root/radiance/ray/src/px/phisto.csh
Revision 3.8 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Feb 4 20:11:49 2022 UTC (3 years, 3 months ago) by greg
CVS Tags: HEAD, rad5R4
Changes since 3.7: +3 -3 lines
Diff to previous 3.7
feat(pvalue,pextrem): Added -O option to report watts/sr/meter^2 always
Revision 3.7 - (view) (download) (as text) (annotate) - [select for diffs]
Fri Aug 21 05:48:28 2015 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R0, rad5R1, rad5R2, rad5R3
Diff to previous 3.6
Fixed issue with undersampled histogram in phisto
Revision 3.6 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Jun 29 21:03:45 2015 UTC (9 years, 11 months ago) by greg
Changes since 3.5: +6 -6 lines
Diff to previous 3.5
Changed to raw data transfer for speed
Revision 3.5 - (view) (download) (as text) (annotate) - [select for diffs]
Mon Aug 25 04:50:32 2008 UTC (16 years, 9 months ago) by greg
CVS Tags: rad4R0, rad4R1, rad4R2, rad4R2P1, rad4R2P2
Changes since 3.4: +9 -9 lines
Diff to previous 3.4
Made temporary files safe from malicious attackers
Revision 3.4 - (view) (download) (as text) (annotate) - [select for diffs]
Wed Feb 16 05:40:11 2005 UTC (20 years, 3 months ago) by greg
Changes since 3.3: +2 -2 lines
Diff to previous 3.3
Revision 3.3 - (view) (download) (as text) (annotate) - [select for diffs]
Sat Feb 22 02:07:27 2003 UTC (22 years, 3 months ago) by greg
Changes since 3.2: +1 -1 lines
Diff to previous 3.2
Revision 3.2 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Mar 12 16:17:17 1998 UTC (27 years, 2 months ago) by gwlarson
Changes since 3.1: +2 -2 lines
Diff to previous 3.1
fixed extrema bug
Revision 3.1 - (view) (download) (as text) (annotate) - [select for diffs]
Thu Mar 12 15:46:53 1998 UTC (27 years, 2 months ago) by gwlarson
Links to HEAD: (view) (download) (as text) (annotate) Links to MAIN: (view) (download) (as text) (annotate)
