| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: pfilt.c,v 2.25 2003/06/30 14:59:12 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* pfilt.c - program to post-process picture file.
| 6 |
| 7 |
* 9/26/85
| 8 |
* 6/23/93 Added additional buffers for value spreading
| 9 |
| 10 |
| 11 |
#include "copyright.h"
| 12 |
| 13 |
#include <signal.h>
| 14 |
#include <string.h>
| 15 |
| 16 |
#include "standard.h"
| 17 |
#include "platform.h"
| 18 |
#include "color.h"
| 19 |
#include "view.h"
| 20 |
#include "paths.h"
| 21 |
| 22 |
extern float *matchlamp();
| 23 |
| 24 |
#define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
| 25 |
| 26 |
double CHECKRAD = 2.0; /* radius to check for filtering */
| 27 |
| 28 |
#define THRESHRAD 5.0 /* maximum sample spread in output */
| 29 |
| 30 |
COLOR exposure = WHTCOLOR; /* exposure for the frame */
| 31 |
| 32 |
double rad = 0.0; /* output pixel radius for filtering */
| 33 |
| 34 |
double thresh = 0.0; /* maximum contribution for subpixel */
| 35 |
| 36 |
int nrows = 0; /* number of rows for output */
| 37 |
int ncols = 0; /* number of columns for output */
| 38 |
| 39 |
double x_c = 1.0; /* ratio of output x size to input */
| 40 |
double y_r = 1.0; /* ratio of output y size to input */
| 41 |
| 42 |
int singlepass = 0; /* true means skip first pass */
| 43 |
| 44 |
int avghot = 0; /* true means average in bright spots */
| 45 |
| 46 |
double hotlvl = 100.0; /* level considered "hot" */
| 47 |
| 48 |
int npts = 0; /* (half) number of points for stars */
| 49 |
| 50 |
double spread = 1e-4; /* spread for star points */
| 51 |
| 52 |
char *tfname = NULL;
| 53 |
| 54 |
char template[] = TEMPLATE;
| 55 |
| 56 |
char *lampdat = "lamp.tab"; /* lamp data file */
| 57 |
| 58 |
int order; /* scanline ordering of input */
| 59 |
int xres, yres; /* resolution of input */
| 60 |
double inpaspect = 1.0; /* pixel aspect ratio of input */
| 61 |
int correctaspect = 0; /* aspect ratio correction? */
| 62 |
| 63 |
int wrongformat = 0;
| 64 |
| 65 |
VIEW ourview = STDVIEW;
| 66 |
int gotview = 0;
| 67 |
int wrapfilt = 0; /* wrap filter horizontally? */
| 68 |
| 69 |
int estatus = 0; /* exit status (for non-fatal errors) */
| 70 |
| 71 |
int xrad; /* x search radius */
| 72 |
int yrad; /* y search radius */
| 73 |
int xbrad; /* x box size */
| 74 |
int ybrad; /* y box size */
| 75 |
| 76 |
int barsize; /* size of input scan bar */
| 77 |
COLOR **scanin; /* input scan bar */
| 78 |
COLOR *scanout; /* output scan line */
| 79 |
COLOR **scoutbar; /* output scan bar (if thresh > 0) */
| 80 |
float **greybar; /* grey-averaged input values */
| 81 |
int obarsize = 0; /* size of output scan bar */
| 82 |
int orad = 0; /* output window radius */
| 83 |
| 84 |
char *progname;
| 85 |
| 86 |
| 87 |
main(argc, argv)
| 88 |
int argc;
| 89 |
char **argv;
| 90 |
| 91 |
extern int headline();
| 92 |
FILE *fin;
| 93 |
float *lampcolor;
| 94 |
char *lamptype = NULL;
| 95 |
long fpos;
| 96 |
double outaspect = 0.0;
| 97 |
double d;
| 98 |
int i, j;
| 99 |
SET_DEFAULT_BINARY();
| 100 |
SET_FILE_BINARY(stdin);
| 101 |
SET_FILE_BINARY(stdout);
| 102 |
if (signal(SIGINT, quit) == SIG_IGN)
| 103 |
signal(SIGINT, SIG_IGN);
| 104 |
#ifdef SIGHUP
| 105 |
if (signal(SIGHUP, quit) == SIG_IGN)
| 106 |
signal(SIGHUP, SIG_IGN);
| 107 |
#endif
| 108 |
signal(SIGTERM, quit);
| 109 |
#ifdef SIGPIPE
| 110 |
signal(SIGPIPE, quit);
| 111 |
#endif
| 112 |
#ifdef SIGXCPU
| 113 |
signal(SIGXCPU, quit);
| 114 |
signal(SIGXFSZ, quit);
| 115 |
#endif
| 116 |
| 117 |
progname = argv[0] = fixargv0(argv[0]);
| 118 |
| 119 |
for (i = 1; i < argc; i++)
| 120 |
if (argv[i][0] == '-')
| 121 |
switch (argv[i][1]) {
| 122 |
case 'x':
| 123 |
i++;
| 124 |
if (argv[i][0] == '/') {
| 125 |
x_c = 1.0/atof(argv[i]+1);
| 126 |
ncols = 0;
| 127 |
} else
| 128 |
ncols = atoi(argv[i]);
| 129 |
break;
| 130 |
case 'y':
| 131 |
i++;
| 132 |
| 133 |
y_r = 1.0/atof(argv[i]+1);
| 134 |
nrows = 0;
| 135 |
} else
| 136 |
nrows = atoi(argv[i]);
| 137 |
break;
| 138 |
case 'c':
| 139 |
correctaspect = !correctaspect;
| 140 |
break;
| 141 |
case 'p':
| 142 |
i++;
| 143 |
outaspect = atof(argv[i]);
| 144 |
break;
| 145 |
case 'e':
| 146 |
if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
| 147 |
d = pow(2.0, atof(argv[i+1]));
| 148 |
else
| 149 |
d = atof(argv[i+1]);
| 150 |
if (d < 1e-20 || d > 1e20) {
| 151 |
fprintf(stderr,
| 152 |
"%s: exposure out of range\n",
| 153 |
argv[0]);
| 154 |
quit(1);
| 155 |
| 156 |
switch (argv[i][2]) {
| 157 |
case '\0':
| 158 |
scalecolor(exposure, d);
| 159 |
break;
| 160 |
case 'r':
| 161 |
colval(exposure,RED) *= d;
| 162 |
break;
| 163 |
case 'g':
| 164 |
colval(exposure,GRN) *= d;
| 165 |
break;
| 166 |
case 'b':
| 167 |
colval(exposure,BLU) *= d;
| 168 |
break;
| 169 |
default:
| 170 |
goto badopt;
| 171 |
| 172 |
i++;
| 173 |
break;
| 174 |
case 'f':
| 175 |
lampdat = argv[++i];
| 176 |
break;
| 177 |
case 't':
| 178 |
lamptype = argv[++i];
| 179 |
break;
| 180 |
case '1':
| 181 |
singlepass = 1;
| 182 |
break;
| 183 |
case '2':
| 184 |
singlepass = 0;
| 185 |
break;
| 186 |
case 'n':
| 187 |
npts = atoi(argv[++i]) / 2;
| 188 |
break;
| 189 |
case 's':
| 190 |
spread = atof(argv[++i]);
| 191 |
break;
| 192 |
case 'a':
| 193 |
avghot = !avghot;
| 194 |
break;
| 195 |
case 'h':
| 196 |
hotlvl = atof(argv[++i]);
| 197 |
break;
| 198 |
case 'r':
| 199 |
rad = atof(argv[++i]);
| 200 |
break;
| 201 |
case 'm':
| 202 |
thresh = atof(argv[++i]);
| 203 |
if (rad <= FTINY)
| 204 |
rad = 0.6;
| 205 |
break;
| 206 |
case 'b':
| 207 |
rad = thresh = 0.0;
| 208 |
break;
| 209 |
default:;
| 210 |
badopt:
| 211 |
fprintf(stderr, "%s: unknown option: %s\n",
| 212 |
progname, argv[i]);
| 213 |
quit(1);
| 214 |
break;
| 215 |
| 216 |
else
| 217 |
break;
| 218 |
/* get lamp data (if necessary) */
| 219 |
if (lamptype != NULL) {
| 220 |
if (loadlamps(lampdat) < 0)
| 221 |
quit(1);
| 222 |
if ((lampcolor = matchlamp(lamptype)) == NULL) {
| 223 |
fprintf(stderr, "%s: unknown lamp type\n", lamptype);
| 224 |
quit(1);
| 225 |
| 226 |
for (j = 0; j < 3; j++)
| 227 |
if (lampcolor[j] > 1e-4)
| 228 |
colval(exposure,j) /= lampcolor[j];
| 229 |
freelamps();
| 230 |
| 231 |
/* open input file */
| 232 |
if (i == argc) {
| 233 |
if (singlepass)
| 234 |
fin = stdin;
| 235 |
else {
| 236 |
tfname = mktemp(template);
| 237 |
if ((fin = fopen(tfname, "w+")) == NULL) {
| 238 |
fprintf(stderr, "%s: can't create ", progname);
| 239 |
fprintf(stderr, "temp file \"%s\"\n", tfname);
| 240 |
quit(1);
| 241 |
| 242 |
copyfile(stdin, fin);
| 243 |
if (fseek(fin, 0L, 0) == -1) {
| 244 |
fprintf(stderr, "%s: seek fail\n", progname);
| 245 |
quit(1);
| 246 |
| 247 |
| 248 |
} else if (i == argc-1) {
| 249 |
if ((fin = fopen(argv[i], "r")) == NULL) {
| 250 |
fprintf(stderr, "%s: can't open file \"%s\"\n",
| 251 |
progname, argv[i]);
| 252 |
quit(1);
| 253 |
| 254 |
} else {
| 255 |
fprintf(stderr, "%s: bad # file arguments\n", progname);
| 256 |
quit(1);
| 257 |
| 258 |
/* get header */
| 259 |
getheader(fin, headline, NULL);
| 260 |
if (wrongformat) {
| 261 |
fprintf(stderr, "%s: input must be a Radiance picture\n",
| 262 |
progname);
| 263 |
quit(1);
| 264 |
| 265 |
/* add new header info. */
| 266 |
printargs(i, argv, stdout);
| 267 |
/* get picture size */
| 268 |
if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
| 269 |
fprintf(stderr, "%s: bad picture size\n", progname);
| 270 |
quit(1);
| 271 |
| 272 |
if (!(order & YMAJOR))
| 273 |
inpaspect = 1.0/inpaspect;
| 274 |
/* wrap around for cylindrical view? */
| 275 |
wrapfilt = gotview && ourview.type == VT_CYL &&
| 276 |
ourview.horiz >= 360.-FTINY && order & YMAJOR;
| 277 |
/* compute output resolution */
| 278 |
if (ncols <= 0)
| 279 |
ncols = x_c*xres + .5;
| 280 |
if (nrows <= 0)
| 281 |
nrows = y_r*yres + .5;
| 282 |
if (outaspect > .01) {
| 283 |
d = inpaspect * yres/xres / outaspect;
| 284 |
if (d * ncols > nrows)
| 285 |
ncols = nrows / d;
| 286 |
else
| 287 |
nrows = ncols * d;
| 288 |
| 289 |
x_c = (double)ncols/xres;
| 290 |
y_r = (double)nrows/yres;
| 291 |
| 292 |
if (singlepass) { /* skip exposure, etc. */
| 293 |
pass1default();
| 294 |
pass2(fin);
| 295 |
quit(0);
| 296 |
| 297 |
| 298 |
fpos = ftell(fin); /* save input file position */
| 299 |
| 300 |
pass1(fin);
| 301 |
| 302 |
if (fseek(fin, fpos, 0) == -1) {
| 303 |
| 304 |
quit(1);
| 305 |
| 306 |
pass2(fin);
| 307 |
| 308 |
quit(estatus);
| 309 |
| 310 |
| 311 |
| 312 |
double
| 313 |
rgb_bright(clr)
| 314 |
COLOR clr;
| 315 |
| 316 |
return(bright(clr));
| 317 |
| 318 |
| 319 |
| 320 |
double
| 321 |
xyz_bright(clr)
| 322 |
COLOR clr;
| 323 |
| 324 |
return(clr[CIEY]);
| 325 |
| 326 |
| 327 |
| 328 |
double (*ourbright)() = rgb_bright;
| 329 |
| 330 |
| 331 |
int
| 332 |
headline(s) /* process line from header */
| 333 |
char *s;
| 334 |
| 335 |
char fmt[32];
| 336 |
| 337 |
fputs(s, stdout); /* copy to output */
| 338 |
if (isaspect(s)) /* get aspect ratio */
| 339 |
inpaspect *= aspectval(s);
| 340 |
else if (isexpos(s)) /* get exposure */
| 341 |
hotlvl *= exposval(s);
| 342 |
else if (formatval(fmt, s)) { /* get format */
| 343 |
wrongformat = 0;
| 344 |
if (!strcmp(COLRFMT, fmt))
| 345 |
ourbright = rgb_bright;
| 346 |
else if (!strcmp(CIEFMT, fmt))
| 347 |
ourbright = xyz_bright;
| 348 |
else
| 349 |
wrongformat = !globmatch(PICFMT, fmt);
| 350 |
} else if (isview(s) && sscanview(&ourview, s) > 0)
| 351 |
gotview++;
| 352 |
return(0);
| 353 |
| 354 |
| 355 |
| 356 |
copyfile(in, out) /* copy a file */
| 357 |
register FILE *in, *out;
| 358 |
| 359 |
register int c;
| 360 |
| 361 |
while ((c = getc(in)) != EOF)
| 362 |
putc(c, out);
| 363 |
| 364 |
if (ferror(out)) {
| 365 |
fprintf(stderr, "%s: write error in copyfile\n", progname);
| 366 |
quit(1);
| 367 |
| 368 |
| 369 |
| 370 |
| 371 |
pass1(in) /* first pass of picture file */
| 372 |
FILE *in;
| 373 |
| 374 |
int i;
| 375 |
COLOR *scan;
| 376 |
| 377 |
pass1init();
| 378 |
| 379 |
scan = (COLOR *)malloc(xres*sizeof(COLOR));
| 380 |
if (scan == NULL) {
| 381 |
fprintf(stderr, "%s: out of memory\n", progname);
| 382 |
quit(1);
| 383 |
| 384 |
for (i = 0; i < yres; i++) {
| 385 |
if (freadscan(scan, xres, in) < 0) {
| 386 |
nrows = (long)nrows * i / yres; /* adjust frame */
| 387 |
if (nrows <= 0) {
| 388 |
fprintf(stderr, "%s: empty frame\n", progname);
| 389 |
quit(1);
| 390 |
| 391 |
fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
| 392 |
progname, (int)(100L*i/yres));
| 393 |
yres = i;
| 394 |
| 395 |
estatus++;
| 396 |
break;
| 397 |
| 398 |
pass1scan(scan, i);
| 399 |
| 400 |
free((void *)scan);
| 401 |
| 402 |
| 403 |
| 404 |
pass2(in) /* last pass on file, write to stdout */
| 405 |
FILE *in;
| 406 |
| 407 |
int yread;
| 408 |
int ycent, xcent;
| 409 |
int r, c;
| 410 |
| 411 |
pass2init();
| 412 |
scan2init();
| 413 |
yread = 0;
| 414 |
for (r = 0; r < nrows; r++) {
| 415 |
ycent = (r+.5)*yres/nrows;
| 416 |
while (yread <= ycent+yrad) {
| 417 |
if (yread < yres) {
| 418 |
if (freadscan(scanin[yread%barsize],
| 419 |
xres, in) < 0) {
| 420 |
fprintf(stderr,
| 421 |
"%s: truncated input (y=%d)\n",
| 422 |
progname, yres-1-yread);
| 423 |
quit(1);
| 424 |
| 425 |
pass2scan(scanin[yread%barsize], yread);
| 426 |
| 427 |
yread++;
| 428 |
| 429 |
if (obarsize > 0)
| 430 |
scan2sync(r);
| 431 |
for (c = 0; c < ncols; c++) {
| 432 |
xcent = (c+.5)*xres/ncols;
| 433 |
if (thresh > FTINY)
| 434 |
dothresh(xcent, ycent, c, r);
| 435 |
else if (rad > FTINY)
| 436 |
dogauss(scanout[c], xcent, ycent, c, r);
| 437 |
else
| 438 |
dobox(scanout[c], xcent, ycent, c, r);
| 439 |
| 440 |
if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
| 441 |
fprintf(stderr, "%s: write error in pass2\n", progname);
| 442 |
quit(1);
| 443 |
| 444 |
| 445 |
/* skip leftover input */
| 446 |
while (yread < yres) {
| 447 |
if (freadscan(scanin[0], xres, in) < 0)
| 448 |
break;
| 449 |
yread++;
| 450 |
| 451 |
scan2flush(); /* flush output */
| 452 |
| 453 |
| 454 |
| 455 |
scan2init() /* prepare scanline arrays */
| 456 |
| 457 |
COLOR ctmp;
| 458 |
double d;
| 459 |
register int i;
| 460 |
| 461 |
xbrad = xres/ncols/2 + 1;
| 462 |
ybrad = yres/nrows/2 + 1;
| 463 |
if (rad > FTINY) {
| 464 |
if (nrows >= yres && ncols >= xres)
| 465 |
rad *= (y_r + x_c)/2.0;
| 466 |
| 467 |
if (thresh > FTINY) {
| 468 |
orad = CHECKRAD*THRESHRAD*rad + 1;
| 469 |
xrad = orad/x_c + xbrad;
| 470 |
yrad = orad/y_r + ybrad;
| 471 |
obarsize = 2*orad + 1;
| 472 |
} else {
| 473 |
xrad = CHECKRAD*rad/x_c + 1;
| 474 |
yrad = CHECKRAD*rad/y_r + 1;
| 475 |
| 476 |
initmask(); /* initialize filter table */
| 477 |
} else {
| 478 |
xrad = xbrad;
| 479 |
yrad = ybrad;
| 480 |
| 481 |
barsize = 2*yrad + 1;
| 482 |
scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
| 483 |
if (scanin == NULL)
| 484 |
goto memerr;
| 485 |
for (i = 0; i < barsize; i++) {
| 486 |
scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
| 487 |
if (scanin[i] == NULL)
| 488 |
goto memerr;
| 489 |
| 490 |
if (obarsize > 0) {
| 491 |
scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
| 492 |
greybar = (float **)malloc(obarsize*sizeof(float *));
| 493 |
if ((scoutbar == NULL) | (greybar == NULL))
| 494 |
goto memerr;
| 495 |
for (i = 0; i < obarsize; i++) {
| 496 |
scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
| 497 |
greybar[i] = (float *)malloc(ncols*sizeof(float));
| 498 |
if ((scoutbar[i] == NULL) | (greybar[i] == NULL))
| 499 |
goto memerr;
| 500 |
| 501 |
} else {
| 502 |
scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
| 503 |
if (scanout == NULL)
| 504 |
goto memerr;
| 505 |
| 506 |
/* record pixel aspect ratio */
| 507 |
if (!correctaspect) {
| 508 |
d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
| 509 |
if (!FEQ(d,1.0))
| 510 |
fputaspect(d, stdout);
| 511 |
| 512 |
/* record exposure */
| 513 |
d = (*ourbright)(exposure);
| 514 |
if (!FEQ(d,1.0))
| 515 |
fputexpos(d, stdout);
| 516 |
/* record color correction */
| 517 |
copycolor(ctmp, exposure);
| 518 |
scalecolor(ctmp, 1.0/d);
| 519 |
if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
| 520 |
!FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
| 521 |
fputcolcor(ctmp, stdout);
| 522 |
printf("\n");
| 523 |
/* write out resolution */
| 524 |
fputresolu(order, ncols, nrows, stdout);
| 525 |
return;
| 526 |
memerr:
| 527 |
| 528 |
quit(1);
| 529 |
| 530 |
| 531 |
| 532 |
scan2sync(r) /* synchronize grey averages and output scan */
| 533 |
int r;
| 534 |
| 535 |
static int nextrow = 0;
| 536 |
COLOR ctmp;
| 537 |
int ybot;
| 538 |
register int c;
| 539 |
/* average input scanlines */
| 540 |
while (nextrow <= r+orad && nextrow < nrows) {
| 541 |
ybot = (nextrow+.5)*yres/nrows;
| 542 |
| 543 |
dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
| 544 |
greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
| 545 |
| 546 |
/* and zero output scanline */
| 547 |
memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR));
| 548 |
nextrow++;
| 549 |
| 550 |
/* point to top scanline for output */
| 551 |
if (r-orad >= 0)
| 552 |
scanout = scoutbar[(r-orad)%obarsize];
| 553 |
else
| 554 |
scanout = NULL;
| 555 |
| 556 |
| 557 |
| 558 |
scan2flush() /* flush output buffer */
| 559 |
| 560 |
register int r;
| 561 |
| 562 |
for (r = nrows-orad; r < nrows; r++)
| 563 |
if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
| 564 |
break;
| 565 |
if (fflush(stdout) < 0) {
| 566 |
fprintf(stderr, "%s: write error at end of pass2\n", progname);
| 567 |
quit(1);
| 568 |
| 569 |
| 570 |
| 571 |
| 572 |
void
| 573 |
quit(code) /* remove temporary file and exit */
| 574 |
int code;
| 575 |
| 576 |
if (tfname != NULL)
| 577 |
unlink(tfname);
| 578 |
exit(code);
| 579 |
