root/radiance/ray/src/px/pinterp.c
Revision: 1.25
Committed: Tue Mar 6 11:14:36 1990 UTC (35 years, 4 months ago) by greg
Changes since 1.24: +52 -34 lines
added sampling
2 static char SCCSid[] = "$SunId$ LBL";
4
5 /*
6 * Interpolate and extrapolate pictures with different view parameters.
7 *
8 * Greg Ward 09Dec89
9 */
10
11 #include "standard.h"
12
13 #include <fcntl.h>
14
15 #include "view.h"
16
17 #include "color.h"
18
19 #include "random.h"
20
21 #ifndef BSD
22 #define vfork fork
23 #endif
24
25 #define pscan(y) (ourpict+(y)*hresolu)
26 #define zscan(y) (ourzbuf+(y)*hresolu)
27
28 #define PMASK 0xfffffff /* probability mask */
29 #define sampval(x) (long)((x)*(PMASK+1)+.5)
30 #define samp(p) ((p) > (random()&PMASK))
31
32 #define F_FORE 1 /* fill foreground */
33 #define F_BACK 2 /* fill background */
34
35 #define PACKSIZ 42 /* calculation packet size */
36
37 #define RTCOM "rtrace -h -ovl -fff %s"
38
39 #define ABS(x) ((x)>0?(x):-(x))
40
41 struct position {int x,y; float z;};
42
43 VIEW ourview = STDVIEW; /* desired view */
44 int hresolu = 512; /* horizontal resolution */
45 int vresolu = 512; /* vertical resolution */
46 double pixaspect = 1.0; /* pixel aspect ratio */
47
48 double zeps = .02; /* allowed z epsilon */
49
50 COLR *ourpict; /* output picture */
51 float *ourzbuf; /* corresponding z-buffer */
52
53 char *progname;
54
55 int fillo = F_FORE|F_BACK; /* selected fill options */
56 long sampprob = 0; /* sample probability */
57 extern int backfill(), rcalfill(); /* fill functions */
58 int (*fillfunc)() = backfill; /* selected fill function */
59 COLR backcolr = BLKCOLR; /* background color */
60 double backz = 0.0; /* background z value */
61 int normdist = 1; /* normalized distance? */
62 double ourexp = -1; /* output picture exposure */
63
64 VIEW theirview = STDVIEW; /* input view */
65 int gotview; /* got input view? */
66 int thresolu, tvresolu; /* input resolution */
67 double theirexp; /* input picture exposure */
68 double theirs2ours[4][4]; /* transformation matrix */
69
70 int childpid = -1; /* id of fill process */
71 FILE *psend, *precv; /* pipes to/from fill calculation */
72 int queue[PACKSIZ][2]; /* pending pixels */
73 int queuesiz; /* number of pixels pending */
74
75
76 main(argc, argv) /* interpolate pictures */
77 int argc;
78 char *argv[];
79 {
80 #define check(olen,narg) if (argv[i][olen] || narg >= argc-i) goto badopt
81 extern double atof();
82 int gotvfile = 0;
83 char *zfile = NULL;
84 char *err;
85 int i, rval;
86
87 progname = argv[0];
88
89 for (i = 1; i < argc && argv[i][0] == '-'; i++) {
90 rval = getviewopt(&ourview, argc-i, argv+i);
91 if (rval >= 0) {
92 i += rval;
93 continue;
94 }
95 switch (argv[i][1]) {
96 case 't': /* threshold */
97 check(2,1);
98 zeps = atof(argv[++i]);
99 break;
100 case 'n': /* dist. normalized? */
101 check(2,0);
102 normdist = !normdist;
103 break;
104 case 'f': /* fill type */
105 switch (argv[i][2]) {
106 case '0': /* none */
107 check(3,0);
108 fillo = 0;
109 break;
110 case 'f': /* foreground */
111 check(3,0);
112 fillo = F_FORE;
113 break;
114 case 'b': /* background */
115 check(3,0);
116 fillo = F_BACK;
117 break;
118 case 'a': /* all */
119 check(3,0);
120 fillo = F_FORE|F_BACK;
121 break;
122 case 's': /* sample */
123 check(3,1);
124 sampprob = sampval(atof(argv[++i]));
125 break;
126 case 'c': /* color */
127 check(3,3);
128 fillfunc = backfill;
129 setcolr(backcolr, atof(argv[i+1]),
130 atof(argv[i+2]), atof(argv[i+3]));
131 i += 3;
132 break;
133 case 'z': /* z value */
134 check(3,1);
135 fillfunc = backfill;
136 backz = atof(argv[++i]);
137 break;
138 case 'r': /* rtrace */
139 check(3,1);
140 fillfunc = rcalfill;
141 calstart(RTCOM, argv[++i]);
142 break;
143 default:
144 goto badopt;
145 }
146 break;
147 case 'z': /* z file */
148 check(2,1);
149 zfile = argv[++i];
150 break;
151 case 'x': /* x resolution */
152 check(2,1);
153 hresolu = atoi(argv[++i]);
154 break;
155 case 'y': /* y resolution */
156 check(2,1);
157 vresolu = atoi(argv[++i]);
158 break;
159 case 'p': /* pixel aspect */
160 check(2,1);
161 pixaspect = atof(argv[++i]);
162 break;
163 case 'v': /* view file */
164 if (argv[i][2] != 'f')
165 goto badopt;
166 check(3,1);
167 gotvfile = viewfile(argv[++i], &ourview, 0, 0);
168 if (gotvfile < 0) {
169 perror(argv[i]);
170 exit(1);
171 } else if (gotvfile == 0) {
172 fprintf(stderr, "%s: bad view file\n",
173 argv[i]);
174 exit(1);
175 }
176 break;
177 default:
178 badopt:
179 fprintf(stderr, "%s: command line error at '%s'\n",
180 progname, argv[i]);
181 goto userr;
182 }
183 }
184 /* check arguments */
185 if ((argc-i)%2)
186 goto userr;
187 /* set view */
188 if (err = setview(&ourview)) {
189 fprintf(stderr, "%s: %s\n", progname, err);
190 exit(1);
191 }
192 normaspect(viewaspect(&ourview), &pixaspect, &hresolu, &vresolu);
193 /* allocate frame */
194 ourpict = (COLR *)malloc(hresolu*vresolu*sizeof(COLR));
195 ourzbuf = (float *)calloc(hresolu*vresolu,sizeof(float));
196 if (ourpict == NULL || ourzbuf == NULL)
197 syserror();
198 /* get input */
199 for ( ; i < argc; i += 2)
200 addpicture(argv[i], argv[i+1]);
201 /* fill in spaces */
202 if (fillo&F_BACK)
203 backpicture(fillfunc, sampprob);
204 else
205 fillpicture(fillfunc);
206 /* close calculation */
207 caldone();
208 /* add to header */
209 printargs(argc, argv, stdout);
210 if (gotvfile) {
211 fputs(VIEWSTR, stdout);
212 fprintview(&ourview, stdout);
213 putc('\n', stdout);
214 }
215 if (pixaspect < .99 || pixaspect > 1.01)
216 fputaspect(pixaspect, stdout);
217 if (ourexp > 0 && (ourexp < .995 || ourexp > 1.005))
218 fputexpos(ourexp, stdout);
219 putc('\n', stdout);
220 /* write picture */
221 writepicture();
222 /* write z file */
223 if (zfile != NULL)
224 writedistance(zfile);
225
226 exit(0);
227 userr:
228 fprintf(stderr,
229 "Usage: %s [view opts][-t eps][-z zout][-fT][-n] pfile zspec ..\n",
230 progname);
231 exit(1);
232 #undef check
233 }
234
235
236 headline(s) /* process header string */
237 char *s;
238 {
239 static char *altname[] = {VIEWSTR,"rpict","rview","pinterp",NULL};
240 register char **an;
241
242 putc('\t', stdout);
243 fputs(s, stdout);
244
245 if (isexpos(s)) {
246 theirexp *= exposval(s);
247 return;
248 }
249 for (an = altname; *an != NULL; an++)
250 if (!strncmp(*an, s, strlen(*an))) {
251 if (sscanview(&theirview, s+strlen(*an)) > 0)
252 gotview++;
253 break;
254 }
255 }
256
257
258 addpicture(pfile, zspec) /* add picture to output */
259 char *pfile, *zspec;
260 {
261 extern double atof();
262 FILE *pfp;
263 int zfd;
264 char *err;
265 COLR *scanin;
266 float *zin;
267 struct position *plast;
268 int y;
269 /* open picture file */
270 if ((pfp = fopen(pfile, "r")) == NULL) {
271 perror(pfile);
272 exit(1);
273 }
274 /* get header with exposure and view */
275 theirexp = 1.0;
276 gotview = 0;
277 printf("%s:\n", pfile);
278 getheader(pfp, headline);
279 if (!gotview || fgetresolu(&thresolu, &tvresolu, pfp)
280 != (YMAJOR|YDECR)) {
281 fprintf(stderr, "%s: picture view error\n", pfile);
282 exit(1);
283 }
284 if (ourexp <= 0)
285 ourexp = theirexp;
286 else if (ABS(theirexp-ourexp) > .01*ourexp)
287 fprintf(stderr, "%s: different exposure (warning)\n", pfile);
288 if (err = setview(&theirview)) {
289 fprintf(stderr, "%s: %s\n", pfile, err);
290 exit(1);
291 }
292 /* compute transformation */
293 pixform(theirs2ours, &theirview, &ourview);
294 /* allocate scanlines */
295 scanin = (COLR *)malloc(thresolu*sizeof(COLR));
296 zin = (float *)malloc(thresolu*sizeof(float));
297 plast = (struct position *)calloc(thresolu, sizeof(struct position));
298 if (scanin == NULL || zin == NULL || plast == NULL)
299 syserror();
300 /* get z specification or file */
301 if ((zfd = open(zspec, O_RDONLY)) == -1) {
302 double zvalue;
303 register int x;
304 if (!isfloat(zspec) || (zvalue = atof(zspec)) <= 0.0) {
305 perror(zspec);
306 exit(1);
307 }
308 for (x = 0; x < thresolu; x++)
309 zin[x] = zvalue;
310 }
311 /* load image */
312 for (y = tvresolu-1; y >= 0; y--) {
313 if (freadcolrs(scanin, thresolu, pfp) < 0) {
314 fprintf(stderr, "%s: read error\n", pfile);
315 exit(1);
316 }
317 if (zfd != -1 && read(zfd,(char *)zin,thresolu*sizeof(float))
318 < thresolu*sizeof(float)) {
319 fprintf(stderr, "%s: read error\n", zspec);
320 exit(1);
321 }
322 addscanline(y, scanin, zin, plast);
323 }
324 /* clean up */
325 free((char *)scanin);
326 free((char *)zin);
327 free((char *)plast);
328 fclose(pfp);
329 if (zfd != -1)
330 close(zfd);
331 }
332
333
334 pixform(xfmat, vw1, vw2) /* compute view1 to view2 matrix */
335 register double xfmat[4][4];
336 register VIEW *vw1, *vw2;
337 {
338 double m4t[4][4];
339
340 setident4(xfmat);
341 xfmat[0][0] = vw1->hvec[0];
342 xfmat[0][1] = vw1->hvec[1];
343 xfmat[0][2] = vw1->hvec[2];
344 xfmat[1][0] = vw1->vvec[0];
345 xfmat[1][1] = vw1->vvec[1];
346 xfmat[1][2] = vw1->vvec[2];
347 xfmat[2][0] = vw1->vdir[0];
348 xfmat[2][1] = vw1->vdir[1];
349 xfmat[2][2] = vw1->vdir[2];
350 xfmat[3][0] = vw1->vp[0];
351 xfmat[3][1] = vw1->vp[1];
352 xfmat[3][2] = vw1->vp[2];
353 setident4(m4t);
354 m4t[0][0] = vw2->hvec[0]/vw2->hn2;
355 m4t[1][0] = vw2->hvec[1]/vw2->hn2;
356 m4t[2][0] = vw2->hvec[2]/vw2->hn2;
357 m4t[3][0] = -DOT(vw2->vp,vw2->hvec)/vw2->hn2;
358 m4t[0][1] = vw2->vvec[0]/vw2->vn2;
359 m4t[1][1] = vw2->vvec[1]/vw2->vn2;
360 m4t[2][1] = vw2->vvec[2]/vw2->vn2;
361 m4t[3][1] = -DOT(vw2->vp,vw2->vvec)/vw2->vn2;
362 m4t[0][2] = vw2->vdir[0];
363 m4t[1][2] = vw2->vdir[1];
364 m4t[2][2] = vw2->vdir[2];
365 m4t[3][2] = -DOT(vw2->vp,vw2->vdir);
366 multmat4(xfmat, xfmat, m4t);
367 }
368
369
370 addscanline(y, pline, zline, lasty) /* add scanline to output */
371 int y;
372 COLR *pline;
373 float *zline;
374 struct position *lasty; /* input/output */
375 {
376 extern double sqrt();
377 double pos[3];
378 struct position lastx, newpos;
379 register int x;
380
381 lastx.z = 0;
382 for (x = thresolu-1; x >= 0; x--) {
383 pos[0] = (x+.5)/thresolu + theirview.hoff - .5;
384 pos[1] = (y+.5)/tvresolu + theirview.voff - .5;
385 pos[2] = zline[x];
386 if (theirview.type == VT_PER) {
387 if (normdist) /* adjust for eye-ray distance */
388 pos[2] /= sqrt( 1.
389 + pos[0]*pos[0]*theirview.hn2
390 + pos[1]*pos[1]*theirview.vn2 );
391 pos[0] *= pos[2];
392 pos[1] *= pos[2];
393 }
394 multp3(pos, pos, theirs2ours);
395 if (pos[2] <= 0) {
396 lasty[x].z = lastx.z = 0; /* mark invalid */
397 continue;
398 }
399 if (ourview.type == VT_PER) {
400 pos[0] /= pos[2];
401 pos[1] /= pos[2];
402 }
403 pos[0] += .5 - ourview.hoff;
404 pos[1] += .5 - ourview.voff;
405 newpos.x = pos[0] * hresolu;
406 newpos.y = pos[1] * vresolu;
407 newpos.z = zline[x];
408 /* add pixel to our image */
409 if (pos[0] >= 0 && newpos.x < hresolu
410 && pos[1] >= 0 && newpos.y < vresolu) {
411 addpixel(&newpos, &lastx, &lasty[x], pline[x], pos[2]);
412 lasty[x].x = lastx.x = newpos.x;
413 lasty[x].y = lastx.y = newpos.y;
414 lasty[x].z = lastx.z = newpos.z;
415 } else
416 lasty[x].z = lastx.z = 0; /* mark invalid */
417 }
418 }
419
420
421 addpixel(p0, p1, p2, pix, z) /* fill in pixel parallelogram */
422 struct position *p0, *p1, *p2;
423 COLR pix;
424 double z;
425 {
426 double zt = 2.*zeps*p0->z; /* threshold */
427 int s1x, s1y, s2x, s2y; /* step sizes */
428 int l1, l2, c1, c2; /* side lengths and counters */
429 int p1isy; /* p0p1 along y? */
430 int x1, y1; /* p1 position */
431 register int x, y; /* final position */
432
433 /* compute vector p0p1 */
434 if (fillo&F_FORE && ABS(p1->z-p0->z) <= zt) {
435 s1x = p1->x - p0->x;
436 s1y = p1->y - p0->y;
437 l1 = ABS(s1x);
438 if (p1isy = (ABS(s1y) > l1))
439 l1 = ABS(s1y);
440 } else {
441 l1 = s1x = s1y = 1;
442 p1isy = -1;
443 }
444 /* compute vector p0p2 */
445 if (fillo&F_FORE && ABS(p2->z-p0->z) <= zt) {
446 s2x = p2->x - p0->x;
447 s2y = p2->y - p0->y;
448 if (p1isy == 1)
449 l2 = ABS(s2x);
450 else {
451 l2 = ABS(s2y);
452 if (p1isy != 0 && ABS(s2x) > l2)
453 l2 = ABS(s2x);
454 }
455 } else
456 l2 = s2x = s2y = 1;
457 /* fill the parallelogram */
458 for (c1 = l1; c1-- > 0; ) {
459 x1 = p0->x + c1*s1x/l1;
460 y1 = p0->y + c1*s1y/l1;
461 for (c2 = l2; c2-- > 0; ) {
462 x = x1 + c2*s2x/l2;
463 y = y1 + c2*s2y/l2;
464 if (zscan(y)[x] <= 0 || zscan(y)[x]-z
465 > zeps*zscan(y)[x]) {
466 zscan(y)[x] = z;
467 copycolr(pscan(y)[x], pix);
468 }
469 }
470 }
471 }
472
473
474 backpicture(fill, prob) /* background fill algorithm */
475 int (*fill)();
476 long prob;
477 {
478 int *yback, xback;
479 int y;
480 COLR pfill;
481 register int x, i;
482 /* get back buffer */
483 yback = (int *)malloc(hresolu*sizeof(int));
484 if (yback == NULL)
485 syserror();
486 for (x = 0; x < hresolu; x++)
487 yback[x] = -2;
488 /*
489 * Xback and yback are the pixel locations of suitable
490 * background values in each direction.
491 * A value of -2 means unassigned, and -1 means
492 * that there is no suitable background in this direction.
493 */
494 /* fill image */
495 for (y = 0; y < vresolu; y++) {
496 xback = -2;
497 for (x = 0; x < hresolu; x++)
498 if (zscan(y)[x] <= 0) { /* empty pixel */
499 /*
500 * First, find background from above or below.
501 * (farthest assigned pixel)
502 */
503 if (yback[x] == -2) {
504 for (i = y+1; i < vresolu; i++)
505 if (zscan(i)[x] > 0)
506 break;
507 if (i < vresolu
508 && (y <= 0 || zscan(y-1)[x] < zscan(i)[x]))
509 yback[x] = i;
510 else
511 yback[x] = y-1;
512 }
513 /*
514 * Next, find background from left or right.
515 */
516 if (xback == -2) {
517 for (i = x+1; i < hresolu; i++)
518 if (zscan(y)[i] > 0)
519 break;
520 if (i < hresolu
521 && (x <= 0 || zscan(y)[x-1] < zscan(y)[i]))
522 xback = i;
523 else
524 xback = x-1;
525 }
526 /*
527 * Check to see if we have no background for
528 * this pixel. If not, or sampling was
529 * requested, use the given fill function.
530 */
531 if ((xback < 0 && yback[x] < 0) || samp(prob)) {
532 (*fill)(x,y);
533 continue;
534 }
535 /*
536 * Compare, and use the background that is
537 * farther, unless one of them is next to us.
538 */
539 if ( yback[x] < 0
540 || (xback >= 0 && ABS(x-xback) <= 1)
541 || ( ABS(y-yback[x]) > 1
542 && zscan(yback[x])[x]
543 < zscan(y)[xback] ) ) {
544 copycolr(pscan(y)[x],pscan(y)[xback]);
545 zscan(y)[x] = zscan(y)[xback];
546 } else {
547 copycolr(pscan(y)[x],pscan(yback[x])[x]);
548 zscan(y)[x] = zscan(yback[x])[x];
549 }
550 } else { /* full pixel */
551 yback[x] = -2;
552 xback = -2;
553 }
554 }
555 free((char *)yback);
556 }
557
558
559 fillpicture(fill) /* paint in empty pixels using fill */
560 int (*fill)();
561 {
562 register int x, y;
563
564 for (y = 0; y < vresolu; y++)
565 for (x = 0; x < hresolu; x++)
566 if (zscan(y)[x] <= 0)
567 (*fill)(x,y);
568 }
569
570
571 writepicture() /* write out picture */
572 {
573 int y;
574
575 fputresolu(YMAJOR|YDECR, hresolu, vresolu, stdout);
576 for (y = vresolu-1; y >= 0; y--)
577 if (fwritecolrs(pscan(y), hresolu, stdout) < 0)
578 syserror();
579 }
580
581
582 writedistance(fname) /* write out z file */
583 char *fname;
584 {
585 extern double sqrt();
586 int donorm = normdist && ourview.type == VT_PER;
587 int fd;
588 int y;
589 float *zout;
590
591 if ((fd = open(fname, O_WRONLY|O_CREAT|O_TRUNC, 0666)) == -1) {
592 perror(fname);
593 exit(1);
594 }
595 if (donorm
596 && (zout = (float *)malloc(hresolu*sizeof(float))) == NULL)
597 syserror();
598 for (y = vresolu-1; y >= 0; y--) {
599 if (donorm) {
600 double vx, yzn2;
601 register int x;
602 yzn2 = y - .5*(vresolu-1);
603 yzn2 = 1. + yzn2*yzn2*ourview.vn2;
604 for (x = 0; x < hresolu; x++) {
605 vx = x - .5*(hresolu-1);
606 zout[x] = zscan(y)[x]
607 * sqrt(vx*vx*ourview.hn2 + yzn2);
608 }
609 } else
610 zout = zscan(y);
611 if (write(fd, (char *)zout, hresolu*sizeof(float))
612 < hresolu*sizeof(float)) {
613 perror(fname);
614 exit(1);
615 }
616 }
617 if (donorm)
618 free((char *)zout);
619 close(fd);
620 }
621
622
623 isfloat(s) /* see if string is floating number */
624 register char *s;
625 {
626 for ( ; *s; s++)
627 if ((*s < '0' || *s > '9') && *s != '.' && *s != '-'
628 && *s != 'e' && *s != 'E' && *s != '+')
629 return(0);
630 return(1);
631 }
632
633
634 backfill(x, y) /* fill pixel with background */
635 int x, y;
636 {
637 register BYTE *dest = pscan(y)[x];
638
639 copycolr(dest, backcolr);
640 zscan(y)[x] = backz;
641 }
642
643
644 calstart(prog, args) /* start fill calculation */
645 char *prog, *args;
646 {
647 char combuf[512];
648 int p0[2], p1[2];
649
650 if (childpid != -1) {
651 fprintf(stderr, "%s: too many calculations\n", progname);
652 exit(1);
653 }
654 sprintf(combuf, prog, args);
655 if (pipe(p0) < 0 || pipe(p1) < 0)
656 syserror();
657 if ((childpid = vfork()) == 0) { /* fork calculation */
658 close(p0[1]);
659 close(p1[0]);
660 if (p0[0] != 0) {
661 dup2(p0[0], 0);
662 close(p0[0]);
663 }
664 if (p1[1] != 1) {
665 dup2(p1[1], 1);
666 close(p1[1]);
667 }
668 execl("/bin/sh", "sh", "-c", combuf, 0);
669 perror("/bin/sh");
670 _exit(127);
671 }
672 if (childpid == -1)
673 syserror();
674 close(p0[0]);
675 close(p1[1]);
676 if ((psend = fdopen(p0[1], "w")) == NULL)
677 syserror();
678 if ((precv = fdopen(p1[0], "r")) == NULL)
679 syserror();
680 queuesiz = 0;
681 }
682
683
684 caldone() /* done with calculation */
685 {
686 int pid;
687
688 if (childpid == -1)
689 return;
690 clearqueue();
691 fclose(psend);
692 fclose(precv);
693 while ((pid = wait(0)) != -1 && pid != childpid)
694 ;
695 childpid = -1;
696 }
697
698
699 rcalfill(x, y) /* fill with ray-calculated pixel */
700 int x, y;
701 {
702 if (queuesiz >= PACKSIZ) /* flush queue if needed */
703 clearqueue();
704 /* add position to queue */
705 queue[queuesiz][0] = x;
706 queue[queuesiz][1] = y;
707 queuesiz++;
708 }
709
710
711 clearqueue() /* process queue */
712 {
713 FVECT orig, dir;
714 float fbuf[6];
715 register int i;
716
717 for (i = 0; i < queuesiz; i++) {
718 viewray(orig, dir, &ourview,
719 (queue[i][0]+.5)/hresolu,
720 (queue[i][1]+.5)/vresolu);
721 fbuf[0] = orig[0]; fbuf[1] = orig[1]; fbuf[2] = orig[2];
722 fbuf[3] = dir[0]; fbuf[4] = dir[1]; fbuf[5] = dir[2];
723 fwrite((char *)fbuf, sizeof(float), 6, psend);
724 }
725 /* flush output and get results */
726 fbuf[3] = fbuf[4] = fbuf[5] = 0.0; /* mark */
727 fwrite((char *)fbuf, sizeof(float), 6, psend);
728 if (fflush(psend) == EOF)
729 syserror();
730 for (i = 0; i < queuesiz; i++) {
731 if (fread((char *)fbuf, sizeof(float), 4, precv) < 4) {
732 fprintf(stderr, "%s: read error in clearqueue\n",
733 progname);
734 exit(1);
735 }
736 if (ourexp > 0 && ourexp != 1.0) {
737 fbuf[0] *= ourexp;
738 fbuf[1] *= ourexp;
739 fbuf[2] *= ourexp;
740 }
741 setcolr(pscan(queue[i][1])[queue[i][0]],
742 fbuf[0], fbuf[1], fbuf[2]);
743 zscan(queue[i][1])[queue[i][0]] = fbuf[3];
744 }
745 queuesiz = 0;
746 }
747
748
749 syserror() /* report error and exit */
750 {
751 perror(progname);
752 exit(1);
753 }
