root/radiance/ray/src/px/phisteq.csh
Revision: 3.1
Committed: Sat Feb 22 02:07:27 2003 UTC (22 years, 2 months ago) by greg
Content type: application/x-csh
1 #!/bin/csh -f
2 # RCSid: $Id$
3 set Ldmin=1 # minimum display luminance
4 set Ldmax=100 # maximum display luminance
5 set nsteps=100 # number of steps in perceptual histogram
6 set cvratio=0.08 # fraction of pixels to ignore in envelope clipping
7 set td=/usr/tmp
8 set tf1=$td/hist$$
9 set tf1b=$td/hist$$.new
10 set tf2=$td/cumt$$
11 set tf3=$td/histeq$$.cal
12 set tf4=$td/cf$$.cal
13 set tf=($tf1 $tf1b $tf2 $tf3 $tf4)
14 if ( $#argv != 1 ) then
15 echo "Usage: $0 input.pic > output.pic"
16 exit 1
17 endif
18 set ifile=$1
19 set ibase=$ifile:t
20 if ( "$ibase" =~ *.pic ) set ibase=$ibase:r
21 set ibase=$ibase:t
22 onintr quit
23 cat > $tf3 << _EOF_
24 WE : 179; { Radiance white luminous efficacy }
25 Lmin : .0001; { minimum allowed luminance }
26 Ldmin : $Ldmin ; { minimum output luminance }
27 Ldmax : $Ldmax ; { maximum output luminance }
28 Stepsiz : 1/ $nsteps ; { brightness step size }
29 { Daly local amplitude nonlinearity formulae }
30 sq(x) : x*x;
31 c1 : 12.6;
32 b : .63;
33 Bl(L) : L / (L + (c1*L)^b);
34 Lb(B) : (c1^b*B/(1-B))^(1/(1-b));
35 BLw(Lw) : Bl(Ldmin) + (Bl(Ldmax)-Bl(Ldmin))*cf(Bl(Lw));
36 { first derivative functions }
37 Bl1(L) : (c1*L)^b*(1-b)/sq(L + (c1*L)^b);
38 Lb1(B) : c1^b/(1-b)/sq(1-B) * (c1^b*B/(1-B))^(b/(1-b));
39 { derivative clamping function }
40 clamp2(L, aLw) : Lb(aLw) / L / Lb1(aLw) / (Bl(Ldmax)-Bl(Ldmin)) / Bl1(L);
41 clamp(L) : clamp2(L, BLw(L));
42 { histogram equalization function }
43 lin = li(1);
44 Lw = WE/le(1) * lin;
45 Lout = Lb(BLw(Lw));
46 mult = if(Lw-Lmin, (Lout-Ldmin)/(Ldmax-Ldmin)/lin, 0) ;
47 ro = mult * ri(1);
48 go = mult * gi(1);
49 bo = mult * bi(1);
50 _EOF_
51 # Compute brightness histogram
52 pfilt -1 -p 1 -x 128 -y 128 $ifile | pvalue -o -b -d -h -H \
53 | rcalc -f $tf3 -e 'Lw=WE*$1;$1=if(Lw-Lmin,Bl(Lw),-1)' \
54 | histo 0 1 $nsteps | sed '/[ ]0$/d' > $tf1
55 # Clamp frequency distribution
56 set totcount=`sed 's/^.*[ ]//' $tf1 | total`
57 set tst=1
58 while ( $totcount > 0 )
59 sed 's/^.*[ ]//' $tf1 | total -1 -r \
60 | rcalc -e '$1=$1/'$totcount | lam $tf1 - \
61 | tabfunc -i 0 cf > $tf4
62 if ( $tst <= 0 ) break
63 rcalc -f $tf4 -f $tf3 -e "T:$totcount*Stepsiz" \
64 -e 'clfq=floor(T*clamp(Lb($1)))' \
65 -e '$1=$1;$2=if($2-clfq,clfq,$2)' $tf1 > $tf1b
66 set newtot=`sed 's/^.*[ ]//' $tf1b | total`
67 set tst=`ev "floor((1-$cvratio)*$totcount)-$newtot"`
68 mv -f $tf1b $tf1
69 set totcount=$newtot
70 end
71 if ( $totcount < 1 ) then
72 # Fits in display range nicely already -- just normalize
73 pfilt -1 -e `pextrem $ifile | rcalc -e 'cond=recno-1.5;$1=1/(.265*$3+.67*$4+.065*$5)'` $ifile
74 else
75 # Plot the mapping function if we are in debug mode
76 if ( $?DEBUG ) then
77 cat > ${ibase}_histo.plt << _EOF_
78 include=curve.plt
79 title="Brightness Frequency Distribution"
80 subtitle= $ibase
81 ymin=0
82 xlabel="Perceptual Brightness B(Lw)"
83 ylabel="Frequency Count"
84 Alabel="Histogram"
85 Alintype=0
86 Blabel="Envelope"
87 Bsymsize=0
88 Adata=
89 _EOF_
90 (cat $tf1; echo \;; echo Bdata=) >> ${ibase}_histo.plt
91 rcalc -f $tf4 -f $tf3 -e "T:$totcount*Stepsiz" \
92 -e '$1=$1;$2=T*clamp(Lb($1))' $tf1 \
93 >> ${ibase}_histo.plt
94 cat > ${ibase}_brmap.plt << _EOF_
95 include=line.plt
96 title="Brightness Mapping Function"
97 subtitle= $ibase
98 xlabel="World Luminance (log cd/m^2)"
99 ylabel="Display Luminance (cd/m^2)"
100 ymax= $Ldmax
101 Adata=
102 _EOF_
103 cnt 100 | rcalc -f $tf4 -f $tf3 -e '$1=lx;$2=Lb(BLw(10^lx))' \
104 -e Lmin:Lb\(`sed -n '1s/[ ].*$//p' $tf1`\) \
105 -e Lmax:Lb\(`sed -n '$s/[ ].*$//p' $tf1`\) \
106 -e 'lx=$1/99*(log10(Lmax)-log10(Lmin))+log10(Lmin)' \
107 >> ${ibase}_brmap.plt
108 if ( $?DISPLAY ) then
109 bgraph ${ibase}_histo.plt ${ibase}_brmap.plt | x11meta &
110 endif
111 endif
112 # Map our picture
113 pcomb -f $tf4 -f $tf3 $ifile
114 endif
115 quit:
116 rm -f $tf
