root/radiance/ray/src/px/pinterp.c
Revision: 1.27
Committed: Tue Mar 6 15:45:31 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.26: +16 -12 lines
fixed sampling so samples are reused as background
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Interpolate and extrapolate pictures with different view parameters.
7 *
8 * Greg Ward 09Dec89
9 */
10
11 #include "standard.h"
12
13 #include <fcntl.h>
14
15 #include "view.h"
16
17 #include "color.h"
18
19 #ifndef BSD
20 #define vfork fork
21 #endif
22
23 #define pscan(y) (ourpict+(y)*hresolu)
24 #define zscan(y) (ourzbuf+(y)*hresolu)
25
26 #define F_FORE 1 /* fill foreground */
27 #define F_BACK 2 /* fill background */
28
29 #define PACKSIZ 42 /* calculation packet size */
30
31 #define RTCOM "rtrace -h -ovl -fff %s"
32
33 #define ABS(x) ((x)>0?(x):-(x))
34
35 struct position {int x,y; float z;};
36
37 VIEW ourview = STDVIEW; /* desired view */
38 int hresolu = 512; /* horizontal resolution */
39 int vresolu = 512; /* vertical resolution */
40 double pixaspect = 1.0; /* pixel aspect ratio */
41
42 double zeps = .02; /* allowed z epsilon */
43
44 COLR *ourpict; /* output picture */
45 float *ourzbuf; /* corresponding z-buffer */
46
47 char *progname;
48
49 int fillo = F_FORE|F_BACK; /* selected fill options */
50 int fillsamp = 0; /* sample separation (0 == inf) */
51 extern int backfill(), rcalfill(); /* fill functions */
52 int (*fillfunc)() = backfill; /* selected fill function */
53 COLR backcolr = BLKCOLR; /* background color */
54 double backz = 0.0; /* background z value */
55 int normdist = 1; /* normalized distance? */
56 double ourexp = -1; /* output picture exposure */
57
58 VIEW theirview = STDVIEW; /* input view */
59 int gotview; /* got input view? */
60 int thresolu, tvresolu; /* input resolution */
61 double theirexp; /* input picture exposure */
62 double theirs2ours[4][4]; /* transformation matrix */
63
64 int childpid = -1; /* id of fill process */
65 FILE *psend, *precv; /* pipes to/from fill calculation */
66 int queue[PACKSIZ][2]; /* pending pixels */
67 int queuesiz; /* number of pixels pending */
68
69
70 main(argc, argv) /* interpolate pictures */
71 int argc;
72 char *argv[];
73 {
74 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
75 extern double atof();
76 int gotvfile = 0;
77 char *zfile = NULL;
78 char *err;
79 int i, rval;
80
81 progname = argv[0];
82
83 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
84 rval = getviewopt(&ourview, argc-i, argv+i);
85 if (rval >= 0) {
86 i += rval;
87 continue;
88 }
89 switch (argv[i][1]) {
90 case 't': /* threshold */
91 check(2,1);
92 zeps = atof(argv[++i]);
93 break;
94 case 'n': /* dist. normalized? */
95 check(2,0);
96 normdist = !normdist;
97 break;
98 case 'f': /* fill type */
99 switch (argv[i][2]) {
100 case '0': /* none */
101 check(3,0);
102 fillo = 0;
103 break;
104 case 'f': /* foreground */
105 check(3,0);
106 fillo = F_FORE;
107 break;
108 case 'b': /* background */
109 check(3,0);
110 fillo = F_BACK;
111 break;
112 case 'a': /* all */
113 check(3,0);
114 fillo = F_FORE|F_BACK;
115 break;
116 case 's': /* sample */
117 check(3,1);
118 fillsamp = atoi(argv[++i]);
119 break;
120 case 'c': /* color */
121 check(3,3);
122 fillfunc = backfill;
123 setcolr(backcolr, atof(argv[i+1]),
124 atof(argv[i+2]), atof(argv[i+3]));
125 i += 3;
126 break;
127 case 'z': /* z value */
128 check(3,1);
129 fillfunc = backfill;
130 backz = atof(argv[++i]);
131 break;
132 case 'r': /* rtrace */
133 check(3,1);
134 fillfunc = rcalfill;
135 calstart(RTCOM, argv[++i]);
136 break;
137 default:
138 goto badopt;
139 }
140 break;
141 case 'z': /* z file */
142 check(2,1);
143 zfile = argv[++i];
144 break;
145 case 'x': /* x resolution */
146 check(2,1);
147 hresolu = atoi(argv[++i]);
148 break;
149 case 'y': /* y resolution */
150 check(2,1);
151 vresolu = atoi(argv[++i]);
152 break;
153 case 'p': /* pixel aspect */
154 check(2,1);
155 pixaspect = atof(argv[++i]);
156 break;
157 case 'v': /* view file */
158 if (argv[i][2] != 'f')
159 goto badopt;
160 check(3,1);
161 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
162 if (gotvfile < 0) {
163 perror(argv[i]);
164 exit(1);
165 } else if (gotvfile == 0) {
166 fprintf(stderr, "%s: bad view file\n",
167 argv[i]);
168 exit(1);
169 }
170 break;
171 default:
172 badopt:
173 fprintf(stderr, "%s: command line error at '%s'\n",
174 progname, argv[i]);
175 goto userr;
176 }
177 }
178 /* check arguments */
179 if ((argc-i)%2)
180 goto userr;
181 /* set view */
182 if (err = setview(&ourview)) {
183 fprintf(stderr, "%s: %s\n", progname, err);
184 exit(1);
185 }
186 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
187 /* allocate frame */
188 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
189 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
190 if (ourpict == NULL || ourzbuf == NULL)
191 syserror();
192 /* get input */
193 for ( ; i < argc; i += 2)
194 addpicture(argv[i], argv[i+1]);
195 /* fill in spaces */
196 if (fillo&F_BACK)
197 backpicture(fillfunc, fillsamp);
198 else
199 fillpicture(fillfunc);
200 /* close calculation */
201 caldone();
202 /* add to header */
203 printargs(argc, argv, stdout);
204 if (gotvfile) {
205 fputs(VIEWSTR, stdout);
206 fprintview(&ourview, stdout);
207 putc('\n', stdout);
208 }
209 if (pixaspect < .99 || pixaspect > 1.01)
210 fputaspect(pixaspect, stdout);
211 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
212 fputexpos(ourexp, stdout);
213 putc('\n', stdout);
214 /* write picture */
215 writepicture();
216 /* write z file */
217 if (zfile != NULL)
218 writedistance(zfile);
219
220 exit(0);
221 userr:
222 fprintf(stderr,
223 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
224 progname);
225 exit(1);
226 #undef check
227 }
228
229
230 headline(s) /* process header string */
231 char *s;
232 {
233 static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL};
234 register char **an;
235
236 putc('\t', stdout);
237 fputs(s, stdout);
238
239 if (isexpos(s)) {
240 theirexp *= exposval(s);
241 return;
242 }
243 for (an = altname; *an != NULL; an++)
244 if (!strncmp(*an, s, strlen(*an))) {
245 if (sscanview(&theirview, s+strlen(*an)) > 0)
246 gotview++;
247 break;
248 }
249 }
250
251
252 addpicture(pfile, zspec) /* add picture to output */
253 char *pfile, *zspec;
254 {
255 extern double atof();
256 FILE *pfp;
257 int zfd;
258 char *err;
259 COLR *scanin;
260 float *zin;
261 struct position *plast;
262 int y;
263 /* open picture file */
264 if ((pfp = fopen(pfile, "r")) == NULL) {
265 perror(pfile);
266 exit(1);
267 }
268 /* get header with exposure and view */
269 theirexp = 1.0;
270 gotview = 0;
271 printf("%s:\n", pfile);
272 getheader(pfp, headline);
273 if (!gotview || fgetresolu(&thresolu, &tvresolu, pfp)
274 != (YMAJOR|YDECR)) {
275 fprintf(stderr, "%s: picture view error\n", pfile);
276 exit(1);
277 }
278 if (ourexp <= 0)
279 ourexp = theirexp;
280 else if (ABS(theirexp-ourexp) > .01*ourexp)
281 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
282 if (err = setview(&theirview)) {
283 fprintf(stderr, "%s: %s\n", pfile, err);
284 exit(1);
285 }
286 /* compute transformation */
287 pixform(theirs2ours, &theirview, &ourview);
288 /* allocate scanlines */
289 scanin = (COLR *)malloc(thresolu*sizeof(COLR));
290 zin = (float *)malloc(thresolu*sizeof(float));
291 plast = (struct position *)calloc(thresolu, sizeof(struct position));
292 if (scanin == NULL || zin == NULL || plast == NULL)
293 syserror();
294 /* get z specification or file */
295 if ((zfd = open(zspec, O_RDONLY)) == -1) {
296 double zvalue;
297 register int x;
298 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
299 perror(zspec);
300 exit(1);
301 }
302 for (x = 0; x < thresolu; x++)
303 zin[x] = zvalue;
304 }
305 /* load image */
306 for (y = tvresolu-1; y >= 0; y--) {
307 if (freadcolrs(scanin, thresolu, pfp) < 0) {
308 fprintf(stderr, "%s: read error\n", pfile);
309 exit(1);
310 }
311 if (zfd != -1 && read(zfd,(char *)zin,thresolu*sizeof(float))
312 < thresolu*sizeof(float)) {
313 fprintf(stderr, "%s: read error\n", zspec);
314 exit(1);
315 }
316 addscanline(y, scanin, zin, plast);
317 }
318 /* clean up */
319 free((char *)scanin);
320 free((char *)zin);
321 free((char *)plast);
322 fclose(pfp);
323 if (zfd != -1)
324 close(zfd);
325 }
326
327
328 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
329 register double xfmat[4][4];
330 register VIEW *vw1, *vw2;
331 {
332 double m4t[4][4];
333
334 setident4(xfmat);
335 xfmat[0][0] = vw1->hvec[0];
336 xfmat[0][1] = vw1->hvec[1];
337 xfmat[0][2] = vw1->hvec[2];
338 xfmat[1][0] = vw1->vvec[0];
339 xfmat[1][1] = vw1->vvec[1];
340 xfmat[1][2] = vw1->vvec[2];
341 xfmat[2][0] = vw1->vdir[0];
342 xfmat[2][1] = vw1->vdir[1];
343 xfmat[2][2] = vw1->vdir[2];
344 xfmat[3][0] = vw1->vp[0];
345 xfmat[3][1] = vw1->vp[1];
346 xfmat[3][2] = vw1->vp[2];
347 setident4(m4t);
348 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
349 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
350 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
351 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
352 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
353 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
354 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
355 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
356 m4t[0][2] = vw2->vdir[0];
357 m4t[1][2] = vw2->vdir[1];
358 m4t[2][2] = vw2->vdir[2];
359 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
360 multmat4(xfmat, xfmat, m4t);
361 }
362
363
364 addscanline(y, pline, zline, lasty) /* add scanline to output */
365 int y;
366 COLR *pline;
367 float *zline;
368 struct position *lasty; /* input/output */
369 {
370 extern double sqrt();
371 double pos[3];
372 struct position lastx, newpos;
373 register int x;
374
375 lastx.z = 0;
376 for (x = thresolu-1; x >= 0; x--) {
377 pos[0] = (x+.5)/thresolu + theirview.hoff - .5;
378 pos[1] = (y+.5)/tvresolu + theirview.voff - .5;
379 pos[2] = zline[x];
380 if (theirview.type == VT_PER) {
381 if (normdist) /* adjust for eye-ray distance */
382 pos[2] /= sqrt( 1.
383 + pos[0]*pos[0]*theirview.hn2
384 + pos[1]*pos[1]*theirview.vn2 );
385 pos[0] *= pos[2];
386 pos[1] *= pos[2];
387 }
388 multp3(pos, pos, theirs2ours);
389 if (pos[2] <= 0) {
390 lasty[x].z = lastx.z = 0; /* mark invalid */
391 continue;
392 }
393 if (ourview.type == VT_PER) {
394 pos[0] /= pos[2];
395 pos[1] /= pos[2];
396 }
397 pos[0] += .5 - ourview.hoff;
398 pos[1] += .5 - ourview.voff;
399 newpos.x = pos[0] * hresolu;
400 newpos.y = pos[1] * vresolu;
401 newpos.z = zline[x];
402 /* add pixel to our image */
403 if (pos[0] >= 0 && newpos.x < hresolu
404 && pos[1] >= 0 && newpos.y < vresolu) {
405 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
406 lasty[x].x = lastx.x = newpos.x;
407 lasty[x].y = lastx.y = newpos.y;
408 lasty[x].z = lastx.z = newpos.z;
409 } else
410 lasty[x].z = lastx.z = 0; /* mark invalid */
411 }
412 }
413
414
415 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
416 struct position *p0, *p1, *p2;
417 COLR pix;
418 double z;
419 {
420 double zt = 2.*zeps*p0->z; /* threshold */
421 int s1x, s1y, s2x, s2y; /* step sizes */
422 int l1, l2, c1, c2; /* side lengths and counters */
423 int p1isy; /* p0p1 along y? */
424 int x1, y1; /* p1 position */
425 register int x, y; /* final position */
426
427 /* compute vector p0p1 */
428 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
429 s1x = p1->x - p0->x;
430 s1y = p1->y - p0->y;
431 l1 = ABS(s1x);
432 if (p1isy = (ABS(s1y) > l1))
433 l1 = ABS(s1y);
434 } else {
435 l1 = s1x = s1y = 1;
436 p1isy = -1;
437 }
438 /* compute vector p0p2 */
439 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
440 s2x = p2->x - p0->x;
441 s2y = p2->y - p0->y;
442 if (p1isy == 1)
443 l2 = ABS(s2x);
444 else {
445 l2 = ABS(s2y);
446 if (p1isy != 0 && ABS(s2x) > l2)
447 l2 = ABS(s2x);
448 }
449 } else
450 l2 = s2x = s2y = 1;
451 /* fill the parallelogram */
452 for (c1 = l1; c1-- > 0; ) {
453 x1 = p0->x + c1*s1x/l1;
454 y1 = p0->y + c1*s1y/l1;
455 for (c2 = l2; c2-- > 0; ) {
456 x = x1 + c2*s2x/l2;
457 y = y1 + c2*s2y/l2;
458 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
459 > zeps*zscan(y)[x]) {
460 zscan(y)[x] = z;
461 copycolr(pscan(y)[x], pix);
462 }
463 }
464 }
465 }
466
467
468 backpicture(fill, samp) /* background fill algorithm */
469 int (*fill)();
470 int samp;
471 {
472 int *yback, xback;
473 int y;
474 COLR pfill;
475 register int x, i;
476 /* get back buffer */
477 yback = (int *)malloc(hresolu*sizeof(int));
478 if (yback == NULL)
479 syserror();
480 for (x = 0; x < hresolu; x++)
481 yback[x] = -2;
482 /*
483 * Xback and yback are the pixel locations of suitable
484 * background values in each direction.
485 * A value of -2 means unassigned, and -1 means
486 * that there is no suitable background in this direction.
487 */
488 /* fill image */
489 for (y = 0; y < vresolu; y++) {
490 xback = -2;
491 for (x = 0; x < hresolu; x++)
492 if (zscan(y)[x] <= 0) { /* empty pixel */
493 /*
494 * First, find background from above or below.
495 * (farthest assigned pixel)
496 */
497 if (yback[x] == -2) {
498 for (i = y+1; i < vresolu; i++)
499 if (zscan(i)[x] > 0)
500 break;
501 if (i < vresolu
502 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
503 yback[x] = i;
504 else
505 yback[x] = y-1;
506 }
507 /*
508 * Next, find background from left or right.
509 */
510 if (xback == -2) {
511 for (i = x+1; i < hresolu; i++)
512 if (zscan(y)[i] > 0)
513 break;
514 if (i < hresolu
515 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
516 xback = i;
517 else
518 xback = x-1;
519 }
520 /*
521 * If we have no background for this pixel,
522 * use the given fill function.
523 */
524 if (xback < 0 && yback[x] < 0)
525 goto fillit;
526 /*
527 * Compare, and use the background that is
528 * farther, unless one of them is next to us.
529 * If the background is too distant, call
530 * the fill function.
531 */
532 if ( yback[x] < 0
533 || (xback >= 0 && ABS(x-xback) <= 1)
534 || ( ABS(y-yback[x]) > 1
535 && zscan(yback[x])[x]
536 < zscan(y)[xback] ) ) {
537 if (samp > 0 && ABS(x-xback) >= samp)
538 goto fillit;
539 copycolr(pscan(y)[x],pscan(y)[xback]);
540 zscan(y)[x] = zscan(y)[xback];
541 } else {
542 if (samp > 0 && ABS(y-yback[x]) > samp)
543 goto fillit;
544 copycolr(pscan(y)[x],pscan(yback[x])[x]);
545 zscan(y)[x] = zscan(yback[x])[x];
546 }
547 continue;
548 fillit:
549 (*fill)(x,y);
550 if (fill == rcalfill) { /* use it */
551 clearqueue();
552 xback = x;
553 yback[x] = y;
554 }
555 } else { /* full pixel */
556 yback[x] = -2;
557 xback = -2;
558 }
559 }
560 free((char *)yback);
561 }
562
563
564 fillpicture(fill) /* paint in empty pixels using fill */
565 int (*fill)();
566 {
567 register int x, y;
568
569 for (y = 0; y < vresolu; y++)
570 for (x = 0; x < hresolu; x++)
571 if (zscan(y)[x] <= 0)
572 (*fill)(x,y);
573 }
574
575
576 writepicture() /* write out picture */
577 {
578 int y;
579
580 fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout);
581 for (y = vresolu-1; y >= 0; y--)
582 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
583 syserror();
584 }
585
586
587 writedistance(fname) /* write out z file */
588 char *fname;
589 {
590 extern double sqrt();
591 int donorm = normdist && ourview.type == VT_PER;
592 int fd;
593 int y;
594 float *zout;
595
596 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
597 perror(fname);
598 exit(1);
599 }
600 if (donorm
601 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
602 syserror();
603 for (y = vresolu-1; y >= 0; y--) {
604 if (donorm) {
605 double vx, yzn2;
606 register int x;
607 yzn2 = y - .5*(vresolu-1);
608 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
609 for (x = 0; x < hresolu; x++) {
610 vx = x - .5*(hresolu-1);
611 zout[x] = zscan(y)[x]
612 * sqrt(vx*vx*ourview.hn2 + yzn2);
613 }
614 } else
615 zout = zscan(y);
616 if (write(fd, (char *)zout, hresolu*sizeof(float))
617 < hresolu*sizeof(float)) {
618 perror(fname);
619 exit(1);
620 }
621 }
622 if (donorm)
623 free((char *)zout);
624 close(fd);
625 }
626
627
628 isfloat(s) /* see if string is floating number */
629 register char *s;
630 {
631 for ( ; *s; s++)
632 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
633 && *s != 'e' && *s != 'E' && *s != '+')
634 return(0);
635 return(1);
636 }
637
638
639 backfill(x, y) /* fill pixel with background */
640 int x, y;
641 {
642 register BYTE *dest = pscan(y)[x];
643
644 copycolr(dest, backcolr);
645 zscan(y)[x] = backz;
646 }
647
648
649 calstart(prog, args) /* start fill calculation */
650 char *prog, *args;
651 {
652 char combuf[512];
653 int p0[2], p1[2];
654
655 if (childpid != -1) {
656 fprintf(stderr, "%s: too many calculations\n", progname);
657 exit(1);
658 }
659 sprintf(combuf, prog, args);
660 if (pipe(p0) < 0 || pipe(p1) < 0)
661 syserror();
662 if ((childpid = vfork()) == 0) { /* fork calculation */
663 close(p0[1]);
664 close(p1[0]);
665 if (p0[0] != 0) {
666 dup2(p0[0], 0);
667 close(p0[0]);
668 }
669 if (p1[1] != 1) {
670 dup2(p1[1], 1);
671 close(p1[1]);
672 }
673 execl("/bin/sh", "sh", "-c", combuf, 0);
674 perror("/bin/sh");
675 _exit(127);
676 }
677 if (childpid == -1)
678 syserror();
679 close(p0[0]);
680 close(p1[1]);
681 if ((psend = fdopen(p0[1], "w")) == NULL)
682 syserror();
683 if ((precv = fdopen(p1[0], "r")) == NULL)
684 syserror();
685 queuesiz = 0;
686 }
687
688
689 caldone() /* done with calculation */
690 {
691 int pid;
692
693 if (childpid == -1)
694 return;
695 clearqueue();
696 fclose(psend);
697 fclose(precv);
698 while ((pid = wait(0)) != -1 && pid != childpid)
699 ;
700 childpid = -1;
701 }
702
703
704 rcalfill(x, y) /* fill with ray-calculated pixel */
705 int x, y;
706 {
707 if (queuesiz >= PACKSIZ) /* flush queue if needed */
708 clearqueue();
709 /* add position to queue */
710 queue[queuesiz][0] = x;
711 queue[queuesiz][1] = y;
712 queuesiz++;
713 }
714
715
716 clearqueue() /* process queue */
717 {
718 FVECT orig, dir;
719 float fbuf[6];
720 register int i;
721
722 for (i = 0; i < queuesiz; i++) {
723 viewray(orig, dir, &ourview,
724 (queue[i][0]+.5)/hresolu,
725 (queue[i][1]+.5)/vresolu);
726 fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2];
727 fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2];
728 fwrite((char *)fbuf, sizeof(float), 6, psend);
729 }
730 /* flush output and get results */
731 fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */
732 fwrite((char *)fbuf, sizeof(float), 6, psend);
733 if (fflush(psend) == EOF)
734 syserror();
735 for (i = 0; i < queuesiz; i++) {
736 if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) {
737 fprintf(stderr, "%s: read error in clearqueue\n",
738 progname);
739 exit(1);
740 }
741 if (ourexp > 0 && ourexp != 1.0) {
742 fbuf[0] *= ourexp;
743 fbuf[1] *= ourexp;
744 fbuf[2] *= ourexp;
745 }
746 setcolr(pscan(queue[i][1])[queue[i][0]],
747 fbuf[0], fbuf[1], fbuf[2]);
748 zscan(queue[i][1])[queue[i][0]] = fbuf[3];
749 }
750 queuesiz = 0;
751 }
752
753
754 syserror() /* report error and exit */
755 {
756 perror(progname);
757 exit(1);
758 }
