root/radiance/ray/src/px/pinterp.c
Revision: 2.15
Committed: Thu Dec 22 19:11:01 1994 UTC (30 years, 4 months ago) by greg
Changes since 2.14: +39 -9 lines
made aft clipping work(?) and fixed bug in movepixel()
1 /* Copyright (c) 1994 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <ctype.h>
16
17 #include "view.h"
18
19 #include "color.h"
20
21 #include "resolu.h"
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 256 /* max. calculation packet size */
30
31 #define RTCOM "rtrace -h- -ovl -fff "
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fillo = F_FORE|F_BACK; /* selected fill options */
50 int fillsamp = 0; /* sample separation (0 == inf) */
51 extern int backfill(), rcalfill(); /* fill functions */
52 int (*fillfunc)() = backfill; /* selected fill function */
53 COLR backcolr = BLKCOLR; /* background color */
54 double backz = 0.0; /* background z value */
55 int normdist = 1; /* normalized distance? */
56 double ourexp = -1; /* output picture exposure */
57
58 VIEW theirview = STDVIEW; /* input view */
59 int gotview; /* got input view? */
60 int wrongformat = 0; /* input in another format? */
61 RESOLU tresolu; /* input resolution */
62 double theirexp; /* input picture exposure */
63 double theirs2ours[4][4]; /* transformation matrix */
64 int hasmatrix = 0; /* has transformation matrix */
65
66 int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
67 #define childpid (PDesc[2])
68 unsigned short queue[PACKSIZ][2]; /* pending pixels */
69 int packsiz; /* actual packet size */
70 int queuesiz; /* number of pixels pending */
71
72
73 main(argc, argv) /* interpolate pictures */
74 int argc;
75 char *argv[];
76 {
77 #define check(ol,al) if (argv[i][ol] || \
78 badarg(argc-i-1,argv+i+1,al)) \
79 goto badopt
80 int gotvfile = 0;
81 char *zfile = NULL;
82 char *err;
83 int i, rval;
84
85 progname = argv[0];
86
87 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
88 rval = getviewopt(&ourview, argc-i, argv+i);
89 if (rval >= 0) {
90 i += rval;
91 continue;
92 }
93 switch (argv[i][1]) {
94 case 't': /* threshold */
95 check(2,"f");
96 zeps = atof(argv[++i]);
97 break;
98 case 'n': /* dist. normalized? */
99 check(2,NULL);
100 normdist = !normdist;
101 break;
102 case 'f': /* fill type */
103 switch (argv[i][2]) {
104 case '0': /* none */
105 check(3,NULL);
106 fillo = 0;
107 break;
108 case 'f': /* foreground */
109 check(3,NULL);
110 fillo = F_FORE;
111 break;
112 case 'b': /* background */
113 check(3,NULL);
114 fillo = F_BACK;
115 break;
116 case 'a': /* all */
117 check(3,NULL);
118 fillo = F_FORE|F_BACK;
119 break;
120 case 's': /* sample */
121 check(3,"i");
122 fillsamp = atoi(argv[++i]);
123 break;
124 case 'c': /* color */
125 check(3,"fff");
126 fillfunc = backfill;
127 setcolr(backcolr, atof(argv[i+1]),
128 atof(argv[i+2]), atof(argv[i+3]));
129 i += 3;
130 break;
131 case 'z': /* z value */
132 check(3,"f");
133 fillfunc = backfill;
134 backz = atof(argv[++i]);
135 break;
136 case 'r': /* rtrace */
137 check(3,"s");
138 fillfunc = rcalfill;
139 calstart(RTCOM, argv[++i]);
140 break;
141 default:
142 goto badopt;
143 }
144 break;
145 case 'z': /* z file */
146 check(2,"s");
147 zfile = argv[++i];
148 break;
149 case 'x': /* x resolution */
150 check(2,"i");
151 hresolu = atoi(argv[++i]);
152 break;
153 case 'y': /* y resolution */
154 check(2,"i");
155 vresolu = atoi(argv[++i]);
156 break;
157 case 'p': /* pixel aspect */
158 if (argv[i][2] != 'a')
159 goto badopt;
160 check(3,"f");
161 pixaspect = atof(argv[++i]);
162 break;
163 case 'v': /* view file */
164 if (argv[i][2] != 'f')
165 goto badopt;
166 check(3,"s");
167 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
168 if (gotvfile < 0)
169 syserror(argv[i]);
170 else if (gotvfile == 0) {
171 fprintf(stderr, "%s: bad view file\n",
172 argv[i]);
173 exit(1);
174 }
175 break;
176 default:
177 badopt:
178 fprintf(stderr, "%s: command line error at '%s'\n",
179 progname, argv[i]);
180 goto userr;
181 }
182 }
183 /* check arguments */
184 if ((argc-i)%2)
185 goto userr;
186 if (fillsamp == 1)
187 fillo &= ~F_BACK;
188 /* set view */
189 if ((err = setview(&ourview)) != NULL) {
190 fprintf(stderr, "%s: %s\n", progname, err);
191 exit(1);
192 }
193 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
194 /* allocate frame */
195 ourpict = (COLR *)bmalloc(hresolu*vresolu*sizeof(COLR));
196 ourzbuf = (float *)bmalloc(hresolu*vresolu*sizeof(float));
197 if (ourpict == NULL || ourzbuf == NULL)
198 syserror(progname);
199 bzero((char *)ourzbuf, hresolu*vresolu*sizeof(float));
200 /* new header */
201 newheader("RADIANCE", stdout);
202 /* get input */
203 for ( ; i < argc; i += 2)
204 addpicture(argv[i], argv[i+1]);
205 /* fill in spaces */
206 if (fillo&F_BACK)
207 backpicture(fillfunc, fillsamp);
208 else
209 fillpicture(fillfunc);
210 /* close calculation */
211 caldone();
212 /* aft clipping */
213 clipaft();
214 /* add to header */
215 printargs(argc, argv, stdout);
216 if (gotvfile) {
217 fputs(VIEWSTR, stdout);
218 fprintview(&ourview, stdout);
219 putc('\n', stdout);
220 }
221 if (pixaspect < .99 || pixaspect > 1.01)
222 fputaspect(pixaspect, stdout);
223 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
224 fputexpos(ourexp, stdout);
225 fputformat(COLRFMT, stdout);
226 putc('\n', stdout);
227 /* write picture */
228 writepicture();
229 /* write z file */
230 if (zfile != NULL)
231 writedistance(zfile);
232
233 exit(0);
234 userr:
235 fprintf(stderr,
236 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
237 progname);
238 exit(1);
239 #undef check
240 }
241
242
243 headline(s) /* process header string */
244 char *s;
245 {
246 char fmt[32];
247
248 if (isheadid(s))
249 return;
250 if (formatval(fmt, s)) {
251 wrongformat = strcmp(fmt, COLRFMT);
252 return;
253 }
254 putc('\t', stdout);
255 fputs(s, stdout);
256
257 if (isexpos(s)) {
258 theirexp *= exposval(s);
259 return;
260 }
261 if (isview(s) && sscanview(&theirview, s) > 0)
262 gotview++;
263 }
264
265
266 addpicture(pfile, zspec) /* add picture to output */
267 char *pfile, *zspec;
268 {
269 FILE *pfp;
270 int zfd;
271 char *err;
272 COLR *scanin;
273 float *zin;
274 struct position *plast;
275 int y;
276 /* open picture file */
277 if ((pfp = fopen(pfile, "r")) == NULL)
278 syserror(pfile);
279 /* get header with exposure and view */
280 theirexp = 1.0;
281 gotview = 0;
282 printf("%s:\n", pfile);
283 getheader(pfp, headline, NULL);
284 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
285 fprintf(stderr, "%s: picture format error\n", pfile);
286 exit(1);
287 }
288 if (ourexp <= 0)
289 ourexp = theirexp;
290 else if (ABS(theirexp-ourexp) > .01*ourexp)
291 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
292 if (err = setview(&theirview)) {
293 fprintf(stderr, "%s: %s\n", pfile, err);
294 exit(1);
295 }
296 /* compute transformation */
297 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
298 /* allocate scanlines */
299 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
300 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
301 plast = (struct position *)calloc(scanlen(&tresolu),
302 sizeof(struct position));
303 if (scanin == NULL || zin == NULL || plast == NULL)
304 syserror(progname);
305 /* get z specification or file */
306 if ((zfd = open(zspec, O_RDONLY)) == -1) {
307 double zvalue;
308 register int x;
309 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0)
310 syserror(zspec);
311 for (x = scanlen(&tresolu); x-- > 0; )
312 zin[x] = zvalue;
313 }
314 /* load image */
315 for (y = 0; y < numscans(&tresolu); y++) {
316 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
317 fprintf(stderr, "%s: read error\n", pfile);
318 exit(1);
319 }
320 if (zfd != -1 && read(zfd,(char *)zin,
321 scanlen(&tresolu)*sizeof(float))
322 < scanlen(&tresolu)*sizeof(float)) {
323 fprintf(stderr, "%s: read error\n", zspec);
324 exit(1);
325 }
326 addscanline(y, scanin, zin, plast);
327 }
328 /* clean up */
329 free((char *)scanin);
330 free((char *)zin);
331 free((char *)plast);
332 fclose(pfp);
333 if (zfd != -1)
334 close(zfd);
335 }
336
337
338 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
339 register double xfmat[4][4];
340 register VIEW *vw1, *vw2;
341 {
342 double m4t[4][4];
343
344 if (vw1->type != VT_PER && vw1->type != VT_PAR)
345 return(0);
346 if (vw2->type != VT_PER && vw2->type != VT_PAR)
347 return(0);
348 setident4(xfmat);
349 xfmat[0][0] = vw1->hvec[0];
350 xfmat[0][1] = vw1->hvec[1];
351 xfmat[0][2] = vw1->hvec[2];
352 xfmat[1][0] = vw1->vvec[0];
353 xfmat[1][1] = vw1->vvec[1];
354 xfmat[1][2] = vw1->vvec[2];
355 xfmat[2][0] = vw1->vdir[0];
356 xfmat[2][1] = vw1->vdir[1];
357 xfmat[2][2] = vw1->vdir[2];
358 xfmat[3][0] = vw1->vp[0];
359 xfmat[3][1] = vw1->vp[1];
360 xfmat[3][2] = vw1->vp[2];
361 setident4(m4t);
362 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
363 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
364 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
365 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
366 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
367 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
368 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
369 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
370 m4t[0][2] = vw2->vdir[0];
371 m4t[1][2] = vw2->vdir[1];
372 m4t[2][2] = vw2->vdir[2];
373 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
374 multmat4(xfmat, xfmat, m4t);
375 return(1);
376 }
377
378
379 addscanline(y, pline, zline, lasty) /* add scanline to output */
380 int y;
381 COLR *pline;
382 float *zline;
383 struct position *lasty; /* input/output */
384 {
385 FVECT pos;
386 struct position lastx, newpos;
387 register int x;
388
389 lastx.z = 0;
390 for (x = scanlen(&tresolu); x-- > 0; ) {
391 pix2loc(pos, &tresolu, x, y);
392 pos[2] = zline[x];
393 if (movepixel(pos) < 0) {
394 lasty[x].z = lastx.z = 0; /* mark invalid */
395 continue;
396 }
397 newpos.x = pos[0] * hresolu;
398 newpos.y = pos[1] * vresolu;
399 newpos.z = zline[x];
400 /* add pixel to our image */
401 if (pos[0] >= 0 && newpos.x < hresolu
402 && pos[1] >= 0 && newpos.y < vresolu) {
403 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
404 lasty[x].x = lastx.x = newpos.x;
405 lasty[x].y = lastx.y = newpos.y;
406 lasty[x].z = lastx.z = newpos.z;
407 } else
408 lasty[x].z = lastx.z = 0; /* mark invalid */
409 }
410 }
411
412
413 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
414 struct position *p0, *p1, *p2;
415 COLR pix;
416 double z;
417 {
418 double zt = 2.*zeps*p0->z; /* threshold */
419 int s1x, s1y, s2x, s2y; /* step sizes */
420 int l1, l2, c1, c2; /* side lengths and counters */
421 int p1isy; /* p0p1 along y? */
422 int x1, y1; /* p1 position */
423 register int x, y; /* final position */
424
425 /* compute vector p0p1 */
426 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
427 s1x = p1->x - p0->x;
428 s1y = p1->y - p0->y;
429 l1 = ABS(s1x);
430 if (p1isy = (ABS(s1y) > l1))
431 l1 = ABS(s1y);
432 } else {
433 l1 = s1x = s1y = 1;
434 p1isy = -1;
435 }
436 /* compute vector p0p2 */
437 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
438 s2x = p2->x - p0->x;
439 s2y = p2->y - p0->y;
440 if (p1isy == 1)
441 l2 = ABS(s2x);
442 else {
443 l2 = ABS(s2y);
444 if (p1isy != 0 && ABS(s2x) > l2)
445 l2 = ABS(s2x);
446 }
447 } else
448 l2 = s2x = s2y = 1;
449 /* fill the parallelogram */
450 for (c1 = l1; c1-- > 0; ) {
451 x1 = p0->x + c1*s1x/l1;
452 y1 = p0->y + c1*s1y/l1;
453 for (c2 = l2; c2-- > 0; ) {
454 x = x1 + c2*s2x/l2;
455 if (x < 0 || x >= hresolu)
456 continue;
457 y = y1 + c2*s2y/l2;
458 if (y < 0 || y >= vresolu)
459 continue;
460 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
461 > zeps*zscan(y)[x]) {
462 zscan(y)[x] = z;
463 copycolr(pscan(y)[x], pix);
464 }
465 }
466 }
467 }
468
469
470 movepixel(pos) /* reposition image point */
471 FVECT pos;
472 {
473 double d0, d1;
474 FVECT pt, direc;
475
476 if (pos[2] <= 0) /* empty pixel */
477 return(-1);
478 if (normdist && theirview.type == VT_PER) { /* adjust distance */
479 d0 = pos[0] + theirview.hoff - .5;
480 d1 = pos[1] + theirview.voff - .5;
481 pos[2] /= sqrt(1. + d0*d0*theirview.hn2 + d1*d1*theirview.vn2);
482 }
483 if (hasmatrix) {
484 pos[0] += theirview.hoff - .5;
485 pos[1] += theirview.voff - .5;
486 if (theirview.type == VT_PER) {
487 pos[0] *= pos[2];
488 pos[1] *= pos[2];
489 }
490 multp3(pos, pos, theirs2ours);
491 if (pos[2] <= 0)
492 return(-1);
493 if (ourview.type == VT_PER) {
494 pos[0] /= pos[2];
495 pos[1] /= pos[2];
496 }
497 pos[0] += .5 - ourview.hoff;
498 pos[1] += .5 - ourview.voff;
499 return(0);
500 }
501 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < -FTINY)
502 return(-1);
503 pt[0] += direc[0]*pos[2];
504 pt[1] += direc[1]*pos[2];
505 pt[2] += direc[2]*pos[2];
506 viewloc(pos, &ourview, pt);
507 if (pos[2] <= 0)
508 return(-1);
509 return(0);
510 }
511
512
513 backpicture(fill, samp) /* background fill algorithm */
514 int (*fill)();
515 int samp;
516 {
517 int *yback, xback;
518 int y;
519 register int x, i;
520 /* get back buffer */
521 yback = (int *)malloc(hresolu*sizeof(int));
522 if (yback == NULL)
523 syserror(progname);
524 for (x = 0; x < hresolu; x++)
525 yback[x] = -2;
526 /*
527 * Xback and yback are the pixel locations of suitable
528 * background values in each direction.
529 * A value of -2 means unassigned, and -1 means
530 * that there is no suitable background in this direction.
531 */
532 /* fill image */
533 for (y = 0; y < vresolu; y++) {
534 xback = -2;
535 for (x = 0; x < hresolu; x++)
536 if (zscan(y)[x] <= 0) { /* empty pixel */
537 /*
538 * First, find background from above or below.
539 * (farthest assigned pixel)
540 */
541 if (yback[x] == -2) {
542 for (i = y+1; i < vresolu; i++)
543 if (zscan(i)[x] > 0)
544 break;
545 if (i < vresolu
546 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
547 yback[x] = i;
548 else
549 yback[x] = y-1;
550 }
551 /*
552 * Next, find background from left or right.
553 */
554 if (xback == -2) {
555 for (i = x+1; i < hresolu; i++)
556 if (zscan(y)[i] > 0)
557 break;
558 if (i < hresolu
559 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
560 xback = i;
561 else
562 xback = x-1;
563 }
564 /*
565 * If we have no background for this pixel,
566 * use the given fill function.
567 */
568 if (xback < 0 && yback[x] < 0)
569 goto fillit;
570 /*
571 * Compare, and use the background that is
572 * farther, unless one of them is next to us.
573 * If the background is too distant, call
574 * the fill function.
575 */
576 if ( yback[x] < 0
577 || (xback >= 0 && ABS(x-xback) <= 1)
578 || ( ABS(y-yback[x]) > 1
579 && zscan(yback[x])[x]
580 < zscan(y)[xback] ) ) {
581 if (samp > 0 && ABS(x-xback) >= samp)
582 goto fillit;
583 copycolr(pscan(y)[x],pscan(y)[xback]);
584 zscan(y)[x] = zscan(y)[xback];
585 } else {
586 if (samp > 0 && ABS(y-yback[x]) > samp)
587 goto fillit;
588 copycolr(pscan(y)[x],pscan(yback[x])[x]);
589 zscan(y)[x] = zscan(yback[x])[x];
590 }
591 continue;
592 fillit:
593 (*fill)(x,y);
594 if (fill == rcalfill) { /* use it */
595 clearqueue();
596 xback = x;
597 yback[x] = y;
598 }
599 } else { /* full pixel */
600 yback[x] = -2;
601 xback = -2;
602 }
603 }
604 free((char *)yback);
605 }
606
607
608 fillpicture(fill) /* paint in empty pixels using fill */
609 int (*fill)();
610 {
611 register int x, y;
612
613 for (y = 0; y < vresolu; y++)
614 for (x = 0; x < hresolu; x++)
615 if (zscan(y)[x] <= 0)
616 (*fill)(x,y);
617 }
618
619
620 clipaft() /* perform aft clipping as indicated */
621 {
622 register int x, y;
623 double tstdist;
624 double yzn2, vx;
625
626 if (ourview.vaft <= FTINY)
627 return;
628 tstdist = ourview.vaft;
629 for (y = 0; y < vresolu; y++) {
630 if (ourview.type == VT_PER) { /* adjust distance */
631 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
632 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
633 tstdist = ourview.vaft * sqrt(yzn2);
634 }
635 for (x = 0; x < hresolu; x++)
636 if (zscan(y)[x] > tstdist) {
637 if (ourview.type == VT_PER) {
638 vx = (x+.5)/hresolu + ourview.hoff - .5;
639 if (zscan(y)[x] <= ourview.vaft *
640 sqrt(vx*vx*ourview.hn2 + yzn2))
641 continue;
642 }
643 bzero(pscan(y)[x], sizeof(COLR));
644 zscan(y)[x] = 0.0;
645 }
646 }
647 }
648
649
650 writepicture() /* write out picture */
651 {
652 int y;
653
654 fprtresolu(hresolu, vresolu, stdout);
655 for (y = vresolu-1; y >= 0; y--)
656 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
657 syserror(progname);
658 }
659
660
661 writedistance(fname) /* write out z file */
662 char *fname;
663 {
664 int donorm = normdist && ourview.type == VT_PER;
665 int fd;
666 int y;
667 float *zout;
668
669 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1)
670 syserror(fname);
671 if (donorm
672 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
673 syserror(progname);
674 for (y = vresolu-1; y >= 0; y--) {
675 if (donorm) {
676 double vx, yzn2;
677 register int x;
678 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
679 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
680 for (x = 0; x < hresolu; x++) {
681 vx = (x+.5)/hresolu + ourview.hoff - .5;
682 zout[x] = zscan(y)[x]
683 * sqrt(vx*vx*ourview.hn2 + yzn2);
684 }
685 } else
686 zout = zscan(y);
687 if (write(fd, (char *)zout, hresolu*sizeof(float))
688 < hresolu*sizeof(float))
689 syserror(fname);
690 }
691 if (donorm)
692 free((char *)zout);
693 close(fd);
694 }
695
696
697 isfloat(s) /* see if string is floating number */
698 register char *s;
699 {
700 for ( ; *s; s++)
701 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
702 && *s != 'e' && *s != 'E' && *s != '+')
703 return(0);
704 return(1);
705 }
706
707
708 backfill(x, y) /* fill pixel with background */
709 int x, y;
710 {
711 register BYTE *dest = pscan(y)[x];
712
713 copycolr(dest, backcolr);
714 zscan(y)[x] = backz;
715 }
716
717
718 calstart(prog, args) /* start fill calculation */
719 char *prog, *args;
720 {
721 char combuf[512];
722 char *argv[64];
723 int rval;
724 register char **wp, *cp;
725
726 if (childpid != -1) {
727 fprintf(stderr, "%s: too many calculations\n", progname);
728 exit(1);
729 }
730 strcpy(combuf, prog);
731 strcat(combuf, args);
732 cp = combuf;
733 wp = argv;
734 for ( ; ; ) {
735 while (isspace(*cp)) /* nullify spaces */
736 *cp++ = '\0';
737 if (!*cp) /* all done? */
738 break;
739 *wp++ = cp; /* add argument to list */
740 while (*++cp && !isspace(*cp))
741 ;
742 }
743 *wp = NULL;
744 /* start process */
745 if ((rval = open_process(PDesc, argv)) < 0)
746 syserror(progname);
747 if (rval == 0) {
748 fprintf(stderr, "%s: command not found\n", argv[0]);
749 exit(1);
750 }
751 packsiz = rval/(6*sizeof(float)) - 1;
752 if (packsiz > PACKSIZ)
753 packsiz = PACKSIZ;
754 queuesiz = 0;
755 }
756
757
758 caldone() /* done with calculation */
759 {
760 if (childpid == -1)
761 return;
762 clearqueue();
763 close_process(PDesc);
764 childpid = -1;
765 }
766
767
768 rcalfill(x, y) /* fill with ray-calculated pixel */
769 int x, y;
770 {
771 if (queuesiz >= packsiz) /* flush queue if needed */
772 clearqueue();
773 /* add position to queue */
774 queue[queuesiz][0] = x;
775 queue[queuesiz][1] = y;
776 queuesiz++;
777 }
778
779
780 clearqueue() /* process queue */
781 {
782 FVECT orig, dir;
783 float fbuf[6*(PACKSIZ+1)];
784 register float *fbp;
785 register int i;
786
787 if (queuesiz == 0)
788 return;
789 fbp = fbuf;
790 for (i = 0; i < queuesiz; i++) {
791 viewray(orig, dir, &ourview,
792 (queue[i][0]+.5)/hresolu,
793 (queue[i][1]+.5)/vresolu);
794 *fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
795 *fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
796 }
797 /* mark end and get results */
798 bzero((char *)fbp, 6*sizeof(float));
799 if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
800 6*sizeof(float)*(queuesiz+1)) !=
801 4*sizeof(float)*queuesiz) {
802 fprintf(stderr, "%s: error reading from rtrace process\n",
803 progname);
804 exit(1);
805 }
806 fbp = fbuf;
807 for (i = 0; i < queuesiz; i++) {
808 if (ourexp > 0 && ourexp != 1.0) {
809 fbp[0] *= ourexp;
810 fbp[1] *= ourexp;
811 fbp[2] *= ourexp;
812 }
813 setcolr(pscan(queue[i][1])[queue[i][0]],
814 fbp[0], fbp[1], fbp[2]);
815 zscan(queue[i][1])[queue[i][0]] = fbp[3];
816 fbp += 4;
817 }
818 queuesiz = 0;
819 }
820
821
822 syserror(s) /* report error and exit */
823 char *s;
824 {
825 perror(s);
826 exit(1);
827 }
