1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id: pfilt.c,v 2.34 2019/12/28 18:05:14 greg Exp $"; |
3 |
#endif |
4 |
5 |
* pfilt.c - program to post-process picture file. |
6 |
7 |
* 9/26/85 |
8 |
* 6/23/93 Added additional buffers for value spreading |
9 |
10 |
11 |
#include "copyright.h" |
12 |
13 |
#include <signal.h> |
14 |
#include "pfilt.h" |
15 |
#include "platform.h" |
16 |
#include "paths.h" |
17 |
#include "view.h" |
18 |
19 |
#define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b)) |
20 |
21 |
double CHECKRAD = 2.0; /* radius to check for filtering */ |
22 |
23 |
#define THRESHRAD 5.0 /* maximum sample spread in output */ |
24 |
25 |
COLOR exposure = WHTCOLOR; /* exposure for the frame */ |
26 |
27 |
double rad = 0.0; /* output pixel radius for filtering */ |
28 |
29 |
double thresh = 0.0; /* maximum contribution for subpixel */ |
30 |
31 |
int nrows = 0; /* number of rows for output */ |
32 |
int ncols = 0; /* number of columns for output */ |
33 |
34 |
double x_c = 1.0; /* ratio of output x size to input */ |
35 |
double y_r = 1.0; /* ratio of output y size to input */ |
36 |
37 |
int singlepass = 0; /* true means skip first pass */ |
38 |
39 |
int avghot = 0; /* true means average in bright spots */ |
40 |
41 |
double hotlvl = 100.0; /* level considered "hot" */ |
42 |
43 |
int npts = 0; /* (half) number of points for stars */ |
44 |
45 |
double spread = 1e-4; /* spread for star points */ |
46 |
47 |
char *tfname = NULL; |
48 |
49 |
char template[] = TEMPLATE; |
50 |
51 |
char *lampdat = "lamp.tab"; /* lamp data file */ |
52 |
53 |
int order; /* scanline ordering of input */ |
54 |
int xres, yres; /* resolution of input */ |
55 |
double inpaspect = 1.0; /* pixel aspect ratio of input */ |
56 |
int correctaspect = 0; /* aspect ratio correction? */ |
57 |
58 |
int wrongformat = 0; |
59 |
60 |
VIEW ourview = STDVIEW; |
61 |
int gotview = 0; |
62 |
int wrapfilt = 0; /* wrap filter horizontally? */ |
63 |
64 |
int estatus = 0; /* exit status (for non-fatal errors) */ |
65 |
66 |
int xrad; /* x search radius */ |
67 |
int yrad; /* y search radius */ |
68 |
int xbrad; /* x box size */ |
69 |
int ybrad; /* y box size */ |
70 |
71 |
int barsize; /* size of input scan bar */ |
72 |
COLOR **scanin; /* input scan bar */ |
73 |
COLOR *scanout; /* output scan line */ |
74 |
COLOR **scoutbar; /* output scan bar (if thresh > 0) */ |
75 |
float **greybar; /* grey-averaged input values */ |
76 |
int obarsize = 0; /* size of output scan bar */ |
77 |
int orad = 0; /* output window radius */ |
78 |
79 |
char *progname; |
80 |
81 |
static gethfunc headline; |
82 |
static brightfunc_t rgb_bright; |
83 |
static brightfunc_t xyz_bright; |
84 |
static void copyfile(FILE *in, FILE *out); |
85 |
static void pass1(FILE *in); |
86 |
static void pass2(FILE *in); |
87 |
static void scan2init(void); |
88 |
static void scan2sync(int r); |
89 |
static void scan2flush(void); |
90 |
91 |
92 |
int |
93 |
main( |
94 |
int argc, |
95 |
char **argv |
96 |
97 |
98 |
FILE *fin; |
99 |
float *lampcolor; |
100 |
char *lamptype = NULL; |
101 |
long fpos; |
102 |
double outaspect = 0.0; |
103 |
double d; |
104 |
int i, j; |
105 |
SET_DEFAULT_BINARY(); |
106 |
SET_FILE_BINARY(stdin); |
107 |
SET_FILE_BINARY(stdout); |
108 |
if (signal(SIGINT, quit) == SIG_IGN) |
109 |
signal(SIGINT, SIG_IGN); |
110 |
#ifdef SIGHUP |
111 |
if (signal(SIGHUP, quit) == SIG_IGN) |
112 |
signal(SIGHUP, SIG_IGN); |
113 |
#endif |
114 |
signal(SIGTERM, quit); |
115 |
#ifdef SIGPIPE |
116 |
signal(SIGPIPE, quit); |
117 |
#endif |
118 |
#ifdef SIGXCPU |
119 |
signal(SIGXCPU, quit); |
120 |
signal(SIGXFSZ, quit); |
121 |
#endif |
122 |
123 |
progname = argv[0] = fixargv0(argv[0]); |
124 |
125 |
for (i = 1; i < argc; i++) |
126 |
if (argv[i][0] == '-') |
127 |
switch (argv[i][1]) { |
128 |
case 'x': |
129 |
i++; |
130 |
if (argv[i][0] == '/') { |
131 |
x_c = 1.0/atof(argv[i]+1); |
132 |
ncols = 0; |
133 |
} else |
134 |
ncols = atoi(argv[i]); |
135 |
break; |
136 |
case 'y': |
137 |
i++; |
138 |
139 |
y_r = 1.0/atof(argv[i]+1); |
140 |
nrows = 0; |
141 |
} else |
142 |
nrows = atoi(argv[i]); |
143 |
break; |
144 |
case 'c': |
145 |
correctaspect = !correctaspect; |
146 |
break; |
147 |
case 'p': |
148 |
i++; |
149 |
outaspect = atof(argv[i]); |
150 |
break; |
151 |
case 'e': |
152 |
if (argv[i+1][0] == '+' || argv[i+1][0] == '-') |
153 |
d = pow(2.0, atof(argv[i+1])); |
154 |
else |
155 |
d = atof(argv[i+1]); |
156 |
if (d < 1e-20 || d > 1e20) { |
157 |
fprintf(stderr, |
158 |
"%s: exposure out of range\n", |
159 |
argv[0]); |
160 |
quit(1); |
161 |
162 |
switch (argv[i][2]) { |
163 |
case '\0': |
164 |
scalecolor(exposure, d); |
165 |
break; |
166 |
case 'r': |
167 |
colval(exposure,RED) *= d; |
168 |
break; |
169 |
case 'g': |
170 |
colval(exposure,GRN) *= d; |
171 |
break; |
172 |
case 'b': |
173 |
colval(exposure,BLU) *= d; |
174 |
break; |
175 |
default: |
176 |
goto badopt; |
177 |
178 |
i++; |
179 |
break; |
180 |
case 'f': |
181 |
lampdat = argv[++i]; |
182 |
break; |
183 |
case 't': |
184 |
lamptype = argv[++i]; |
185 |
break; |
186 |
case '1': |
187 |
singlepass = 1; |
188 |
break; |
189 |
case '2': |
190 |
singlepass = 0; |
191 |
break; |
192 |
case 'n': |
193 |
npts = atoi(argv[++i]) / 2; |
194 |
break; |
195 |
case 's': |
196 |
spread = atof(argv[++i]); |
197 |
break; |
198 |
case 'a': |
199 |
avghot = !avghot; |
200 |
break; |
201 |
case 'h': |
202 |
hotlvl = atof(argv[++i]); |
203 |
break; |
204 |
case 'r': |
205 |
rad = atof(argv[++i]); |
206 |
break; |
207 |
case 'm': |
208 |
thresh = atof(argv[++i]); |
209 |
if (rad <= FTINY) |
210 |
rad = 0.6; |
211 |
break; |
212 |
case 'b': |
213 |
rad = thresh = 0.0; |
214 |
break; |
215 |
default:; |
216 |
badopt: |
217 |
fprintf(stderr, "%s: unknown option: %s\n", |
218 |
progname, argv[i]); |
219 |
quit(1); |
220 |
break; |
221 |
222 |
else |
223 |
break; |
224 |
/* get lamp data (if necessary) */ |
225 |
if (lamptype != NULL) { |
226 |
if (loadlamps(lampdat) < 0) |
227 |
quit(1); |
228 |
if ((lampcolor = matchlamp(lamptype)) == NULL) { |
229 |
fprintf(stderr, "%s: unknown lamp type\n", lamptype); |
230 |
quit(1); |
231 |
232 |
for (j = 0; j < 3; j++) |
233 |
if (lampcolor[j] > 1e-4) |
234 |
colval(exposure,j) /= lampcolor[j]; |
235 |
freelamps(); |
236 |
237 |
/* open input file */ |
238 |
if (i == argc) { |
239 |
if (singlepass) |
240 |
fin = stdin; |
241 |
else { |
242 |
tfname = mktemp(template); |
243 |
if ((fin = fopen(tfname, "w+")) == NULL) { |
244 |
fprintf(stderr, "%s: can't create ", progname); |
245 |
fprintf(stderr, "temp file \"%s\"\n", tfname); |
246 |
quit(1); |
247 |
248 |
copyfile(stdin, fin); |
249 |
if (fseek(fin, 0L, 0) == -1) { |
250 |
fprintf(stderr, "%s: seek fail\n", progname); |
251 |
quit(1); |
252 |
253 |
254 |
} else if (i == argc-1) { |
255 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
256 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
257 |
258 |
quit(1); |
259 |
260 |
} else { |
261 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
262 |
quit(1); |
263 |
264 |
/* get header */ |
265 |
getheader(fin, headline, NULL); |
266 |
if (wrongformat) { |
267 |
fprintf(stderr, "%s: input must be a Radiance picture\n", |
268 |
progname); |
269 |
quit(1); |
270 |
271 |
/* add new header info. */ |
272 |
printargs(i, argv, stdout); |
273 |
/* get picture size */ |
274 |
if ((order = fgetresolu(&xres, &yres, fin)) < 0) { |
275 |
fprintf(stderr, "%s: bad picture size\n", progname); |
276 |
quit(1); |
277 |
278 |
if (!(order & YMAJOR)) |
279 |
inpaspect = 1.0/inpaspect; |
280 |
/* wrap around for cylindrical view? */ |
281 |
wrapfilt = gotview && ourview.type == VT_CYL && |
282 |
ourview.horiz >= 360.-FTINY && order & YMAJOR; |
283 |
/* compute output resolution */ |
284 |
if (ncols <= 0) |
285 |
ncols = x_c*xres + .5; |
286 |
if (nrows <= 0) |
287 |
nrows = y_r*yres + .5; |
288 |
if (outaspect > .01) { |
289 |
d = inpaspect * yres/xres / outaspect; |
290 |
if (d * ncols > nrows) |
291 |
ncols = nrows / d; |
292 |
else |
293 |
nrows = ncols * d; |
294 |
295 |
x_c = (double)ncols/xres; |
296 |
y_r = (double)nrows/yres; |
297 |
298 |
if (singlepass) { /* skip exposure, etc. */ |
299 |
pass1default(); |
300 |
pass2(fin); |
301 |
quit(0); |
302 |
303 |
304 |
fpos = ftell(fin); /* save input file position */ |
305 |
306 |
pass1(fin); |
307 |
308 |
if (fseek(fin, fpos, 0) == -1) { |
309 |
310 |
quit(1); |
311 |
312 |
pass2(fin); |
313 |
314 |
quit(estatus); |
315 |
return estatus; /* pro forma return */ |
316 |
317 |
318 |
319 |
static double |
320 |
rgb_bright( |
321 |
COLOR clr |
322 |
323 |
324 |
return(bright(clr)); |
325 |
326 |
327 |
328 |
static double |
329 |
xyz_bright( |
330 |
COLOR clr |
331 |
332 |
333 |
return(clr[CIEY]); |
334 |
335 |
336 |
337 |
brightfunc_t *ourbright = rgb_bright; |
338 |
339 |
static int |
340 |
headline( /* process line from header */ |
341 |
char *s, |
342 |
void *p |
343 |
344 |
345 |
char fmt[MAXFMTLEN]; |
346 |
347 |
fputs(s, stdout); /* copy to output */ |
348 |
if (isaspect(s)) /* get aspect ratio */ |
349 |
inpaspect *= aspectval(s); |
350 |
else if (isexpos(s)) /* get exposure */ |
351 |
hotlvl *= exposval(s); |
352 |
else if (formatval(fmt, s)) { /* get format */ |
353 |
wrongformat = 0; |
354 |
if (!strcmp(COLRFMT, fmt)) |
355 |
356 |
else if (!strcmp(CIEFMT, fmt)) |
357 |
ourbright = xyz_bright; |
358 |
else |
359 |
wrongformat = !globmatch(PICFMT, fmt); |
360 |
} else if (isview(s) && sscanview(&ourview, s) > 0) |
361 |
gotview++; |
362 |
return(0); |
363 |
364 |
365 |
366 |
static void |
367 |
copyfile( /* copy a file */ |
368 |
FILE *in, |
369 |
FILE *out |
370 |
371 |
372 |
int c; |
373 |
374 |
while ((c = getc(in)) != EOF) |
375 |
putc(c, out); |
376 |
377 |
if (ferror(out)) { |
378 |
fprintf(stderr, "%s: write error in copyfile\n", progname); |
379 |
quit(1); |
380 |
381 |
382 |
383 |
384 |
static void |
385 |
pass1( /* first pass of picture file */ |
386 |
FILE *in |
387 |
388 |
389 |
int i; |
390 |
COLOR *scan; |
391 |
392 |
pass1init(); |
393 |
394 |
scan = (COLOR *)malloc(xres*sizeof(COLOR)); |
395 |
if (scan == NULL) { |
396 |
fprintf(stderr, "%s: out of memory\n", progname); |
397 |
quit(1); |
398 |
399 |
for (i = 0; i < yres; i++) { |
400 |
if (freadscan(scan, xres, in) < 0) { |
401 |
nrows = (long)nrows * i / yres; /* adjust frame */ |
402 |
if (nrows <= 0) { |
403 |
fprintf(stderr, "%s: empty frame\n", progname); |
404 |
quit(1); |
405 |
406 |
fprintf(stderr, "%s: warning - partial frame (%d%%)\n", |
407 |
progname, (int)(100L*i/yres)); |
408 |
yres = i; |
409 |
410 |
estatus++; |
411 |
break; |
412 |
413 |
pass1scan(scan, i); |
414 |
415 |
free((void *)scan); |
416 |
417 |
418 |
419 |
static void |
420 |
pass2( /* last pass on file, write to stdout */ |
421 |
FILE *in |
422 |
423 |
424 |
int yread; |
425 |
int ycent, xcent; |
426 |
int r, c; |
427 |
428 |
pass2init(); |
429 |
scan2init(); |
430 |
yread = 0; |
431 |
for (r = 0; r < nrows; r++) { |
432 |
ycent = (r+.5)*yres/nrows; |
433 |
while (yread <= ycent+yrad) { |
434 |
if (yread < yres) { |
435 |
if (freadscan(scanin[yread%barsize], |
436 |
xres, in) < 0) { |
437 |
fprintf(stderr, |
438 |
"%s: truncated input (y=%d)\n", |
439 |
progname, yres-1-yread); |
440 |
quit(1); |
441 |
442 |
pass2scan(scanin[yread%barsize], yread); |
443 |
444 |
yread++; |
445 |
446 |
if (obarsize > 0) |
447 |
scan2sync(r); |
448 |
for (c = 0; c < ncols; c++) { |
449 |
xcent = (c+.5)*xres/ncols; |
450 |
if (thresh > FTINY) |
451 |
dothresh(xcent, ycent, c, r); |
452 |
else if (rad > FTINY) |
453 |
dogauss(scanout[c], xcent, ycent, c, r); |
454 |
else |
455 |
dobox(scanout[c], xcent, ycent, c, r); |
456 |
457 |
if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) { |
458 |
fprintf(stderr, "%s: write error in pass2\n", progname); |
459 |
quit(1); |
460 |
461 |
462 |
/* skip leftover input */ |
463 |
while (yread < yres) { |
464 |
if (freadscan(scanin[0], xres, in) < 0) |
465 |
break; |
466 |
yread++; |
467 |
468 |
scan2flush(); /* flush output */ |
469 |
470 |
471 |
472 |
static void |
473 |
scan2init(void) /* prepare scanline arrays */ |
474 |
475 |
COLOR ctmp; |
476 |
double d; |
477 |
int i; |
478 |
479 |
xbrad = xres/ncols/2 + 1; |
480 |
ybrad = yres/nrows/2 + 1; |
481 |
if (rad > FTINY) { |
482 |
if (nrows >= yres && ncols >= xres) |
483 |
rad *= (y_r + x_c)/2.0; |
484 |
485 |
if (thresh > FTINY) { |
486 |
orad = CHECKRAD*THRESHRAD*rad + 1; |
487 |
xrad = orad/x_c + xbrad; |
488 |
yrad = orad/y_r + ybrad; |
489 |
obarsize = 2*orad + 1; |
490 |
} else { |
491 |
xrad = CHECKRAD*rad/x_c + 1; |
492 |
yrad = CHECKRAD*rad/y_r + 1; |
493 |
494 |
initmask(); /* initialize filter table */ |
495 |
} else { |
496 |
xrad = xbrad; |
497 |
yrad = ybrad; |
498 |
499 |
barsize = 2*yrad + 1; |
500 |
scanin = (COLOR **)malloc(barsize*sizeof(COLOR *)); |
501 |
if (scanin == NULL) |
502 |
goto memerr; |
503 |
for (i = 0; i < barsize; i++) { |
504 |
scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR)); |
505 |
if (scanin[i] == NULL) |
506 |
goto memerr; |
507 |
508 |
if (obarsize > 0) { |
509 |
scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *)); |
510 |
greybar = (float **)malloc(obarsize*sizeof(float *)); |
511 |
if ((scoutbar == NULL) | (greybar == NULL)) |
512 |
goto memerr; |
513 |
for (i = 0; i < obarsize; i++) { |
514 |
scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR)); |
515 |
greybar[i] = (float *)malloc(ncols*sizeof(float)); |
516 |
if ((scoutbar[i] == NULL) | (greybar[i] == NULL)) |
517 |
goto memerr; |
518 |
519 |
} else { |
520 |
scanout = (COLOR *)malloc(ncols*sizeof(COLOR)); |
521 |
if (scanout == NULL) |
522 |
goto memerr; |
523 |
524 |
/* record pixel aspect ratio */ |
525 |
if (!correctaspect) { |
526 |
d = order & YMAJOR ? x_c/y_r : y_r/x_c ; |
527 |
if (!FEQ(d,1.0)) |
528 |
fputaspect(d, stdout); |
529 |
530 |
/* record exposure */ |
531 |
d = (*ourbright)(exposure); |
532 |
if (!FEQ(d,1.0)) |
533 |
fputexpos(d, stdout); |
534 |
/* record color correction */ |
535 |
copycolor(ctmp, exposure); |
536 |
scalecolor(ctmp, 1.0/d); |
537 |
if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) || |
538 |
!FEQ(colval(ctmp,GRN),colval(ctmp,BLU))) |
539 |
fputcolcor(ctmp, stdout); |
540 |
printf("\n"); |
541 |
/* write out resolution */ |
542 |
fputresolu(order, ncols, nrows, stdout); |
543 |
return; |
544 |
memerr: |
545 |
546 |
quit(1); |
547 |
548 |
549 |
550 |
static void |
551 |
scan2sync( /* synchronize grey averages and output scan */ |
552 |
int r |
553 |
554 |
555 |
static int nextrow = 0; |
556 |
COLOR ctmp; |
557 |
int ybot; |
558 |
int c; |
559 |
/* average input scanlines */ |
560 |
while (nextrow <= r+orad && nextrow < nrows) { |
561 |
ybot = (nextrow+.5)*yres/nrows; |
562 |
563 |
dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow); |
564 |
greybar[nextrow%obarsize][c] = (*ourbright)(ctmp); |
565 |
566 |
/* and zero output scanline */ |
567 |
memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR)); |
568 |
nextrow++; |
569 |
570 |
/* point to top scanline for output */ |
571 |
if (r-orad >= 0) |
572 |
scanout = scoutbar[(r-orad)%obarsize]; |
573 |
else |
574 |
scanout = NULL; |
575 |
576 |
577 |
578 |
static void |
579 |
scan2flush(void) /* flush output buffer */ |
580 |
581 |
int r; |
582 |
583 |
for (r = nrows-orad; r < nrows; r++) |
584 |
if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0) |
585 |
break; |
586 |
if (fflush(stdout) < 0) { |
587 |
fprintf(stderr, "%s: write error at end of pass2\n", progname); |
588 |
quit(1); |
589 |
590 |
591 |
592 |
593 |
void |
594 |
quit(code) /* remove temporary file and exit */ |
595 |
int code; |
596 |
597 |
if (tfname != NULL) |
598 |
unlink(tfname); |
599 |
exit(code); |
600 |
