root/radiance/ray/src/px/pinterp.c
Revision: 1.10
Committed: Wed Jan 3 15:33:44 1990 UTC (35 years, 7 months ago) by greg
Changes since 1.9: +49 -25 lines
added constant z specification and -r option
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Interpolate and extrapolate pictures with different view parameters.
7 *
8 * Greg Ward 09Dec89
9 */
10
11 #include "standard.h"
12
13 #include "view.h"
14
15 #include "color.h"
16
17 #define pscan(y) (ourpict+(y)*ourview.hresolu)
18 #define zscan(y) (ourzbuf+(y)*ourview.hresolu)
19
20 #define ABS(x) ((x)>0?(x):-(x))
21
22 VIEW ourview = STDVIEW(512); /* desired view */
23
24 double zeps = .02; /* allowed z epsilon */
25
26 COLR *ourpict; /* output picture */
27 float *ourzbuf; /* corresponding z-buffer */
28
29 char *progname;
30
31 VIEW theirview = STDVIEW(512); /* input view */
32 int gotview; /* got input view? */
33
34 double theirs2ours[4][4]; /* transformation matrix */
35 int regdist = 0; /* regular distance? */
36
37
38 main(argc, argv) /* interpolate pictures */
39 int argc;
40 char *argv[];
41 {
42 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
43 int gotvfile = 0;
44 char *err;
45 int i;
46
47 progname = argv[0];
48
49 for (i = 1; i < argc && argv[i][0] == '-'; i++)
50 switch (argv[i][1]) {
51 case 't': /* threshold */
52 check(2,1);
53 zeps = atof(argv[++i]);
54 break;
55 case 'r': /* regular distance */
56 check(2,0);
57 regdist = !regdist;
58 break;
59 case 'x': /* x resolution */
60 check(2,1);
61 ourview.hresolu = atoi(argv[++i]);
62 break;
63 case 'y': /* y resolution */
64 check(2,1);
65 ourview.vresolu = atoi(argv[++i]);
66 break;
67 case 'v': /* view */
68 switch (argv[i][2]) {
69 case 't': /* type */
70 check(4,0);
71 ourview.type = argv[i][3];
72 break;
73 case 'p': /* point */
74 check(3,3);
75 ourview.vp[0] = atof(argv[++i]);
76 ourview.vp[1] = atof(argv[++i]);
77 ourview.vp[2] = atof(argv[++i]);
78 break;
79 case 'd': /* direction */
80 check(3,3);
81 ourview.vdir[0] = atof(argv[++i]);
82 ourview.vdir[1] = atof(argv[++i]);
83 ourview.vdir[2] = atof(argv[++i]);
84 break;
85 case 'u': /* up */
86 check(3,3);
87 ourview.vup[0] = atof(argv[++i]);
88 ourview.vup[1] = atof(argv[++i]);
89 ourview.vup[2] = atof(argv[++i]);
90 break;
91 case 'h': /* horizontal */
92 check(3,1);
93 ourview.horiz = atof(argv[++i]);
94 break;
95 case 'v': /* vertical */
96 check(3,1);
97 ourview.vert = atof(argv[++i]);
98 break;
99 case 'f': /* file */
100 check(3,1);
101 gotvfile = viewfile(argv[++i], &ourview);
102 if (gotvfile < 0) {
103 perror(argv[i]);
104 exit(1);
105 } else if (gotvfile == 0) {
106 fprintf(stderr, "%s: bad view file\n",
107 argv[i]);
108 exit(1);
109 }
110 break;
111 default:
112 goto badopt;
113 }
114 break;
115 default:
116 badopt:
117 fprintf(stderr, "%s: command line error at '%s'\n",
118 progname, argv[i]);
119 goto userr;
120 }
121 /* check arguments */
122 if (argc-i < 2 || (argc-i)%2)
123 goto userr;
124 /* set view */
125 if (err = setview(&ourview)) {
126 fprintf(stderr, "%s: %s\n", progname, err);
127 exit(1);
128 }
129 /* allocate frame */
130 ourpict = (COLR *)calloc(ourview.hresolu*ourview.vresolu,sizeof(COLR));
131 ourzbuf = (float *)calloc(ourview.hresolu*ourview.vresolu,sizeof(float));
132 if (ourpict == NULL || ourzbuf == NULL) {
133 perror(progname);
134 exit(1);
135 }
136 /* get input */
137 for ( ; i < argc; i += 2)
138 addpicture(argv[i], argv[i+1]);
139 /* fill in spaces */
140 fillpicture();
141 /* add to header */
142 printargs(argc, argv, stdout);
143 if (gotvfile) {
144 printf(VIEWSTR);
145 fprintview(&ourview, stdout);
146 printf("\n");
147 }
148 printf("\n");
149 /* write output */
150 writepicture();
151
152 exit(0);
153 userr:
154 fprintf(stderr,
155 "Usage: %s [view opts][-t zthresh][-r] pfile zspec ..\n",
156 progname);
157 exit(1);
158 #undef check
159 }
160
161
162 headline(s) /* process header string */
163 char *s;
164 {
165 static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL};
166 register char **an;
167
168 printf("\t%s", s);
169
170 for (an = altname; *an != NULL; an++)
171 if (!strncmp(*an, s, strlen(*an))) {
172 if (sscanview(&theirview, s+strlen(*an)) == 0)
173 gotview++;
174 break;
175 }
176 }
177
178
179 addpicture(pfile, zspec) /* add picture to output */
180 char *pfile, *zspec;
181 {
182 extern double atof();
183 FILE *pfp, *zfp;
184 char *err;
185 COLR *scanin;
186 float *zin, *zlast;
187 int *plast;
188 int y;
189 /* open picture file */
190 if ((pfp = fopen(pfile, "r")) == NULL) {
191 perror(pfile);
192 exit(1);
193 }
194 /* get header and view */
195 printf("%s:\n", pfile);
196 gotview = 0;
197 getheader(pfp, headline);
198 if (!gotview || fgetresolu(&theirview.hresolu, &theirview.vresolu, pfp)
199 != (YMAJOR|YDECR)) {
200 fprintf(stderr, "%s: picture view error\n", pfile);
201 exit(1);
202 }
203 if (err = setview(&theirview)) {
204 fprintf(stderr, "%s: %s\n", pfile, err);
205 exit(1);
206 }
207 /* compute transformation */
208 pixform(theirs2ours, &theirview, &ourview);
209 /* allocate scanlines */
210 scanin = (COLR *)malloc(theirview.hresolu*sizeof(COLR));
211 zin = (float *)malloc(theirview.hresolu*sizeof(float));
212 plast = (int *)calloc(theirview.hresolu, sizeof(int));
213 zlast = (float *)calloc(theirview.hresolu, sizeof(float));
214 if (scanin == NULL || zin == NULL || plast == NULL || zlast == NULL) {
215 perror(progname);
216 exit(1);
217 }
218 /* get z specification or file */
219 if ((zfp = fopen(zspec, "r")) == NULL) {
220 double zvalue;
221 register int x;
222 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
223 perror(zspec);
224 exit(1);
225 }
226 for (x = 0; x < theirview.hresolu; x++)
227 zin[x] = zvalue;
228 }
229 /* load image */
230 for (y = theirview.vresolu-1; y >= 0; y--) {
231 if (freadcolrs(scanin, theirview.hresolu, pfp) < 0) {
232 fprintf(stderr, "%s: read error\n", pfile);
233 exit(1);
234 }
235 if (zfp != NULL
236 && fread(zin,sizeof(float),theirview.hresolu,zfp)
237 < theirview.hresolu) {
238 fprintf(stderr, "%s: read error\n", zspec);
239 exit(1);
240 }
241 addscanline(y, scanin, zin, plast, zlast);
242 }
243 /* clean up */
244 free((char *)scanin);
245 free((char *)zin);
246 free((char *)plast);
247 free((char *)zlast);
248 fclose(pfp);
249 if (zfp != NULL)
250 fclose(zfp);
251 }
252
253
254 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
255 register double xfmat[4][4];
256 register VIEW *vw1, *vw2;
257 {
258 double m4t[4][4];
259
260 setident4(xfmat);
261 xfmat[0][0] = vw1->vhinc[0];
262 xfmat[0][1] = vw1->vhinc[1];
263 xfmat[0][2] = vw1->vhinc[2];
264 xfmat[1][0] = vw1->vvinc[0];
265 xfmat[1][1] = vw1->vvinc[1];
266 xfmat[1][2] = vw1->vvinc[2];
267 xfmat[2][0] = vw1->vdir[0];
268 xfmat[2][1] = vw1->vdir[1];
269 xfmat[2][2] = vw1->vdir[2];
270 xfmat[3][0] = vw1->vp[0];
271 xfmat[3][1] = vw1->vp[1];
272 xfmat[3][2] = vw1->vp[2];
273 setident4(m4t);
274 m4t[0][0] = vw2->vhinc[0]/vw2->vhn2;
275 m4t[1][0] = vw2->vhinc[1]/vw2->vhn2;
276 m4t[2][0] = vw2->vhinc[2]/vw2->vhn2;
277 m4t[3][0] = -DOT(vw2->vp,vw2->vhinc)/vw2->vhn2;
278 m4t[0][1] = vw2->vvinc[0]/vw2->vvn2;
279 m4t[1][1] = vw2->vvinc[1]/vw2->vvn2;
280 m4t[2][1] = vw2->vvinc[2]/vw2->vvn2;
281 m4t[3][1] = -DOT(vw2->vp,vw2->vvinc)/vw2->vvn2;
282 m4t[0][2] = vw2->vdir[0];
283 m4t[1][2] = vw2->vdir[1];
284 m4t[2][2] = vw2->vdir[2];
285 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
286 multmat4(xfmat, xfmat, m4t);
287 }
288
289
290 addscanline(y, pline, zline, lasty, lastyz) /* add scanline to output */
291 int y;
292 COLR *pline;
293 float *zline;
294 int *lasty; /* input/output */
295 float *lastyz; /* input/output */
296 {
297 extern double sqrt(), fabs();
298 double pos[3];
299 int lastx = 0;
300 double lastxz = 0;
301 double zt;
302 int xpos, ypos;
303 register int x;
304
305 for (x = theirview.hresolu-1; x >= 0; x--) {
306 pos[0] = x - .5*(theirview.hresolu-1);
307 pos[1] = y - .5*(theirview.vresolu-1);
308 pos[2] = zline[x];
309 if (theirview.type == VT_PER) {
310 if (!regdist) /* adjust for eye-ray distance */
311 pos[2] /= sqrt( 1.
312 + pos[0]*pos[0]*theirview.vhn2
313 + pos[1]*pos[1]*theirview.vvn2 );
314 pos[0] *= pos[2];
315 pos[1] *= pos[2];
316 }
317 multp3(pos, pos, theirs2ours);
318 if (pos[2] <= 0)
319 continue;
320 if (ourview.type == VT_PER) {
321 pos[0] /= pos[2];
322 pos[1] /= pos[2];
323 }
324 pos[0] += .5*ourview.hresolu;
325 pos[1] += .5*ourview.vresolu;
326 if (pos[0] < 0 || (xpos = pos[0]) >= ourview.hresolu
327 || pos[1] < 0 || (ypos = pos[1]) >= ourview.vresolu)
328 continue;
329 /* add pixel to our image */
330 zt = 2.*zeps*zline[x];
331 addpixel(xpos, ypos,
332 (fabs(zline[x]-lastxz) <= zt) ? lastx - xpos : 1,
333 (fabs(zline[x]-lastyz[x]) <= zt) ? lasty[x] - ypos : 1,
334 pline[x], pos[2]);
335 lastx = xpos;
336 lasty[x] = ypos;
337 lastxz = lastyz[x] = zline[x];
338 }
339 }
340
341
342 addpixel(xstart, ystart, width, height, pix, z) /* fill in area for pixel */
343 int xstart, ystart;
344 int width, height;
345 COLR pix;
346 double z;
347 {
348 register int x, y;
349 /* make width and height positive */
350 if (width < 0) {
351 width = -width;
352 xstart = xstart-width+1;
353 } else if (width == 0)
354 width = 1;
355 if (height < 0) {
356 height = -height;
357 ystart = ystart-height+1;
358 } else if (height == 0)
359 height = 1;
360 /* fill pixel(s) within rectangle */
361 for (y = ystart; y < ystart+height; y++)
362 for (x = xstart; x < xstart+width; x++)
363 if (zscan(y)[x] <= 0
364 || zscan(y)[x]-z > zeps*zscan(y)[x]) {
365 zscan(y)[x] = z;
366 copycolr(pscan(y)[x], pix);
367 }
368 }
369
370
371 fillpicture() /* fill in empty spaces */
372 {
373 int *yback, xback;
374 int y;
375 COLR pfill;
376 register int x, i;
377 /* get back buffer */
378 yback = (int *)malloc(ourview.hresolu*sizeof(int));
379 if (yback == NULL) {
380 perror(progname);
381 return;
382 }
383 for (x = 0; x < ourview.hresolu; x++)
384 yback[x] = -2;
385 /*
386 * Xback and yback are the pixel locations of suitable
387 * background values in each direction.
388 * A value of -2 means unassigned, and -1 means
389 * that there is no suitable background in this direction.
390 */
391 /* fill image */
392 for (y = 0; y < ourview.vresolu; y++) {
393 xback = -2;
394 for (x = 0; x < ourview.hresolu; x++)
395 if (zscan(y)[x] <= 0) { /* empty pixel */
396 /*
397 * First, find background from above or below.
398 * (farthest assigned pixel)
399 */
400 if (yback[x] == -2) {
401 for (i = y+1; i < ourview.vresolu; i++)
402 if (zscan(i)[x] > 0)
403 break;
404 if (i < ourview.vresolu
405 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
406 yback[x] = i;
407 else
408 yback[x] = y-1;
409 }
410 /*
411 * Next, find background from left or right.
412 */
413 if (xback == -2) {
414 for (i = x+1; x < ourview.hresolu; i++)
415 if (zscan(y)[i] > 0)
416 break;
417 if (i < ourview.hresolu
418 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
419 xback = i;
420 else
421 xback = x-1;
422 }
423 if (xback < 0 && yback[x] < 0)
424 continue; /* no background */
425 /*
426 * Compare, and use the background that is
427 * farther, unless one of them is next to us.
428 */
429 if (yback[x] < 0 || ABS(x-xback) <= 1
430 || ( ABS(y-yback[x]) > 1
431 && zscan(yback[x])[x] < zscan(y)[xback] ))
432 copycolr(pscan(y)[x],pscan(y)[xback]);
433 else
434 copycolr(pscan(y)[x],pscan(yback[x])[x]);
435 } else { /* full pixel */
436 yback[x] = -2;
437 xback = -2;
438 }
439 }
440 free((char *)yback);
441 }
442
443
444 writepicture() /* write out picture */
445 {
446 int y;
447
448 fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, stdout);
449 for (y = ourview.vresolu-1; y >= 0; y--)
450 if (fwritecolrs(pscan(y), ourview.hresolu, stdout) < 0) {
451 perror(progname);
452 exit(1);
453 }
454 }
455
456
457 isfloat(s) /* see if string is floating number */
458 register char *s;
459 {
460 for ( ; *s; s++)
461 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
462 && *s != 'e' && *s != 'E' && *s != '+')
463 return(0);
464 return(1);
465 }
