--- ray/src/px/pfilt.h 2004/03/29 00:34:23 2.1 +++ ray/src/px/pfilt.h 2023/12/08 17:56:26 2.3 @@ -1,15 +1,17 @@ -/* RCSid: $Id: pfilt.h,v 2.1 2004/03/29 00:34:23 schorsch Exp $ */ +/* RCSid: $Id: pfilt.h,v 2.3 2023/12/08 17:56:26 greg Exp $ */ /* * Header file for picture filtering */ #ifndef _RAD_PFILT_H_ #define _RAD_PFILT_H_ +#include "standard.h" +#include "color.h" + #ifdef __cplusplus extern "C" { #endif - extern double CHECKRAD; /* radius over which gaussian is summed */ extern double rad; /* output pixel radius for filtering */ extern double thresh; /* maximum contribution for subpixel */ @@ -30,30 +32,30 @@ extern int xbrad; /* x box size */ extern int ybrad; /* y box size */ extern int barsize; /* size of input scan bar */ -extern COLOR **scanin; /* input scan bar */ -extern COLOR *scanout; /* output scan line */ -extern COLOR **scoutbar; /* output scan bar (if thresh > 0) */ +extern COLORV **scanin; /* input scan bar */ +extern COLORV *scanout; /* output scan line */ +extern COLORV **scoutbar; /* output scan bar (if thresh > 0) */ extern float **greybar; /* grey-averaged input values */ extern int obarsize; /* size of output scan bar */ extern int orad; /* output window radius */ extern int wrapfilt; /* wrap filter horizontally? */ -typedef double brightfunc_t(COLOR c); +typedef double brightfunc_t(SCOLOR c); extern brightfunc_t *ourbright; /* brightness calculation function */ /* defined in pf2.c */ extern void pass1init(void); /* prepare for first pass */ extern void pass1default(void); /* for single pass */ -extern void pass1scan(COLOR *scan, int y); /* process first pass scanline */ +extern void pass1scan(COLORV *scan, int y); /* process first pass scanline */ extern void pass2init(void); /* prepare for final pass */ -extern void pass2scan(COLOR *scan, int y); /* process final pass scanline */ +extern void pass2scan(COLORV *scan, int y); /* process final pass scanline */ /* defined in pf3.c */ extern void initmask(void); /* initialize gaussian lookup table */ -extern void dobox(COLOR csum, int xcent, int ycent, +extern void dobox(SCOLOR csum, int xcent, int ycent, int c, int r); /* simple box filter */ -extern void dogauss(COLOR csum, int xcent, int ycent, +extern void dogauss(SCOLOR csum, int xcent, int ycent, int c, int r); /* gaussian filter */ extern void dothresh(int xcent, int ycent, int ccent, int rcent); /* gaussian threshold filter */ @@ -62,4 +64,3 @@ extern void dothresh(int xcent, int ycent, } #endif #endif /* _RAD_PFILT_H_ */ -
