root/radiance/ray/src/px/pfilt.c
Revision: 2.5
Committed: Fri Oct 2 16:24:06 1992 UTC (31 years, 8 months ago) by greg
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #ifdef MSDOS
16 #include <fcntl.h>
17 #endif
18
19 #include <math.h>
20
21 #include <signal.h>
22
23 #include "color.h"
24
25 #include "resolu.h"
26
27 #include "paths.h"
28
29 extern char *malloc();
30 extern float *matchlamp();
31
32 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
33
34 #define CHECKRAD 1.5 /* radius to check for filtering */
35
36 COLOR exposure = WHTCOLOR; /* exposure for the frame */
37
38 double rad = 0.0; /* output pixel radius for filtering */
39
40 int nrows = 0; /* number of rows for output */
41 int ncols = 0; /* number of columns for output */
42
43 double x_c = 1.0; /* ratio of output x size to input */
44 double y_r = 1.0; /* ratio of output y size to input */
45
46 int singlepass = 0; /* true means skip first pass */
47
48 int avghot = 0; /* true means average in bright spots */
49
50 double hotlvl = 1000.0; /* level considered "hot" */
51
52 int npts = 0; /* (half) number of points for stars */
53
54 double spread = 1e-4; /* spread for star points */
55
56 char *tfname = NULL;
57
58 char *lampdat = "lamp.tab"; /* lamp data file */
59
60 int order; /* scanline ordering of input */
61 int xres, yres; /* resolution of input */
62 double inpaspect = 1.0; /* pixel aspect ratio of input */
63 int correctaspect = 0; /* aspect ratio correction? */
64
65 int wrongformat = 0;
66
67 int xrad; /* x window size */
68 int yrad; /* y window size */
69
70 int barsize; /* size of input scan bar */
71 COLOR **scanin; /* input scan bar */
72 COLOR *scanout; /* output scan line */
73
74 char *progname;
75
76
77 main(argc, argv)
78 int argc;
79 char **argv;
80 {
81 extern long ftell();
82 extern int quit(), headline();
83 FILE *fin;
84 float *lampcolor;
85 char *lamptype = NULL;
86 long fpos;
87 double outaspect = 0.0;
88 double d;
89 int i, j;
90 #ifdef MSDOS
91 extern int _fmode;
92 _fmode = O_BINARY;
93 setmode(fileno(stdin), O_BINARY);
94 setmode(fileno(stdout), O_BINARY);
95 #endif
96 if (signal(SIGINT, quit) == SIG_IGN)
97 signal(SIGINT, SIG_IGN);
98 if (signal(SIGHUP, quit) == SIG_IGN)
99 signal(SIGINT, SIG_IGN);
100 signal(SIGTERM, quit);
101 signal(SIGPIPE, quit);
102 #ifdef SIGXCPU
103 signal(SIGXCPU, quit);
104 signal(SIGXFSZ, quit);
105 #endif
106
107 progname = argv[0];
108
109 for (i = 1; i < argc; i++)
110 if (argv[i][0] == '-')
111 switch (argv[i][1]) {
112 case 'x':
113 i++;
114 if (argv[i][0] == '/') {
115 x_c = 1.0/atof(argv[i]+1);
116 ncols = 0;
117 } else
118 ncols = atoi(argv[i]);
119 break;
120 case 'y':
121 i++;
122 if (argv[i][0] == '/') {
123 y_r = 1.0/atof(argv[i]+1);
124 nrows = 0;
125 } else
126 nrows = atoi(argv[i]);
127 break;
128 case 'c':
129 correctaspect = !correctaspect;
130 break;
131 case 'p':
132 i++;
133 outaspect = atof(argv[i]);
134 break;
135 case 'e':
136 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
137 d = pow(2.0, atof(argv[i+1]));
138 else
139 d = atof(argv[i+1]);
140 if (d < 1e-20 || d > 1e20) {
141 fprintf(stderr,
142 "%s: exposure out of range\n",
143 argv[0]);
144 exit(1);
145 }
146 switch (argv[i][2]) {
147 case '\0':
148 scalecolor(exposure, d);
149 break;
150 case 'r':
151 colval(exposure,RED) *= d;
152 break;
153 case 'g':
154 colval(exposure,GRN) *= d;
155 break;
156 case 'b':
157 colval(exposure,BLU) *= d;
158 break;
159 default:
160 goto badopt;
161 }
162 i++;
163 break;
164 case 'f':
165 lampdat = argv[++i];
166 break;
167 case 't':
168 lamptype = argv[++i];
169 break;
170 case '1':
171 singlepass = 1;
172 break;
173 case '2':
174 singlepass = 0;
175 break;
176 case 'n':
177 npts = atoi(argv[++i]) / 2;
178 break;
179 case 's':
180 spread = atof(argv[++i]);
181 break;
182 case 'a':
183 avghot = !avghot;
184 break;
185 case 'h':
186 hotlvl = atof(argv[++i]);
187 break;
188 case 'r':
189 rad = atof(argv[++i]);
190 break;
191 case 'b':
192 rad = 0.0;
193 break;
194 default:;
195 badopt:
196 fprintf(stderr, "%s: unknown option: %s\n",
197 progname, argv[i]);
198 quit(1);
199 break;
200 }
201 else
202 break;
203 /* get lamp data (if necessary) */
204 if (lamptype != NULL) {
205 if (loadlamps(lampdat) < 0)
206 quit(1);
207 if ((lampcolor = matchlamp(lamptype)) == NULL) {
208 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
209 quit(1);
210 }
211 for (i = 0; i < 3; i++)
212 if (lampcolor[i] > 1e-4)
213 colval(exposure,i) /= lampcolor[i];
214 freelamps();
215 }
216 /* open input file */
217 if (i == argc) {
218 if (singlepass)
219 fin = stdin;
220 else {
221 tfname = mktemp(TEMPLATE);
222 if ((fin = fopen(tfname, "w+")) == NULL) {
223 fprintf(stderr, "%s: can't create ", progname);
224 fprintf(stderr, "temp file \"%s\"\n", tfname);
225 quit(1);
226 }
227 copyfile(stdin, fin);
228 if (fseek(fin, 0L, 0) == -1) {
229 fprintf(stderr, "%s: seek fail\n", progname);
230 quit(1);
231 }
232 }
233 } else if (i == argc-1) {
234 if ((fin = fopen(argv[i], "r")) == NULL) {
235 fprintf(stderr, "%s: can't open file \"%s\"\n",
236 progname, argv[i]);
237 quit(1);
238 }
239 } else {
240 fprintf(stderr, "%s: bad # file arguments\n", progname);
241 quit(1);
242 }
243 /* get header */
244 getheader(fin, headline, NULL);
245 if (wrongformat) {
246 fprintf(stderr, "%s: input must be a Radiance picture\n",
247 progname);
248 quit(1);
249 }
250 /* add new header info. */
251 printargs(i, argv, stdout);
252 /* get picture size */
253 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
254 fprintf(stderr, "%s: bad picture size\n", progname);
255 quit(1);
256 }
257 if (!(order & YMAJOR))
258 inpaspect = 1.0/inpaspect;
259 /* compute output resolution */
260 if (ncols <= 0)
261 ncols = x_c*xres + .5;
262 if (nrows <= 0)
263 nrows = y_r*yres + .5;
264 if (outaspect > .01) {
265 d = inpaspect * yres/xres / outaspect;
266 if (d * ncols > nrows)
267 ncols = nrows / d;
268 else
269 nrows = ncols * d;
270 }
271 x_c = (double)ncols/xres;
272 y_r = (double)nrows/yres;
273
274 if (singlepass) { /* skip exposure, etc. */
275 pass1default();
276 pass2(fin);
277 quit(0);
278 }
279
280 fpos = ftell(fin); /* save input file position */
281
282 pass1(fin);
283
284 if (fseek(fin, fpos, 0) == -1) {
285 fprintf(stderr, "%s: seek fail\n", progname);
286 quit(1);
287 }
288 pass2(fin);
289
290 quit(0);
291 }
292
293
294 headline(s) /* process line from header */
295 char *s;
296 {
297 char fmt[32];
298
299 fputs(s, stdout); /* copy to output */
300 if (isaspect(s)) /* get aspect ratio */
301 inpaspect *= aspectval(s);
302 else if (isformat(s)) {
303 formatval(fmt, s);
304 wrongformat = strcmp(fmt, COLRFMT);
305 }
306 }
307
308
309 copyfile(in, out) /* copy a file */
310 register FILE *in, *out;
311 {
312 register int c;
313
314 while ((c = getc(in)) != EOF)
315 putc(c, out);
316
317 if (ferror(out)) {
318 fprintf(stderr, "%s: write error in copyfile\n", progname);
319 quit(1);
320 }
321 }
322
323
324 pass1(in) /* first pass of picture file */
325 FILE *in;
326 {
327 int i;
328 COLOR *scan;
329
330 pass1init();
331
332 scan = (COLOR *)malloc(xres*sizeof(COLOR));
333 if (scan == NULL) {
334 fprintf(stderr, "%s: out of memory\n", progname);
335 quit(1);
336 }
337 for (i = 0; i < yres; i++) {
338 if (freadscan(scan, xres, in) < 0) {
339 nrows = nrows * i / yres; /* adjust frame */
340 if (nrows <= 0) {
341 fprintf(stderr, "%s: empty frame\n", progname);
342 quit(1);
343 }
344 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
345 progname, 100*i/yres);
346 yres = i;
347 y_r = (double)nrows/yres;
348 break;
349 }
350 pass1scan(scan, i);
351 }
352 free((char *)scan);
353 }
354
355
356 pass2(in) /* last pass on file, write to stdout */
357 FILE *in;
358 {
359 int yread;
360 int ycent, xcent;
361 int r, c;
362
363 pass2init();
364 scan2init();
365 yread = 0;
366 for (r = 0; r < nrows; r++) {
367 ycent = (long)r*yres/nrows;
368 while (yread <= ycent+yrad) {
369 if (yread < yres) {
370 if (freadscan(scanin[yread%barsize],
371 xres, in) < 0) {
372 fprintf(stderr,
373 "%s: bad read (y=%d)\n",
374 progname, yres-1-yread);
375 quit(1);
376 }
377 pass2scan(scanin[yread%barsize], yread);
378 }
379 yread++;
380 }
381 for (c = 0; c < ncols; c++) {
382 xcent = (long)c*xres/ncols;
383 if (rad <= 0.0)
384 dobox(scanout[c], xcent, ycent, c, r);
385 else
386 dogauss(scanout[c], xcent, ycent, c, r);
387 }
388 if (fwritescan(scanout, ncols, stdout) < 0) {
389 fprintf(stderr, "%s: write error in pass2\n", progname);
390 quit(1);
391 }
392 }
393 /* skip leftovers */
394 while (yread < yres) {
395 if (freadscan(scanin[0], xres, in) < 0)
396 break;
397 yread++;
398 }
399 }
400
401
402 scan2init() /* prepare scanline arrays */
403 {
404 COLOR ctmp;
405 double d;
406 register int i;
407
408 if (rad <= 0.0) {
409 xrad = xres/ncols/2 + 1;
410 yrad = yres/nrows/2 + 1;
411 } else {
412 if (nrows >= yres && ncols >= xres)
413 rad *= (y_r + x_c)/2.0;
414
415 xrad = CHECKRAD*rad/x_c + 1;
416 yrad = CHECKRAD*rad/y_r + 1;
417
418 initmask(); /* initialize filter table */
419 }
420 barsize = 2*yrad + 1;
421 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
422 for (i = 0; i < barsize; i++) {
423 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
424 if (scanin[i] == NULL) {
425 fprintf(stderr, "%s: out of memory\n", progname);
426 quit(1);
427 }
428 }
429 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
430 if (scanout == NULL) {
431 fprintf(stderr, "%s: out of memory\n", progname);
432 quit(1);
433 }
434 /* record pixel aspect ratio */
435 if (!correctaspect) {
436 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
437 if (!FEQ(d,1.0))
438 fputaspect(d, stdout);
439 }
440 /* record exposure */
441 d = bright(exposure);
442 if (!FEQ(d,1.0))
443 fputexpos(d, stdout);
444 /* record color correction */
445 copycolor(ctmp, exposure);
446 scalecolor(ctmp, 1.0/d);
447 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
448 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
449 fputcolcor(ctmp, stdout);
450 printf("\n");
451 /* write out resolution */
452 fputresolu(order, ncols, nrows, stdout);
453 }
454
455
456 quit(code) /* remove temporary file and exit */
457 int code;
458 {
459 if (tfname != NULL)
460 unlink(tfname);
461 exit(code);
462 }
