--- ray/src/px/pinterp.c 1989/12/12 15:53:10 1.3 +++ ray/src/px/pinterp.c 1990/01/03 09:37:16 1.8 @@ -21,7 +21,7 @@ static char SCCSid[] = "$SunId$ LBL"; VIEW ourview = STDVIEW(512); /* desired view */ -double zeps = 0.001; /* allowed z epsilon */ +double zeps = .02; /* allowed z epsilon */ COLR *ourpict; /* output picture */ float *ourzbuf; /* corresponding z-buffer */ @@ -31,7 +31,9 @@ char *progname; VIEW theirview = STDVIEW(512); /* input view */ int gotview; /* got input view? */ +double theirs2ours[4][4]; /* transformation matrix */ + main(argc, argv) /* interpolate pictures */ int argc; char *argv[]; @@ -49,6 +51,14 @@ char *argv[]; check(2,1); zeps = atof(argv[++i]); break; + case 'x': /* x resolution */ + check(2,1); + ourview.hresolu = atoi(argv[++i]); + break; + case 'y': /* y resolution */ + check(2,1); + ourview.vresolu = atoi(argv[++i]); + break; case 'v': /* view */ switch (argv[i][2]) { case 't': /* type */ @@ -163,9 +173,10 @@ addpicture(pfile, zfile) /* add picture to output */ char *pfile, *zfile; { FILE *pfp, *zfp; - COLR *scanin; - float *zin; char *err; + COLR *scanin; + float *zin, *zout; + int *pout; int xres, yres; int y; /* open input files */ @@ -191,10 +202,14 @@ char *pfile, *zfile; fprintf(stderr, "%s: %s\n", pfile, err); exit(1); } + /* compute transformation */ + pixform(theirs2ours, &theirview, &ourview); /* allocate scanlines */ scanin = (COLR *)malloc(xres*sizeof(COLR)); zin = (float *)malloc(xres*sizeof(float)); - if (scanin == NULL || zin == NULL) { + zout = (float *)calloc(xres, sizeof(float)); + pout = (int *)calloc(xres, sizeof(int)); + if (scanin == NULL || zin == NULL || zout == NULL || pout == NULL) { perror(progname); exit(1); } @@ -208,48 +223,139 @@ char *pfile, *zfile; fprintf(stderr, "%s: read error\n", zfile); exit(1); } - addscanline(y, scanin, zin); + addscanline(y, scanin, zin, pout, zout); } /* clean up */ free((char *)scanin); free((char *)zin); + free((char *)pout); + free((char *)zout); fclose(pfp); fclose(zfp); } -addscanline(y, pline, zline) /* add scanline to output */ +pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */ +register double xfmat[4][4]; +register VIEW *vw1, *vw2; +{ + double m4t[4][4]; + + setident4(xfmat); + xfmat[0][0] = vw1->vhinc[0]; + xfmat[0][1] = vw1->vhinc[1]; + xfmat[0][2] = vw1->vhinc[2]; + xfmat[1][0] = vw1->vvinc[0]; + xfmat[1][1] = vw1->vvinc[1]; + xfmat[1][2] = vw1->vvinc[2]; + xfmat[2][0] = vw1->vdir[0]; + xfmat[2][1] = vw1->vdir[1]; + xfmat[2][2] = vw1->vdir[2]; + xfmat[3][0] = vw1->vp[0]; + xfmat[3][1] = vw1->vp[1]; + xfmat[3][2] = vw1->vp[2]; + setident4(m4t); + m4t[0][0] = vw2->vhinc[0]/vw2->vhn2; + m4t[1][0] = vw2->vhinc[1]/vw2->vhn2; + m4t[2][0] = vw2->vhinc[2]/vw2->vhn2; + m4t[3][0] = -DOT(vw2->vp,vw2->vhinc)/vw2->vhn2; + m4t[0][1] = vw2->vvinc[0]/vw2->vvn2; + m4t[1][1] = vw2->vvinc[1]/vw2->vvn2; + m4t[2][1] = vw2->vvinc[2]/vw2->vvn2; + m4t[3][1] = -DOT(vw2->vp,vw2->vvinc)/vw2->vvn2; + m4t[0][2] = vw2->vdir[0]; + m4t[1][2] = vw2->vdir[1]; + m4t[2][2] = vw2->vdir[2]; + m4t[3][2] = -DOT(vw2->vp,vw2->vdir); + multmat4(xfmat, xfmat, m4t); +} + + +addscanline(y, pline, zline, lasty, lastyz) /* add scanline to output */ int y; COLR *pline; float *zline; +int *lasty; +float *lastyz; { - FVECT p, dir; - double xnew, ynew, znew; + extern double sqrt(), fabs(); + double pos[3]; + int lastx = 0; + double lastxz = 0; + double zt; + int xpos, ypos; register int x; - register int xpos, ypos; - for (x = 0; x < theirview.hresolu; x++) { - rayview(p, dir, &theirview, x+.5, y+.5); - p[0] += zline[x]*dir[0]; - p[1] += zline[x]*dir[1]; - p[2] += zline[x]*dir[2]; - pixelview(&xnew, &ynew, &znew, &ourview, p); - if (znew <= 0.0 || xnew < 0 || xnew > ourview.hresolu - || ynew < 0 || ynew > ourview.vresolu) + for (x = theirview.hresolu-1; x >= 0; x--) { + pos[0] = x - .5*(theirview.hresolu-1); + pos[1] = y - .5*(theirview.vresolu-1); + pos[2] = zline[x]; + if (theirview.type == VT_PER) { + /* + * The following (single) statement can go + * if z is along the view direction rather + * than an eye ray. + */ + pos[2] /= sqrt( 1. + + pos[0]*pos[0]*theirview.vhn2 + + pos[1]*pos[1]*theirview.vvn2 ); + pos[0] *= pos[2]; + pos[1] *= pos[2]; + } + multp3(pos, pos, theirs2ours); + if (pos[2] <= 0) continue; - /* check current value at position */ - xpos = xnew; - ypos = ynew; - if (zscan(ypos)[xpos] <= 0.0 - || zscan(ypos)[xpos] - znew - > zeps*zscan(ypos)[xpos]) { - zscan(ypos)[xpos] = znew; - copycolr(pscan(ypos)[xpos], pline[x]); + if (ourview.type == VT_PER) { + pos[0] /= pos[2]; + pos[1] /= pos[2]; } + pos[0] += .5*ourview.hresolu; + pos[1] += .5*ourview.vresolu; + if (pos[0] < 0 || (xpos = pos[0]) >= ourview.hresolu + || pos[1] < 0 || (ypos = pos[1]) >= ourview.vresolu) + continue; + /* add pixel to our image */ + zt = 2.*zeps*zline[x]; + addpixel(xpos, ypos, + (fabs(zline[x]-lastxz) <= zt) ? lastx - xpos : 1, + (fabs(zline[x]-lastyz[x]) <= zt) ? lasty[x] - ypos : 1, + pline[x], pos[2]); + lastx = xpos; + lasty[x] = ypos; + lastxz = lastyz[x] = zline[x]; } } +addpixel(xstart, ystart, width, height, pix, z) /* fill in area for pixel */ +int xstart, ystart; +int width, height; +COLR pix; +double z; +{ + register int x, y; + /* make width and height positive */ + if (width < 0) { + width = -width; + xstart = xstart-width+1; + } else if (width == 0) + width = 1; + if (height < 0) { + height = -height; + ystart = ystart-height+1; + } else if (height == 0) + height = 1; + /* fill pixel(s) within rectangle */ + for (y = ystart; y < ystart+height; y++) + for (x = xstart; x < xstart+width; x++) + if (zscan(y)[x] <= 0 + || zscan(y)[x]-z > zeps*zscan(y)[x]) { + zscan(y)[x] = z; + copycolr(pscan(y)[x], pix); + } +} + + fillpicture() /* fill in empty spaces */ { int *yback, xback; @@ -263,47 +369,62 @@ fillpicture() /* fill in empty spaces */ return; } for (x = 0; x < ourview.hresolu; x++) - yback[x] = -1; + yback[x] = -2; + /* + * Xback and yback are the pixel locations of suitable + * background values in each direction. + * A value of -2 means unassigned, and -1 means + * that there is no suitable background in this direction. + */ /* fill image */ - for (y = 0; y < ourview.vresolu; y++) + for (y = 0; y < ourview.vresolu; y++) { + xback = -2; for (x = 0; x < ourview.hresolu; x++) - if (zscan(y)[x] <= 0.0) { /* found hole */ - xback = x-1; - do { /* find boundary */ - if (yback[x] < 0) { - for (i = y+1; - i < ourview.vresolu; - i++) - if (zscan(i)[x] > 0.0) - break; - if (i < ourview.vresolu + if (zscan(y)[x] <= 0) { /* empty pixel */ + /* + * First, find background from above or below. + * (farthest assigned pixel) + */ + if (yback[x] == -2) { + for (i = y+1; i < ourview.vresolu; i++) + if (zscan(i)[x] > 0) + break; + if (i < ourview.vresolu && (y <= 0 || zscan(y-1)[x] < zscan(i)[x])) - yback[x] = i; - else - yback[x] = y-1; - } - } while (++x < ourview.hresolu - && zscan(y)[x] <= 0.0); - i = xback; /* pick background */ - if (x < ourview.hresolu - && (i < 0 || zscan(y)[i] < zscan(y)[x])) - xback = x; - /* fill hole */ - if (xback < 0) { - while (++i < x) - if (yback[i] >= 0) - copycolr(pscan(y)[i],pscan(yback[i])[i]); - } else { - while (++i < x) - if (yback[i] < 0 - || ABS(i-xback) <= 1 || (ABS(y-yback[i]) > 1 - && zscan(yback[i])[i] < zscan(y)[xback])) - copycolr(pscan(y)[i],pscan(y)[xback]); - else - copycolr(pscan(y)[i],pscan(yback[i])[i]); + yback[x] = i; + else + yback[x] = y-1; } - } else - yback[x] = -1; /* clear boundary */ + /* + * Next, find background from left or right. + */ + if (xback == -2) { + for (i = x+1; x < ourview.hresolu; i++) + if (zscan(y)[i] > 0) + break; + if (i < ourview.hresolu + && (x <= 0 || zscan(y)[x-1] < zscan(y)[i])) + xback = i; + else + xback = x-1; + } + if (xback < 0 && yback[x] < 0) + continue; /* no background */ + /* + * Compare, and use the background that is + * farther, unless one of them is next to us. + */ + if (yback[x] < 0 || ABS(x-xback) <= 1 + || ( ABS(y-yback[x]) > 1 + && zscan(yback[x])[x] < zscan(y)[xback] )) + copycolr(pscan(y)[x],pscan(y)[xback]); + else + copycolr(pscan(y)[x],pscan(yback[x])[x]); + } else { /* full pixel */ + yback[x] = -2; + xback = -2; + } + } free((char *)yback); }
