root/radiance/ray/src/px/pinterp.c
Revision: 2.9
Committed: Fri Oct 2 16:24:22 1992 UTC (32 years, 9 months ago) by greg
Changes since 2.8: +0 -2 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * Interpolate and extrapolate pictures with different view parameters.
9 *
10 * Greg Ward 09Dec89
11 */
12
13 #include "standard.h"
14
15 #include <ctype.h>
16
17 #include "view.h"
18
19 #include "color.h"
20
21 #include "resolu.h"
22
23 #ifndef BSD
24 #define vfork fork
25 #endif
26
27 #define pscan(y) (ourpict+(y)*hresolu)
28 #define zscan(y) (ourzbuf+(y)*hresolu)
29
30 #define F_FORE 1 /* fill foreground */
31 #define F_BACK 2 /* fill background */
32
33 #define PACKSIZ 256 /* max. calculation packet size */
34
35 #define RTCOM "rtrace -h- -ovl -fff "
36
37 #define ABS(x) ((x)>0?(x):-(x))
38
39 struct position {int x,y; float z;};
40
41 VIEW ourview = STDVIEW; /* desired view */
42 int hresolu = 512; /* horizontal resolution */
43 int vresolu = 512; /* vertical resolution */
44 double pixaspect = 1.0; /* pixel aspect ratio */
45
46 double zeps = .02; /* allowed z epsilon */
47
48 COLR *ourpict; /* output picture */
49 float *ourzbuf; /* corresponding z-buffer */
50
51 char *progname;
52
53 int fillo = F_FORE|F_BACK; /* selected fill options */
54 int fillsamp = 0; /* sample separation (0 == inf) */
55 extern int backfill(), rcalfill(); /* fill functions */
56 int (*fillfunc)() = backfill; /* selected fill function */
57 COLR backcolr = BLKCOLR; /* background color */
58 double backz = 0.0; /* background z value */
59 int normdist = 1; /* normalized distance? */
60 double ourexp = -1; /* output picture exposure */
61
62 VIEW theirview = STDVIEW; /* input view */
63 int gotview; /* got input view? */
64 int wrongformat = 0; /* input in another format? */
65 RESOLU tresolu; /* input resolution */
66 double theirexp; /* input picture exposure */
67 double theirs2ours[4][4]; /* transformation matrix */
68 int hasmatrix = 0; /* has transformation matrix */
69
70 int PDesc[3] = {-1,-1,-1}; /* rtrace process descriptor */
71 #define childpid (PDesc[2])
72 unsigned short queue[PACKSIZ][2]; /* pending pixels */
73 int packsiz; /* actual packet size */
74 int queuesiz; /* number of pixels pending */
75
76
77 main(argc, argv) /* interpolate pictures */
78 int argc;
79 char *argv[];
80 {
81 #define check(ol,al) if (argv[i][ol] || \
82 badarg(argc-i-1,argv+i+1,al)) \
83 goto badopt
84 int gotvfile = 0;
85 char *zfile = NULL;
86 char *err;
87 int i, rval;
88
89 progname = argv[0];
90
91 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
92 rval = getviewopt(&ourview, argc-i, argv+i);
93 if (rval >= 0) {
94 i += rval;
95 continue;
96 }
97 switch (argv[i][1]) {
98 case 't': /* threshold */
99 check(2,"f");
100 zeps = atof(argv[++i]);
101 break;
102 case 'n': /* dist. normalized? */
103 check(2,NULL);
104 normdist = !normdist;
105 break;
106 case 'f': /* fill type */
107 switch (argv[i][2]) {
108 case '0': /* none */
109 check(3,NULL);
110 fillo = 0;
111 break;
112 case 'f': /* foreground */
113 check(3,NULL);
114 fillo = F_FORE;
115 break;
116 case 'b': /* background */
117 check(3,NULL);
118 fillo = F_BACK;
119 break;
120 case 'a': /* all */
121 check(3,NULL);
122 fillo = F_FORE|F_BACK;
123 break;
124 case 's': /* sample */
125 check(3,"i");
126 fillsamp = atoi(argv[++i]);
127 break;
128 case 'c': /* color */
129 check(3,"fff");
130 fillfunc = backfill;
131 setcolr(backcolr, atof(argv[i+1]),
132 atof(argv[i+2]), atof(argv[i+3]));
133 i += 3;
134 break;
135 case 'z': /* z value */
136 check(3,"f");
137 fillfunc = backfill;
138 backz = atof(argv[++i]);
139 break;
140 case 'r': /* rtrace */
141 check(3,"s");
142 fillfunc = rcalfill;
143 calstart(RTCOM, argv[++i]);
144 break;
145 default:
146 goto badopt;
147 }
148 break;
149 case 'z': /* z file */
150 check(2,"s");
151 zfile = argv[++i];
152 break;
153 case 'x': /* x resolution */
154 check(2,"i");
155 hresolu = atoi(argv[++i]);
156 break;
157 case 'y': /* y resolution */
158 check(2,"i");
159 vresolu = atoi(argv[++i]);
160 break;
161 case 'p': /* pixel aspect */
162 if (argv[i][2] != 'a')
163 goto badopt;
164 check(3,"f");
165 pixaspect = atof(argv[++i]);
166 break;
167 case 'v': /* view file */
168 if (argv[i][2] != 'f')
169 goto badopt;
170 check(3,"s");
171 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
172 if (gotvfile < 0) {
173 perror(argv[i]);
174 exit(1);
175 } else if (gotvfile == 0) {
176 fprintf(stderr, "%s: bad view file\n",
177 argv[i]);
178 exit(1);
179 }
180 break;
181 default:
182 badopt:
183 fprintf(stderr, "%s: command line error at '%s'\n",
184 progname, argv[i]);
185 goto userr;
186 }
187 }
188 /* check arguments */
189 if ((argc-i)%2)
190 goto userr;
191 if (fillsamp == 1)
192 fillo &= ~F_BACK;
193 /* set view */
194 if (err = setview(&ourview)) {
195 fprintf(stderr, "%s: %s\n", progname, err);
196 exit(1);
197 }
198 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
199 /* allocate frame */
200 ourpict = (COLR *)bmalloc(hresolu*vresolu*sizeof(COLR));
201 ourzbuf = (float *)bmalloc(hresolu*vresolu*sizeof(float));
202 if (ourpict == NULL || ourzbuf == NULL)
203 syserror();
204 bzero((char *)ourzbuf, hresolu*vresolu*sizeof(float));
205 /* get input */
206 for ( ; i < argc; i += 2)
207 addpicture(argv[i], argv[i+1]);
208 /* fill in spaces */
209 if (fillo&F_BACK)
210 backpicture(fillfunc, fillsamp);
211 else
212 fillpicture(fillfunc);
213 /* close calculation */
214 caldone();
215 /* add to header */
216 printargs(argc, argv, stdout);
217 if (gotvfile) {
218 fputs(VIEWSTR, stdout);
219 fprintview(&ourview, stdout);
220 putc('\n', stdout);
221 }
222 if (pixaspect < .99 || pixaspect > 1.01)
223 fputaspect(pixaspect, stdout);
224 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
225 fputexpos(ourexp, stdout);
226 fputformat(COLRFMT, stdout);
227 putc('\n', stdout);
228 /* write picture */
229 writepicture();
230 /* write z file */
231 if (zfile != NULL)
232 writedistance(zfile);
233
234 exit(0);
235 userr:
236 fprintf(stderr,
237 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
238 progname);
239 exit(1);
240 #undef check
241 }
242
243
244 headline(s) /* process header string */
245 char *s;
246 {
247 char fmt[32];
248
249 if (isformat(s)) {
250 formatval(fmt, s);
251 wrongformat = strcmp(fmt, COLRFMT);
252 return;
253 }
254 putc('\t', stdout);
255 fputs(s, stdout);
256
257 if (isexpos(s)) {
258 theirexp *= exposval(s);
259 return;
260 }
261 if (isview(s) && sscanview(&theirview, s) > 0)
262 gotview++;
263 }
264
265
266 addpicture(pfile, zspec) /* add picture to output */
267 char *pfile, *zspec;
268 {
269 FILE *pfp;
270 int zfd;
271 char *err;
272 COLR *scanin;
273 float *zin;
274 struct position *plast;
275 int y;
276 /* open picture file */
277 if ((pfp = fopen(pfile, "r")) == NULL) {
278 perror(pfile);
279 exit(1);
280 }
281 /* get header with exposure and view */
282 theirexp = 1.0;
283 gotview = 0;
284 printf("%s:\n", pfile);
285 getheader(pfp, headline, NULL);
286 if (wrongformat || !gotview || !fgetsresolu(&tresolu, pfp)) {
287 fprintf(stderr, "%s: picture format error\n", pfile);
288 exit(1);
289 }
290 if (ourexp <= 0)
291 ourexp = theirexp;
292 else if (ABS(theirexp-ourexp) > .01*ourexp)
293 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
294 if (err = setview(&theirview)) {
295 fprintf(stderr, "%s: %s\n", pfile, err);
296 exit(1);
297 }
298 /* compute transformation */
299 hasmatrix = pixform(theirs2ours, &theirview, &ourview);
300 /* allocate scanlines */
301 scanin = (COLR *)malloc(scanlen(&tresolu)*sizeof(COLR));
302 zin = (float *)malloc(scanlen(&tresolu)*sizeof(float));
303 plast = (struct position *)calloc(scanlen(&tresolu),
304 sizeof(struct position));
305 if (scanin == NULL || zin == NULL || plast == NULL)
306 syserror();
307 /* get z specification or file */
308 if ((zfd = open(zspec, O_RDONLY)) == -1) {
309 double zvalue;
310 register int x;
311 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
312 perror(zspec);
313 exit(1);
314 }
315 for (x = scanlen(&tresolu); x-- > 0; )
316 zin[x] = zvalue;
317 }
318 /* load image */
319 for (y = 0; y < numscans(&tresolu); y++) {
320 if (freadcolrs(scanin, scanlen(&tresolu), pfp) < 0) {
321 fprintf(stderr, "%s: read error\n", pfile);
322 exit(1);
323 }
324 if (zfd != -1 && read(zfd,(char *)zin,
325 scanlen(&tresolu)*sizeof(float))
326 < scanlen(&tresolu)*sizeof(float)) {
327 fprintf(stderr, "%s: read error\n", zspec);
328 exit(1);
329 }
330 addscanline(y, scanin, zin, plast);
331 }
332 /* clean up */
333 free((char *)scanin);
334 free((char *)zin);
335 free((char *)plast);
336 fclose(pfp);
337 if (zfd != -1)
338 close(zfd);
339 }
340
341
342 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
343 register double xfmat[4][4];
344 register VIEW *vw1, *vw2;
345 {
346 double m4t[4][4];
347
348 if (vw1->type != VT_PER && vw1->type != VT_PAR)
349 return(0);
350 if (vw2->type != VT_PER && vw2->type != VT_PAR)
351 return(0);
352 setident4(xfmat);
353 xfmat[0][0] = vw1->hvec[0];
354 xfmat[0][1] = vw1->hvec[1];
355 xfmat[0][2] = vw1->hvec[2];
356 xfmat[1][0] = vw1->vvec[0];
357 xfmat[1][1] = vw1->vvec[1];
358 xfmat[1][2] = vw1->vvec[2];
359 xfmat[2][0] = vw1->vdir[0];
360 xfmat[2][1] = vw1->vdir[1];
361 xfmat[2][2] = vw1->vdir[2];
362 xfmat[3][0] = vw1->vp[0];
363 xfmat[3][1] = vw1->vp[1];
364 xfmat[3][2] = vw1->vp[2];
365 setident4(m4t);
366 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
367 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
368 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
369 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
370 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
371 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
372 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
373 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
374 m4t[0][2] = vw2->vdir[0];
375 m4t[1][2] = vw2->vdir[1];
376 m4t[2][2] = vw2->vdir[2];
377 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
378 multmat4(xfmat, xfmat, m4t);
379 return(1);
380 }
381
382
383 addscanline(y, pline, zline, lasty) /* add scanline to output */
384 int y;
385 COLR *pline;
386 float *zline;
387 struct position *lasty; /* input/output */
388 {
389 FVECT pos;
390 struct position lastx, newpos;
391 register int x;
392
393 lastx.z = 0;
394 for (x = scanlen(&tresolu); x-- > 0; ) {
395 pix2loc(pos, &tresolu, x, y);
396 pos[2] = zline[x];
397 if (movepixel(pos) < 0) {
398 lasty[x].z = lastx.z = 0; /* mark invalid */
399 continue;
400 }
401 newpos.x = pos[0] * hresolu;
402 newpos.y = pos[1] * vresolu;
403 newpos.z = zline[x];
404 /* add pixel to our image */
405 if (pos[0] >= 0 && newpos.x < hresolu
406 && pos[1] >= 0 && newpos.y < vresolu) {
407 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
408 lasty[x].x = lastx.x = newpos.x;
409 lasty[x].y = lastx.y = newpos.y;
410 lasty[x].z = lastx.z = newpos.z;
411 } else
412 lasty[x].z = lastx.z = 0; /* mark invalid */
413 }
414 }
415
416
417 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
418 struct position *p0, *p1, *p2;
419 COLR pix;
420 double z;
421 {
422 double zt = 2.*zeps*p0->z; /* threshold */
423 int s1x, s1y, s2x, s2y; /* step sizes */
424 int l1, l2, c1, c2; /* side lengths and counters */
425 int p1isy; /* p0p1 along y? */
426 int x1, y1; /* p1 position */
427 register int x, y; /* final position */
428
429 /* compute vector p0p1 */
430 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
431 s1x = p1->x - p0->x;
432 s1y = p1->y - p0->y;
433 l1 = ABS(s1x);
434 if (p1isy = (ABS(s1y) > l1))
435 l1 = ABS(s1y);
436 } else {
437 l1 = s1x = s1y = 1;
438 p1isy = -1;
439 }
440 /* compute vector p0p2 */
441 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
442 s2x = p2->x - p0->x;
443 s2y = p2->y - p0->y;
444 if (p1isy == 1)
445 l2 = ABS(s2x);
446 else {
447 l2 = ABS(s2y);
448 if (p1isy != 0 && ABS(s2x) > l2)
449 l2 = ABS(s2x);
450 }
451 } else
452 l2 = s2x = s2y = 1;
453 /* fill the parallelogram */
454 for (c1 = l1; c1-- > 0; ) {
455 x1 = p0->x + c1*s1x/l1;
456 y1 = p0->y + c1*s1y/l1;
457 for (c2 = l2; c2-- > 0; ) {
458 x = x1 + c2*s2x/l2;
459 if (x < 0 || x >= hresolu)
460 continue;
461 y = y1 + c2*s2y/l2;
462 if (y < 0 || y >= vresolu)
463 continue;
464 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
465 > zeps*zscan(y)[x]) {
466 zscan(y)[x] = z;
467 copycolr(pscan(y)[x], pix);
468 }
469 }
470 }
471 }
472
473
474 movepixel(pos) /* reposition image point */
475 FVECT pos;
476 {
477 FVECT pt, direc;
478
479 if (pos[2] <= 0) /* empty pixel */
480 return(-1);
481 if (hasmatrix) {
482 pos[0] += theirview.hoff - .5;
483 pos[1] += theirview.voff - .5;
484 if (theirview.type == VT_PER) {
485 if (normdist) /* adjust for eye-ray distance */
486 pos[2] /= sqrt( 1.
487 + pos[0]*pos[0]*theirview.hn2
488 + pos[1]*pos[1]*theirview.vn2 );
489 pos[0] *= pos[2];
490 pos[1] *= pos[2];
491 }
492 multp3(pos, pos, theirs2ours);
493 if (pos[2] <= 0)
494 return(-1);
495 if (ourview.type == VT_PER) {
496 pos[0] /= pos[2];
497 pos[1] /= pos[2];
498 }
499 pos[0] += .5 - ourview.hoff;
500 pos[1] += .5 - ourview.voff;
501 return(0);
502 }
503 if (viewray(pt, direc, &theirview, pos[0], pos[1]) < 0)
504 return(-1);
505 pt[0] += direc[0]*pos[2];
506 pt[1] += direc[1]*pos[2];
507 pt[2] += direc[2]*pos[2];
508 viewloc(pos, &ourview, pt);
509 if (pos[2] <= 0)
510 return(-1);
511 return(0);
512 }
513
514
515 backpicture(fill, samp) /* background fill algorithm */
516 int (*fill)();
517 int samp;
518 {
519 int *yback, xback;
520 int y;
521 register int x, i;
522 /* get back buffer */
523 yback = (int *)malloc(hresolu*sizeof(int));
524 if (yback == NULL)
525 syserror();
526 for (x = 0; x < hresolu; x++)
527 yback[x] = -2;
528 /*
529 * Xback and yback are the pixel locations of suitable
530 * background values in each direction.
531 * A value of -2 means unassigned, and -1 means
532 * that there is no suitable background in this direction.
533 */
534 /* fill image */
535 for (y = 0; y < vresolu; y++) {
536 xback = -2;
537 for (x = 0; x < hresolu; x++)
538 if (zscan(y)[x] <= 0) { /* empty pixel */
539 /*
540 * First, find background from above or below.
541 * (farthest assigned pixel)
542 */
543 if (yback[x] == -2) {
544 for (i = y+1; i < vresolu; i++)
545 if (zscan(i)[x] > 0)
546 break;
547 if (i < vresolu
548 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
549 yback[x] = i;
550 else
551 yback[x] = y-1;
552 }
553 /*
554 * Next, find background from left or right.
555 */
556 if (xback == -2) {
557 for (i = x+1; i < hresolu; i++)
558 if (zscan(y)[i] > 0)
559 break;
560 if (i < hresolu
561 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
562 xback = i;
563 else
564 xback = x-1;
565 }
566 /*
567 * If we have no background for this pixel,
568 * use the given fill function.
569 */
570 if (xback < 0 && yback[x] < 0)
571 goto fillit;
572 /*
573 * Compare, and use the background that is
574 * farther, unless one of them is next to us.
575 * If the background is too distant, call
576 * the fill function.
577 */
578 if ( yback[x] < 0
579 || (xback >= 0 && ABS(x-xback) <= 1)
580 || ( ABS(y-yback[x]) > 1
581 && zscan(yback[x])[x]
582 < zscan(y)[xback] ) ) {
583 if (samp > 0 && ABS(x-xback) >= samp)
584 goto fillit;
585 copycolr(pscan(y)[x],pscan(y)[xback]);
586 zscan(y)[x] = zscan(y)[xback];
587 } else {
588 if (samp > 0 && ABS(y-yback[x]) > samp)
589 goto fillit;
590 copycolr(pscan(y)[x],pscan(yback[x])[x]);
591 zscan(y)[x] = zscan(yback[x])[x];
592 }
593 continue;
594 fillit:
595 (*fill)(x,y);
596 if (fill == rcalfill) { /* use it */
597 clearqueue();
598 xback = x;
599 yback[x] = y;
600 }
601 } else { /* full pixel */
602 yback[x] = -2;
603 xback = -2;
604 }
605 }
606 free((char *)yback);
607 }
608
609
610 fillpicture(fill) /* paint in empty pixels using fill */
611 int (*fill)();
612 {
613 register int x, y;
614
615 for (y = 0; y < vresolu; y++)
616 for (x = 0; x < hresolu; x++)
617 if (zscan(y)[x] <= 0)
618 (*fill)(x,y);
619 }
620
621
622 writepicture() /* write out picture */
623 {
624 int y;
625
626 fprtresolu(hresolu, vresolu, stdout);
627 for (y = vresolu-1; y >= 0; y--)
628 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
629 syserror();
630 }
631
632
633 writedistance(fname) /* write out z file */
634 char *fname;
635 {
636 int donorm = normdist && ourview.type == VT_PER;
637 int fd;
638 int y;
639 float *zout;
640
641 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
642 perror(fname);
643 exit(1);
644 }
645 if (donorm
646 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
647 syserror();
648 for (y = vresolu-1; y >= 0; y--) {
649 if (donorm) {
650 double vx, yzn2;
651 register int x;
652 yzn2 = (y+.5)/vresolu + ourview.voff - .5;
653 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
654 for (x = 0; x < hresolu; x++) {
655 vx = (x+.5)/hresolu + ourview.hoff - .5;
656 zout[x] = zscan(y)[x]
657 * sqrt(vx*vx*ourview.hn2 + yzn2);
658 }
659 } else
660 zout = zscan(y);
661 if (write(fd, (char *)zout, hresolu*sizeof(float))
662 < hresolu*sizeof(float)) {
663 perror(fname);
664 exit(1);
665 }
666 }
667 if (donorm)
668 free((char *)zout);
669 close(fd);
670 }
671
672
673 isfloat(s) /* see if string is floating number */
674 register char *s;
675 {
676 for ( ; *s; s++)
677 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
678 && *s != 'e' && *s != 'E' && *s != '+')
679 return(0);
680 return(1);
681 }
682
683
684 backfill(x, y) /* fill pixel with background */
685 int x, y;
686 {
687 register BYTE *dest = pscan(y)[x];
688
689 copycolr(dest, backcolr);
690 zscan(y)[x] = backz;
691 }
692
693
694 calstart(prog, args) /* start fill calculation */
695 char *prog, *args;
696 {
697 char combuf[512];
698 char *argv[64];
699 int rval;
700 register char **wp, *cp;
701
702 if (childpid != -1) {
703 fprintf(stderr, "%s: too many calculations\n", progname);
704 exit(1);
705 }
706 strcpy(combuf, prog);
707 strcat(combuf, args);
708 cp = combuf;
709 wp = argv;
710 for ( ; ; ) {
711 while (isspace(*cp)) cp++;
712 if (!*cp) break;
713 *wp++ = cp;
714 while (!isspace(*cp))
715 if (!*cp++) goto done;
716 *cp++ = '\0';
717 }
718 done:
719 *wp = NULL;
720 /* start process */
721 if ((rval = open_process(PDesc, argv)) < 0)
722 syserror();
723 if (rval == 0) {
724 fprintf(stderr, "%s: command not found\n", argv[0]);
725 exit(1);
726 }
727 packsiz = rval/(6*sizeof(float)) - 1;
728 if (packsiz > PACKSIZ)
729 packsiz = PACKSIZ;
730 queuesiz = 0;
731 }
732
733
734 caldone() /* done with calculation */
735 {
736 if (childpid == -1)
737 return;
738 clearqueue();
739 close_process(PDesc);
740 childpid = -1;
741 }
742
743
744 rcalfill(x, y) /* fill with ray-calculated pixel */
745 int x, y;
746 {
747 if (queuesiz >= packsiz) /* flush queue if needed */
748 clearqueue();
749 /* add position to queue */
750 queue[queuesiz][0] = x;
751 queue[queuesiz][1] = y;
752 queuesiz++;
753 }
754
755
756 clearqueue() /* process queue */
757 {
758 FVECT orig, dir;
759 float fbuf[6*(PACKSIZ+1)];
760 register float *fbp;
761 register int i;
762
763 fbp = fbuf;
764 for (i = 0; i < queuesiz; i++) {
765 viewray(orig, dir, &ourview,
766 (queue[i][0]+.5)/hresolu,
767 (queue[i][1]+.5)/vresolu);
768 *fbp++ = orig[0]; *fbp++ = orig[1]; *fbp++ = orig[2];
769 *fbp++ = dir[0]; *fbp++ = dir[1]; *fbp++ = dir[2];
770 }
771 /* mark end and get results */
772 bzero((char *)fbp, 6*sizeof(float));
773 if (process(PDesc, fbuf, fbuf, 4*sizeof(float)*queuesiz,
774 6*sizeof(float)*(queuesiz+1)) !=
775 4*sizeof(float)*queuesiz) {
776 fprintf(stderr, "%s: error reading from rtrace process\n",
777 progname);
778 exit(1);
779 }
780 fbp = fbuf;
781 for (i = 0; i < queuesiz; i++) {
782 if (ourexp > 0 && ourexp != 1.0) {
783 fbp[0] *= ourexp;
784 fbp[1] *= ourexp;
785 fbp[2] *= ourexp;
786 }
787 setcolr(pscan(queue[i][1])[queue[i][0]],
788 fbp[0], fbp[1], fbp[2]);
789 zscan(queue[i][1])[queue[i][0]] = fbp[3];
790 fbp += 4;
791 }
792 queuesiz = 0;
793 }
794
795
796 syserror() /* report error and exit */
797 {
798 perror(progname);
799 exit(1);
800 }
