root/radiance/ray/src/px/pinterp.c
Revision: 2.11
Committed: Fri Apr 2 09:10:48 1993 UTC (32 years, 4 months ago) by greg
Changes since 2.10: +7 -7 lines
minor change in argument parsing in calstart()
1 /* Copyright (c) 1993 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <ctype.h>
16
17 #include "view.h"
18
19 #include "color.h"
20
21 #include "resolu.h"
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 256 /* max. calculation packet size */
30
31 #define RTCOM "rtrace -h- -ovl -fff "
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fillo = F_FORE|F_BACK; /* selected fill options */
50 int fillsamp = 0; /* sample separation (0 == inf) */
51 extern int backfill(), rcalfill(); /* fill functions */
52 int (*fillfunc)() = backfill; /* selected fill function */
53 COLR backcolr = BLKCOLR; /* background color */
54 double backz = 0.0; /* background z value */
55 int normdist = 1; /* normalized distance? */
56 double ourexp = -1; /* output picture exposure */
57
58 VIEW theirview = STDVIEW; /* input view */
59 int gotview; /* got input view? */
60 int wrongformat = 0; /* input in another format? */
61 RESOLU tresolu; /* input resolution */
62 double theirexp; /* input picture exposure */
63 double theirs2ours[4][4]; /* transformation matrix */
64 int hasmatrix = 0; /* has transformation matrix */
65
66 int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
67 #define childpid (PDesc[2])
68 unsigned short queue[PACKSIZ][2]; /* pending pixels */
69 int packsiz; /* actual packet size */
70 int queuesiz; /* number of pixels pending */
71
72
73 main(argc, argv) /* interpolate pictures */
74 int argc;
75 char *argv[];
76 {
77 #define check(ol,al) if (argv[i][ol] || \
78 badarg(argc-i-1,argv+i+1,al)) \
79 goto badopt
80 int gotvfile = 0;
81 char *zfile = NULL;
82 char *err;
83 int i, rval;
84
85 progname = argv[0];
86
87 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
88 rval = getviewopt(&ourview, argc-i, argv+i);
89 if (rval >= 0) {
90 i += rval;
91 continue;
92 }
93 switch (argv[i][1]) {
94 case 't': /* threshold */
95 check(2,"f");
96 zeps = atof(argv[++i]);
97 break;
98 case 'n': /* dist. normalized? */
99 check(2,NULL);
100 normdist = !normdist;
101 break;
102 case 'f': /* fill type */
103 switch (argv[i][2]) {
104 case '0': /* none */
105 check(3,NULL);
106 fillo = 0;
107 break;
108 case 'f': /* foreground */
109 check(3,NULL);
110 fillo = F_FORE;
111 break;
112 case 'b': /* background */
113 check(3,NULL);
114 fillo = F_BACK;
115 break;
116 case 'a': /* all */
117 check(3,NULL);
118 fillo = F_FORE|F_BACK;
119 break;
120 case 's': /* sample */
121 check(3,"i");
122 fillsamp = atoi(argv[++i]);
123 break;
124 case 'c': /* color */
125 check(3,"fff");
126 fillfunc = backfill;
127 setcolr(backcolr, atof(argv[i+1]),
128 atof(argv[i+2]), atof(argv[i+3]));
129 i += 3;
130 break;
131 case 'z': /* z value */
132 check(3,"f");
133 fillfunc = backfill;
134 backz = atof(argv[++i]);
135 break;
136 case 'r': /* rtrace */
137 check(3,"s");
138 fillfunc = rcalfill;
139 calstart(RTCOM, argv[++i]);
140 break;
141 default:
142 goto badopt;
143 }
144 break;
145 case 'z': /* z file */
146 check(2,"s");
147 zfile = argv[++i];
148 break;
149 case 'x': /* x resolution */
150 check(2,"i");
151 hresolu = atoi(argv[++i]);
152 break;
153 case 'y': /* y resolution */
154 check(2,"i");
155 vresolu = atoi(argv[++i]);
156 break;
157 case 'p': /* pixel aspect */
158 if (argv[i][2] != 'a')
159 goto badopt;
160 check(3,"f");
161 pixaspect = atof(argv[++i]);
162 break;
163 case 'v': /* view file */
164 if (argv[i][2] != 'f')
165 goto badopt;
166 check(3,"s");
167 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
168 if (gotvfile < 0)
169 syserror(argv[i]);
170 else if (gotvfile == 0) {
171 fprintf(stderr, "%s: bad view file\n",
172 argv[i]);
173 exit(1);
174 }
175 break;
176 default:
177 badopt:
178 fprintf(stderr, "%s: command line error at '%s'\n",
179 progname, argv[i]);
180 goto userr;
181 }
182 }
183 /* check arguments */
184 if ((argc-i)%2)
185 goto userr;
186 if (fillsamp == 1)
187 fillo &= ~F_BACK;
188 /* set view */
189 if (err = setview(&ourview)) {
190 fprintf(stderr, "%s: %s\n", progname, err);
191 exit(1);
192 }
193 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
194 /* allocate frame */
195 ourpict = (COLR *)bmalloc(hresolu*vresolu*sizeof(COLR));
196 ourzbuf = (float *)bmalloc(hresolu*vresolu*sizeof(float));
197 if (ourpict == NULL || ourzbuf == NULL)
198 syserror(progname);
199 bzero((char *)ourzbuf, hresolu*vresolu*sizeof(float));
200 /* get input */
201 for ( ; i < argc; i += 2)
202 addpicture(argv[i], argv[i+1]);
203 /* fill in spaces */
204 if (fillo&F_BACK)
205 backpicture(fillfunc, fillsamp);
206 else
207 fillpicture(fillfunc);
208 /* close calculation */
209 caldone();
210 /* add to header */
211 printargs(argc, argv, stdout);
212 if (gotvfile) {
213 fputs(VIEWSTR, stdout);
214 fprintview(&ourview, stdout);
215 putc('\n', stdout);
216 }
217 if (pixaspect < .99 || pixaspect > 1.01)
218 fputaspect(pixaspect, stdout);
219 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
220 fputexpos(ourexp, stdout);
221 fputformat(COLRFMT, stdout);
222 putc('\n', stdout);
223 /* write picture */
224 writepicture();
225 /* write z file */
226 if (zfile != NULL)
227 writedistance(zfile);
228
229 exit(0);
230 userr:
231 fprintf(stderr,
232 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
233 progname);
234 exit(1);
235 #undef check
236 }
237
238
239 headline(s) /* process header string */
240 char *s;
241 {
242 char fmt[32];
243
244 if (isformat(s)) {
245 formatval(fmt, s);
246 wrongformat = strcmp(fmt, COLRFMT);
247 return;
248 }
249 putc('\t', stdout);
250 fputs(s, stdout);
251
252 if (isexpos(s)) {
253 theirexp *= exposval(s);
254 return;
255 }
256 if (isview(s) && sscanview(&theirview, s) > 0)
257 gotview++;
258 }
259
260
261 addpicture(pfile, zspec) /* add picture to output */
262 char *pfile, *zspec;
263 {
264 FILE *pfp;
265 int zfd;
266 char *err;
267 COLR *scanin;
268 float *zin;
269 struct position *plast;
270 int y;
271 /* open picture file */
272 if ((pfp = fopen(pfile, "r")) == NULL)
273 syserror(pfile);
274 /* get header with exposure and view */
275 theirexp = 1.0;
276 gotview = 0;
277 printf("%s:\n", pfile);
278 getheader(pfp, headline, NULL);
279 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
280 fprintf(stderr, "%s: picture format error\n", pfile);
281 exit(1);
282 }
283 if (ourexp <= 0)
284 ourexp = theirexp;
285 else if (ABS(theirexp-ourexp) > .01*ourexp)
286 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
287 if (err = setview(&theirview)) {
288 fprintf(stderr, "%s: %s\n", pfile, err);
289 exit(1);
290 }
291 /* compute transformation */
292 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
293 /* allocate scanlines */
294 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
295 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
296 plast = (struct position *)calloc(scanlen(&tresolu),
297 sizeof(struct position));
298 if (scanin == NULL || zin == NULL || plast == NULL)
299 syserror(progname);
300 /* get z specification or file */
301 if ((zfd = open(zspec, O_RDONLY)) == -1) {
302 double zvalue;
303 register int x;
304 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0)
305 syserror(zspec);
306 exit(1);
307 for (x = scanlen(&tresolu); x-- > 0; )
308 zin[x] = zvalue;
309 }
310 /* load image */
311 for (y = 0; y < numscans(&tresolu); y++) {
312 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
313 fprintf(stderr, "%s: read error\n", pfile);
314 exit(1);
315 }
316 if (zfd != -1 && read(zfd,(char *)zin,
317 scanlen(&tresolu)*sizeof(float))
318 < scanlen(&tresolu)*sizeof(float)) {
319 fprintf(stderr, "%s: read error\n", zspec);
320 exit(1);
321 }
322 addscanline(y, scanin, zin, plast);
323 }
324 /* clean up */
325 free((char *)scanin);
326 free((char *)zin);
327 free((char *)plast);
328 fclose(pfp);
329 if (zfd != -1)
330 close(zfd);
331 }
332
333
334 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
335 register double xfmat[4][4];
336 register VIEW *vw1, *vw2;
337 {
338 double m4t[4][4];
339
340 if (vw1->type != VT_PER && vw1->type != VT_PAR)
341 return(0);
342 if (vw2->type != VT_PER && vw2->type != VT_PAR)
343 return(0);
344 setident4(xfmat);
345 xfmat[0][0] = vw1->hvec[0];
346 xfmat[0][1] = vw1->hvec[1];
347 xfmat[0][2] = vw1->hvec[2];
348 xfmat[1][0] = vw1->vvec[0];
349 xfmat[1][1] = vw1->vvec[1];
350 xfmat[1][2] = vw1->vvec[2];
351 xfmat[2][0] = vw1->vdir[0];
352 xfmat[2][1] = vw1->vdir[1];
353 xfmat[2][2] = vw1->vdir[2];
354 xfmat[3][0] = vw1->vp[0];
355 xfmat[3][1] = vw1->vp[1];
356 xfmat[3][2] = vw1->vp[2];
357 setident4(m4t);
358 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
359 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
360 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
361 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
362 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
363 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
364 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
365 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
366 m4t[0][2] = vw2->vdir[0];
367 m4t[1][2] = vw2->vdir[1];
368 m4t[2][2] = vw2->vdir[2];
369 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
370 multmat4(xfmat, xfmat, m4t);
371 return(1);
372 }
373
374
375 addscanline(y, pline, zline, lasty) /* add scanline to output */
376 int y;
377 COLR *pline;
378 float *zline;
379 struct position *lasty; /* input/output */
380 {
381 FVECT pos;
382 struct position lastx, newpos;
383 register int x;
384
385 lastx.z = 0;
386 for (x = scanlen(&tresolu); x-- > 0; ) {
387 pix2loc(pos, &tresolu, x, y);
388 pos[2] = zline[x];
389 if (movepixel(pos) < 0) {
390 lasty[x].z = lastx.z = 0; /* mark invalid */
391 continue;
392 }
393 newpos.x = pos[0] * hresolu;
394 newpos.y = pos[1] * vresolu;
395 newpos.z = zline[x];
396 /* add pixel to our image */
397 if (pos[0] >= 0 && newpos.x < hresolu
398 && pos[1] >= 0 && newpos.y < vresolu) {
399 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
400 lasty[x].x = lastx.x = newpos.x;
401 lasty[x].y = lastx.y = newpos.y;
402 lasty[x].z = lastx.z = newpos.z;
403 } else
404 lasty[x].z = lastx.z = 0; /* mark invalid */
405 }
406 }
407
408
409 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
410 struct position *p0, *p1, *p2;
411 COLR pix;
412 double z;
413 {
414 double zt = 2.*zeps*p0->z; /* threshold */
415 int s1x, s1y, s2x, s2y; /* step sizes */
416 int l1, l2, c1, c2; /* side lengths and counters */
417 int p1isy; /* p0p1 along y? */
418 int x1, y1; /* p1 position */
419 register int x, y; /* final position */
420
421 /* compute vector p0p1 */
422 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
423 s1x = p1->x - p0->x;
424 s1y = p1->y - p0->y;
425 l1 = ABS(s1x);
426 if (p1isy = (ABS(s1y) > l1))
427 l1 = ABS(s1y);
428 } else {
429 l1 = s1x = s1y = 1;
430 p1isy = -1;
431 }
432 /* compute vector p0p2 */
433 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
434 s2x = p2->x - p0->x;
435 s2y = p2->y - p0->y;
436 if (p1isy == 1)
437 l2 = ABS(s2x);
438 else {
439 l2 = ABS(s2y);
440 if (p1isy != 0 && ABS(s2x) > l2)
441 l2 = ABS(s2x);
442 }
443 } else
444 l2 = s2x = s2y = 1;
445 /* fill the parallelogram */
446 for (c1 = l1; c1-- > 0; ) {
447 x1 = p0->x + c1*s1x/l1;
448 y1 = p0->y + c1*s1y/l1;
449 for (c2 = l2; c2-- > 0; ) {
450 x = x1 + c2*s2x/l2;
451 if (x < 0 || x >= hresolu)
452 continue;
453 y = y1 + c2*s2y/l2;
454 if (y < 0 || y >= vresolu)
455 continue;
456 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
457 > zeps*zscan(y)[x]) {
458 zscan(y)[x] = z;
459 copycolr(pscan(y)[x], pix);
460 }
461 }
462 }
463 }
464
465
466 movepixel(pos) /* reposition image point */
467 FVECT pos;
468 {
469 FVECT pt, direc;
470
471 if (pos[2] <= 0) /* empty pixel */
472 return(-1);
473 if (hasmatrix) {
474 pos[0] += theirview.hoff - .5;
475 pos[1] += theirview.voff - .5;
476 if (theirview.type == VT_PER) {
477 if (normdist) /* adjust for eye-ray distance */
478 pos[2] /= sqrt( 1.
479 + pos[0]*pos[0]*theirview.hn2
480 + pos[1]*pos[1]*theirview.vn2 );
481 pos[0] *= pos[2];
482 pos[1] *= pos[2];
483 }
484 multp3(pos, pos, theirs2ours);
485 if (pos[2] <= 0)
486 return(-1);
487 if (ourview.type == VT_PER) {
488 pos[0] /= pos[2];
489 pos[1] /= pos[2];
490 }
491 pos[0] += .5 - ourview.hoff;
492 pos[1] += .5 - ourview.voff;
493 return(0);
494 }
495 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
496 return(-1);
497 pt[0] += direc[0]*pos[2];
498 pt[1] += direc[1]*pos[2];
499 pt[2] += direc[2]*pos[2];
500 viewloc(pos, &ourview, pt);
501 if (pos[2] <= 0)
502 return(-1);
503 return(0);
504 }
505
506
507 backpicture(fill, samp) /* background fill algorithm */
508 int (*fill)();
509 int samp;
510 {
511 int *yback, xback;
512 int y;
513 register int x, i;
514 /* get back buffer */
515 yback = (int *)malloc(hresolu*sizeof(int));
516 if (yback == NULL)
517 syserror(progname);
518 for (x = 0; x < hresolu; x++)
519 yback[x] = -2;
520 /*
521 * Xback and yback are the pixel locations of suitable
522 * background values in each direction.
523 * A value of -2 means unassigned, and -1 means
524 * that there is no suitable background in this direction.
525 */
526 /* fill image */
527 for (y = 0; y < vresolu; y++) {
528 xback = -2;
529 for (x = 0; x < hresolu; x++)
530 if (zscan(y)[x] <= 0) { /* empty pixel */
531 /*
532 * First, find background from above or below.
533 * (farthest assigned pixel)
534 */
535 if (yback[x] == -2) {
536 for (i = y+1; i < vresolu; i++)
537 if (zscan(i)[x] > 0)
538 break;
539 if (i < vresolu
540 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
541 yback[x] = i;
542 else
543 yback[x] = y-1;
544 }
545 /*
546 * Next, find background from left or right.
547 */
548 if (xback == -2) {
549 for (i = x+1; i < hresolu; i++)
550 if (zscan(y)[i] > 0)
551 break;
552 if (i < hresolu
553 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
554 xback = i;
555 else
556 xback = x-1;
557 }
558 /*
559 * If we have no background for this pixel,
560 * use the given fill function.
561 */
562 if (xback < 0 && yback[x] < 0)
563 goto fillit;
564 /*
565 * Compare, and use the background that is
566 * farther, unless one of them is next to us.
567 * If the background is too distant, call
568 * the fill function.
569 */
570 if ( yback[x] < 0
571 || (xback >= 0 && ABS(x-xback) <= 1)
572 || ( ABS(y-yback[x]) > 1
573 && zscan(yback[x])[x]
574 < zscan(y)[xback] ) ) {
575 if (samp > 0 && ABS(x-xback) >= samp)
576 goto fillit;
577 copycolr(pscan(y)[x],pscan(y)[xback]);
578 zscan(y)[x] = zscan(y)[xback];
579 } else {
580 if (samp > 0 && ABS(y-yback[x]) > samp)
581 goto fillit;
582 copycolr(pscan(y)[x],pscan(yback[x])[x]);
583 zscan(y)[x] = zscan(yback[x])[x];
584 }
585 continue;
586 fillit:
587 (*fill)(x,y);
588 if (fill == rcalfill) { /* use it */
589 clearqueue();
590 xback = x;
591 yback[x] = y;
592 }
593 } else { /* full pixel */
594 yback[x] = -2;
595 xback = -2;
596 }
597 }
598 free((char *)yback);
599 }
600
601
602 fillpicture(fill) /* paint in empty pixels using fill */
603 int (*fill)();
604 {
605 register int x, y;
606
607 for (y = 0; y < vresolu; y++)
608 for (x = 0; x < hresolu; x++)
609 if (zscan(y)[x] <= 0)
610 (*fill)(x,y);
611 }
612
613
614 writepicture() /* write out picture */
615 {
616 int y;
617
618 fprtresolu(hresolu, vresolu, stdout);
619 for (y = vresolu-1; y >= 0; y--)
620 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
621 syserror(progname);
622 }
623
624
625 writedistance(fname) /* write out z file */
626 char *fname;
627 {
628 int donorm = normdist && ourview.type == VT_PER;
629 int fd;
630 int y;
631 float *zout;
632
633 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1)
634 syserror(fname);
635 if (donorm
636 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
637 syserror(progname);
638 for (y = vresolu-1; y >= 0; y--) {
639 if (donorm) {
640 double vx, yzn2;
641 register int x;
642 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
643 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
644 for (x = 0; x < hresolu; x++) {
645 vx = (x+.5)/hresolu + ourview.hoff - .5;
646 zout[x] = zscan(y)[x]
647 * sqrt(vx*vx*ourview.hn2 + yzn2);
648 }
649 } else
650 zout = zscan(y);
651 if (write(fd, (char *)zout, hresolu*sizeof(float))
652 < hresolu*sizeof(float))
653 syserror(fname);
654 }
655 if (donorm)
656 free((char *)zout);
657 close(fd);
658 }
659
660
661 isfloat(s) /* see if string is floating number */
662 register char *s;
663 {
664 for ( ; *s; s++)
665 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
666 && *s != 'e' && *s != 'E' && *s != '+')
667 return(0);
668 return(1);
669 }
670
671
672 backfill(x, y) /* fill pixel with background */
673 int x, y;
674 {
675 register BYTE *dest = pscan(y)[x];
676
677 copycolr(dest, backcolr);
678 zscan(y)[x] = backz;
679 }
680
681
682 calstart(prog, args) /* start fill calculation */
683 char *prog, *args;
684 {
685 char combuf[512];
686 char *argv[64];
687 int rval;
688 register char **wp, *cp;
689
690 if (childpid != -1) {
691 fprintf(stderr, "%s: too many calculations\n", progname);
692 exit(1);
693 }
694 strcpy(combuf, prog);
695 strcat(combuf, args);
696 cp = combuf;
697 wp = argv;
698 for ( ; ; ) {
699 while (isspace(*cp)) /* nullify spaces */
700 *cp++ = '\0';
701 if (!*cp) /* all done? */
702 break;
703 *wp++ = cp; /* add argument to list */
704 while (*++cp && !isspace(*cp))
705 ;
706 }
707 *wp = NULL;
708 /* start process */
709 if ((rval = open_process(PDesc, argv)) < 0)
710 syserror(progname);
711 if (rval == 0) {
712 fprintf(stderr, "%s: command not found\n", argv[0]);
713 exit(1);
714 }
715 packsiz = rval/(6*sizeof(float)) - 1;
716 if (packsiz > PACKSIZ)
717 packsiz = PACKSIZ;
718 queuesiz = 0;
719 }
720
721
722 caldone() /* done with calculation */
723 {
724 if (childpid == -1)
725 return;
726 clearqueue();
727 close_process(PDesc);
728 childpid = -1;
729 }
730
731
732 rcalfill(x, y) /* fill with ray-calculated pixel */
733 int x, y;
734 {
735 if (queuesiz >= packsiz) /* flush queue if needed */
736 clearqueue();
737 /* add position to queue */
738 queue[queuesiz][0] = x;
739 queue[queuesiz][1] = y;
740 queuesiz++;
741 }
742
743
744 clearqueue() /* process queue */
745 {
746 FVECT orig, dir;
747 float fbuf[6*(PACKSIZ+1)];
748 register float *fbp;
749 register int i;
750
751 if (queuesiz == 0)
752 return;
753 fbp = fbuf;
754 for (i = 0; i < queuesiz; i++) {
755 viewray(orig, dir, &ourview,
756 (queue[i][0]+.5)/hresolu,
757 (queue[i][1]+.5)/vresolu);
758 *fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
759 *fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
760 }
761 /* mark end and get results */
762 bzero((char *)fbp, 6*sizeof(float));
763 if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
764 6*sizeof(float)*(queuesiz+1)) !=
765 4*sizeof(float)*queuesiz) {
766 fprintf(stderr, "%s: error reading from rtrace process\n",
767 progname);
768 exit(1);
769 }
770 fbp = fbuf;
771 for (i = 0; i < queuesiz; i++) {
772 if (ourexp > 0 && ourexp != 1.0) {
773 fbp[0] *= ourexp;
774 fbp[1] *= ourexp;
775 fbp[2] *= ourexp;
776 }
777 setcolr(pscan(queue[i][1])[queue[i][0]],
778 fbp[0], fbp[1], fbp[2]);
779 zscan(queue[i][1])[queue[i][0]] = fbp[3];
780 fbp += 4;
781 }
782 queuesiz = 0;
783 }
784
785
786 syserror(s) /* report error and exit */
787 char *s;
788 {
789 perror(s);
790 exit(1);
791 }
