--- ray/src/px/pinterp.c 1990/01/06 22:27:10 1.16 +++ ray/src/px/pinterp.c 1990/01/17 18:05:07 1.22 @@ -10,13 +10,19 @@ static char SCCSid[] = "$SunId$ LBL"; #include "standard.h" +#include + #include "view.h" #include "color.h" -#define pscan(y) (ourpict+(y)*ourview.hresolu) -#define zscan(y) (ourzbuf+(y)*ourview.hresolu) +#ifndef BSD +#define vfork fork +#endif +#define pscan(y) (ourpict+(y)*hresolu) +#define zscan(y) (ourzbuf+(y)*hresolu) + #define F_FORE 1 /* fill foreground */ #define F_BACK 2 /* fill background */ @@ -28,7 +34,10 @@ static char SCCSid[] = "$SunId$ LBL"; struct position {int x,y; float z;}; -VIEW ourview = STDVIEW(512); /* desired view */ +VIEW ourview = STDVIEW; /* desired view */ +int hresolu = 512; /* horizontal resolution */ +int vresolu = 512; /* vertical resolution */ +double pixaspect = 1.0; /* pixel aspect ratio */ double zeps = .02; /* allowed z epsilon */ @@ -45,10 +54,11 @@ double backz = 0.0; /* background z value */ int normdist = 1; /* normalized distance? */ double ourexp = -1; /* output picture exposure */ -VIEW theirview = STDVIEW(512); /* input view */ +VIEW theirview = STDVIEW; /* input view */ int gotview; /* got input view? */ -double theirs2ours[4][4]; /* transformation matrix */ +int thresolu, tvresolu; /* input resolution */ double theirexp; /* input picture exposure */ +double theirs2ours[4][4]; /* transformation matrix */ int childpid = -1; /* id of fill process */ FILE *psend, *precv; /* pipes to/from fill calculation */ @@ -65,11 +75,16 @@ char *argv[]; int gotvfile = 0; char *zfile = NULL; char *err; - int i; + int i, rval; progname = argv[0]; - for (i = 1; i < argc && argv[i][0] == '-'; i++) + for (i = 1; i < argc && argv[i][0] == '-'; i++) { + rval = getviewopt(&ourview, argc-i, argv+i); + if (rval >= 0) { + i += rval; + continue; + } switch (argv[i][1]) { case 't': /* threshold */ check(2,1); @@ -124,58 +139,28 @@ char *argv[]; break; case 'x': /* x resolution */ check(2,1); - ourview.hresolu = atoi(argv[++i]); + hresolu = atoi(argv[++i]); break; case 'y': /* y resolution */ check(2,1); - ourview.vresolu = atoi(argv[++i]); + vresolu = atoi(argv[++i]); break; - case 'v': /* view */ - switch (argv[i][2]) { - case 't': /* type */ - check(4,0); - ourview.type = argv[i][3]; - break; - case 'p': /* point */ - check(3,3); - ourview.vp[0] = atof(argv[++i]); - ourview.vp[1] = atof(argv[++i]); - ourview.vp[2] = atof(argv[++i]); - break; - case 'd': /* direction */ - check(3,3); - ourview.vdir[0] = atof(argv[++i]); - ourview.vdir[1] = atof(argv[++i]); - ourview.vdir[2] = atof(argv[++i]); - break; - case 'u': /* up */ - check(3,3); - ourview.vup[0] = atof(argv[++i]); - ourview.vup[1] = atof(argv[++i]); - ourview.vup[2] = atof(argv[++i]); - break; - case 'h': /* horizontal */ - check(3,1); - ourview.horiz = atof(argv[++i]); - break; - case 'v': /* vertical */ - check(3,1); - ourview.vert = atof(argv[++i]); - break; - case 'f': /* file */ - check(3,1); - gotvfile = viewfile(argv[++i], &ourview); - if (gotvfile < 0) { - perror(argv[i]); - exit(1); - } else if (gotvfile == 0) { - fprintf(stderr, "%s: bad view file\n", - argv[i]); - exit(1); - } - break; - default: + case 'p': /* pixel aspect */ + check(2,1); + pixaspect = atof(argv[++i]); + break; + case 'v': /* view file */ + if (argv[i][2] != 'f') goto badopt; + check(3,1); + gotvfile = viewfile(argv[++i], &ourview, 0, 0); + if (gotvfile < 0) { + perror(argv[i]); + exit(1); + } else if (gotvfile == 0) { + fprintf(stderr, "%s: bad view file\n", + argv[i]); + exit(1); } break; default: @@ -184,6 +169,7 @@ char *argv[]; progname, argv[i]); goto userr; } + } /* check arguments */ if ((argc-i)%2) goto userr; @@ -192,9 +178,10 @@ char *argv[]; fprintf(stderr, "%s: %s\n", progname, err); exit(1); } + normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu); /* allocate frame */ - ourpict = (COLR *)malloc(ourview.hresolu*ourview.vresolu*sizeof(COLR)); - ourzbuf = (float *)calloc(ourview.hresolu*ourview.vresolu,sizeof(float)); + ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR)); + ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float)); if (ourpict == NULL || ourzbuf == NULL) syserror(); /* get input */ @@ -214,7 +201,9 @@ char *argv[]; fprintview(&ourview, stdout); printf("\n"); } - if (ourexp > 0 && ourexp != 1.0) + if (pixaspect < .99 || pixaspect > 1.01) + fputaspect(pixaspect, stdout); + if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005)) fputexpos(ourexp, stdout); printf("\n"); /* write picture */ @@ -226,7 +215,7 @@ char *argv[]; exit(0); userr: fprintf(stderr, - "Usage: %s [view opts][-t zthresh][-z zout][-fT][-n] pfile zspec ..\n", + "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n", progname); exit(1); #undef check @@ -247,7 +236,7 @@ char *s; } for (an = altname; *an != NULL; an++) if (!strncmp(*an, s, strlen(*an))) { - if (sscanview(&theirview, s+strlen(*an)) == 0) + if (sscanview(&theirview, s+strlen(*an)) > 0) gotview++; break; } @@ -258,7 +247,8 @@ addpicture(pfile, zspec) /* add picture to output */ char *pfile, *zspec; { extern double atof(); - FILE *pfp, *zfp; + FILE *pfp; + int zfd; char *err; COLR *scanin; float *zin; @@ -274,7 +264,7 @@ char *pfile, *zspec; gotview = 0; printf("%s:\n", pfile); getheader(pfp, headline); - if (!gotview || fgetresolu(&theirview.hresolu, &theirview.vresolu, pfp) + if (!gotview || fgetresolu(&thresolu, &tvresolu, pfp) != (YMAJOR|YDECR)) { fprintf(stderr, "%s: picture view error\n", pfile); exit(1); @@ -290,32 +280,30 @@ char *pfile, *zspec; /* compute transformation */ pixform(theirs2ours, &theirview, &ourview); /* allocate scanlines */ - scanin = (COLR *)malloc(theirview.hresolu*sizeof(COLR)); - zin = (float *)malloc(theirview.hresolu*sizeof(float)); - plast = (struct position *)calloc(theirview.hresolu, - sizeof(struct position)); + scanin = (COLR *)malloc(thresolu*sizeof(COLR)); + zin = (float *)malloc(thresolu*sizeof(float)); + plast = (struct position *)calloc(thresolu, sizeof(struct position)); if (scanin == NULL || zin == NULL || plast == NULL) syserror(); /* get z specification or file */ - if ((zfp = fopen(zspec, "r")) == NULL) { + if ((zfd = open(zspec, O_RDONLY)) == -1) { double zvalue; register int x; if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) { perror(zspec); exit(1); } - for (x = 0; x < theirview.hresolu; x++) + for (x = 0; x < thresolu; x++) zin[x] = zvalue; } /* load image */ - for (y = theirview.vresolu-1; y >= 0; y--) { - if (freadcolrs(scanin, theirview.hresolu, pfp) < 0) { + for (y = tvresolu-1; y >= 0; y--) { + if (freadcolrs(scanin, thresolu, pfp) < 0) { fprintf(stderr, "%s: read error\n", pfile); exit(1); } - if (zfp != NULL - && fread(zin,sizeof(float),theirview.hresolu,zfp) - < theirview.hresolu) { + if (zfd != -1 && read(zfd,zin,thresolu*sizeof(float)) + < thresolu*sizeof(float)) { fprintf(stderr, "%s: read error\n", zspec); exit(1); } @@ -326,8 +314,8 @@ char *pfile, *zspec; free((char *)zin); free((char *)plast); fclose(pfp); - if (zfp != NULL) - fclose(zfp); + if (zfd != -1) + close(zfd); } @@ -338,12 +326,12 @@ register VIEW *vw1, *vw2; double m4t[4][4]; setident4(xfmat); - xfmat[0][0] = vw1->vhinc[0]; - xfmat[0][1] = vw1->vhinc[1]; - xfmat[0][2] = vw1->vhinc[2]; - xfmat[1][0] = vw1->vvinc[0]; - xfmat[1][1] = vw1->vvinc[1]; - xfmat[1][2] = vw1->vvinc[2]; + xfmat[0][0] = vw1->hvec[0]; + xfmat[0][1] = vw1->hvec[1]; + xfmat[0][2] = vw1->hvec[2]; + xfmat[1][0] = vw1->vvec[0]; + xfmat[1][1] = vw1->vvec[1]; + xfmat[1][2] = vw1->vvec[2]; xfmat[2][0] = vw1->vdir[0]; xfmat[2][1] = vw1->vdir[1]; xfmat[2][2] = vw1->vdir[2]; @@ -351,14 +339,14 @@ register VIEW *vw1, *vw2; xfmat[3][1] = vw1->vp[1]; xfmat[3][2] = vw1->vp[2]; setident4(m4t); - m4t[0][0] = vw2->vhinc[0]/vw2->vhn2; - m4t[1][0] = vw2->vhinc[1]/vw2->vhn2; - m4t[2][0] = vw2->vhinc[2]/vw2->vhn2; - m4t[3][0] = -DOT(vw2->vp,vw2->vhinc)/vw2->vhn2; - m4t[0][1] = vw2->vvinc[0]/vw2->vvn2; - m4t[1][1] = vw2->vvinc[1]/vw2->vvn2; - m4t[2][1] = vw2->vvinc[2]/vw2->vvn2; - m4t[3][1] = -DOT(vw2->vp,vw2->vvinc)/vw2->vvn2; + m4t[0][0] = vw2->hvec[0]/vw2->hn2; + m4t[1][0] = vw2->hvec[1]/vw2->hn2; + m4t[2][0] = vw2->hvec[2]/vw2->hn2; + m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2; + m4t[0][1] = vw2->vvec[0]/vw2->vn2; + m4t[1][1] = vw2->vvec[1]/vw2->vn2; + m4t[2][1] = vw2->vvec[2]/vw2->vn2; + m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2; m4t[0][2] = vw2->vdir[0]; m4t[1][2] = vw2->vdir[1]; m4t[2][2] = vw2->vdir[2]; @@ -378,15 +366,16 @@ struct position *lasty; /* input/output */ struct position lastx, newpos; register int x; - for (x = theirview.hresolu-1; x >= 0; x--) { - pos[0] = x - .5*(theirview.hresolu-1); - pos[1] = y - .5*(theirview.vresolu-1); + lastx.z = 0; + for (x = thresolu-1; x >= 0; x--) { + pos[0] = (x+.5)/thresolu + theirview.hoff - .5; + pos[1] = (y+.5)/tvresolu + theirview.voff - .5; pos[2] = zline[x]; if (theirview.type == VT_PER) { if (normdist) /* adjust for eye-ray distance */ pos[2] /= sqrt( 1. - + pos[0]*pos[0]*theirview.vhn2 - + pos[1]*pos[1]*theirview.vvn2 ); + + pos[0]*pos[0]*theirview.hn2 + + pos[1]*pos[1]*theirview.vn2 ); pos[0] *= pos[2]; pos[1] *= pos[2]; } @@ -399,14 +388,14 @@ struct position *lasty; /* input/output */ pos[0] /= pos[2]; pos[1] /= pos[2]; } - pos[0] += .5*ourview.hresolu; - pos[1] += .5*ourview.vresolu; - newpos.x = pos[0]; - newpos.y = pos[1]; + pos[0] += .5 - ourview.hoff; + pos[1] += .5 - ourview.voff; + newpos.x = pos[0] * hresolu; + newpos.y = pos[1] * vresolu; newpos.z = zline[x]; /* add pixel to our image */ - if (pos[0] >= 0 && newpos.x < ourview.hresolu - && pos[1] >= 0 && newpos.y < ourview.vresolu) { + if (pos[0] >= 0 && newpos.x < hresolu + && pos[1] >= 0 && newpos.y < vresolu) { addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]); lasty[x].x = lastx.x = newpos.x; lasty[x].y = lastx.y = newpos.y; @@ -477,10 +466,10 @@ backpicture() /* background fill algorithm */ COLR pfill; register int x, i; /* get back buffer */ - yback = (int *)malloc(ourview.hresolu*sizeof(int)); + yback = (int *)malloc(hresolu*sizeof(int)); if (yback == NULL) syserror(); - for (x = 0; x < ourview.hresolu; x++) + for (x = 0; x < hresolu; x++) yback[x] = -2; /* * Xback and yback are the pixel locations of suitable @@ -489,19 +478,19 @@ backpicture() /* background fill algorithm */ * that there is no suitable background in this direction. */ /* fill image */ - for (y = 0; y < ourview.vresolu; y++) { + for (y = 0; y < vresolu; y++) { xback = -2; - for (x = 0; x < ourview.hresolu; x++) + for (x = 0; x < hresolu; x++) if (zscan(y)[x] <= 0) { /* empty pixel */ /* * First, find background from above or below. * (farthest assigned pixel) */ if (yback[x] == -2) { - for (i = y+1; i < ourview.vresolu; i++) + for (i = y+1; i < vresolu; i++) if (zscan(i)[x] > 0) break; - if (i < ourview.vresolu + if (i < vresolu && (y <= 0 || zscan(y-1)[x] < zscan(i)[x])) yback[x] = i; else @@ -511,10 +500,10 @@ backpicture() /* background fill algorithm */ * Next, find background from left or right. */ if (xback == -2) { - for (i = x+1; i < ourview.hresolu; i++) + for (i = x+1; i < hresolu; i++) if (zscan(y)[i] > 0) break; - if (i < ourview.hresolu + if (i < hresolu && (x <= 0 || zscan(y)[x-1] < zscan(y)[i])) xback = i; else @@ -556,8 +545,8 @@ fillpicture() /* paint in empty pixels with default { register int x, y; - for (y = 0; y < ourview.vresolu; y++) - for (x = 0; x < ourview.hresolu; x++) + for (y = 0; y < vresolu; y++) + for (x = 0; x < hresolu; x++) if (zscan(y)[x] <= 0) (*deffill)(x,y); } @@ -567,9 +556,9 @@ writepicture() /* write out picture */ { int y; - fputresolu(YMAJOR|YDECR, ourview.hresolu, ourview.vresolu, stdout); - for (y = ourview.vresolu-1; y >= 0; y--) - if (fwritecolrs(pscan(y), ourview.hresolu, stdout) < 0) + fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout); + for (y = vresolu-1; y >= 0; y--) + if (fwritecolrs(pscan(y), hresolu, stdout) < 0) syserror(); } @@ -579,39 +568,39 @@ char *fname; { extern double sqrt(); int donorm = normdist && ourview.type == VT_PER; - FILE *fp; + int fd; int y; float *zout; - if ((fp = fopen(fname, "w")) == NULL) { + if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) { perror(fname); exit(1); } if (donorm - && (zout = (float *)malloc(ourview.hresolu*sizeof(float))) == NULL) + && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL) syserror(); - for (y = ourview.vresolu-1; y >= 0; y--) { + for (y = vresolu-1; y >= 0; y--) { if (donorm) { double vx, yzn2; register int x; - yzn2 = y - .5*(ourview.vresolu-1); - yzn2 = 1. + yzn2*yzn2*ourview.vvn2; - for (x = 0; x < ourview.hresolu; x++) { - vx = x - .5*(ourview.hresolu-1); + yzn2 = y - .5*(vresolu-1); + yzn2 = 1. + yzn2*yzn2*ourview.vn2; + for (x = 0; x < hresolu; x++) { + vx = x - .5*(hresolu-1); zout[x] = zscan(y)[x] - * sqrt(vx*vx*ourview.vhn2 + yzn2); + * sqrt(vx*vx*ourview.hn2 + yzn2); } } else zout = zscan(y); - if (fwrite(zout, sizeof(float), ourview.hresolu, fp) - < ourview.hresolu) { + if (write(fd, zout, hresolu*sizeof(float)) + < hresolu*sizeof(float)) { perror(fname); exit(1); } } if (donorm) free((char *)zout); - fclose(fp); + close(fd); } @@ -682,10 +671,7 @@ caldone() /* done with calculation */ if (childpid == -1) return; - if (fclose(psend) == EOF) - syserror(); - clearqueue(); - fclose(precv); + clearqueue(1); while ((pid = wait(0)) != -1 && pid != childpid) ; childpid = -1; @@ -695,47 +681,49 @@ caldone() /* done with calculation */ rcalfill(x, y) /* fill with ray-calculated pixel */ int x, y; { - FVECT orig, dir; - float outbuf[6]; - - if (queuesiz >= PACKSIZ) { /* flush queue */ - if (fflush(psend) == EOF) - syserror(); - clearqueue(); - } - /* send new ray */ - rayview(orig, dir, &ourview, x+.5, y+.5); - outbuf[0] = orig[0]; outbuf[1] = orig[1]; outbuf[2] = orig[2]; - outbuf[3] = dir[0]; outbuf[4] = dir[1]; outbuf[5] = dir[2]; - if (fwrite(outbuf, sizeof(float), 6, psend) < 6) - syserror(); - /* remember it */ + if (queuesiz >= PACKSIZ) /* flush queue if needed */ + clearqueue(0); + /* add position to queue */ queue[queuesiz][0] = x; queue[queuesiz][1] = y; queuesiz++; } -clearqueue() /* get results from queue */ +clearqueue(done) /* process queue */ +int done; { - float inbuf[4]; + FVECT orig, dir; + float fbuf[6]; register int i; for (i = 0; i < queuesiz; i++) { - if (fread(inbuf, sizeof(float), 4, precv) < 4) { + viewray(orig, dir, &ourview, + (queue[i][0]+.5)/hresolu, + (queue[i][1]+.5)/vresolu); + fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2]; + fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2]; + fwrite(fbuf, sizeof(float), 6, psend); + } + if ((done ? fclose(psend) : fflush(psend)) == EOF) + syserror(); + for (i = 0; i < queuesiz; i++) { + if (fread(fbuf, sizeof(float), 4, precv) < 4) { fprintf(stderr, "%s: read error in clearqueue\n", progname); exit(1); } if (ourexp > 0 && ourexp != 1.0) { - inbuf[0] *= ourexp; - inbuf[1] *= ourexp; - inbuf[2] *= ourexp; + fbuf[0] *= ourexp; + fbuf[1] *= ourexp; + fbuf[2] *= ourexp; } setcolr(pscan(queue[i][1])[queue[i][0]], - inbuf[0], inbuf[1], inbuf[2]); - zscan(queue[i][1])[queue[i][0]] = inbuf[3]; + fbuf[0], fbuf[1], fbuf[2]); + zscan(queue[i][1])[queue[i][0]] = fbuf[3]; } + if (done) + fclose(precv); queuesiz = 0; }
