root/radiance/ray/src/px/pinterp.c
Revision: 2.13
Committed: Sun Feb 27 10:16:57 1994 UTC (31 years, 4 months ago) by greg
Changes since 2.12: +5 -2 lines
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <ctype.h>
16
17 #include "view.h"
18
19 #include "color.h"
20
21 #include "resolu.h"
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 256 /* max. calculation packet size */
30
31 #define RTCOM "rtrace -h- -ovl -fff "
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fillo = F_FORE|F_BACK; /* selected fill options */
50 int fillsamp = 0; /* sample separation (0 == inf) */
51 extern int backfill(), rcalfill(); /* fill functions */
52 int (*fillfunc)() = backfill; /* selected fill function */
53 COLR backcolr = BLKCOLR; /* background color */
54 double backz = 0.0; /* background z value */
55 int normdist = 1; /* normalized distance? */
56 double ourexp = -1; /* output picture exposure */
57
58 VIEW theirview = STDVIEW; /* input view */
59 int gotview; /* got input view? */
60 int wrongformat = 0; /* input in another format? */
61 RESOLU tresolu; /* input resolution */
62 double theirexp; /* input picture exposure */
63 double theirs2ours[4][4]; /* transformation matrix */
64 int hasmatrix = 0; /* has transformation matrix */
65
66 int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
67 #define childpid (PDesc[2])
68 unsigned short queue[PACKSIZ][2]; /* pending pixels */
69 int packsiz; /* actual packet size */
70 int queuesiz; /* number of pixels pending */
71
72
73 main(argc, argv) /* interpolate pictures */
74 int argc;
75 char *argv[];
76 {
77 #define check(ol,al) if (argv[i][ol] || \
78 badarg(argc-i-1,argv+i+1,al)) \
79 goto badopt
80 int gotvfile = 0;
81 char *zfile = NULL;
82 char *err;
83 int i, rval;
84
85 progname = argv[0];
86
87 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
88 rval = getviewopt(&ourview, argc-i, argv+i);
89 if (rval >= 0) {
90 i += rval;
91 continue;
92 }
93 switch (argv[i][1]) {
94 case 't': /* threshold */
95 check(2,"f");
96 zeps = atof(argv[++i]);
97 break;
98 case 'n': /* dist. normalized? */
99 check(2,NULL);
100 normdist = !normdist;
101 break;
102 case 'f': /* fill type */
103 switch (argv[i][2]) {
104 case '0': /* none */
105 check(3,NULL);
106 fillo = 0;
107 break;
108 case 'f': /* foreground */
109 check(3,NULL);
110 fillo = F_FORE;
111 break;
112 case 'b': /* background */
113 check(3,NULL);
114 fillo = F_BACK;
115 break;
116 case 'a': /* all */
117 check(3,NULL);
118 fillo = F_FORE|F_BACK;
119 break;
120 case 's': /* sample */
121 check(3,"i");
122 fillsamp = atoi(argv[++i]);
123 break;
124 case 'c': /* color */
125 check(3,"fff");
126 fillfunc = backfill;
127 setcolr(backcolr, atof(argv[i+1]),
128 atof(argv[i+2]), atof(argv[i+3]));
129 i += 3;
130 break;
131 case 'z': /* z value */
132 check(3,"f");
133 fillfunc = backfill;
134 backz = atof(argv[++i]);
135 break;
136 case 'r': /* rtrace */
137 check(3,"s");
138 fillfunc = rcalfill;
139 calstart(RTCOM, argv[++i]);
140 break;
141 default:
142 goto badopt;
143 }
144 break;
145 case 'z': /* z file */
146 check(2,"s");
147 zfile = argv[++i];
148 break;
149 case 'x': /* x resolution */
150 check(2,"i");
151 hresolu = atoi(argv[++i]);
152 break;
153 case 'y': /* y resolution */
154 check(2,"i");
155 vresolu = atoi(argv[++i]);
156 break;
157 case 'p': /* pixel aspect */
158 if (argv[i][2] != 'a')
159 goto badopt;
160 check(3,"f");
161 pixaspect = atof(argv[++i]);
162 break;
163 case 'v': /* view file */
164 if (argv[i][2] != 'f')
165 goto badopt;
166 check(3,"s");
167 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
168 if (gotvfile < 0)
169 syserror(argv[i]);
170 else if (gotvfile == 0) {
171 fprintf(stderr, "%s: bad view file\n",
172 argv[i]);
173 exit(1);
174 }
175 break;
176 default:
177 badopt:
178 fprintf(stderr, "%s: command line error at '%s'\n",
179 progname, argv[i]);
180 goto userr;
181 }
182 }
183 /* check arguments */
184 if ((argc-i)%2)
185 goto userr;
186 if (fillsamp == 1)
187 fillo &= ~F_BACK;
188 /* set view */
189 if (err = setview(&ourview)) {
190 fprintf(stderr, "%s: %s\n", progname, err);
191 exit(1);
192 }
193 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
194 /* allocate frame */
195 ourpict = (COLR *)bmalloc(hresolu*vresolu*sizeof(COLR));
196 ourzbuf = (float *)bmalloc(hresolu*vresolu*sizeof(float));
197 if (ourpict == NULL || ourzbuf == NULL)
198 syserror(progname);
199 bzero((char *)ourzbuf, hresolu*vresolu*sizeof(float));
200 /* new header */
201 newheader("RADIANCE", stdout);
202 /* get input */
203 for ( ; i < argc; i += 2)
204 addpicture(argv[i], argv[i+1]);
205 /* fill in spaces */
206 if (fillo&F_BACK)
207 backpicture(fillfunc, fillsamp);
208 else
209 fillpicture(fillfunc);
210 /* close calculation */
211 caldone();
212 /* add to header */
213 printargs(argc, argv, stdout);
214 if (gotvfile) {
215 fputs(VIEWSTR, stdout);
216 fprintview(&ourview, stdout);
217 putc('\n', stdout);
218 }
219 if (pixaspect < .99 || pixaspect > 1.01)
220 fputaspect(pixaspect, stdout);
221 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
222 fputexpos(ourexp, stdout);
223 fputformat(COLRFMT, stdout);
224 putc('\n', stdout);
225 /* write picture */
226 writepicture();
227 /* write z file */
228 if (zfile != NULL)
229 writedistance(zfile);
230
231 exit(0);
232 userr:
233 fprintf(stderr,
234 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
235 progname);
236 exit(1);
237 #undef check
238 }
239
240
241 headline(s) /* process header string */
242 char *s;
243 {
244 char fmt[32];
245
246 if (isheadid(s))
247 return;
248 if (formatval(fmt, s)) {
249 wrongformat = strcmp(fmt, COLRFMT);
250 return;
251 }
252 putc('\t', stdout);
253 fputs(s, stdout);
254
255 if (isexpos(s)) {
256 theirexp *= exposval(s);
257 return;
258 }
259 if (isview(s) && sscanview(&theirview, s) > 0)
260 gotview++;
261 }
262
263
264 addpicture(pfile, zspec) /* add picture to output */
265 char *pfile, *zspec;
266 {
267 FILE *pfp;
268 int zfd;
269 char *err;
270 COLR *scanin;
271 float *zin;
272 struct position *plast;
273 int y;
274 /* open picture file */
275 if ((pfp = fopen(pfile, "r")) == NULL)
276 syserror(pfile);
277 /* get header with exposure and view */
278 theirexp = 1.0;
279 gotview = 0;
280 printf("%s:\n", pfile);
281 getheader(pfp, headline, NULL);
282 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
283 fprintf(stderr, "%s: picture format error\n", pfile);
284 exit(1);
285 }
286 if (ourexp <= 0)
287 ourexp = theirexp;
288 else if (ABS(theirexp-ourexp) > .01*ourexp)
289 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
290 if (err = setview(&theirview)) {
291 fprintf(stderr, "%s: %s\n", pfile, err);
292 exit(1);
293 }
294 /* compute transformation */
295 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
296 /* allocate scanlines */
297 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
298 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
299 plast = (struct position *)calloc(scanlen(&tresolu),
300 sizeof(struct position));
301 if (scanin == NULL || zin == NULL || plast == NULL)
302 syserror(progname);
303 /* get z specification or file */
304 if ((zfd = open(zspec, O_RDONLY)) == -1) {
305 double zvalue;
306 register int x;
307 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0)
308 syserror(zspec);
309 for (x = scanlen(&tresolu); x-- > 0; )
310 zin[x] = zvalue;
311 }
312 /* load image */
313 for (y = 0; y < numscans(&tresolu); y++) {
314 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
315 fprintf(stderr, "%s: read error\n", pfile);
316 exit(1);
317 }
318 if (zfd != -1 && read(zfd,(char *)zin,
319 scanlen(&tresolu)*sizeof(float))
320 < scanlen(&tresolu)*sizeof(float)) {
321 fprintf(stderr, "%s: read error\n", zspec);
322 exit(1);
323 }
324 addscanline(y, scanin, zin, plast);
325 }
326 /* clean up */
327 free((char *)scanin);
328 free((char *)zin);
329 free((char *)plast);
330 fclose(pfp);
331 if (zfd != -1)
332 close(zfd);
333 }
334
335
336 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
337 register double xfmat[4][4];
338 register VIEW *vw1, *vw2;
339 {
340 double m4t[4][4];
341
342 if (vw1->type != VT_PER && vw1->type != VT_PAR)
343 return(0);
344 if (vw2->type != VT_PER && vw2->type != VT_PAR)
345 return(0);
346 setident4(xfmat);
347 xfmat[0][0] = vw1->hvec[0];
348 xfmat[0][1] = vw1->hvec[1];
349 xfmat[0][2] = vw1->hvec[2];
350 xfmat[1][0] = vw1->vvec[0];
351 xfmat[1][1] = vw1->vvec[1];
352 xfmat[1][2] = vw1->vvec[2];
353 xfmat[2][0] = vw1->vdir[0];
354 xfmat[2][1] = vw1->vdir[1];
355 xfmat[2][2] = vw1->vdir[2];
356 xfmat[3][0] = vw1->vp[0];
357 xfmat[3][1] = vw1->vp[1];
358 xfmat[3][2] = vw1->vp[2];
359 setident4(m4t);
360 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
361 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
362 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
363 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
364 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
365 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
366 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
367 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
368 m4t[0][2] = vw2->vdir[0];
369 m4t[1][2] = vw2->vdir[1];
370 m4t[2][2] = vw2->vdir[2];
371 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
372 multmat4(xfmat, xfmat, m4t);
373 return(1);
374 }
375
376
377 addscanline(y, pline, zline, lasty) /* add scanline to output */
378 int y;
379 COLR *pline;
380 float *zline;
381 struct position *lasty; /* input/output */
382 {
383 FVECT pos;
384 struct position lastx, newpos;
385 register int x;
386
387 lastx.z = 0;
388 for (x = scanlen(&tresolu); x-- > 0; ) {
389 pix2loc(pos, &tresolu, x, y);
390 pos[2] = zline[x];
391 if (movepixel(pos) < 0) {
392 lasty[x].z = lastx.z = 0; /* mark invalid */
393 continue;
394 }
395 newpos.x = pos[0] * hresolu;
396 newpos.y = pos[1] * vresolu;
397 newpos.z = zline[x];
398 /* add pixel to our image */
399 if (pos[0] >= 0 && newpos.x < hresolu
400 && pos[1] >= 0 && newpos.y < vresolu) {
401 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
402 lasty[x].x = lastx.x = newpos.x;
403 lasty[x].y = lastx.y = newpos.y;
404 lasty[x].z = lastx.z = newpos.z;
405 } else
406 lasty[x].z = lastx.z = 0; /* mark invalid */
407 }
408 }
409
410
411 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
412 struct position *p0, *p1, *p2;
413 COLR pix;
414 double z;
415 {
416 double zt = 2.*zeps*p0->z; /* threshold */
417 int s1x, s1y, s2x, s2y; /* step sizes */
418 int l1, l2, c1, c2; /* side lengths and counters */
419 int p1isy; /* p0p1 along y? */
420 int x1, y1; /* p1 position */
421 register int x, y; /* final position */
422
423 /* compute vector p0p1 */
424 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
425 s1x = p1->x - p0->x;
426 s1y = p1->y - p0->y;
427 l1 = ABS(s1x);
428 if (p1isy = (ABS(s1y) > l1))
429 l1 = ABS(s1y);
430 } else {
431 l1 = s1x = s1y = 1;
432 p1isy = -1;
433 }
434 /* compute vector p0p2 */
435 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
436 s2x = p2->x - p0->x;
437 s2y = p2->y - p0->y;
438 if (p1isy == 1)
439 l2 = ABS(s2x);
440 else {
441 l2 = ABS(s2y);
442 if (p1isy != 0 && ABS(s2x) > l2)
443 l2 = ABS(s2x);
444 }
445 } else
446 l2 = s2x = s2y = 1;
447 /* fill the parallelogram */
448 for (c1 = l1; c1-- > 0; ) {
449 x1 = p0->x + c1*s1x/l1;
450 y1 = p0->y + c1*s1y/l1;
451 for (c2 = l2; c2-- > 0; ) {
452 x = x1 + c2*s2x/l2;
453 if (x < 0 || x >= hresolu)
454 continue;
455 y = y1 + c2*s2y/l2;
456 if (y < 0 || y >= vresolu)
457 continue;
458 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
459 > zeps*zscan(y)[x]) {
460 zscan(y)[x] = z;
461 copycolr(pscan(y)[x], pix);
462 }
463 }
464 }
465 }
466
467
468 movepixel(pos) /* reposition image point */
469 FVECT pos;
470 {
471 FVECT pt, direc;
472
473 if (pos[2] <= 0) /* empty pixel */
474 return(-1);
475 if (hasmatrix) {
476 pos[0] += theirview.hoff - .5;
477 pos[1] += theirview.voff - .5;
478 if (theirview.type == VT_PER) {
479 if (normdist) /* adjust for eye-ray distance */
480 pos[2] /= sqrt( 1.
481 + pos[0]*pos[0]*theirview.hn2
482 + pos[1]*pos[1]*theirview.vn2 );
483 pos[0] *= pos[2];
484 pos[1] *= pos[2];
485 }
486 multp3(pos, pos, theirs2ours);
487 if (pos[2] <= 0)
488 return(-1);
489 if (ourview.type == VT_PER) {
490 pos[0] /= pos[2];
491 pos[1] /= pos[2];
492 }
493 pos[0] += .5 - ourview.hoff;
494 pos[1] += .5 - ourview.voff;
495 return(0);
496 }
497 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
498 return(-1);
499 pt[0] += direc[0]*pos[2];
500 pt[1] += direc[1]*pos[2];
501 pt[2] += direc[2]*pos[2];
502 viewloc(pos, &ourview, pt);
503 if (pos[2] <= 0)
504 return(-1);
505 return(0);
506 }
507
508
509 backpicture(fill, samp) /* background fill algorithm */
510 int (*fill)();
511 int samp;
512 {
513 int *yback, xback;
514 int y;
515 register int x, i;
516 /* get back buffer */
517 yback = (int *)malloc(hresolu*sizeof(int));
518 if (yback == NULL)
519 syserror(progname);
520 for (x = 0; x < hresolu; x++)
521 yback[x] = -2;
522 /*
523 * Xback and yback are the pixel locations of suitable
524 * background values in each direction.
525 * A value of -2 means unassigned, and -1 means
526 * that there is no suitable background in this direction.
527 */
528 /* fill image */
529 for (y = 0; y < vresolu; y++) {
530 xback = -2;
531 for (x = 0; x < hresolu; x++)
532 if (zscan(y)[x] <= 0) { /* empty pixel */
533 /*
534 * First, find background from above or below.
535 * (farthest assigned pixel)
536 */
537 if (yback[x] == -2) {
538 for (i = y+1; i < vresolu; i++)
539 if (zscan(i)[x] > 0)
540 break;
541 if (i < vresolu
542 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
543 yback[x] = i;
544 else
545 yback[x] = y-1;
546 }
547 /*
548 * Next, find background from left or right.
549 */
550 if (xback == -2) {
551 for (i = x+1; i < hresolu; i++)
552 if (zscan(y)[i] > 0)
553 break;
554 if (i < hresolu
555 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
556 xback = i;
557 else
558 xback = x-1;
559 }
560 /*
561 * If we have no background for this pixel,
562 * use the given fill function.
563 */
564 if (xback < 0 && yback[x] < 0)
565 goto fillit;
566 /*
567 * Compare, and use the background that is
568 * farther, unless one of them is next to us.
569 * If the background is too distant, call
570 * the fill function.
571 */
572 if ( yback[x] < 0
573 || (xback >= 0 && ABS(x-xback) <= 1)
574 || ( ABS(y-yback[x]) > 1
575 && zscan(yback[x])[x]
576 < zscan(y)[xback] ) ) {
577 if (samp > 0 && ABS(x-xback) >= samp)
578 goto fillit;
579 copycolr(pscan(y)[x],pscan(y)[xback]);
580 zscan(y)[x] = zscan(y)[xback];
581 } else {
582 if (samp > 0 && ABS(y-yback[x]) > samp)
583 goto fillit;
584 copycolr(pscan(y)[x],pscan(yback[x])[x]);
585 zscan(y)[x] = zscan(yback[x])[x];
586 }
587 continue;
588 fillit:
589 (*fill)(x,y);
590 if (fill == rcalfill) { /* use it */
591 clearqueue();
592 xback = x;
593 yback[x] = y;
594 }
595 } else { /* full pixel */
596 yback[x] = -2;
597 xback = -2;
598 }
599 }
600 free((char *)yback);
601 }
602
603
604 fillpicture(fill) /* paint in empty pixels using fill */
605 int (*fill)();
606 {
607 register int x, y;
608
609 for (y = 0; y < vresolu; y++)
610 for (x = 0; x < hresolu; x++)
611 if (zscan(y)[x] <= 0)
612 (*fill)(x,y);
613 }
614
615
616 writepicture() /* write out picture */
617 {
618 int y;
619
620 fprtresolu(hresolu, vresolu, stdout);
621 for (y = vresolu-1; y >= 0; y--)
622 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
623 syserror(progname);
624 }
625
626
627 writedistance(fname) /* write out z file */
628 char *fname;
629 {
630 int donorm = normdist && ourview.type == VT_PER;
631 int fd;
632 int y;
633 float *zout;
634
635 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1)
636 syserror(fname);
637 if (donorm
638 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
639 syserror(progname);
640 for (y = vresolu-1; y >= 0; y--) {
641 if (donorm) {
642 double vx, yzn2;
643 register int x;
644 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
645 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
646 for (x = 0; x < hresolu; x++) {
647 vx = (x+.5)/hresolu + ourview.hoff - .5;
648 zout[x] = zscan(y)[x]
649 * sqrt(vx*vx*ourview.hn2 + yzn2);
650 }
651 } else
652 zout = zscan(y);
653 if (write(fd, (char *)zout, hresolu*sizeof(float))
654 < hresolu*sizeof(float))
655 syserror(fname);
656 }
657 if (donorm)
658 free((char *)zout);
659 close(fd);
660 }
661
662
663 isfloat(s) /* see if string is floating number */
664 register char *s;
665 {
666 for ( ; *s; s++)
667 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
668 && *s != 'e' && *s != 'E' && *s != '+')
669 return(0);
670 return(1);
671 }
672
673
674 backfill(x, y) /* fill pixel with background */
675 int x, y;
676 {
677 register BYTE *dest = pscan(y)[x];
678
679 copycolr(dest, backcolr);
680 zscan(y)[x] = backz;
681 }
682
683
684 calstart(prog, args) /* start fill calculation */
685 char *prog, *args;
686 {
687 char combuf[512];
688 char *argv[64];
689 int rval;
690 register char **wp, *cp;
691
692 if (childpid != -1) {
693 fprintf(stderr, "%s: too many calculations\n", progname);
694 exit(1);
695 }
696 strcpy(combuf, prog);
697 strcat(combuf, args);
698 cp = combuf;
699 wp = argv;
700 for ( ; ; ) {
701 while (isspace(*cp)) /* nullify spaces */
702 *cp++ = '\0';
703 if (!*cp) /* all done? */
704 break;
705 *wp++ = cp; /* add argument to list */
706 while (*++cp && !isspace(*cp))
707 ;
708 }
709 *wp = NULL;
710 /* start process */
711 if ((rval = open_process(PDesc, argv)) < 0)
712 syserror(progname);
713 if (rval == 0) {
714 fprintf(stderr, "%s: command not found\n", argv[0]);
715 exit(1);
716 }
717 packsiz = rval/(6*sizeof(float)) - 1;
718 if (packsiz > PACKSIZ)
719 packsiz = PACKSIZ;
720 queuesiz = 0;
721 }
722
723
724 caldone() /* done with calculation */
725 {
726 if (childpid == -1)
727 return;
728 clearqueue();
729 close_process(PDesc);
730 childpid = -1;
731 }
732
733
734 rcalfill(x, y) /* fill with ray-calculated pixel */
735 int x, y;
736 {
737 if (queuesiz >= packsiz) /* flush queue if needed */
738 clearqueue();
739 /* add position to queue */
740 queue[queuesiz][0] = x;
741 queue[queuesiz][1] = y;
742 queuesiz++;
743 }
744
745
746 clearqueue() /* process queue */
747 {
748 FVECT orig, dir;
749 float fbuf[6*(PACKSIZ+1)];
750 register float *fbp;
751 register int i;
752
753 if (queuesiz == 0)
754 return;
755 fbp = fbuf;
756 for (i = 0; i < queuesiz; i++) {
757 viewray(orig, dir, &ourview,
758 (queue[i][0]+.5)/hresolu,
759 (queue[i][1]+.5)/vresolu);
760 *fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
761 *fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
762 }
763 /* mark end and get results */
764 bzero((char *)fbp, 6*sizeof(float));
765 if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
766 6*sizeof(float)*(queuesiz+1)) !=
767 4*sizeof(float)*queuesiz) {
768 fprintf(stderr, "%s: error reading from rtrace process\n",
769 progname);
770 exit(1);
771 }
772 fbp = fbuf;
773 for (i = 0; i < queuesiz; i++) {
774 if (ourexp > 0 && ourexp != 1.0) {
775 fbp[0] *= ourexp;
776 fbp[1] *= ourexp;
777 fbp[2] *= ourexp;
778 }
779 setcolr(pscan(queue[i][1])[queue[i][0]],
780 fbp[0], fbp[1], fbp[2]);
781 zscan(queue[i][1])[queue[i][0]] = fbp[3];
782 fbp += 4;
783 }
784 queuesiz = 0;
785 }
786
787
788 syserror(s) /* report error and exit */
789 char *s;
790 {
791 perror(s);
792 exit(1);
793 }
