4][4]; /* transformation matrix */
64 int hasmatrix = 0; /* has transformation matrix */
65
66 int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
67 #define childpid (PDesc[2])
68 unsigned short queue[PACKSIZ][2]; /* pending pixels */
69 int packsiz; /* actual packet size */
70 int queuesiz; /* number of pixels pending */
71
72
73 main(argc, argv) /* interpolate pictures */
74 int argc;
75 char *argv[];
76 {
77 #define check(ol,al) if (argv[i][ol] || \
78 badarg(argc-i-1,argv+i+1,al)) \
79 goto badopt
80 int gotvfile = 0;
81 char *zfile = NULL;
82 char *err;
83 int i, rval;
84
85 progname = argv[0];
86
87 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
88 rval = getviewopt(&ourview, argc-i, argv+i);
89 if (rval >= 0) {
90 i += rval;
91 continue;
92 }
93 switch (argv[i][1]) {
94 case 't': /* threshold */
95 check(2,"f");
96 zeps = atof(argv[++i]);
97 break;
98 case 'n': /* dist. normalized? */
99 check(2,NULL);
100 normdist = !normdist;
101 break;
102 case 'f': /* fill type */
103 switch (argv[i][2]) {
104 case '0': /* none */
105 check(3,NULL);
106 fillo = 0;
107 break;
108 case 'f': /* foreground */
109 check(3,NULL);
110 fillo = F_FORE;
111 break;
112 case 'b': /* background */
113 check(3,NULL);
114 fillo = F_BACK;
115 break;
116 case 'a': /* all */
117 check(3,NULL);
118 fillo = F_FORE|F_BACK;
119 break;
120 case 's': /* sample */
121 check(3,"i");
122 fillsamp = atoi(argv[++i]);
123 break;
124 case 'c': /* color */
125 check(3,"fff");
126 fillfunc = backfill;
127 setcolr(backcolr, atof(argv[i+1]),
128 atof(argv[i+2]), atof(argv[i+3]));
129 i += 3;
130 break;
131 case 'z': /* z value */
132 check(3,"f");
133 fillfunc = backfill;
134 backz = atof(argv[++i]);
135 break;
136 case 'r': /* rtrace */
137 check(3,"s");
138 fillfunc = rcalfill;
139 calstart(RTCOM, argv[++i]);
140 break;
141 default:
142 goto badopt;
143 }
144 break;
145 case 'z': /* z file */
146 check(2,"s");
147 zfile = argv[++i];
148 break;
149 case 'x': /* x resolution */
150 check(2,"i");
151 hresolu = atoi(argv[++i]);
152 break;
153 case 'y': /* y resolution */
154 check(2,"i");
155 vresolu = atoi(argv[++i]);
156 break;
157 case 'p': /* pixel aspect */
158 if (argv[i][2] != 'a')
159 goto badopt;
160 check(3,"f");
161 pixaspect = atof(argv[++i]);
162 break;
163 case 'v': /* view file */
164 if (argv[i][2] != 'f')
165 goto badopt;
166 check(3,"s");
167 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
168 if (gotvfile < 0)
169 syserror(argv[i]);
170 else if (gotvfile == 0) {
171 fprintf(stderr, "%s: bad view file\n",
172 argv[i]);
173 exit(1);
174 }
175 break;
176 default:
177 badopt:
178 fprintf(stderr, "%s: command line error at '%s'\n",
179 progname, argv[i]);
180 goto userr;
181 }
182 }
183 /* check arguments */
184 if ((argc-i)%2)
185 goto userr;
186 if (fillsamp == 1)
187 fillo &= ~F_BACK;
188 /* set view */
189 if (ourview.vaft > FTINY)
190 err = "no aft clipping plane allowed";
191 else
192 err = setview(&ourview);
193 if (err != NULL) {
194 fprintf(stderr, "%s: %s\n", progname, err);
195 exit(1);
196 }
197 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
198 /* allocate frame */
199 ourpict = (COLR *)bmalloc(hresolu*vresolu*sizeof(COLR));
200 ourzbuf = (float *)bmalloc(hresolu*vresolu*sizeof(float));
201 if (ourpict == NULL || ourzbuf == NULL)
202 syserror(progname);
203 bzero((char *)ourzbuf, hresolu*vresolu*sizeof(float));
204 /* new header */
205 newheader("RADIANCE", stdout);
206 /* get input */
207 for ( ; i < argc; i += 2)
208 addpicture(argv[i], argv[i+1]);
209 /* fill in spaces */
210 if (fillo&F_BACK)
211 backpicture(fillfunc, fillsamp);
212 else
213 fillpicture(fillfunc);
214 /* close calculation */
215 caldone();
216 /* add to header */
217 printargs(argc, argv, stdout);
218 if (gotvfile) {
219 fputs(VIEWSTR, stdout);
220 fprintview(&ourview, stdout);
221 putc('\n', stdout);
222 }
223 if (pixaspect < .99 || pixaspect > 1.01)
224 fputaspect(pixaspect, stdout);
225 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
226 fputexpos(ourexp, stdout);
227 fputformat(COLRFMT, stdout);
228 putc('\n', stdout);
229 /* write picture */
230 writepicture();
231 /* write z file */
232 if (zfile != NULL)
233 writedistance(zfile);
234
235 exit(0);
236 userr:
237 fprintf(stderr,
238 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
239 progname);
240 exit(1);
241 #undef check
242 }
243
244
245 headline(s) /* process header string */
246 char *s;
247 {
248 char fmt[32];
249
250 if (isheadid(s))
251 return;
252 if (formatval(fmt, s)) {
253 wrongformat = strcmp(fmt, COLRFMT);
254 return;
255 }
256 putc('\t', stdout);
257 fputs(s, stdout);
258
259 if (isexpos(s)) {
260 theirexp *= exposval(s);
261 return;
262 }
263 if (isview(s) && sscanview(&theirview, s) > 0)
264 gotview++;
265 }
266
267
268 addpicture(pfile, zspec) /* add picture to output */
269 char *pfile, *zspec;
270 {
271 FILE *pfp;
272 int zfd;
273 char *err;
274 COLR *scanin;
275 float *zin;
276 struct position *plast;
277 int y;
278 /* open picture file */
279 if ((pfp = fopen(pfile, "r")) == NULL)
280 syserror(pfile);
281 /* get header with exposure and view */
282 theirexp = 1.0;
283 gotview = 0;
284 printf("%s:\n", pfile);
285 getheader(pfp, headline, NULL);
286 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
287 fprintf(stderr, "%s: picture format error\n", pfile);
288 exit(1);
289 }
290 if (ourexp <= 0)
291 ourexp = theirexp;
292 else if (ABS(theirexp-ourexp) > .01*ourexp)
293 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
294 if (err = setview(&theirview)) {
295 fprintf(stderr, "%s: %s\n", pfile, err);
296 exit(1);
297 }
298 /* compute transformation */
299 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
300 /* allocate scanlines */
301 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
302 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
303 plast = (struct position *)calloc(scanlen(&tresolu),
304 sizeof(struct position));
305 if (scanin == NULL || zin == NULL || plast == NULL)
306 syserror(progname);
307 /* get z specification or file */
308 if ((zfd = open(zspec, O_RDONLY)) == -1) {
309 double zvalue;
310 register int x;
311 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0)
312 syserror(zspec);
313 for (x = scanlen(&tresolu); x-- > 0; )
314 zin[x] = zvalue;
315 }
316 /* load image */
317 for (y = 0; y < numscans(&tresolu); y++) {
318 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
319 fprintf(stderr, "%s: read error\n", pfile);
320 exit(1);
321 }
322 if (zfd != -1 && read(zfd,(char *)zin,
323 scanlen(&tresolu)*sizeof(float))
324 < scanlen(&tresolu)*sizeof(float)) {
325 fprintf(stderr, "%s: read error\n", zspec);
326 exit(1);
327 }
328 addscanline(y, scanin, zin, plast);
329 }
330 /* clean up */
331 free((char *)scanin);
332 free((char *)zin);
333 free((char *)plast);
334 fclose(pfp);
335 if (zfd != -1)
336 close(zfd);
337 }
338
339
340 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
341 register double xfmat[4][4];
342 register VIEW *vw1, *vw2;
343 {
344 double m4t[4][4];
345
346 if (vw1->type != VT_PER && vw1->type != VT_PAR)
347 return(0);
348 if (vw2->type != VT_PER && vw2->type != VT_PAR)
349 return(0);
350 setident4(xfmat);
351 xfmat[0][0] = vw1->hvec[0];
352 xfmat[0][1] = vw1->hvec[1];
353 xfmat[0][2] = vw1->hvec[2];
354 xfmat[1][0] = vw1->vvec[0];
355 xfmat[1][1] = vw1->vvec[1];
356 xfmat[1][2] = vw1->vvec[2];
357 xfmat[2][0] = vw1->vdir[0];
358 xfmat[2][1] = vw1->vdir[1];
359 xfmat[2][2] = vw1->vdir[2];
360 xfmat[3][0] = vw1->vp[0];
361 xfmat[3][1] = vw1->vp[1];
362 xfmat[3][2] = vw1->vp[2];
363 setident4(m4t);
364 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
365 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
366 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
367 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
368 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
369 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
370 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
371 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
372 m4t[0][2] = vw2->vdir[0];
373 m4t[1][2] = vw2->vdir[1];
374 m4t[2][2] = vw2->vdir[2];
375 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
376 multmat4(xfmat, xfmat, m4t);
377 return(1);
378 }
379
380
381 addscanline(y, pline, zline, lasty) /* add scanline to output */
382 int y;
383 COLR *pline;
384 float *zline;
385 struct position *lasty; /* input/output */
386 {
387 FVECT pos;
388 struct position lastx, newpos;
389 register int x;
390
391 lastx.z = 0;
392 for (x = scanlen(&tresolu); x-- > 0; ) {
393 pix2loc(pos, &tresolu, x, y);
394 pos[2] = zline[x];
395 if (movepixel(pos) < 0) {
396 lasty[x].z = lastx.z = 0; /* mark invalid */
397 continue;
398 }
399 newpos.x = pos[0] * hresolu;
400 newpos.y = pos[1] * vresolu;
401 newpos.z = zline[x];
402 /* add pixel to our image */
403 if (pos[0] >= 0 && newpos.x < hresolu
404 && pos[1] >= 0 && newpos.y < vresolu) {
405 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
406 lasty[x].x = lastx.x = newpos.x;
407 lasty[x].y = lastx.y = newpos.y;
408 lasty[x].z = lastx.z = newpos.z;
409 } else
410 lasty[x].z = lastx.z = 0; /* mark invalid */
411 }
412 }
413
414
415 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
416 struct position *p0, *p1, *p2;
417 COLR pix;
418 double z;
419 {
420 double zt = 2.*zeps*p0->z; /* threshold */
421 int s1x, s1y, s2x, s2y; /* step sizes */
422 int l1, l2, c1, c2; /* side lengths and counters */
423 int p1isy; /* p0p1 along y? */
424 int x1, y1; /* p1 position */
425 register int x, y; /* final position */
426
427 /* compute vector p0p1 */
428 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
429 s1x = p1->x - p0->x;
430 s1y = p1->y - p0->y;
431 l1 = ABS(s1x);
432 if (p1isy = (ABS(s1y) > l1))
433 l1 = ABS(s1y);
434 } else {
435 l1 = s1x = s1y = 1;
436 p1isy = -1;
437 }
438 /* compute vector p0p2 */
439 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
440 s2x = p2->x - p0->x;
441 s2y = p2->y - p0->y;
442 if (p1isy == 1)
443 l2 = ABS(s2x);
444 else {
445 l2 = ABS(s2y);
446 if (p1isy != 0 && ABS(s2x) > l2)
447 l2 = ABS(s2x);
448 }
449 } else
450 l2 = s2x = s2y = 1;
451 /* fill the parallelogram */
452 for (c1 = l1; c1-- > 0; ) {
453 x1 = p0->x + c1*s1x/l1;
454 y1 = p0->y + c1*s1y/l1;
455 for (c2 = l2; c2-- > 0; ) {
456 x = x1 + c2*s2x/l2;
457 if (x < 0 || x >= hresolu)
458 continue;
459 y = y1 + c2*s2y/l2;
460 if (y < 0 || y >= vresolu)
461 continue;
462 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
463 > zeps*zscan(y)[x]) {
464 zscan(y)[x] = z;
465 copycolr(pscan(y)[x], pix);
466 }
467 }
468 }
469 }
470
471
472 movepixel(pos) /* reposition image point */
473 FVECT pos;
474 {
475 FVECT pt, direc;
476
477 if (pos[2] <= 0) /* empty pixel */
478 return(-1);
479 if (hasmatrix) {
480 pos[0] += theirview.hoff - .5;
481 pos[1] += theirview.voff - .5;
482 if (theirview.type == VT_PER) {
483 if (normdist) /* adjust for eye-ray distance */
484 pos[2] /= sqrt( 1.
485 + pos[0]*pos[0]*theirview.hn2
486 + pos[1]*pos[1]*theirview.vn2 );
487 pos[0] *= pos[2];
488 pos[1] *= pos[2];
489 }
490 multp3(pos, pos, theirs2ours);
491 if (pos[2] <= 0)
492 return(-1);
493 if (ourview.type == VT_PER) {
494 pos[0] /= pos[2];
495 pos[1] /= pos[2];
496 }
497 pos[0] += .5 - ourview.hoff;
498 pos[1] += .5 - ourview.voff;
499 return(0);
500 }
501 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < -FTINY)
502 return(-1);
503 pt[0] += direc[0]*pos[2];
504 pt[1] += direc[1]*pos[2];
505 pt[2] += direc[2]*pos[2];
506 viewloc(pos, &ourview, pt);
507 if (pos[2] <= 0)
508 return(-1);
509 return(0);
510 }
511
512
513 backpicture(fill, samp) /* background fill algorithm */
514 int (*fill)();
515 int samp;
516 {
517 int *yback, xback;
518 int y;
519 register int x, i;
520 /* get back buffer */
521 yback = (int *)malloc(hresolu*sizeof(int));
522 if (yback == NULL)
523 syserror(progname);
524 for (x = 0; x < hresolu; x++)
525 yback[x] = -2;
526 /*
527 * Xback and yback are the pixel locations of suitable
528 * background values in each direction.
529 * A value of -2 means unassigned, and -1 means
530 * that there is no suitable background in this direction.
531 */
532 /* fill image */
533 for (y = 0; y < vresolu; y++) {
534 xback = -2;
535 for (x = 0; x < hresolu; x++)
536 if (zscan(y)[x] <= 0) { /* empty pixel */
537 /*
538 * First, find background from above or below.
539 * (farthest assigned pixel)
540 */
541 if (yback[x] == -2) {
542 for (i = y+1; i < vresolu; i++)
543 if (zscan(i)[x] > 0)
544 break;
545 if (i < vresolu
546 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
547 yback[x] = i;
548 else
549 yback[x] = y-1;
550 }
551 /*
552 * Next, find background from left or right.
553 */
554 if (xback == -2) {
555 for (i = x+1; i < hresolu; i++)
556 if (zscan(y)[i] > 0)
557 break;
558 if (i < hresolu
559 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
560 xback = i;
561 else
562 xback = x-1;
563 }
564 /*
565 * If we have no background for this pixel,
566 * use the given fill function.
567 */
568 if (xback < 0 && yback[x] < 0)
569 goto fillit;
570 /*
571 * Compare, and use the background that is
572 * farther, unless one of them is next to us.
573 * If the background is too distant, call
574 * the fill function.
575 */
576 if ( yback[x] < 0
577 || (xback >= 0 && ABS(x-xback) <= 1)
578 || ( ABS(y-yback[x]) > 1
579 && zscan(yback[x])[x]
580 < zscan(y)[xback] ) ) {
581 if (samp > 0 && ABS(x-xback) >= samp)
582 goto fillit;
583 copycolr(pscan(y)[x],pscan(y)[xback]);
584 zscan(y)[x] = zscan(y)[xback];
585 } else {
586 if (samp > 0 && ABS(y-yback[x]) > samp)
587 goto fillit;
588 copycolr(pscan(y)[x],pscan(yback[x])[x]);
589 zscan(y)[x] = zscan(yback[x])[x];
590 }
591 continue;
592 fillit:
593 (*fill)(x,y);
594 if (fill == rcalfill) { /* use it */
595 clearqueue();
596 xback = x;
597 yback[x] = y;
598 }
599 } else { /* full pixel */
600 yback[x] = -2;
601 xback = -2;
602 }
603 }
604 free((char *)yback);
605 }
606
607
608 fillpicture(fill) /* paint in empty pixels using fill */
609 int (*fill)();
610 {
611 register int x, y;
612
613 for (y = 0; y < vresolu; y++)
614 for (x = 0; x < hresolu; x++)
615 if (zscan(y)[x] <= 0)
616 (*fill)(x,y);
617 }
618
619
620 writepicture() /* write out picture */
621 {
622 int y;
623
624 fprtresolu(hresolu, vresolu, stdout);
625 for (y = vresolu-1; y >= 0; y--)
626 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
627 syserror(progname);
628 }
629
630
631 writedistance(fname) /* write out z file */
632 char *fname;
633 {
634 int donorm = normdist && ourview.type == VT_PER;
635 int fd;
636 int y;
637 float *zout;
638
639 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1)
640 syserror(fname);
641 if (donorm
642 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
643 syserror(progname);
644 for (y = vresolu-1; y >= 0; y--) {
645 if (donorm) {
646 double vx, yzn2;
647 register int x;
648 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
649 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
650 for (x = 0; x < hresolu; x++) {
651 vx = (x+.5)/hresolu + ourview.hoff - .5;
652 zout[x] = zscan(y)[x]
653 * sqrt(vx*vx*ourview.hn2 + yzn2);
654 }
655 } else
656 zout = zscan(y);
657 if (write(fd, (char *)zout, hresolu*sizeof(float))
658 < hresolu*sizeof(float))
659 syserror(fname);
660 }
661 if (donorm)
662 free((char *)zout);
663 close(fd);
664 }
665
666
667 isfloat(s) /* see if string is floating number */
668 register char *s;
669 {
670 for ( ; *s; s++)
671 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
672 && *s != 'e' && *s != 'E' && *s != '+')
673 return(0);
674 return(1);
675 }
676
677
678 backfill(x, y) /* fill pixel with background */
679 int x, y;
680 {
681 register BYTE *dest = pscan(y)[x];
682
683 copycolr(dest, backcolr);
684 zscan(y)[x] = backz;
685 }
686
687
688 calstart(prog, args) /* start fill calculation */
689 char *prog, *args;
690 {
691 char combuf[512];
692 char *argv[64];
693 int rval;
694 register char **wp, *cp;
695
696 if (childpid != -1) {
697 fprintf(stderr, "%s: too many calculations\n", progname);
698 exit(1);
699 }
700 strcpy(combuf, prog);
701 strcat(combuf, args);
702 cp = combuf;
703 wp = argv;
704 for ( ; ; ) {
705 while (isspace(*cp)) /* nullify spaces */
706 *cp++ = '\0';
707 if (!*cp) /* all done? */
708 break;
709 *wp++ = cp; /* add argument to list */
710 while (*++cp && !isspace(*cp))
711 ;
712 }
713 *wp = NULL;
714 /* start process */
715 if ((rval = open_process(PDesc, argv)) < 0)
716 syserror(progname);
717 if (rval == 0) {
718 fprintf(stderr, "%s: command not found\n", argv[0]);
719 exit(1);
720 }
721 packsiz = rval/(6*sizeof(float)) - 1;
722 if (packsiz > PACKSIZ)
723 packsiz = PACKSIZ;
724 queuesiz = 0;
725 }
726
727
728 caldone() /* done with calculation */
729 {
730 if (childpid == -1)
731 return;
732 clearqueue();
733 close_process(PDesc);
734 childpid = -1;
735 }
736
737
738 rcalfill(x, y) /* fill with ray-calculated pixel */
739 int x, y;
740 {
741 if (queuesiz >= packsiz) /* flush queue if needed */
742 clearqueue();
743 /* add position to queue */
744 queue[queuesiz][0] = x;
745 queue[queuesiz][1] = y;
746 queuesiz++;
747 }
748
749
750 clearqueue() /* process queue */
751 {
752 FVECT orig, dir;
753 float fbuf[6*(PACKSIZ+1)];
754 register float *fbp;
755 register int i;
756
757 if (queuesiz == 0)
758 return;
759 fbp = fbuf;
760 for (i = 0; i < queuesiz; i++) {
761 viewray(orig, dir, &ourview,
762 (queue[i][0]+.5)/hresolu,
763 (queue[i][1]+.5)/vresolu);
764 *fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
765 *fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
766 }
767 /* mark end and get results */
768 bzero((char *)fbp, 6*sizeof(float));
769 if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
770 6*sizeof(float)*(queuesiz+1)) !=
771 4*sizeof(float)*queuesiz) {
772 fprintf(stderr, "%s: error reading from rtrace process\n",
773 progname);
774 exit(1);
775 }
776 fbp = fbuf;
777 for (i = 0; i < queuesiz; i++) {
778 if (ourexp > 0 && ourexp != 1.0) {
779 fbp[0] *= ourexp;
780 fbp[1] *= ourexp;
781 fbp[2] *= ourexp;
782 }
783 setcolr(pscan(queue[i][1])[queue[i][0]],
784 fbp[0], fbp[1], fbp[2]);
785 zscan(queue[i][1])[queue[i][0]] = fbp[3];
786 fbp += 4;
787 }
788 queuesiz = 0;
789 }
790
791
792 syserror(s) /* report error and exit */
793 char *s;
794 {
795 perror(s);
796 exit(1);
797 }
