root/radiance/ray/src/px/pinterp.c
Mon Nov 20 21:44:29 2023 UTC (5 months, 3 weeks ago) by greg
Diff to previous 2.50 , to selected 2.49
refactor: Eliminated LPICFMT macro
Thu May 14 20:51:02 2020 UTC (4 years ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.49: +17 -11 lines
Diff to previous 2.49
Fixed issue with return value checking on viewloc() and open_float_depth()
Revision 2.49 - (view) (download) (annotate) - [selected]
Fri Feb 28 05:18:49 2020 UTC (4 years, 2 months ago) by greg
Diff to previous 2.48
Thu Nov 7 23:20:28 2019 UTC (4 years, 6 months ago) by greg
Diff to previous 2.47 , to selected 2.49
Thu Aug 2 18:33:45 2018 UTC (5 years, 9 months ago) by greg
Diff to previous 2.46 , to selected 2.49
Wed Jan 24 04:39:52 2018 UTC (6 years, 3 months ago) by greg
Changes since 2.45: +2 -3 lines
Diff to previous 2.45 , to selected 2.49
Mon May 20 21:52:06 2013 UTC (10 years, 11 months ago) by greg
Changes since 2.44: +2 -3 lines
Diff to previous 2.44 , to selected 2.49
Fixed never-noticed bug in pinterp with -n option
Sun Mar 24 19:00:33 2013 UTC (11 years, 1 month ago) by greg
Changes since 2.43: +22 -22 lines
Diff to previous 2.43 , to selected 2.49
Corrected definition of matrix
Wed Feb 8 13:43:21 2012 UTC (12 years, 3 months ago) by greg
Changes since 2.42: +4 -1 lines
Diff to previous 2.42 , to selected 2.49
Added missing Windows binary file mode
Tue Jan 18 03:59:41 2005 UTC (19 years, 3 months ago) by greg
Changes since 2.41: +3 -1 lines
Diff to previous 2.41 , to selected 2.49
Changes since 2.40: +119 -56 lines
Diff to previous 2.40 , to selected 2.49
Fri Jan 2 12:47:01 2004 UTC (20 years, 4 months ago) by schorsch
Changes since 2.39: +8 -4 lines
Diff to previous 2.39 , to selected 2.49
Wed Oct 22 02:06:35 2003 UTC (20 years, 6 months ago) by greg
Diff to previous 2.38 , to selected 2.49
Mon Oct 20 16:01:55 2003 UTC (20 years, 6 months ago) by greg
Changes since 2.37: +5 -3 lines
Diff to previous 2.37 , to selected 2.49
Changes since 2.36: +18 -18 lines
Diff to previous 2.36 , to selected 2.49
Mon Jul 21 22:30:18 2003 UTC (20 years, 9 months ago) by schorsch
Changes since 2.35: +8 -7 lines
Diff to previous 2.35 , to selected 2.49
Changes since 2.34: +6 -5 lines
Diff to previous 2.34 , to selected 2.49
Changes since 2.33: +10 -11 lines
Diff to previous 2.33 , to selected 2.49
Changes since 2.32: +14 -17 lines
Diff to previous 2.32 , to selected 2.49
Fri Jul 16 16:11:31 1999 UTC (24 years, 10 months ago) by gwlarson
Changes since 2.31: +13 -11 lines
Diff to previous 2.31 , to selected 2.49
improved pixel weighting computation
Tue Oct 27 09:08:26 1998 UTC (25 years, 6 months ago) by gwlarson
Changes since 2.30: +5 -3 lines
Diff to previous 2.30 , to selected 2.49
Mon Oct 20 16:36:32 1997 UTC (26 years, 6 months ago) by gregl
Diff to previous 2.29 , to selected 2.49
Wed Jul 9 11:23:07 1997 UTC (26 years, 10 months ago) by gregl
Diff to previous 2.28 , to selected 2.49
Mon Jun 24 09:17:47 1996 UTC (27 years, 10 months ago) by greg
Diff to previous 2.27 , to selected 2.49
fixed NULL pointer for AIX
Mon Oct 16 11:40:16 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.26: +8 -2 lines
Diff to previous 2.26 , to selected 2.49
added compatibility with alternate RADIANCE picture formats
Sat Sep 16 10:30:52 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.25: +4 -2 lines
Diff to previous 2.25 , to selected 2.49
fixed error related to rtrace queue and -B option
Fri Sep 15 22:04:04 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.24: +8 -8 lines
Diff to previous 2.24 , to selected 2.49
minor modifications
Thu Sep 14 13:40:17 1995 UTC (28 years, 8 months ago) by greg
Changes since 2.23: +187 -55 lines
Diff to previous 2.23 , to selected 2.49
added -B option for blurring images
Fri Jan 6 13:19:37 1995 UTC (29 years, 4 months ago) by greg
Changes since 2.22: +9 -4 lines
Diff to previous 2.22 , to selected 2.49
bug fix in view fore clipping plane with matrix code
Tue Dec 27 18:04:29 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.21: +28 -21 lines
Diff to previous 2.21 , to selected 2.49
bug fixes related to -n, -z and -fr options
Mon Dec 26 21:02:31 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.20: +42 -10 lines
Diff to previous 2.20 , to selected 2.49
add -e exposure option and fixed small bug
Mon Dec 26 19:57:22 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.19: +19 -18 lines
Diff to previous 2.19 , to selected 2.49
bug fixes and improvements to last change (averaging)
Fri Dec 23 22:35:12 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.18: +143 -62 lines
Diff to previous 2.18 , to selected 2.49
added pixel averaging (-a and -q options)
Fri Dec 23 19:15:48 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.17: +54 -49 lines
Diff to previous 2.17 , to selected 2.49
bug fix in getperim()
Fri Dec 23 17:23:05 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.16: +4 -3 lines
Diff to previous 2.16 , to selected 2.49
bug fix in clipaft()
Fri Dec 23 15:42:55 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.15: +128 -15 lines
Diff to previous 2.15 , to selected 2.49
added automatic cropping to speed transfer of low-overlap images
Thu Dec 22 19:11:01 1994 UTC (29 years, 4 months ago) by greg
Changes since 2.14: +39 -9 lines
Diff to previous 2.14 , to selected 2.49
made aft clipping work(?) and fixed bug in movepixel()
Wed Dec 21 16:59:03 1994 UTC (29 years, 4 months ago) by greg
Diff to previous 2.13 , to selected 2.49
added -vo and -va fore and aft clipping plane options
Sun Feb 27 10:16:57 1994 UTC (30 years, 2 months ago) by greg
Changes since 2.12: +5 -2 lines
Diff to previous 2.12 , to selected 2.49
Mon Apr 12 09:58:09 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.11: +0 -1 lines
Diff to previous 2.11 , to selected 2.49
fixed incomplete change
Fri Apr 2 09:10:48 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.10: +7 -7 lines
Diff to previous 2.10 , to selected 2.49
minor change in argument parsing in calstart()
Thu Apr 1 11:21:18 1993 UTC (31 years, 1 month ago) by greg
Changes since 2.9: +23 -32 lines
Diff to previous 2.9 , to selected 2.49
minor fixes and improvements in error reporting
Fri Oct 2 16:24:22 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.8: +0 -2 lines
Diff to previous 2.8 , to selected 2.49
Thu Sep 24 21:33:52 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.7: +0 -2 lines
Diff to previous 2.7 , to selected 2.49
removed redundant fcntl.h include (included in standard.h)
Fri Jun 19 12:54:41 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.6 , to selected 2.49
changed malloc() call to bmalloc() for frame storage
Tue May 26 15:23:09 1992 UTC (31 years, 11 months ago) by greg
Diff to previous 2.5 , to selected 2.49
fixed -pa option
Tue Apr 28 09:40:39 1992 UTC (32 years ago) by greg
Changes since 2.4: +2 -8 lines
Diff to previous 2.4 , to selected 2.49
changed calls to get view parameters from files
Thu Mar 26 13:03:34 1992 UTC (32 years, 1 month ago) by greg
Diff to previous 2.3 , to selected 2.49
added missing space to rtrace command
Mon Mar 23 16:50:26 1992 UTC (32 years, 1 month ago) by greg
Changes since 2.2: +78 -74 lines
Diff to previous 2.2 , to selected 2.49
modified to use process.c routines and badarg.c -- not checked!
Thu Dec 19 14:51:55 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 2.1 , to selected 2.49
Tue Nov 12 16:04:39 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.34: +0 -0 lines
Diff to previous 1.34 , to selected 2.49
Mon Nov 11 14:01:57 1991 UTC (32 years, 6 months ago) by greg
Changes since 1.33: +20 -17 lines
Diff to previous 1.33 , to selected 2.49
Thu Apr 18 14:35:26 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.32: +13 -4 lines
Diff to previous 1.32 , to selected 2.49
Mon Feb 11 18:10:56 1991 UTC (33 years, 3 months ago) by greg
Changes since 1.31: +2 -0 lines
Diff to previous 1.31 , to selected 2.49
added test for zero z input values (bug fix)
Fri Dec 21 17:20:07 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.30: +0 -1 lines
Diff to previous 1.30 , to selected 2.49
minor compiler complaints
Mon Oct 15 11:01:48 1990 UTC (33 years, 7 months ago) by greg
Changes since 1.29: +50 -20 lines
Diff to previous 1.29 , to selected 2.49
added fisheye view types
Tue Sep 4 21:16:25 1990 UTC (33 years, 8 months ago) by greg
Diff to previous 1.28 , to selected 2.49
fixed bug in normalization used in writedistance()
Fri Mar 16 19:19:52 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.27: +4 -0 lines
Diff to previous 1.27 , to selected 2.49
tightened up constraints in addpixel() (bug fix)
Tue Mar 6 15:45:31 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.26: +16 -12 lines
Diff to previous 1.26 , to selected 2.49
fixed sampling so samples are reused as background
Tue Mar 6 12:04:56 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.25: +16 -15 lines
Diff to previous 1.25 , to selected 2.49
changed sampling to pixel distance rather than probability
Tue Mar 6 11:14:36 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.24: +52 -34 lines
Diff to previous 1.24 , to selected 2.49
added sampling
Mon Feb 26 14:01:44 1990 UTC (34 years, 2 months ago) by greg
Changes since 1.23: +1 -1 lines
Diff to previous 1.23 , to selected 2.49
changed <sys/fcntl.h> to <fcntl.h>
Thu Jan 18 23:58:29 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.22: +4 -4 lines
Diff to previous 1.22 , to selected 2.49
Wed Jan 17 18:05:07 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.21: +26 -27 lines
Diff to previous 1.21 , to selected 2.49
simplified call to clearqueue()
Wed Jan 17 15:12:37 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.20: +4 -0 lines
Diff to previous 1.20 , to selected 2.49
removed vfork() dependency and added -DBSD to Makefile
Tue Jan 16 16:10:57 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.19: +1 -0 lines
Diff to previous 1.19 , to selected 2.49
added initialization in addscanline()
Tue Jan 16 11:29:14 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.18: +15 -11 lines
Diff to previous 1.18 , to selected 2.49
changed reading and writing of z-files and viewfiles
Tue Jan 9 11:39:17 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.17: +9 -1 lines
Diff to previous 1.17 , to selected 2.49
added maintenance of pixel aspect ratio
Mon Jan 8 14:47:15 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.16: +88 -116 lines
Diff to previous 1.16 , to selected 2.49
changed handling of view parameters
Sat Jan 6 22:27:10 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.15: +23 -6 lines
Diff to previous 1.15 , to selected 2.49
added code to deal with picture exposure
Fri Jan 5 11:34:27 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.14: +78 -67 lines
Diff to previous 1.14 , to selected 2.49
changed addpixel() to fill parallelogram
Thu Jan 4 17:47:37 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.13: +35 -19 lines
Diff to previous 1.13 , to selected 2.49
added error checking on calculation I/O
Thu Jan 4 16:52:05 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.12: +122 -6 lines
Diff to previous 1.12 , to selected 2.49
added fill calculation with rtrace
Thu Jan 4 14:25:56 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.11: +20 -8 lines
Diff to previous 1.11 , to selected 2.49
added (*deffill)() in anticipation of computed fill
Thu Jan 4 10:12:49 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.10: +125 -15 lines
Diff to previous 1.10 , to selected 2.49
added -f and -n options, bug fixes in fillpicture()
Wed Jan 3 15:33:44 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.9: +49 -25 lines
Diff to previous 1.9 , to selected 2.49
added constant z specification and -r option
Wed Jan 3 12:52:30 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.8: +18 -19 lines
Diff to previous 1.8 , to selected 2.49
changed use of variables in addpicture()
Wed Jan 3 09:37:16 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.7: +68 -24 lines
Diff to previous 1.7 , to selected 2.49
improved initial fill to use object coherence
Tue Jan 2 17:22:07 1990 UTC (34 years, 4 months ago) by greg
Changes since 1.6: +20 -3 lines
Diff to previous 1.6 , to selected 2.49
Added comments and fixed small comparison error.
Thu Dec 28 15:09:28 1989 UTC (34 years, 4 months ago) by greg
Changes since 1.5: +8 -0 lines
Diff to previous 1.5 , to selected 2.49
forgot x and y resolution options
Fri Dec 22 10:08:33 1989 UTC (34 years, 4 months ago) by greg
Changes since 1.4: +68 -14 lines
Diff to previous 1.4 , to selected 2.49
Changed calls to rayview() and pixelview() to matrix transform
Wed Dec 13 12:41:25 1989 UTC (34 years, 5 months ago) by greg
Changes since 1.3: +35 -37 lines
Diff to previous 1.3 , to selected 2.49
changed fillpicture() to make it more efficient
Tue Dec 12 15:53:10 1989 UTC (34 years, 5 months ago) by greg
Changes since 1.2: +5 -2 lines
Diff to previous 1.2 , to selected 2.49
added test for neighbor to fillpicture()
Tue Dec 12 11:21:25 1989 UTC (34 years, 5 months ago) by greg
Changes since 1.1: +50 -23 lines
Diff to previous 1.1 , to selected 2.49
enhanced fillpicture() function
Sun Dec 10 17:34:13 1989 UTC (34 years, 5 months ago) by greg
Diff to selected 2.49
