root/radiance/ray/src/px/pfilt.c
Revision: 2.24
Committed: Sun Jun 8 12:03:10 2003 UTC (20 years, 11 months ago) by schorsch
Changes since 2.23: +6 -1 lines
2 static const char RCSid[] = "$Id: pfilt.c,v 2.23 2003/06/05 19:29:34 schorsch Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include <signal.h>
12
13 #include "standard.h"
14 #include "platform.h"
15 #include "color.h"
16 #include "view.h"
17 #include "paths.h"
18
19 extern float *matchlamp();
20
21 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
22
23 double CHECKRAD = 2.0; /* radius to check for filtering */
24
25 #define THRESHRAD 5.0 /* maximum sample spread in output */
26
27 COLOR exposure = WHTCOLOR; /* exposure for the frame */
28
29 double rad = 0.0; /* output pixel radius for filtering */
30
31 double thresh = 0.0; /* maximum contribution for subpixel */
32
33 int nrows = 0; /* number of rows for output */
34 int ncols = 0; /* number of columns for output */
35
36 double x_c = 1.0; /* ratio of output x size to input */
37 double y_r = 1.0; /* ratio of output y size to input */
38
39 int singlepass = 0; /* true means skip first pass */
40
41 int avghot = 0; /* true means average in bright spots */
42
43 double hotlvl = 100.0; /* level considered "hot" */
44
45 int npts = 0; /* (half) number of points for stars */
46
47 double spread = 1e-4; /* spread for star points */
48
49 char *tfname = NULL;
50
51 char template[] = TEMPLATE;
52
53 char *lampdat = "lamp.tab"; /* lamp data file */
54
55 int order; /* scanline ordering of input */
56 int xres, yres; /* resolution of input */
57 double inpaspect = 1.0; /* pixel aspect ratio of input */
58 int correctaspect = 0; /* aspect ratio correction? */
59
60 int wrongformat = 0;
61
62 VIEW ourview = STDVIEW;
63 int gotview = 0;
64 int wrapfilt = 0; /* wrap filter horizontally? */
65
66 int estatus = 0; /* exit status (for non-fatal errors) */
67
68 int xrad; /* x search radius */
69 int yrad; /* y search radius */
70 int xbrad; /* x box size */
71 int ybrad; /* y box size */
72
73 int barsize; /* size of input scan bar */
74 COLOR **scanin; /* input scan bar */
75 COLOR *scanout; /* output scan line */
76 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
77 float **greybar; /* grey-averaged input values */
78 int obarsize = 0; /* size of output scan bar */
79 int orad = 0; /* output window radius */
80
81 char *progname;
82
83
84 main(argc, argv)
85 int argc;
86 char **argv;
87 {
88 extern int headline();
89 FILE *fin;
90 float *lampcolor;
91 char *lamptype = NULL;
92 long fpos;
93 double outaspect = 0.0;
94 double d;
95 int i, j;
96 SET_DEFAULT_BINARY();
97 SET_FILE_BINARY(stdin);
98 SET_FILE_BINARY(stdout);
99 if (signal(SIGINT, quit) == SIG_IGN)
100 signal(SIGINT, SIG_IGN);
101 #ifdef SIGHUP
102 if (signal(SIGHUP, quit) == SIG_IGN)
103 signal(SIGHUP, SIG_IGN);
104 #endif
105 signal(SIGTERM, quit);
106 #ifdef SIGPIPE
107 signal(SIGPIPE, quit);
108 #endif
109 #ifdef SIGXCPU
110 signal(SIGXCPU, quit);
111 signal(SIGXFSZ, quit);
112 #endif
113
114 progname = argv[0] = fixargv0(argv[0]);
115
116 for (i = 1; i < argc; i++)
117 if (argv[i][0] == '-')
118 switch (argv[i][1]) {
119 case 'x':
120 i++;
121 if (argv[i][0] == '/') {
122 x_c = 1.0/atof(argv[i]+1);
123 ncols = 0;
124 } else
125 ncols = atoi(argv[i]);
126 break;
127 case 'y':
128 i++;
129 if (argv[i][0] == '/') {
130 y_r = 1.0/atof(argv[i]+1);
131 nrows = 0;
132 } else
133 nrows = atoi(argv[i]);
134 break;
135 case 'c':
136 correctaspect = !correctaspect;
137 break;
138 case 'p':
139 i++;
140 outaspect = atof(argv[i]);
141 break;
142 case 'e':
143 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
144 d = pow(2.0, atof(argv[i+1]));
145 else
146 d = atof(argv[i+1]);
147 if (d < 1e-20 || d > 1e20) {
148 fprintf(stderr,
149 "%s: exposure out of range\n",
150 argv[0]);
151 quit(1);
152 }
153 switch (argv[i][2]) {
154 case '\0':
155 scalecolor(exposure, d);
156 break;
157 case 'r':
158 colval(exposure,RED) *= d;
159 break;
160 case 'g':
161 colval(exposure,GRN) *= d;
162 break;
163 case 'b':
164 colval(exposure,BLU) *= d;
165 break;
166 default:
167 goto badopt;
168 }
169 i++;
170 break;
171 case 'f':
172 lampdat = argv[++i];
173 break;
174 case 't':
175 lamptype = argv[++i];
176 break;
177 case '1':
178 singlepass = 1;
179 break;
180 case '2':
181 singlepass = 0;
182 break;
183 case 'n':
184 npts = atoi(argv[++i]) / 2;
185 break;
186 case 's':
187 spread = atof(argv[++i]);
188 break;
189 case 'a':
190 avghot = !avghot;
191 break;
192 case 'h':
193 hotlvl = atof(argv[++i]);
194 break;
195 case 'r':
196 rad = atof(argv[++i]);
197 break;
198 case 'm':
199 thresh = atof(argv[++i]);
200 if (rad <= FTINY)
201 rad = 0.6;
202 break;
203 case 'b':
204 rad = thresh = 0.0;
205 break;
206 default:;
207 badopt:
208 fprintf(stderr, "%s: unknown option: %s\n",
209 progname, argv[i]);
210 quit(1);
211 break;
212 }
213 else
214 break;
215 /* get lamp data (if necessary) */
216 if (lamptype != NULL) {
217 if (loadlamps(lampdat) < 0)
218 quit(1);
219 if ((lampcolor = matchlamp(lamptype)) == NULL) {
220 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
221 quit(1);
222 }
223 for (j = 0; j < 3; j++)
224 if (lampcolor[j] > 1e-4)
225 colval(exposure,j) /= lampcolor[j];
226 freelamps();
227 }
228 /* open input file */
229 if (i == argc) {
230 if (singlepass)
231 fin = stdin;
232 else {
233 tfname = mktemp(template);
234 if ((fin = fopen(tfname, "w+")) == NULL) {
235 fprintf(stderr, "%s: can't create ", progname);
236 fprintf(stderr, "temp file \"%s\"\n", tfname);
237 quit(1);
238 }
239 copyfile(stdin, fin);
240 if (fseek(fin, 0L, 0) == -1) {
241 fprintf(stderr, "%s: seek fail\n", progname);
242 quit(1);
243 }
244 }
245 } else if (i == argc-1) {
246 if ((fin = fopen(argv[i], "r")) == NULL) {
247 fprintf(stderr, "%s: can't open file \"%s\"\n",
248 progname, argv[i]);
249 quit(1);
250 }
251 } else {
252 fprintf(stderr, "%s: bad # file arguments\n", progname);
253 quit(1);
254 }
255 /* get header */
256 getheader(fin, headline, NULL);
257 if (wrongformat) {
258 fprintf(stderr, "%s: input must be a Radiance picture\n",
259 progname);
260 quit(1);
261 }
262 /* add new header info. */
263 printargs(i, argv, stdout);
264 /* get picture size */
265 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
266 fprintf(stderr, "%s: bad picture size\n", progname);
267 quit(1);
268 }
269 if (!(order & YMAJOR))
270 inpaspect = 1.0/inpaspect;
271 /* wrap around for cylindrical view? */
272 wrapfilt = gotview && ourview.type == VT_CYL &&
273 ourview.horiz >= 360.-FTINY && order & YMAJOR;
274 /* compute output resolution */
275 if (ncols <= 0)
276 ncols = x_c*xres + .5;
277 if (nrows <= 0)
278 nrows = y_r*yres + .5;
279 if (outaspect > .01) {
280 d = inpaspect * yres/xres / outaspect;
281 if (d * ncols > nrows)
282 ncols = nrows / d;
283 else
284 nrows = ncols * d;
285 }
286 x_c = (double)ncols/xres;
287 y_r = (double)nrows/yres;
288
289 if (singlepass) { /* skip exposure, etc. */
290 pass1default();
291 pass2(fin);
292 quit(0);
293 }
294
295 fpos = ftell(fin); /* save input file position */
296
297 pass1(fin);
298
299 if (fseek(fin, fpos, 0) == -1) {
300 fprintf(stderr, "%s: seek fail\n", progname);
301 quit(1);
302 }
303 pass2(fin);
304
305 quit(estatus);
306 }
307
308
309 double
310 rgb_bright(clr)
311 COLOR clr;
312 {
313 return(bright(clr));
314 }
315
316
317 double
318 xyz_bright(clr)
319 COLOR clr;
320 {
321 return(clr[CIEY]);
322 }
323
324
325 double (*ourbright)() = rgb_bright;
326
327
328 int
329 headline(s) /* process line from header */
330 char *s;
331 {
332 char fmt[32];
333
334 fputs(s, stdout); /* copy to output */
335 if (isaspect(s)) /* get aspect ratio */
336 inpaspect *= aspectval(s);
337 else if (isexpos(s)) /* get exposure */
338 hotlvl *= exposval(s);
339 else if (formatval(fmt, s)) { /* get format */
340 wrongformat = 0;
341 if (!strcmp(COLRFMT, fmt))
342 ourbright = rgb_bright;
343 else if (!strcmp(CIEFMT, fmt))
344 ourbright = xyz_bright;
345 else
346 wrongformat = !globmatch(PICFMT, fmt);
347 } else if (isview(s) && sscanview(&ourview, s) > 0)
348 gotview++;
349 return(0);
350 }
351
352
353 copyfile(in, out) /* copy a file */
354 register FILE *in, *out;
355 {
356 register int c;
357
358 while ((c = getc(in)) != EOF)
359 putc(c, out);
360
361 if (ferror(out)) {
362 fprintf(stderr, "%s: write error in copyfile\n", progname);
363 quit(1);
364 }
365 }
366
367
368 pass1(in) /* first pass of picture file */
369 FILE *in;
370 {
371 int i;
372 COLOR *scan;
373
374 pass1init();
375
376 scan = (COLOR *)malloc(xres*sizeof(COLOR));
377 if (scan == NULL) {
378 fprintf(stderr, "%s: out of memory\n", progname);
379 quit(1);
380 }
381 for (i = 0; i < yres; i++) {
382 if (freadscan(scan, xres, in) < 0) {
383 nrows = (long)nrows * i / yres; /* adjust frame */
384 if (nrows <= 0) {
385 fprintf(stderr, "%s: empty frame\n", progname);
386 quit(1);
387 }
388 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
389 progname, (int)(100L*i/yres));
390 yres = i;
391 y_r = (double)nrows/yres;
392 estatus++;
393 break;
394 }
395 pass1scan(scan, i);
396 }
397 free((void *)scan);
398 }
399
400
401 pass2(in) /* last pass on file, write to stdout */
402 FILE *in;
403 {
404 int yread;
405 int ycent, xcent;
406 int r, c;
407
408 pass2init();
409 scan2init();
410 yread = 0;
411 for (r = 0; r < nrows; r++) {
412 ycent = (r+.5)*yres/nrows;
413 while (yread <= ycent+yrad) {
414 if (yread < yres) {
415 if (freadscan(scanin[yread%barsize],
416 xres, in) < 0) {
417 fprintf(stderr,
418 "%s: truncated input (y=%d)\n",
419 progname, yres-1-yread);
420 quit(1);
421 }
422 pass2scan(scanin[yread%barsize], yread);
423 }
424 yread++;
425 }
426 if (obarsize > 0)
427 scan2sync(r);
428 for (c = 0; c < ncols; c++) {
429 xcent = (c+.5)*xres/ncols;
430 if (thresh > FTINY)
431 dothresh(xcent, ycent, c, r);
432 else if (rad > FTINY)
433 dogauss(scanout[c], xcent, ycent, c, r);
434 else
435 dobox(scanout[c], xcent, ycent, c, r);
436 }
437 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
438 fprintf(stderr, "%s: write error in pass2\n", progname);
439 quit(1);
440 }
441 }
442 /* skip leftover input */
443 while (yread < yres) {
444 if (freadscan(scanin[0], xres, in) < 0)
445 break;
446 yread++;
447 }
448 scan2flush(); /* flush output */
449 }
450
451
452 scan2init() /* prepare scanline arrays */
453 {
454 COLOR ctmp;
455 double d;
456 register int i;
457
458 xbrad = xres/ncols/2 + 1;
459 ybrad = yres/nrows/2 + 1;
460 if (rad > FTINY) {
461 if (nrows >= yres && ncols >= xres)
462 rad *= (y_r + x_c)/2.0;
463
464 if (thresh > FTINY) {
465 orad = CHECKRAD*THRESHRAD*rad + 1;
466 xrad = orad/x_c + xbrad;
467 yrad = orad/y_r + ybrad;
468 obarsize = 2*orad + 1;
469 } else {
470 xrad = CHECKRAD*rad/x_c + 1;
471 yrad = CHECKRAD*rad/y_r + 1;
472 }
473 initmask(); /* initialize filter table */
474 } else {
475 xrad = xbrad;
476 yrad = ybrad;
477 }
478 barsize = 2*yrad + 1;
479 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
480 if (scanin == NULL)
481 goto memerr;
482 for (i = 0; i < barsize; i++) {
483 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
484 if (scanin[i] == NULL)
485 goto memerr;
486 }
487 if (obarsize > 0) {
488 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
489 greybar = (float **)malloc(obarsize*sizeof(float *));
490 if (scoutbar == NULL | greybar == NULL)
491 goto memerr;
492 for (i = 0; i < obarsize; i++) {
493 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
494 greybar[i] = (float *)malloc(ncols*sizeof(float));
495 if (scoutbar[i] == NULL | greybar[i] == NULL)
496 goto memerr;
497 }
498 } else {
499 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
500 if (scanout == NULL)
501 goto memerr;
502 }
503 /* record pixel aspect ratio */
504 if (!correctaspect) {
505 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
506 if (!FEQ(d,1.0))
507 fputaspect(d, stdout);
508 }
509 /* record exposure */
510 d = (*ourbright)(exposure);
511 if (!FEQ(d,1.0))
512 fputexpos(d, stdout);
513 /* record color correction */
514 copycolor(ctmp, exposure);
515 scalecolor(ctmp, 1.0/d);
516 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
517 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
518 fputcolcor(ctmp, stdout);
519 printf("\n");
520 /* write out resolution */
521 fputresolu(order, ncols, nrows, stdout);
522 return;
523 memerr:
524 fprintf(stderr, "%s: out of memory\n", progname);
525 quit(1);
526 }
527
528
529 scan2sync(r) /* synchronize grey averages and output scan */
530 int r;
531 {
532 static int nextrow = 0;
533 COLOR ctmp;
534 int ybot;
535 register int c;
536 /* average input scanlines */
537 while (nextrow <= r+orad && nextrow < nrows) {
538 ybot = (nextrow+.5)*yres/nrows;
539 for (c = 0; c < ncols; c++) {
540 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
541 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
542 }
543 /* and zero output scanline */
544 bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR));
545 nextrow++;
546 }
547 /* point to top scanline for output */
548 if (r-orad >= 0)
549 scanout = scoutbar[(r-orad)%obarsize];
550 else
551 scanout = NULL;
552 }
553
554
555 scan2flush() /* flush output buffer */
556 {
557 register int r;
558
559 for (r = nrows-orad; r < nrows; r++)
560 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
561 break;
562 if (fflush(stdout) < 0) {
563 fprintf(stderr, "%s: write error at end of pass2\n", progname);
564 quit(1);
565 }
566 }
567
568
569 void
570 quit(code) /* remove temporary file and exit */
571 int code;
572 {
573 if (tfname != NULL)
574 unlink(tfname);
575 exit(code);
576 }
