root/radiance/ray/src/px/pinterp.c
Revision: 1.22
Committed: Wed Jan 17 18:05:07 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.21: +26 -27 lines
simplified call to clearqueue()
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Interpolate and extrapolate pictures with different view parameters.
7 *
8 * Greg Ward 09Dec89
9 */
10
11 #include "standard.h"
12
13 #include <sys/fcntl.h>
14
15 #include "view.h"
16
17 #include "color.h"
18
19 #ifndef BSD
20 #define vfork fork
21 #endif
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 42 /* calculation packet size */
30
31 #define RTCOM "rtrace -h -ovl -fff -x %d %s"
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fill = F_FORE|F_BACK; /* selected fill algorithm */
50 extern int backfill(), rcalfill(); /* fill functions */
51 int (*deffill)() = backfill; /* selected fill function */
52 COLR backcolr = BLKCOLR; /* background color */
53 double backz = 0.0; /* background z value */
54 int normdist = 1; /* normalized distance? */
55 double ourexp = -1; /* output picture exposure */
56
57 VIEW theirview = STDVIEW; /* input view */
58 int gotview; /* got input view? */
59 int thresolu, tvresolu; /* input resolution */
60 double theirexp; /* input picture exposure */
61 double theirs2ours[4][4]; /* transformation matrix */
62
63 int childpid = -1; /* id of fill process */
64 FILE *psend, *precv; /* pipes to/from fill calculation */
65 int queue[PACKSIZ][2]; /* pending pixels */
66 int queuesiz; /* number of pixels pending */
67
68
69 main(argc, argv) /* interpolate pictures */
70 int argc;
71 char *argv[];
72 {
73 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
74 extern double atof();
75 int gotvfile = 0;
76 char *zfile = NULL;
77 char *err;
78 int i, rval;
79
80 progname = argv[0];
81
82 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
83 rval = getviewopt(&ourview, argc-i, argv+i);
84 if (rval >= 0) {
85 i += rval;
86 continue;
87 }
88 switch (argv[i][1]) {
89 case 't': /* threshold */
90 check(2,1);
91 zeps = atof(argv[++i]);
92 break;
93 case 'n': /* dist. normalized? */
94 check(2,0);
95 normdist = !normdist;
96 break;
97 case 'f': /* fill type */
98 switch (argv[i][2]) {
99 case '0': /* none */
100 check(3,0);
101 fill = 0;
102 break;
103 case 'f': /* foreground */
104 check(3,0);
105 fill = F_FORE;
106 break;
107 case 'b': /* background */
108 check(3,0);
109 fill = F_BACK;
110 break;
111 case 'a': /* all */
112 check(3,0);
113 fill = F_FORE|F_BACK;
114 break;
115 case 'c': /* color */
116 check(3,3);
117 deffill = backfill;
118 setcolr(backcolr, atof(argv[i+1]),
119 atof(argv[i+2]), atof(argv[i+3]));
120 i += 3;
121 break;
122 case 'z': /* z value */
123 check(3,1);
124 deffill = backfill;
125 backz = atof(argv[++i]);
126 break;
127 case 'r': /* rtrace */
128 check(3,1);
129 deffill = rcalfill;
130 calstart(RTCOM, argv[++i]);
131 break;
132 default:
133 goto badopt;
134 }
135 break;
136 case 'z': /* z file */
137 check(2,1);
138 zfile = argv[++i];
139 break;
140 case 'x': /* x resolution */
141 check(2,1);
142 hresolu = atoi(argv[++i]);
143 break;
144 case 'y': /* y resolution */
145 check(2,1);
146 vresolu = atoi(argv[++i]);
147 break;
148 case 'p': /* pixel aspect */
149 check(2,1);
150 pixaspect = atof(argv[++i]);
151 break;
152 case 'v': /* view file */
153 if (argv[i][2] != 'f')
154 goto badopt;
155 check(3,1);
156 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
157 if (gotvfile < 0) {
158 perror(argv[i]);
159 exit(1);
160 } else if (gotvfile == 0) {
161 fprintf(stderr, "%s: bad view file\n",
162 argv[i]);
163 exit(1);
164 }
165 break;
166 default:
167 badopt:
168 fprintf(stderr, "%s: command line error at '%s'\n",
169 progname, argv[i]);
170 goto userr;
171 }
172 }
173 /* check arguments */
174 if ((argc-i)%2)
175 goto userr;
176 /* set view */
177 if (err = setview(&ourview)) {
178 fprintf(stderr, "%s: %s\n", progname, err);
179 exit(1);
180 }
181 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
182 /* allocate frame */
183 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
184 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
185 if (ourpict == NULL || ourzbuf == NULL)
186 syserror();
187 /* get input */
188 for ( ; i < argc; i += 2)
189 addpicture(argv[i], argv[i+1]);
190 /* fill in spaces */
191 if (fill&F_BACK)
192 backpicture();
193 else
194 fillpicture();
195 /* close calculation */
196 caldone();
197 /* add to header */
198 printargs(argc, argv, stdout);
199 if (gotvfile) {
200 printf(VIEWSTR);
201 fprintview(&ourview, stdout);
202 printf("\n");
203 }
204 if (pixaspect < .99 || pixaspect > 1.01)
205 fputaspect(pixaspect, stdout);
206 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
207 fputexpos(ourexp, stdout);
208 printf("\n");
209 /* write picture */
210 writepicture();
211 /* write z file */
212 if (zfile != NULL)
213 writedistance(zfile);
214
215 exit(0);
216 userr:
217 fprintf(stderr,
218 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
219 progname);
220 exit(1);
221 #undef check
222 }
223
224
225 headline(s) /* process header string */
226 char *s;
227 {
228 static char *altname[] = {"rview","rpict","pinterp",VIEWSTR,NULL};
229 register char **an;
230
231 printf("\t%s", s);
232
233 if (isexpos(s)) {
234 theirexp *= exposval(s);
235 return;
236 }
237 for (an = altname; *an != NULL; an++)
238 if (!strncmp(*an, s, strlen(*an))) {
239 if (sscanview(&theirview, s+strlen(*an)) > 0)
240 gotview++;
241 break;
242 }
243 }
244
245
246 addpicture(pfile, zspec) /* add picture to output */
247 char *pfile, *zspec;
248 {
249 extern double atof();
250 FILE *pfp;
251 int zfd;
252 char *err;
253 COLR *scanin;
254 float *zin;
255 struct position *plast;
256 int y;
257 /* open picture file */
258 if ((pfp = fopen(pfile, "r")) == NULL) {
259 perror(pfile);
260 exit(1);
261 }
262 /* get header with exposure and view */
263 theirexp = 1.0;
264 gotview = 0;
265 printf("%s:\n", pfile);
266 getheader(pfp, headline);
267 if (!gotview || fgetresolu(&thresolu, &tvresolu, pfp)
268 != (YMAJOR|YDECR)) {
269 fprintf(stderr, "%s: picture view error\n", pfile);
270 exit(1);
271 }
272 if (ourexp <= 0)
273 ourexp = theirexp;
274 else if (ABS(theirexp-ourexp) > .01*ourexp)
275 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
276 if (err = setview(&theirview)) {
277 fprintf(stderr, "%s: %s\n", pfile, err);
278 exit(1);
279 }
280 /* compute transformation */
281 pixform(theirs2ours, &theirview, &ourview);
282 /* allocate scanlines */
283 scanin = (COLR *)malloc(thresolu*sizeof(COLR));
284 zin = (float *)malloc(thresolu*sizeof(float));
285 plast = (struct position *)calloc(thresolu, sizeof(struct position));
286 if (scanin == NULL || zin == NULL || plast == NULL)
287 syserror();
288 /* get z specification or file */
289 if ((zfd = open(zspec, O_RDONLY)) == -1) {
290 double zvalue;
291 register int x;
292 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
293 perror(zspec);
294 exit(1);
295 }
296 for (x = 0; x < thresolu; x++)
297 zin[x] = zvalue;
298 }
299 /* load image */
300 for (y = tvresolu-1; y >= 0; y--) {
301 if (freadcolrs(scanin, thresolu, pfp) < 0) {
302 fprintf(stderr, "%s: read error\n", pfile);
303 exit(1);
304 }
305 if (zfd != -1 && read(zfd,zin,thresolu*sizeof(float))
306 < thresolu*sizeof(float)) {
307 fprintf(stderr, "%s: read error\n", zspec);
308 exit(1);
309 }
310 addscanline(y, scanin, zin, plast);
311 }
312 /* clean up */
313 free((char *)scanin);
314 free((char *)zin);
315 free((char *)plast);
316 fclose(pfp);
317 if (zfd != -1)
318 close(zfd);
319 }
320
321
322 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
323 register double xfmat[4][4];
324 register VIEW *vw1, *vw2;
325 {
326 double m4t[4][4];
327
328 setident4(xfmat);
329 xfmat[0][0] = vw1->hvec[0];
330 xfmat[0][1] = vw1->hvec[1];
331 xfmat[0][2] = vw1->hvec[2];
332 xfmat[1][0] = vw1->vvec[0];
333 xfmat[1][1] = vw1->vvec[1];
334 xfmat[1][2] = vw1->vvec[2];
335 xfmat[2][0] = vw1->vdir[0];
336 xfmat[2][1] = vw1->vdir[1];
337 xfmat[2][2] = vw1->vdir[2];
338 xfmat[3][0] = vw1->vp[0];
339 xfmat[3][1] = vw1->vp[1];
340 xfmat[3][2] = vw1->vp[2];
341 setident4(m4t);
342 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
343 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
344 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
345 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
346 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
347 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
348 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
349 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
350 m4t[0][2] = vw2->vdir[0];
351 m4t[1][2] = vw2->vdir[1];
352 m4t[2][2] = vw2->vdir[2];
353 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
354 multmat4(xfmat, xfmat, m4t);
355 }
356
357
358 addscanline(y, pline, zline, lasty) /* add scanline to output */
359 int y;
360 COLR *pline;
361 float *zline;
362 struct position *lasty; /* input/output */
363 {
364 extern double sqrt();
365 double pos[3];
366 struct position lastx, newpos;
367 register int x;
368
369 lastx.z = 0;
370 for (x = thresolu-1; x >= 0; x--) {
371 pos[0] = (x+.5)/thresolu + theirview.hoff - .5;
372 pos[1] = (y+.5)/tvresolu + theirview.voff - .5;
373 pos[2] = zline[x];
374 if (theirview.type == VT_PER) {
375 if (normdist) /* adjust for eye-ray distance */
376 pos[2] /= sqrt( 1.
377 + pos[0]*pos[0]*theirview.hn2
378 + pos[1]*pos[1]*theirview.vn2 );
379 pos[0] *= pos[2];
380 pos[1] *= pos[2];
381 }
382 multp3(pos, pos, theirs2ours);
383 if (pos[2] <= 0) {
384 lasty[x].z = lastx.z = 0; /* mark invalid */
385 continue;
386 }
387 if (ourview.type == VT_PER) {
388 pos[0] /= pos[2];
389 pos[1] /= pos[2];
390 }
391 pos[0] += .5 - ourview.hoff;
392 pos[1] += .5 - ourview.voff;
393 newpos.x = pos[0] * hresolu;
394 newpos.y = pos[1] * vresolu;
395 newpos.z = zline[x];
396 /* add pixel to our image */
397 if (pos[0] >= 0 && newpos.x < hresolu
398 && pos[1] >= 0 && newpos.y < vresolu) {
399 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
400 lasty[x].x = lastx.x = newpos.x;
401 lasty[x].y = lastx.y = newpos.y;
402 lasty[x].z = lastx.z = newpos.z;
403 } else
404 lasty[x].z = lastx.z = 0; /* mark invalid */
405 }
406 }
407
408
409 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
410 struct position *p0, *p1, *p2;
411 COLR pix;
412 double z;
413 {
414 double zt = 2.*zeps*p0->z; /* threshold */
415 int s1x, s1y, s2x, s2y; /* step sizes */
416 int l1, l2, c1, c2; /* side lengths and counters */
417 int p1isy; /* p0p1 along y? */
418 int x1, y1; /* p1 position */
419 register int x, y; /* final position */
420
421 /* compute vector p0p1 */
422 if (fill&F_FORE && ABS(p1->z-p0->z) <= zt) {
423 s1x = p1->x - p0->x;
424 s1y = p1->y - p0->y;
425 l1 = ABS(s1x);
426 if (p1isy = (ABS(s1y) > l1))
427 l1 = ABS(s1y);
428 } else {
429 l1 = s1x = s1y = 1;
430 p1isy = -1;
431 }
432 /* compute vector p0p2 */
433 if (fill&F_FORE && ABS(p2->z-p0->z) <= zt) {
434 s2x = p2->x - p0->x;
435 s2y = p2->y - p0->y;
436 if (p1isy == 1)
437 l2 = ABS(s2x);
438 else {
439 l2 = ABS(s2y);
440 if (p1isy != 0 && ABS(s2x) > l2)
441 l2 = ABS(s2x);
442 }
443 } else
444 l2 = s2x = s2y = 1;
445 /* fill the parallelogram */
446 for (c1 = l1; c1-- > 0; ) {
447 x1 = p0->x + c1*s1x/l1;
448 y1 = p0->y + c1*s1y/l1;
449 for (c2 = l2; c2-- > 0; ) {
450 x = x1 + c2*s2x/l2;
451 y = y1 + c2*s2y/l2;
452 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
453 > zeps*zscan(y)[x]) {
454 zscan(y)[x] = z;
455 copycolr(pscan(y)[x], pix);
456 }
457 }
458 }
459 }
460
461
462 backpicture() /* background fill algorithm */
463 {
464 int *yback, xback;
465 int y;
466 COLR pfill;
467 register int x, i;
468 /* get back buffer */
469 yback = (int *)malloc(hresolu*sizeof(int));
470 if (yback == NULL)
471 syserror();
472 for (x = 0; x < hresolu; x++)
473 yback[x] = -2;
474 /*
475 * Xback and yback are the pixel locations of suitable
476 * background values in each direction.
477 * A value of -2 means unassigned, and -1 means
478 * that there is no suitable background in this direction.
479 */
480 /* fill image */
481 for (y = 0; y < vresolu; y++) {
482 xback = -2;
483 for (x = 0; x < hresolu; x++)
484 if (zscan(y)[x] <= 0) { /* empty pixel */
485 /*
486 * First, find background from above or below.
487 * (farthest assigned pixel)
488 */
489 if (yback[x] == -2) {
490 for (i = y+1; i < vresolu; i++)
491 if (zscan(i)[x] > 0)
492 break;
493 if (i < vresolu
494 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
495 yback[x] = i;
496 else
497 yback[x] = y-1;
498 }
499 /*
500 * Next, find background from left or right.
501 */
502 if (xback == -2) {
503 for (i = x+1; i < hresolu; i++)
504 if (zscan(y)[i] > 0)
505 break;
506 if (i < hresolu
507 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
508 xback = i;
509 else
510 xback = x-1;
511 }
512 /*
513 * Check to see if we have no background for
514 * this pixel. If not, use background color.
515 */
516 if (xback < 0 && yback[x] < 0) {
517 (*deffill)(x,y);
518 continue;
519 }
520 /*
521 * Compare, and use the background that is
522 * farther, unless one of them is next to us.
523 */
524 if ( yback[x] < 0
525 || (xback >= 0 && ABS(x-xback) <= 1)
526 || ( ABS(y-yback[x]) > 1
527 && zscan(yback[x])[x]
528 < zscan(y)[xback] ) ) {
529 copycolr(pscan(y)[x],pscan(y)[xback]);
530 zscan(y)[x] = zscan(y)[xback];
531 } else {
532 copycolr(pscan(y)[x],pscan(yback[x])[x]);
533 zscan(y)[x] = zscan(yback[x])[x];
534 }
535 } else { /* full pixel */
536 yback[x] = -2;
537 xback = -2;
538 }
539 }
540 free((char *)yback);
541 }
542
543
544 fillpicture() /* paint in empty pixels with default */
545 {
546 register int x, y;
547
548 for (y = 0; y < vresolu; y++)
549 for (x = 0; x < hresolu; x++)
550 if (zscan(y)[x] <= 0)
551 (*deffill)(x,y);
552 }
553
554
555 writepicture() /* write out picture */
556 {
557 int y;
558
559 fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout);
560 for (y = vresolu-1; y >= 0; y--)
561 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
562 syserror();
563 }
564
565
566 writedistance(fname) /* write out z file */
567 char *fname;
568 {
569 extern double sqrt();
570 int donorm = normdist && ourview.type == VT_PER;
571 int fd;
572 int y;
573 float *zout;
574
575 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
576 perror(fname);
577 exit(1);
578 }
579 if (donorm
580 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
581 syserror();
582 for (y = vresolu-1; y >= 0; y--) {
583 if (donorm) {
584 double vx, yzn2;
585 register int x;
586 yzn2 = y - .5*(vresolu-1);
587 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
588 for (x = 0; x < hresolu; x++) {
589 vx = x - .5*(hresolu-1);
590 zout[x] = zscan(y)[x]
591 * sqrt(vx*vx*ourview.hn2 + yzn2);
592 }
593 } else
594 zout = zscan(y);
595 if (write(fd, zout, hresolu*sizeof(float))
596 < hresolu*sizeof(float)) {
597 perror(fname);
598 exit(1);
599 }
600 }
601 if (donorm)
602 free((char *)zout);
603 close(fd);
604 }
605
606
607 isfloat(s) /* see if string is floating number */
608 register char *s;
609 {
610 for ( ; *s; s++)
611 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
612 && *s != 'e' && *s != 'E' && *s != '+')
613 return(0);
614 return(1);
615 }
616
617
618 backfill(x, y) /* fill pixel with background */
619 int x, y;
620 {
621 register BYTE *dest = pscan(y)[x];
622
623 copycolr(dest, backcolr);
624 zscan(y)[x] = backz;
625 }
626
627
628 calstart(prog, args) /* start fill calculation */
629 char *prog, *args;
630 {
631 char combuf[512];
632 int p0[2], p1[2];
633
634 if (childpid != -1) {
635 fprintf(stderr, "%s: too many calculations\n", progname);
636 exit(1);
637 }
638 sprintf(combuf, prog, PACKSIZ, args);
639 if (pipe(p0) < 0 || pipe(p1) < 0)
640 syserror();
641 if ((childpid = vfork()) == 0) { /* fork calculation */
642 close(p0[1]);
643 close(p1[0]);
644 if (p0[0] != 0) {
645 dup2(p0[0], 0);
646 close(p0[0]);
647 }
648 if (p1[1] != 1) {
649 dup2(p1[1], 1);
650 close(p1[1]);
651 }
652 execl("/bin/sh", "sh", "-c", combuf, 0);
653 perror("/bin/sh");
654 _exit(127);
655 }
656 if (childpid == -1)
657 syserror();
658 close(p0[0]);
659 close(p1[1]);
660 if ((psend = fdopen(p0[1], "w")) == NULL)
661 syserror();
662 if ((precv = fdopen(p1[0], "r")) == NULL)
663 syserror();
664 queuesiz = 0;
665 }
666
667
668 caldone() /* done with calculation */
669 {
670 int pid;
671
672 if (childpid == -1)
673 return;
674 clearqueue(1);
675 while ((pid = wait(0)) != -1 && pid != childpid)
676 ;
677 childpid = -1;
678 }
679
680
681 rcalfill(x, y) /* fill with ray-calculated pixel */
682 int x, y;
683 {
684 if (queuesiz >= PACKSIZ) /* flush queue if needed */
685 clearqueue(0);
686 /* add position to queue */
687 queue[queuesiz][0] = x;
688 queue[queuesiz][1] = y;
689 queuesiz++;
690 }
691
692
693 clearqueue(done) /* process queue */
694 int done;
695 {
696 FVECT orig, dir;
697 float fbuf[6];
698 register int i;
699
700 for (i = 0; i < queuesiz; i++) {
701 viewray(orig, dir, &ourview,
702 (queue[i][0]+.5)/hresolu,
703 (queue[i][1]+.5)/vresolu);
704 fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2];
705 fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2];
706 fwrite(fbuf, sizeof(float), 6, psend);
707 }
708 if ((done ? fclose(psend) : fflush(psend)) == EOF)
709 syserror();
710 for (i = 0; i < queuesiz; i++) {
711 if (fread(fbuf, sizeof(float), 4, precv) < 4) {
712 fprintf(stderr, "%s: read error in clearqueue\n",
713 progname);
714 exit(1);
715 }
716 if (ourexp > 0 && ourexp != 1.0) {
717 fbuf[0] *= ourexp;
718 fbuf[1] *= ourexp;
719 fbuf[2] *= ourexp;
720 }
721 setcolr(pscan(queue[i][1])[queue[i][0]],
722 fbuf[0], fbuf[1], fbuf[2]);
723 zscan(queue[i][1])[queue[i][0]] = fbuf[3];
724 }
725 if (done)
726 fclose(precv);
727 queuesiz = 0;
728 }
729
730
731 syserror() /* report error and exit */
732 {
733 perror(progname);
734 exit(1);
735 }
