--- ray/src/px/pinterp.c 1990/01/17 15:12:37 1.21 +++ ray/src/px/pinterp.c 1990/03/06 12:04:56 1.26 @@ -10,7 +10,7 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" -#include +#include #include "view.h" @@ -28,7 +28,7 @@ static char SCCSid[] = "$SunId$ LBL"; #define PACKSIZ 42 /* calculation packet size */ -#define RTCOM "rtrace -h -ovl -fff -x %d %s" +#define RTCOM "rtrace -h -ovl -fff %s" #define ABS(x) ((x)>0?(x):-(x)) @@ -46,9 +46,10 @@ float *ourzbuf; /* corresponding z-buffer */ char *progname; -int fill = F_FORE|F_BACK; /* selected fill algorithm */ +int fillo = F_FORE|F_BACK; /* selected fill options */ +int fillsamp = 0; /* sample separation (0 == inf) */ extern int backfill(), rcalfill(); /* fill functions */ -int (*deffill)() = backfill; /* selected fill function */ +int (*fillfunc)() = backfill; /* selected fill function */ COLR backcolr = BLKCOLR; /* background color */ double backz = 0.0; /* background z value */ int normdist = 1; /* normalized distance? */ @@ -98,35 +99,39 @@ char *argv[]; switch (argv[i][2]) { case '0': /* none */ check(3,0); - fill = 0; + fillo = 0; break; case 'f': /* foreground */ check(3,0); - fill = F_FORE; + fillo = F_FORE; break; case 'b': /* background */ check(3,0); - fill = F_BACK; + fillo = F_BACK; break; case 'a': /* all */ check(3,0); - fill = F_FORE|F_BACK; + fillo = F_FORE|F_BACK; break; + case 's': /* sample */ + check(3,1); + fillsamp = atoi(argv[++i]); + break; case 'c': /* color */ check(3,3); - deffill = backfill; + fillfunc = backfill; setcolr(backcolr, atof(argv[i+1]), atof(argv[i+2]), atof(argv[i+3])); i += 3; break; case 'z': /* z value */ check(3,1); - deffill = backfill; + fillfunc = backfill; backz = atof(argv[++i]); break; case 'r': /* rtrace */ check(3,1); - deffill = rcalfill; + fillfunc = rcalfill; calstart(RTCOM, argv[++i]); break; default: @@ -188,24 +193,24 @@ char *argv[]; for ( ; i < argc; i += 2) addpicture(argv[i], argv[i+1]); /* fill in spaces */ - if (fill&F_BACK) - backpicture(); + if (fillo&F_BACK) + backpicture(fillfunc, fillsamp); else - fillpicture(); + fillpicture(fillfunc); /* close calculation */ caldone(); /* add to header */ printargs(argc, argv, stdout); if (gotvfile) { - printf(VIEWSTR); + fputs(VIEWSTR, stdout); fprintview(&ourview, stdout); - printf("\n"); + putc('\n', stdout); } if (pixaspect < .99 || pixaspect > 1.01) fputaspect(pixaspect, stdout); if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005)) fputexpos(ourexp, stdout); - printf("\n"); + putc('\n', stdout); /* write picture */ writepicture(); /* write z file */ @@ -225,10 +230,11 @@ userr: headline(s) /* process header string */ char *s; { - static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL}; + static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL}; register char **an; - printf("\t%s", s); + putc('\t', stdout); + fputs(s, stdout); if (isexpos(s)) { theirexp *= exposval(s); @@ -302,7 +308,7 @@ char *pfile, *zspec; fprintf(stderr, "%s: read error\n", pfile); exit(1); } - if (zfd != -1 && read(zfd,zin,thresolu*sizeof(float)) + if (zfd != -1 && read(zfd,(char *)zin,thresolu*sizeof(float)) < thresolu*sizeof(float)) { fprintf(stderr, "%s: read error\n", zspec); exit(1); @@ -419,7 +425,7 @@ double z; register int x, y; /* final position */ /* compute vector p0p1 */ - if (fill&F_FORE && ABS(p1->z-p0->z) <= zt) { + if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) { s1x = p1->x - p0->x; s1y = p1->y - p0->y; l1 = ABS(s1x); @@ -430,7 +436,7 @@ double z; p1isy = -1; } /* compute vector p0p2 */ - if (fill&F_FORE && ABS(p2->z-p0->z) <= zt) { + if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) { s2x = p2->x - p0->x; s2y = p2->y - p0->y; if (p1isy == 1) @@ -459,7 +465,9 @@ double z; } -backpicture() /* background fill algorithm */ +backpicture(fill, samp) /* background fill algorithm */ +int (*fill)(); +int samp; { int *yback, xback; int y; @@ -510,11 +518,19 @@ backpicture() /* background fill algorithm */ xback = x-1; } /* - * Check to see if we have no background for - * this pixel. If not, use background color. + * If we have no background for this pixel, + * or if the background is too distant, + * use the given fill function. */ - if (xback < 0 && yback[x] < 0) { - (*deffill)(x,y); + if ((xback < 0 && yback[x] < 0) + || (samp > 0 + && ABS(x-xback) >= samp + && ABS(y-yback[y]) >= samp)) { + (*fill)(x,y); + if (fill != backfill) { /* reuse */ + yback[x] = -2; + xback = -2; + } continue; } /* @@ -541,14 +557,15 @@ backpicture() /* background fill algorithm */ } -fillpicture() /* paint in empty pixels with default */ +fillpicture(fill) /* paint in empty pixels using fill */ +int (*fill)(); { register int x, y; for (y = 0; y < vresolu; y++) for (x = 0; x < hresolu; x++) if (zscan(y)[x] <= 0) - (*deffill)(x,y); + (*fill)(x,y); } @@ -592,7 +609,7 @@ char *fname; } } else zout = zscan(y); - if (write(fd, zout, hresolu*sizeof(float)) + if (write(fd, (char *)zout, hresolu*sizeof(float)) < hresolu*sizeof(float)) { perror(fname); exit(1); @@ -635,7 +652,7 @@ char *prog, *args; fprintf(stderr, "%s: too many calculations\n", progname); exit(1); } - sprintf(combuf, prog, PACKSIZ, args); + sprintf(combuf, prog, args); if (pipe(p0) < 0 || pipe(p1) < 0) syserror(); if ((childpid = vfork()) == 0) { /* fork calculation */ @@ -671,9 +688,8 @@ caldone() /* done with calculation */ if (childpid == -1) return; - if (fclose(psend) == EOF) - syserror(); clearqueue(); + fclose(psend); fclose(precv); while ((pid = wait(0)) != -1 && pid != childpid) ; @@ -684,46 +700,48 @@ caldone() /* done with calculation */ rcalfill(x, y) /* fill with ray-calculated pixel */ int x, y; { - FVECT orig, dir; - float outbuf[6]; - - if (queuesiz >= PACKSIZ) { /* flush queue */ - if (fflush(psend) == EOF) - syserror(); + if (queuesiz >= PACKSIZ) /* flush queue if needed */ clearqueue(); - } - /* send new ray */ - viewray(orig, dir, &ourview, (x+.5)/hresolu, (y+.5)/vresolu); - outbuf[0] = orig[0]; outbuf[1] = orig[1]; outbuf[2] = orig[2]; - outbuf[3] = dir[0]; outbuf[4] = dir[1]; outbuf[5] = dir[2]; - if (fwrite(outbuf, sizeof(float), 6, psend) < 6) - syserror(); - /* remember it */ + /* add position to queue */ queue[queuesiz][0] = x; queue[queuesiz][1] = y; queuesiz++; } -clearqueue() /* get results from queue */ +clearqueue() /* process queue */ { - float inbuf[4]; + FVECT orig, dir; + float fbuf[6]; register int i; for (i = 0; i < queuesiz; i++) { - if (fread(inbuf, sizeof(float), 4, precv) < 4) { + viewray(orig, dir, &ourview, + (queue[i][0]+.5)/hresolu, + (queue[i][1]+.5)/vresolu); + fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2]; + fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2]; + fwrite((char *)fbuf, sizeof(float), 6, psend); + } + /* flush output and get results */ + fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */ + fwrite((char *)fbuf, sizeof(float), 6, psend); + if (fflush(psend) == EOF) + syserror(); + for (i = 0; i < queuesiz; i++) { + if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) { fprintf(stderr, "%s: read error in clearqueue\n", progname); exit(1); } if (ourexp > 0 && ourexp != 1.0) { - inbuf[0] *= ourexp; - inbuf[1] *= ourexp; - inbuf[2] *= ourexp; + fbuf[0] *= ourexp; + fbuf[1] *= ourexp; + fbuf[2] *= ourexp; } setcolr(pscan(queue[i][1])[queue[i][0]], - inbuf[0], inbuf[1], inbuf[2]); - zscan(queue[i][1])[queue[i][0]] = inbuf[3]; + fbuf[0], fbuf[1], fbuf[2]); + zscan(queue[i][1])[queue[i][0]] = fbuf[3]; } queuesiz = 0; }
