root/radiance/ray/src/px/pfilt.c
Revision: 2.23
Committed: Thu Jun 5 19:29:34 2003 UTC (20 years, 10 months ago) by schorsch
Changes since 2.22: +5 -11 lines
2 static const char RCSid[] = "$Id: pfilt.c,v 2.22 2003/02/25 00:26:05 greg Exp $";
5 * pfilt.c - program to post-process picture file.
6 *
7 * 9/26/85
8 * 6/23/93 Added additional buffers for value spreading
9 */
10
11 #include <signal.h>
12
13 #include "standard.h"
14 #include "color.h"
15 #include "view.h"
16 #include "paths.h"
17
18 extern float *matchlamp();
19
20 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
21
22 double CHECKRAD = 2.0; /* radius to check for filtering */
23
24 #define THRESHRAD 5.0 /* maximum sample spread in output */
25
26 COLOR exposure = WHTCOLOR; /* exposure for the frame */
27
28 double rad = 0.0; /* output pixel radius for filtering */
29
30 double thresh = 0.0; /* maximum contribution for subpixel */
31
32 int nrows = 0; /* number of rows for output */
33 int ncols = 0; /* number of columns for output */
34
35 double x_c = 1.0; /* ratio of output x size to input */
36 double y_r = 1.0; /* ratio of output y size to input */
37
38 int singlepass = 0; /* true means skip first pass */
39
40 int avghot = 0; /* true means average in bright spots */
41
42 double hotlvl = 100.0; /* level considered "hot" */
43
44 int npts = 0; /* (half) number of points for stars */
45
46 double spread = 1e-4; /* spread for star points */
47
48 char *tfname = NULL;
49
50 char template[] = TEMPLATE;
51
52 char *lampdat = "lamp.tab"; /* lamp data file */
53
54 int order; /* scanline ordering of input */
55 int xres, yres; /* resolution of input */
56 double inpaspect = 1.0; /* pixel aspect ratio of input */
57 int correctaspect = 0; /* aspect ratio correction? */
58
59 int wrongformat = 0;
60
61 VIEW ourview = STDVIEW;
62 int gotview = 0;
63 int wrapfilt = 0; /* wrap filter horizontally? */
64
65 int estatus = 0; /* exit status (for non-fatal errors) */
66
67 int xrad; /* x search radius */
68 int yrad; /* y search radius */
69 int xbrad; /* x box size */
70 int ybrad; /* y box size */
71
72 int barsize; /* size of input scan bar */
73 COLOR **scanin; /* input scan bar */
74 COLOR *scanout; /* output scan line */
75 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
76 float **greybar; /* grey-averaged input values */
77 int obarsize = 0; /* size of output scan bar */
78 int orad = 0; /* output window radius */
79
80 char *progname;
81
82
83 main(argc, argv)
84 int argc;
85 char **argv;
86 {
87 extern int headline();
88 FILE *fin;
89 float *lampcolor;
90 char *lamptype = NULL;
91 long fpos;
92 double outaspect = 0.0;
93 double d;
94 int i, j;
95 SET_DEFAULT_BINARY();
96 SET_FILE_BINARY(stdin);
97 SET_FILE_BINARY(stdout);
98 if (signal(SIGINT, quit) == SIG_IGN)
99 signal(SIGINT, SIG_IGN);
100 if (signal(SIGHUP, quit) == SIG_IGN)
101 signal(SIGHUP, SIG_IGN);
102 signal(SIGTERM, quit);
103 signal(SIGPIPE, quit);
104 #ifdef SIGXCPU
105 signal(SIGXCPU, quit);
106 signal(SIGXFSZ, quit);
107 #endif
108
109 progname = argv[0] = fixargv0(argv[0]);
110
111 for (i = 1; i < argc; i++)
112 if (argv[i][0] == '-')
113 switch (argv[i][1]) {
114 case 'x':
115 i++;
116 if (argv[i][0] == '/') {
117 x_c = 1.0/atof(argv[i]+1);
118 ncols = 0;
119 } else
120 ncols = atoi(argv[i]);
121 break;
122 case 'y':
123 i++;
124 if (argv[i][0] == '/') {
125 y_r = 1.0/atof(argv[i]+1);
126 nrows = 0;
127 } else
128 nrows = atoi(argv[i]);
129 break;
130 case 'c':
131 correctaspect = !correctaspect;
132 break;
133 case 'p':
134 i++;
135 outaspect = atof(argv[i]);
136 break;
137 case 'e':
138 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
139 d = pow(2.0, atof(argv[i+1]));
140 else
141 d = atof(argv[i+1]);
142 if (d < 1e-20 || d > 1e20) {
143 fprintf(stderr,
144 "%s: exposure out of range\n",
145 argv[0]);
146 quit(1);
147 }
148 switch (argv[i][2]) {
149 case '\0':
150 scalecolor(exposure, d);
151 break;
152 case 'r':
153 colval(exposure,RED) *= d;
154 break;
155 case 'g':
156 colval(exposure,GRN) *= d;
157 break;
158 case 'b':
159 colval(exposure,BLU) *= d;
160 break;
161 default:
162 goto badopt;
163 }
164 i++;
165 break;
166 case 'f':
167 lampdat = argv[++i];
168 break;
169 case 't':
170 lamptype = argv[++i];
171 break;
172 case '1':
173 singlepass = 1;
174 break;
175 case '2':
176 singlepass = 0;
177 break;
178 case 'n':
179 npts = atoi(argv[++i]) / 2;
180 break;
181 case 's':
182 spread = atof(argv[++i]);
183 break;
184 case 'a':
185 avghot = !avghot;
186 break;
187 case 'h':
188 hotlvl = atof(argv[++i]);
189 break;
190 case 'r':
191 rad = atof(argv[++i]);
192 break;
193 case 'm':
194 thresh = atof(argv[++i]);
195 if (rad <= FTINY)
196 rad = 0.6;
197 break;
198 case 'b':
199 rad = thresh = 0.0;
200 break;
201 default:;
202 badopt:
203 fprintf(stderr, "%s: unknown option: %s\n",
204 progname, argv[i]);
205 quit(1);
206 break;
207 }
208 else
209 break;
210 /* get lamp data (if necessary) */
211 if (lamptype != NULL) {
212 if (loadlamps(lampdat) < 0)
213 quit(1);
214 if ((lampcolor = matchlamp(lamptype)) == NULL) {
215 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
216 quit(1);
217 }
218 for (j = 0; j < 3; j++)
219 if (lampcolor[j] > 1e-4)
220 colval(exposure,j) /= lampcolor[j];
221 freelamps();
222 }
223 /* open input file */
224 if (i == argc) {
225 if (singlepass)
226 fin = stdin;
227 else {
228 tfname = mktemp(template);
229 if ((fin = fopen(tfname, "w+")) == NULL) {
230 fprintf(stderr, "%s: can't create ", progname);
231 fprintf(stderr, "temp file \"%s\"\n", tfname);
232 quit(1);
233 }
234 copyfile(stdin, fin);
235 if (fseek(fin, 0L, 0) == -1) {
236 fprintf(stderr, "%s: seek fail\n", progname);
237 quit(1);
238 }
239 }
240 } else if (i == argc-1) {
241 if ((fin = fopen(argv[i], "r")) == NULL) {
242 fprintf(stderr, "%s: can't open file \"%s\"\n",
243 progname, argv[i]);
244 quit(1);
245 }
246 } else {
247 fprintf(stderr, "%s: bad # file arguments\n", progname);
248 quit(1);
249 }
250 /* get header */
251 getheader(fin, headline, NULL);
252 if (wrongformat) {
253 fprintf(stderr, "%s: input must be a Radiance picture\n",
254 progname);
255 quit(1);
256 }
257 /* add new header info. */
258 printargs(i, argv, stdout);
259 /* get picture size */
260 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
261 fprintf(stderr, "%s: bad picture size\n", progname);
262 quit(1);
263 }
264 if (!(order & YMAJOR))
265 inpaspect = 1.0/inpaspect;
266 /* wrap around for cylindrical view? */
267 wrapfilt = gotview && ourview.type == VT_CYL &&
268 ourview.horiz >= 360.-FTINY && order & YMAJOR;
269 /* compute output resolution */
270 if (ncols <= 0)
271 ncols = x_c*xres + .5;
272 if (nrows <= 0)
273 nrows = y_r*yres + .5;
274 if (outaspect > .01) {
275 d = inpaspect * yres/xres / outaspect;
276 if (d * ncols > nrows)
277 ncols = nrows / d;
278 else
279 nrows = ncols * d;
280 }
281 x_c = (double)ncols/xres;
282 y_r = (double)nrows/yres;
283
284 if (singlepass) { /* skip exposure, etc. */
285 pass1default();
286 pass2(fin);
287 quit(0);
288 }
289
290 fpos = ftell(fin); /* save input file position */
291
292 pass1(fin);
293
294 if (fseek(fin, fpos, 0) == -1) {
295 fprintf(stderr, "%s: seek fail\n", progname);
296 quit(1);
297 }
298 pass2(fin);
299
300 quit(estatus);
301 }
302
303
304 double
305 rgb_bright(clr)
306 COLOR clr;
307 {
308 return(bright(clr));
309 }
310
311
312 double
313 xyz_bright(clr)
314 COLOR clr;
315 {
316 return(clr[CIEY]);
317 }
318
319
320 double (*ourbright)() = rgb_bright;
321
322
323 int
324 headline(s) /* process line from header */
325 char *s;
326 {
327 char fmt[32];
328
329 fputs(s, stdout); /* copy to output */
330 if (isaspect(s)) /* get aspect ratio */
331 inpaspect *= aspectval(s);
332 else if (isexpos(s)) /* get exposure */
333 hotlvl *= exposval(s);
334 else if (formatval(fmt, s)) { /* get format */
335 wrongformat = 0;
336 if (!strcmp(COLRFMT, fmt))
337 ourbright = rgb_bright;
338 else if (!strcmp(CIEFMT, fmt))
339 ourbright = xyz_bright;
340 else
341 wrongformat = !globmatch(PICFMT, fmt);
342 } else if (isview(s) && sscanview(&ourview, s) > 0)
343 gotview++;
344 return(0);
345 }
346
347
348 copyfile(in, out) /* copy a file */
349 register FILE *in, *out;
350 {
351 register int c;
352
353 while ((c = getc(in)) != EOF)
354 putc(c, out);
355
356 if (ferror(out)) {
357 fprintf(stderr, "%s: write error in copyfile\n", progname);
358 quit(1);
359 }
360 }
361
362
363 pass1(in) /* first pass of picture file */
364 FILE *in;
365 {
366 int i;
367 COLOR *scan;
368
369 pass1init();
370
371 scan = (COLOR *)malloc(xres*sizeof(COLOR));
372 if (scan == NULL) {
373 fprintf(stderr, "%s: out of memory\n", progname);
374 quit(1);
375 }
376 for (i = 0; i < yres; i++) {
377 if (freadscan(scan, xres, in) < 0) {
378 nrows = (long)nrows * i / yres; /* adjust frame */
379 if (nrows <= 0) {
380 fprintf(stderr, "%s: empty frame\n", progname);
381 quit(1);
382 }
383 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
384 progname, (int)(100L*i/yres));
385 yres = i;
386 y_r = (double)nrows/yres;
387 estatus++;
388 break;
389 }
390 pass1scan(scan, i);
391 }
392 free((void *)scan);
393 }
394
395
396 pass2(in) /* last pass on file, write to stdout */
397 FILE *in;
398 {
399 int yread;
400 int ycent, xcent;
401 int r, c;
402
403 pass2init();
404 scan2init();
405 yread = 0;
406 for (r = 0; r < nrows; r++) {
407 ycent = (r+.5)*yres/nrows;
408 while (yread <= ycent+yrad) {
409 if (yread < yres) {
410 if (freadscan(scanin[yread%barsize],
411 xres, in) < 0) {
412 fprintf(stderr,
413 "%s: truncated input (y=%d)\n",
414 progname, yres-1-yread);
415 quit(1);
416 }
417 pass2scan(scanin[yread%barsize], yread);
418 }
419 yread++;
420 }
421 if (obarsize > 0)
422 scan2sync(r);
423 for (c = 0; c < ncols; c++) {
424 xcent = (c+.5)*xres/ncols;
425 if (thresh > FTINY)
426 dothresh(xcent, ycent, c, r);
427 else if (rad > FTINY)
428 dogauss(scanout[c], xcent, ycent, c, r);
429 else
430 dobox(scanout[c], xcent, ycent, c, r);
431 }
432 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
433 fprintf(stderr, "%s: write error in pass2\n", progname);
434 quit(1);
435 }
436 }
437 /* skip leftover input */
438 while (yread < yres) {
439 if (freadscan(scanin[0], xres, in) < 0)
440 break;
441 yread++;
442 }
443 scan2flush(); /* flush output */
444 }
445
446
447 scan2init() /* prepare scanline arrays */
448 {
449 COLOR ctmp;
450 double d;
451 register int i;
452
453 xbrad = xres/ncols/2 + 1;
454 ybrad = yres/nrows/2 + 1;
455 if (rad > FTINY) {
456 if (nrows >= yres && ncols >= xres)
457 rad *= (y_r + x_c)/2.0;
458
459 if (thresh > FTINY) {
460 orad = CHECKRAD*THRESHRAD*rad + 1;
461 xrad = orad/x_c + xbrad;
462 yrad = orad/y_r + ybrad;
463 obarsize = 2*orad + 1;
464 } else {
465 xrad = CHECKRAD*rad/x_c + 1;
466 yrad = CHECKRAD*rad/y_r + 1;
467 }
468 initmask(); /* initialize filter table */
469 } else {
470 xrad = xbrad;
471 yrad = ybrad;
472 }
473 barsize = 2*yrad + 1;
474 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
475 if (scanin == NULL)
476 goto memerr;
477 for (i = 0; i < barsize; i++) {
478 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
479 if (scanin[i] == NULL)
480 goto memerr;
481 }
482 if (obarsize > 0) {
483 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
484 greybar = (float **)malloc(obarsize*sizeof(float *));
485 if (scoutbar == NULL | greybar == NULL)
486 goto memerr;
487 for (i = 0; i < obarsize; i++) {
488 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
489 greybar[i] = (float *)malloc(ncols*sizeof(float));
490 if (scoutbar[i] == NULL | greybar[i] == NULL)
491 goto memerr;
492 }
493 } else {
494 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
495 if (scanout == NULL)
496 goto memerr;
497 }
498 /* record pixel aspect ratio */
499 if (!correctaspect) {
500 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
501 if (!FEQ(d,1.0))
502 fputaspect(d, stdout);
503 }
504 /* record exposure */
505 d = (*ourbright)(exposure);
506 if (!FEQ(d,1.0))
507 fputexpos(d, stdout);
508 /* record color correction */
509 copycolor(ctmp, exposure);
510 scalecolor(ctmp, 1.0/d);
511 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
512 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
513 fputcolcor(ctmp, stdout);
514 printf("\n");
515 /* write out resolution */
516 fputresolu(order, ncols, nrows, stdout);
517 return;
518 memerr:
519 fprintf(stderr, "%s: out of memory\n", progname);
520 quit(1);
521 }
522
523
524 scan2sync(r) /* synchronize grey averages and output scan */
525 int r;
526 {
527 static int nextrow = 0;
528 COLOR ctmp;
529 int ybot;
530 register int c;
531 /* average input scanlines */
532 while (nextrow <= r+orad && nextrow < nrows) {
533 ybot = (nextrow+.5)*yres/nrows;
534 for (c = 0; c < ncols; c++) {
535 dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow);
536 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
537 }
538 /* and zero output scanline */
539 bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR));
540 nextrow++;
541 }
542 /* point to top scanline for output */
543 if (r-orad >= 0)
544 scanout = scoutbar[(r-orad)%obarsize];
545 else
546 scanout = NULL;
547 }
548
549
550 scan2flush() /* flush output buffer */
551 {
552 register int r;
553
554 for (r = nrows-orad; r < nrows; r++)
555 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
556 break;
557 if (fflush(stdout) < 0) {
558 fprintf(stderr, "%s: write error at end of pass2\n", progname);
559 quit(1);
560 }
561 }
562
563
564 void
565 quit(code) /* remove temporary file and exit */
566 int code;
567 {
568 if (tfname != NULL)
569 unlink(tfname);
570 exit(code);
571 }
