--- ray/src/px/pinterp.c 1990/01/03 09:37:16 1.8 +++ ray/src/px/pinterp.c 1990/01/05 11:34:27 1.15 @@ -17,8 +17,17 @@ static char SCCSid[] = "$SunId$ LBL"; #define pscan(y) (ourpict+(y)*ourview.hresolu) #define zscan(y) (ourzbuf+(y)*ourview.hresolu) +#define F_FORE 1 /* fill foreground */ +#define F_BACK 2 /* fill background */ + +#define PACKSIZ 42 /* calculation packet size */ + +#define RTCOM "rtrace -h -ovl -fff -x %d %s" + #define ABS(x) ((x)>0?(x):-(x)) +struct position {int x,y; float z;}; + VIEW ourview = STDVIEW(512); /* desired view */ double zeps = .02; /* allowed z epsilon */ @@ -31,15 +40,29 @@ char *progname; VIEW theirview = STDVIEW(512); /* input view */ int gotview; /* got input view? */ +int fill = F_FORE|F_BACK; /* selected fill algorithm */ +extern int backfill(), rcalfill(); /* fill functions */ +int (*deffill)() = backfill; /* selected fill function */ +COLR backcolr = BLKCOLR; /* background color */ +double backz = 0.0; /* background z value */ + double theirs2ours[4][4]; /* transformation matrix */ +int normdist = 1; /* normalized distance? */ +int childpid = -1; /* id of fill process */ +FILE *psend, *precv; /* pipes to/from fill calculation */ +int queue[PACKSIZ][2]; /* pending pixels */ +int queuesiz; /* number of pixels pending */ + main(argc, argv) /* interpolate pictures */ int argc; char *argv[]; { #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt + extern double atof(); int gotvfile = 0; + char *zfile = NULL; char *err; int i; @@ -51,6 +74,53 @@ char *argv[]; check(2,1); zeps = atof(argv[++i]); break; + case 'n': /* dist. normalized? */ + check(2,0); + normdist = !normdist; + break; + case 'f': /* fill type */ + switch (argv[i][2]) { + case '0': /* none */ + check(3,0); + fill = 0; + break; + case 'f': /* foreground */ + check(3,0); + fill = F_FORE; + break; + case 'b': /* background */ + check(3,0); + fill = F_BACK; + break; + case 'a': /* all */ + check(3,0); + fill = F_FORE|F_BACK; + break; + case 'c': /* color */ + check(3,3); + deffill = backfill; + setcolr(backcolr, atof(argv[i+1]), + atof(argv[i+2]), atof(argv[i+3])); + i += 3; + break; + case 'z': /* z value */ + check(3,1); + deffill = backfill; + backz = atof(argv[++i]); + break; + case 'r': /* rtrace */ + check(3,1); + deffill = rcalfill; + calstart(RTCOM, argv[++i]); + break; + default: + goto badopt; + } + break; + case 'z': /* z file */ + check(2,1); + zfile = argv[++i]; + break; case 'x': /* x resolution */ check(2,1); ourview.hresolu = atoi(argv[++i]); @@ -109,33 +179,33 @@ char *argv[]; break; default: badopt: - fprintf(stderr, "%s: unknown option '%s'\n", + fprintf(stderr, "%s: command line error at '%s'\n", progname, argv[i]); - exit(1); + goto userr; } /* check arguments */ - if (argc-i < 2 || (argc-i)%2) { - fprintf(stderr, "Usage: %s [view args] pfile zfile ..\n", - progname); - exit(1); - } + if ((argc-i)%2) + goto userr; /* set view */ if (err = setview(&ourview)) { fprintf(stderr, "%s: %s\n", progname, err); exit(1); } /* allocate frame */ - ourpict = (COLR *)calloc(ourview.hresolu*ourview.vresolu,sizeof(COLR)); + ourpict = (COLR *)malloc(ourview.hresolu*ourview.vresolu*sizeof(COLR)); ourzbuf = (float *)calloc(ourview.hresolu*ourview.vresolu,sizeof(float)); - if (ourpict == NULL || ourzbuf == NULL) { - perror(progname); - exit(1); - } + if (ourpict == NULL || ourzbuf == NULL) + syserror(); /* get input */ for ( ; i < argc; i += 2) addpicture(argv[i], argv[i+1]); /* fill in spaces */ - fillpicture(); + if (fill&F_BACK) + backpicture(); + else + fillpicture(); + /* close calculation */ + caldone(); /* add to header */ printargs(argc, argv, stdout); if (gotvfile) { @@ -144,10 +214,18 @@ char *argv[]; printf("\n"); } printf("\n"); - /* write output */ + /* write picture */ writepicture(); + /* write z file */ + if (zfile != NULL) + writedistance(zfile); exit(0); +userr: + fprintf(stderr, + "Usage: %s [view opts][-t zthresh][-z zout][-fT][-n] pfile zspec ..\n", + progname); + exit(1); #undef check } @@ -169,35 +247,30 @@ char *s; } -addpicture(pfile, zfile) /* add picture to output */ -char *pfile, *zfile; +addpicture(pfile, zspec) /* add picture to output */ +char *pfile, *zspec; { + extern double atof(); FILE *pfp, *zfp; char *err; COLR *scanin; - float *zin, *zout; - int *pout; - int xres, yres; + float *zin; + struct position *plast; int y; - /* open input files */ + /* open picture file */ if ((pfp = fopen(pfile, "r")) == NULL) { perror(pfile); exit(1); } - if ((zfp = fopen(zfile, "r")) == NULL) { - perror(zfile); - exit(1); - } /* get header and view */ printf("%s:\n", pfile); gotview = 0; getheader(pfp, headline); - if (!gotview || fgetresolu(&xres, &yres, pfp) != (YMAJOR|YDECR)) { + if (!gotview || fgetresolu(&theirview.hresolu, &theirview.vresolu, pfp) + != (YMAJOR|YDECR)) { fprintf(stderr, "%s: picture view error\n", pfile); exit(1); } - theirview.hresolu = xres; - theirview.vresolu = yres; if (err = setview(&theirview)) { fprintf(stderr, "%s: %s\n", pfile, err); exit(1); @@ -205,33 +278,44 @@ char *pfile, *zfile; /* compute transformation */ pixform(theirs2ours, &theirview, &ourview); /* allocate scanlines */ - scanin = (COLR *)malloc(xres*sizeof(COLR)); - zin = (float *)malloc(xres*sizeof(float)); - zout = (float *)calloc(xres, sizeof(float)); - pout = (int *)calloc(xres, sizeof(int)); - if (scanin == NULL || zin == NULL || zout == NULL || pout == NULL) { - perror(progname); - exit(1); + scanin = (COLR *)malloc(theirview.hresolu*sizeof(COLR)); + zin = (float *)malloc(theirview.hresolu*sizeof(float)); + plast = (struct position *)calloc(theirview.hresolu, + sizeof(struct position)); + if (scanin == NULL || zin == NULL || plast == NULL) + syserror(); + /* get z specification or file */ + if ((zfp = fopen(zspec, "r")) == NULL) { + double zvalue; + register int x; + if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) { + perror(zspec); + exit(1); + } + for (x = 0; x < theirview.hresolu; x++) + zin[x] = zvalue; } /* load image */ - for (y = yres-1; y >= 0; y--) { - if (freadcolrs(scanin, xres, pfp) < 0) { + for (y = theirview.vresolu-1; y >= 0; y--) { + if (freadcolrs(scanin, theirview.hresolu, pfp) < 0) { fprintf(stderr, "%s: read error\n", pfile); exit(1); } - if (fread(zin, sizeof(float), xres, zfp) < xres) { - fprintf(stderr, "%s: read error\n", zfile); + if (zfp != NULL + && fread(zin,sizeof(float),theirview.hresolu,zfp) + < theirview.hresolu) { + fprintf(stderr, "%s: read error\n", zspec); exit(1); } - addscanline(y, scanin, zin, pout, zout); + addscanline(y, scanin, zin, plast); } /* clean up */ free((char *)scanin); free((char *)zin); - free((char *)pout); - free((char *)zout); + free((char *)plast); fclose(pfp); - fclose(zfp); + if (zfp != NULL) + fclose(zfp); } @@ -271,19 +355,15 @@ register VIEW *vw1, *vw2; } -addscanline(y, pline, zline, lasty, lastyz) /* add scanline to output */ +addscanline(y, pline, zline, lasty) /* add scanline to output */ int y; COLR *pline; float *zline; -int *lasty; -float *lastyz; +struct position *lasty; /* input/output */ { - extern double sqrt(), fabs(); + extern double sqrt(); double pos[3]; - int lastx = 0; - double lastxz = 0; - double zt; - int xpos, ypos; + struct position lastx, newpos; register int x; for (x = theirview.hresolu-1; x >= 0; x--) { @@ -291,72 +371,94 @@ float *lastyz; pos[1] = y - .5*(theirview.vresolu-1); pos[2] = zline[x]; if (theirview.type == VT_PER) { - /* - * The following (single) statement can go - * if z is along the view direction rather - * than an eye ray. - */ - pos[2] /= sqrt( 1. + if (normdist) /* adjust for eye-ray distance */ + pos[2] /= sqrt( 1. + pos[0]*pos[0]*theirview.vhn2 + pos[1]*pos[1]*theirview.vvn2 ); pos[0] *= pos[2]; pos[1] *= pos[2]; } multp3(pos, pos, theirs2ours); - if (pos[2] <= 0) + if (pos[2] <= 0) { + lasty[x].z = lastx.z = 0; /* mark invalid */ continue; + } if (ourview.type == VT_PER) { pos[0] /= pos[2]; pos[1] /= pos[2]; } pos[0] += .5*ourview.hresolu; pos[1] += .5*ourview.vresolu; - if (pos[0] < 0 || (xpos = pos[0]) >= ourview.hresolu - || pos[1] < 0 || (ypos = pos[1]) >= ourview.vresolu) - continue; + newpos.x = pos[0]; + newpos.y = pos[1]; + newpos.z = zline[x]; /* add pixel to our image */ - zt = 2.*zeps*zline[x]; - addpixel(xpos, ypos, - (fabs(zline[x]-lastxz) <= zt) ? lastx - xpos : 1, - (fabs(zline[x]-lastyz[x]) <= zt) ? lasty[x] - ypos : 1, - pline[x], pos[2]); - lastx = xpos; - lasty[x] = ypos; - lastxz = lastyz[x] = zline[x]; + if (pos[0] >= 0 && newpos.x < ourview.hresolu + && pos[1] >= 0 && newpos.y < ourview.vresolu) { + addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]); + lasty[x].x = lastx.x = newpos.x; + lasty[x].y = lastx.y = newpos.y; + lasty[x].z = lastx.z = newpos.z; + } else + lasty[x].z = lastx.z = 0; /* mark invalid */ } } -addpixel(xstart, ystart, width, height, pix, z) /* fill in area for pixel */ -int xstart, ystart; -int width, height; +addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */ +struct position *p0, *p1, *p2; COLR pix; double z; { - register int x, y; - /* make width and height positive */ - if (width < 0) { - width = -width; - xstart = xstart-width+1; - } else if (width == 0) - width = 1; - if (height < 0) { - height = -height; - ystart = ystart-height+1; - } else if (height == 0) - height = 1; - /* fill pixel(s) within rectangle */ - for (y = ystart; y < ystart+height; y++) - for (x = xstart; x < xstart+width; x++) - if (zscan(y)[x] <= 0 - || zscan(y)[x]-z > zeps*zscan(y)[x]) { + double zt = 2.*zeps*p0->z; /* threshold */ + int s1x, s1y, s2x, s2y; /* step sizes */ + int l1, l2, c1, c2; /* side lengths and counters */ + int p1isy; /* p0p1 along y? */ + int x1, y1; /* p1 position */ + register int x, y; /* final position */ + + /* compute vector p0p1 */ + if (fill&F_FORE && ABS(p1->z-p0->z) <= zt) { + s1x = p1->x - p0->x; + s1y = p1->y - p0->y; + l1 = ABS(s1x); + if (p1isy = (ABS(s1y) > l1)) + l1 = ABS(s1y); + } else { + l1 = s1x = s1y = 1; + p1isy = -1; + } + /* compute vector p0p2 */ + if (fill&F_FORE && ABS(p2->z-p0->z) <= zt) { + s2x = p2->x - p0->x; + s2y = p2->y - p0->y; + if (p1isy == 1) + l2 = ABS(s2x); + else { + l2 = ABS(s2y); + if (p1isy != 0 && ABS(s2x) > l2) + l2 = ABS(s2x); + } + } else + l2 = s2x = s2y = 1; + /* fill the parallelogram */ + for (c1 = l1; c1-- > 0; ) { + x1 = p0->x + c1*s1x/l1; + y1 = p0->y + c1*s1y/l1; + for (c2 = l2; c2-- > 0; ) { + x = x1 + c2*s2x/l2; + y = y1 + c2*s2y/l2; + if (zscan(y)[x] <= 0 || zscan(y)[x]-z + > zeps*zscan(y)[x]) { zscan(y)[x] = z; copycolr(pscan(y)[x], pix); } + } + } } -fillpicture() /* fill in empty spaces */ +backpicture() /* background fill algorithm */ { int *yback, xback; int y; @@ -364,10 +466,8 @@ fillpicture() /* fill in empty spaces */ register int x, i; /* get back buffer */ yback = (int *)malloc(ourview.hresolu*sizeof(int)); - if (yback == NULL) { - perror(progname); - return; - } + if (yback == NULL) + syserror(); for (x = 0; x < ourview.hresolu; x++) yback[x] = -2; /* @@ -399,7 +499,7 @@ fillpicture() /* fill in empty spaces */ * Next, find background from left or right. */ if (xback == -2) { - for (i = x+1; x < ourview.hresolu; i++) + for (i = x+1; i < ourview.hresolu; i++) if (zscan(y)[i] > 0) break; if (i < ourview.hresolu @@ -408,18 +508,29 @@ fillpicture() /* fill in empty spaces */ else xback = x-1; } - if (xback < 0 && yback[x] < 0) - continue; /* no background */ /* + * Check to see if we have no background for + * this pixel. If not, use background color. + */ + if (xback < 0 && yback[x] < 0) { + (*deffill)(x,y); + continue; + } + /* * Compare, and use the background that is * farther, unless one of them is next to us. */ - if (yback[x] < 0 || ABS(x-xback) <= 1 + if ( yback[x] < 0 + || (xback >= 0 && ABS(x-xback) <= 1) || ( ABS(y-yback[x]) > 1 - && zscan(yback[x])[x] < zscan(y)[xback] )) + && zscan(yback[x])[x] + < zscan(y)[xback] ) ) { copycolr(pscan(y)[x],pscan(y)[xback]); - else + zscan(y)[x] = zscan(y)[xback]; + } else { copycolr(pscan(y)[x],pscan(yback[x])[x]); + zscan(y)[x] = zscan(yback[x])[x]; + } } else { /* full pixel */ yback[x] = -2; xback = -2; @@ -429,14 +540,191 @@ fillpicture() /* fill in empty spaces */ } +fillpicture() /* paint in empty pixels with default */ +{ + register int x, y; + + for (y = 0; y < ourview.vresolu; y++) + for (x = 0; x < ourview.hresolu; x++) + if (zscan(y)[x] <= 0) + (*deffill)(x,y); +} + + writepicture() /* write out picture */ { int y; fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, stdout); for (y = ourview.vresolu-1; y >= 0; y--) - if (fwritecolrs(pscan(y), ourview.hresolu, stdout) < 0) { - perror(progname); + if (fwritecolrs(pscan(y), ourview.hresolu, stdout) < 0) + syserror(); +} + + +writedistance(fname) /* write out z file */ +char *fname; +{ + extern double sqrt(); + int donorm = normdist && ourview.type == VT_PER; + FILE *fp; + int y; + float *zout; + + if ((fp = fopen(fname, "w")) == NULL) { + perror(fname); + exit(1); + } + if (donorm + && (zout = (float *)malloc(ourview.hresolu*sizeof(float))) == NULL) + syserror(); + for (y = ourview.vresolu-1; y >= 0; y--) { + if (donorm) { + double vx, yzn2; + register int x; + yzn2 = y - .5*(ourview.vresolu-1); + yzn2 = 1. + yzn2*yzn2*ourview.vvn2; + for (x = 0; x < ourview.hresolu; x++) { + vx = x - .5*(ourview.hresolu-1); + zout[x] = zscan(y)[x] + * sqrt(vx*vx*ourview.vhn2 + yzn2); + } + } else + zout = zscan(y); + if (fwrite(zout, sizeof(float), ourview.hresolu, fp) + < ourview.hresolu) { + perror(fname); exit(1); } + } + if (donorm) + free((char *)zout); + fclose(fp); +} + + +isfloat(s) /* see if string is floating number */ +register char *s; +{ + for ( ; *s; s++) + if ((*s < '0' || *s > '9') && *s != '.' && *s != '-' + && *s != 'e' && *s != 'E' && *s != '+') + return(0); + return(1); +} + + +backfill(x, y) /* fill pixel with background */ +int x, y; +{ + register BYTE *dest = pscan(y)[x]; + + copycolr(dest, backcolr); + zscan(y)[x] = backz; +} + + +calstart(prog, args) /* start fill calculation */ +char *prog, *args; +{ + char combuf[512]; + int p0[2], p1[2]; + + if (childpid != -1) { + fprintf(stderr, "%s: too many calculations\n", progname); + exit(1); + } + sprintf(combuf, prog, PACKSIZ, args); + if (pipe(p0) < 0 || pipe(p1) < 0) + syserror(); + if ((childpid = vfork()) == 0) { /* fork calculation */ + close(p0[1]); + close(p1[0]); + if (p0[0] != 0) { + dup2(p0[0], 0); + close(p0[0]); + } + if (p1[1] != 1) { + dup2(p1[1], 1); + close(p1[1]); + } + execl("/bin/sh", "sh", "-c", combuf, 0); + perror("/bin/sh"); + _exit(127); + } + if (childpid == -1) + syserror(); + close(p0[0]); + close(p1[1]); + if ((psend = fdopen(p0[1], "w")) == NULL) + syserror(); + if ((precv = fdopen(p1[0], "r")) == NULL) + syserror(); + queuesiz = 0; +} + + +caldone() /* done with calculation */ +{ + int pid; + + if (childpid == -1) + return; + if (fclose(psend) == EOF) + syserror(); + clearqueue(); + fclose(precv); + while ((pid = wait(0)) != -1 && pid != childpid) + ; + childpid = -1; +} + + +rcalfill(x, y) /* fill with ray-calculated pixel */ +int x, y; +{ + FVECT orig, dir; + float outbuf[6]; + + if (queuesiz >= PACKSIZ) { /* flush queue */ + if (fflush(psend) == EOF) + syserror(); + clearqueue(); + } + /* send new ray */ + rayview(orig, dir, &ourview, x+.5, y+.5); + outbuf[0] = orig[0]; outbuf[1] = orig[1]; outbuf[2] = orig[2]; + outbuf[3] = dir[0]; outbuf[4] = dir[1]; outbuf[5] = dir[2]; + if (fwrite(outbuf, sizeof(float), 6, psend) < 6) + syserror(); + /* remember it */ + queue[queuesiz][0] = x; + queue[queuesiz][1] = y; + queuesiz++; +} + + +clearqueue() /* get results from queue */ +{ + float inbuf[4]; + register int i; + + for (i = 0; i < queuesiz; i++) { + if (fread(inbuf, sizeof(float), 4, precv) < 4) { + fprintf(stderr, "%s: read error in clearqueue\n", + progname); + exit(1); + } + setcolr(pscan(queue[i][1])[queue[i][0]], + inbuf[0], inbuf[1], inbuf[2]); + zscan(queue[i][1])[queue[i][0]] = inbuf[3]; + } + queuesiz = 0; +} + + +syserror() /* report error and exit */ +{ + perror(progname); + exit(1); }
