root/Development/ray/src/px/pfilt.h
Revision: 2.1
Committed: Mon Mar 29 00:34:23 2004 UTC (21 years, 9 months ago) by schorsch
CVS Tags: rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, rad4R1, rad4R0, rad3R9, rad3R8, rad3R7P2, rad3R7P1, rad3R6P1, rad3R6
Continued ANSIfication. Added headerfiles pfilt.h and clrtab.h.
# User Rev Content
1 schorsch 2.1 /* RCSid: $Id$ */
2     /*
3     * Header file for picture filtering
4     */
5     #ifndef _RAD_PFILT_H_
6     #define _RAD_PFILT_H_
7
8     #ifdef __cplusplus
9     extern "C" {
10     #endif
11
12
13     extern double CHECKRAD; /* radius over which gaussian is summed */
14     extern double rad; /* output pixel radius for filtering */
15     extern double thresh; /* maximum contribution for subpixel */
16     extern int nrows, ncols; /* number of rows and columns for output */
17     extern int xres, yres; /* x and y resolution */
18     extern int avghot; /* true means average in avgbrt spots */
19     extern double hotlvl; /* brightness considered "hot" */
20     extern int npts; /* # of points for stars */
21     extern double spread; /* spread for star points */
22     extern char *progname;
23     extern COLOR exposure; /* exposure for frame */
24
25     extern double x_c, y_r; /* conversion factors */
26
27     extern int xrad; /* x search radius */
28     extern int yrad; /* y search radius */
29     extern int xbrad; /* x box size */
30     extern int ybrad; /* y box size */
31
32     extern int barsize; /* size of input scan bar */
33     extern COLOR **scanin; /* input scan bar */
34     extern COLOR *scanout; /* output scan line */
35     extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */
36     extern float **greybar; /* grey-averaged input values */
37     extern int obarsize; /* size of output scan bar */
38     extern int orad; /* output window radius */
39
40     extern int wrapfilt; /* wrap filter horizontally? */
41
42     typedef double brightfunc_t(COLOR c);
43     extern brightfunc_t *ourbright; /* brightness calculation function */
44
45     /* defined in pf2.c */
46     extern void pass1init(void); /* prepare for first pass */
47     extern void pass1default(void); /* for single pass */
48     extern void pass1scan(COLOR *scan, int y); /* process first pass scanline */
49     extern void pass2init(void); /* prepare for final pass */
50     extern void pass2scan(COLOR *scan, int y); /* process final pass scanline */
51
52     /* defined in pf3.c */
53     extern void initmask(void); /* initialize gaussian lookup table */
54     extern void dobox(COLOR csum, int xcent, int ycent,
55     int c, int r); /* simple box filter */
56     extern void dogauss(COLOR csum, int xcent, int ycent,
57     int c, int r); /* gaussian filter */
58     extern void dothresh(int xcent, int ycent,
59     int ccent, int rcent); /* gaussian threshold filter */
60
61     #ifdef __cplusplus
62     }
63     #endif
64     #endif /* _RAD_PFILT_H_ */
65
