1 |
schorsch |
2.4 |
/* RCSid: $Id: pic.h,v 2.3 2003/07/14 22:24:00 schorsch Exp $ */ |
2 |
greg |
1.2 |
/* the following three structures are used by ciq */ |
3 |
greg |
1.1 |
4 |
schorsch |
2.3 |
#ifndef _RAD_PIC_H_ |
5 |
#define _RAD_PIC_H_ |
6 |
7 |
#ifdef __cplusplus |
8 |
extern "C" { |
9 |
#endif |
10 |
11 |
greg |
1.1 |
typedef int colormap[3][256]; |
12 |
13 |
typedef unsigned char pixel; |
14 |
15 |
typedef struct { |
16 |
pixel r,g,b; |
17 |
} rgbpixel; |
18 |
19 |
#define rgb_bright(p) (int)((77L*(p)->r+151L*(p)->g+28L*(p)->b)/256) |
20 |
21 |
/* image resolution */ |
22 |
extern int xmax,ymax; |
23 |
schorsch |
2.3 |
24 |
schorsch |
2.4 |
/* defined in closest.c */ |
25 |
extern void initializeclosest(void); |
26 |
extern int closest(int r, int g, int b); |
27 |
28 |
/* defined in cut.c */ |
29 |
extern int makecm(int nw, int *na); |
30 |
31 |
/* defined in ciq.c */ |
32 |
extern void ciq(int dith, int nw, int synth, colormap cm); |
33 |
34 |
/* defined in biq.c */ |
35 |
extern void biq(int dith, int nw, int synth, colormap cm); |
36 |
37 |
/* defined in in the calling program */ |
38 |
extern void picreadcm(colormap map); |
39 |
extern void picwritecm(colormap cm); |
40 |
extern void picwriteline(int y, pixel *l); |
41 |
extern void picreadline3(int y, rgbpixel *l3); |
42 |
43 |
44 |
schorsch |
2.3 |
45 |
46 |
#endif |
47 |
#endif /* _RAD_PIC_H_ */ |
48 |
