root/radiance/ray/src/px/pfilt.c
Revision: 2.17
Committed: Mon Apr 1 17:24:44 1996 UTC (29 years, 2 months ago) by greg
Changes since 2.16: +11 -1 lines
1 /* Copyright (c) 1996 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 * 6/23/93 Added additional buffers for value spreading
12 */
13
14 #include "standard.h"
15
16 #include <signal.h>
17
18 #include "color.h"
19
20 #include "view.h"
21
22 #include "resolu.h"
23
24 #include "paths.h"
25
26 extern float *matchlamp();
27
28 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
29
30 double CHECKRAD = 1.5; /* radius to check for filtering */
31
32 #define THRESHRAD 5.0 /* maximum sample spread in output */
33
34 COLOR exposure = WHTCOLOR; /* exposure for the frame */
35
36 double rad = 0.0; /* output pixel radius for filtering */
37
38 double thresh = 0.0; /* maximum contribution for subpixel */
39
40 int nrows = 0; /* number of rows for output */
41 int ncols = 0; /* number of columns for output */
42
43 double x_c = 1.0; /* ratio of output x size to input */
44 double y_r = 1.0; /* ratio of output y size to input */
45
46 int singlepass = 0; /* true means skip first pass */
47
48 int avghot = 0; /* true means average in bright spots */
49
50 double hotlvl = 100.0; /* level considered "hot" */
51
52 int npts = 0; /* (half) number of points for stars */
53
54 double spread = 1e-4; /* spread for star points */
55
56 char *tfname = NULL;
57
58 char template[] = TEMPLATE;
59
60 char *lampdat = "lamp.tab"; /* lamp data file */
61
62 int order; /* scanline ordering of input */
63 int xres, yres; /* resolution of input */
64 double inpaspect = 1.0; /* pixel aspect ratio of input */
65 int correctaspect = 0; /* aspect ratio correction? */
66
67 int wrongformat = 0;
68
69 VIEW ourview = STDVIEW;
70 int gotview = 0;
71 int wrapfilt = 0; /* wrap filter horizontally? */
72
73 int xrad; /* x search radius */
74 int yrad; /* y search radius */
75 int xbrad; /* x box size */
76 int ybrad; /* y box size */
77
78 int barsize; /* size of input scan bar */
79 COLOR **scanin; /* input scan bar */
80 COLOR *scanout; /* output scan line */
81 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
82 float **greybar; /* grey-averaged input values */
83 int obarsize = 0; /* size of output scan bar */
84 int orad = 0; /* output window radius */
85
86 char *progname;
87
88
89 main(argc, argv)
90 int argc;
91 char **argv;
92 {
93 extern long ftell();
94 extern int quit(), headline();
95 FILE *fin;
96 float *lampcolor;
97 char *lamptype = NULL;
98 long fpos;
99 double outaspect = 0.0;
100 double d;
101 int i, j;
102 #ifdef MSDOS
103 extern int _fmode;
104 _fmode = O_BINARY;
105 setmode(fileno(stdin), O_BINARY);
106 setmode(fileno(stdout), O_BINARY);
107 #endif
108 if (signal(SIGINT, quit) == SIG_IGN)
109 signal(SIGINT, SIG_IGN);
110 if (signal(SIGHUP, quit) == SIG_IGN)
111 signal(SIGHUP, SIG_IGN);
112 signal(SIGTERM, quit);
113 signal(SIGPIPE, quit);
114 #ifdef SIGXCPU
115 signal(SIGXCPU, quit);
116 signal(SIGXFSZ, quit);
117 #endif
118
119 progname = argv[0] = fixargv0(argv[0]);
120
121 for (i = 1; i < argc; i++)
122 if (argv[i][0] == '-')
123 switch (argv[i][1]) {
124 case 'x':
125 i++;
126 if (argv[i][0] == '/') {
127 x_c = 1.0/atof(argv[i]+1);
128 ncols = 0;
129 } else
130 ncols = atoi(argv[i]);
131 break;
132 case 'y':
133 i++;
134 if (argv[i][0] == '/') {
135 y_r = 1.0/atof(argv[i]+1);
136 nrows = 0;
137 } else
138 nrows = atoi(argv[i]);
139 break;
140 case 'c':
141 correctaspect = !correctaspect;
142 break;
143 case 'p':
144 i++;
145 outaspect = atof(argv[i]);
146 break;
147 case 'e':
148 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
149 d = pow(2.0, atof(argv[i+1]));
150 else
151 d = atof(argv[i+1]);
152 if (d < 1e-20 || d > 1e20) {
153 fprintf(stderr,
154 "%s: exposure out of range\n",
155 argv[0]);
156 exit(1);
157 }
158 switch (argv[i][2]) {
159 case '\0':
160 scalecolor(exposure, d);
161 break;
162 case 'r':
163 colval(exposure,RED) *= d;
164 break;
165 case 'g':
166 colval(exposure,GRN) *= d;
167 break;
168 case 'b':
169 colval(exposure,BLU) *= d;
170 break;
171 default:
172 goto badopt;
173 }
174 i++;
175 break;
176 case 'f':
177 lampdat = argv[++i];
178 break;
179 case 't':
180 lamptype = argv[++i];
181 break;
182 case '1':
183 singlepass = 1;
184 break;
185 case '2':
186 singlepass = 0;
187 break;
188 case 'n':
189 npts = atoi(argv[++i]) / 2;
190 break;
191 case 's':
192 spread = atof(argv[++i]);
193 break;
194 case 'a':
195 avghot = !avghot;
196 break;
197 case 'h':
198 hotlvl = atof(argv[++i]);
199 break;
200 case 'r':
201 rad = atof(argv[++i]);
202 break;
203 case 'm':
204 thresh = atof(argv[++i]);
205 if (rad <= FTINY)
206 rad = 1.0;
207 break;
208 case 'b':
209 rad = thresh = 0.0;
210 break;
211 default:;
212 badopt:
213 fprintf(stderr, "%s: unknown option: %s\n",
214 progname, argv[i]);
215 quit(1);
216 break;
217 }
218 else
219 break;
220 /* get lamp data (if necessary) */
221 if (lamptype != NULL) {
222 if (loadlamps(lampdat) < 0)
223 quit(1);
224 if ((lampcolor = matchlamp(lamptype)) == NULL) {
225 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
226 quit(1);
227 }
228 for (j = 0; j < 3; j++)
229 if (lampcolor[j] > 1e-4)
230 colval(exposure,j) /= lampcolor[j];
231 freelamps();
232 }
233 /* open input file */
234 if (i == argc) {
235 if (singlepass)
236 fin = stdin;
237 else {
238 tfname = mktemp(template);
239 if ((fin = fopen(tfname, "w+")) == NULL) {
240 fprintf(stderr, "%s: can't create ", progname);
241 fprintf(stderr, "temp file \"%s\"\n", tfname);
242 quit(1);
243 }
244 copyfile(stdin, fin);
245 if (fseek(fin, 0L, 0) == -1) {
246 fprintf(stderr, "%s: seek fail\n", progname);
247 quit(1);
248 }
249 }
250 } else if (i == argc-1) {
251 if ((fin = fopen(argv[i], "r")) == NULL) {
252 fprintf(stderr, "%s: can't open file \"%s\"\n",
253 progname, argv[i]);
254 quit(1);
255 }
256 } else {
257 fprintf(stderr, "%s: bad # file arguments\n", progname);
258 quit(1);
259 }
260 /* get header */
261 getheader(fin, headline, NULL);
262 if (wrongformat) {
263 fprintf(stderr, "%s: input must be a Radiance picture\n",
264 progname);
265 quit(1);
266 }
267 /* add new header info. */
268 printargs(i, argv, stdout);
269 /* get picture size */
270 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
271 fprintf(stderr, "%s: bad picture size\n", progname);
272 quit(1);
273 }
274 if (!(order & YMAJOR))
275 inpaspect = 1.0/inpaspect;
276 /* wrap around for cylindrical view? */
277 wrapfilt = gotview && ourview.type == VT_CYL &&
278 ourview.horiz >= 360.-FTINY && order & YMAJOR;
279 /* compute output resolution */
280 if (ncols <= 0)
281 ncols = x_c*xres + .5;
282 if (nrows <= 0)
283 nrows = y_r*yres + .5;
284 if (outaspect > .01) {
285 d = inpaspect * yres/xres / outaspect;
286 if (d * ncols > nrows)
287 ncols = nrows / d;
288 else
289 nrows = ncols * d;
290 }
291 x_c = (double)ncols/xres;
292 y_r = (double)nrows/yres;
293
294 if (singlepass) { /* skip exposure, etc. */
295 pass1default();
296 pass2(fin);
297 quit(0);
298 }
299
300 fpos = ftell(fin); /* save input file position */
301
302 pass1(fin);
303
304 if (fseek(fin, fpos, 0) == -1) {
305 fprintf(stderr, "%s: seek fail\n", progname);
306 quit(1);
307 }
308 pass2(fin);
309
310 quit(0);
311 }
312
313
314 double
315 rgb_bright(clr)
316 COLOR clr;
317 {
318 return(bright(clr));
319 }
320
321
322 double
323 xyz_bright(clr)
324 COLOR clr;
325 {
326 return(clr[CIEY]);
327 }
328
329
330 double (*ourbright)() = rgb_bright;
331
332
333 headline(s) /* process line from header */
334 char *s;
335 {
336 char fmt[32];
337
338 fputs(s, stdout); /* copy to output */
339 if (isaspect(s)) /* get aspect ratio */
340 inpaspect *= aspectval(s);
341 else if (isexpos(s)) /* get exposure */
342 hotlvl *= exposval(s);
343 else if (formatval(fmt, s)) { /* get format */
344 wrongformat = 0;
345 if (!strcmp(COLRFMT, fmt))
346 ourbright = rgb_bright;
347 else if (!strcmp(CIEFMT, fmt))
348 ourbright = xyz_bright;
349 else
350 wrongformat = !globmatch(PICFMT, fmt);
351 } else if (isview(s) && sscanview(&ourview, s) > 0)
352 gotview++;
353 }
354
355
356 copyfile(in, out) /* copy a file */
357 register FILE *in, *out;
358 {
359 register int c;
360
361 while ((c = getc(in)) != EOF)
362 putc(c, out);
363
364 if (ferror(out)) {
365 fprintf(stderr, "%s: write error in copyfile\n", progname);
366 quit(1);
367 }
368 }
369
370
371 pass1(in) /* first pass of picture file */
372 FILE *in;
373 {
374 int i;
375 COLOR *scan;
376
377 pass1init();
378
379 scan = (COLOR *)malloc(xres*sizeof(COLOR));
380 if (scan == NULL) {
381 fprintf(stderr, "%s: out of memory\n", progname);
382 quit(1);
383 }
384 for (i = 0; i < yres; i++) {
385 if (freadscan(scan, xres, in) < 0) {
386 nrows = (long)nrows * i / yres; /* adjust frame */
387 if (nrows <= 0) {
388 fprintf(stderr, "%s: empty frame\n", progname);
389 quit(1);
390 }
391 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
392 progname, (int)(100L*i/yres));
393 yres = i;
394 y_r = (double)nrows/yres;
395 break;
396 }
397 pass1scan(scan, i);
398 }
399 free((char *)scan);
400 }
401
402
403 pass2(in) /* last pass on file, write to stdout */
404 FILE *in;
405 {
406 int yread;
407 int ycent, xcent;
408 int r, c;
409
410 pass2init();
411 scan2init();
412 yread = 0;
413 for (r = 0; r < nrows; r++) {
414 ycent = (long)r*yres/nrows;
415 while (yread <= ycent+yrad) {
416 if (yread < yres) {
417 if (freadscan(scanin[yread%barsize],
418 xres, in) < 0) {
419 fprintf(stderr,
420 "%s: truncated input (y=%d)\n",
421 progname, yres-1-yread);
422 quit(1);
423 }
424 pass2scan(scanin[yread%barsize], yread);
425 }
426 yread++;
427 }
428 if (obarsize > 0)
429 scan2sync(r);
430 for (c = 0; c < ncols; c++) {
431 xcent = (long)c*xres/ncols;
432 if (thresh > FTINY)
433 dothresh(xcent, ycent, c, r);
434 else if (rad > FTINY)
435 dogauss(scanout[c], xcent, ycent, c, r);
436 else
437 dobox(scanout[c], xcent, ycent, c, r);
438 }
439 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
440 fprintf(stderr, "%s: write error in pass2\n", progname);
441 quit(1);
442 }
443 }
444 /* skip leftover input */
445 while (yread < yres) {
446 if (freadscan(scanin[0], xres, in) < 0)
447 break;
448 yread++;
449 }
450 scan2flush(); /* flush output */
451 }
452
453
454 scan2init() /* prepare scanline arrays */
455 {
456 COLOR ctmp;
457 double d;
458 register int i;
459
460 xbrad = xres/ncols/2 + 1;
461 ybrad = yres/nrows/2 + 1;
462 if (rad > FTINY) {
463 if (nrows >= yres && ncols >= xres)
464 rad *= (y_r + x_c)/2.0;
465
466 if (thresh > FTINY) {
467 orad = CHECKRAD*THRESHRAD*rad + 1;
468 xrad = orad/x_c + xbrad;
469 yrad = orad/y_r + ybrad;
470 obarsize = 2*orad + 1;
471 } else {
472 xrad = CHECKRAD*rad/x_c + 1;
473 yrad = CHECKRAD*rad/y_r + 1;
474 }
475 initmask(); /* initialize filter table */
476 } else {
477 xrad = xbrad;
478 yrad = ybrad;
479 }
480 barsize = 2*yrad + 1;
481 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
482 if (scanin == NULL)
483 goto memerr;
484 for (i = 0; i < barsize; i++) {
485 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
486 if (scanin[i] == NULL)
487 goto memerr;
488 }
489 if (obarsize > 0) {
490 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
491 greybar = (float **)malloc(obarsize*sizeof(float *));
492 if (scoutbar == NULL | greybar == NULL)
493 goto memerr;
494 for (i = 0; i < obarsize; i++) {
495 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
496 greybar[i] = (float *)malloc(ncols*sizeof(float));
497 if (scoutbar[i] == NULL | greybar[i] == NULL)
498 goto memerr;
499 }
500 } else {
501 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
502 if (scanout == NULL)
503 goto memerr;
504 }
505 /* record pixel aspect ratio */
506 if (!correctaspect) {
507 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
508 if (!FEQ(d,1.0))
509 fputaspect(d, stdout);
510 }
511 /* record exposure */
512 d = (*ourbright)(exposure);
513 if (!FEQ(d,1.0))
514 fputexpos(d, stdout);
515 /* record color correction */
516 copycolor(ctmp, exposure);
517 scalecolor(ctmp, 1.0/d);
518 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
519 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
520 fputcolcor(ctmp, stdout);
521 printf("\n");
522 /* write out resolution */
523 fputresolu(order, ncols, nrows, stdout);
524 return;
525 memerr:
526 fprintf(stderr, "%s: out of memory\n", progname);
527 quit(1);
528 }
529
530
531 scan2sync(r) /* synchronize grey averages and output scan */
532 int r;
533 {
534 static int nextrow = 0;
535 COLOR ctmp;
536 int ybot;
537 register int c;
538 /* average input scanlines */
539 while (nextrow <= r+orad && nextrow < nrows) {
540 ybot = (long)nextrow*yres/nrows;
541 for (c = 0; c < ncols; c++) {
542 dobox(ctmp, (int)((long)c*xres/ncols),ybot, c,nextrow);
543 greybar[nextrow%obarsize][c] = (*ourbright)(ctmp);
544 }
545 /* and zero output scanline */
546 bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR));
547 nextrow++;
548 }
549 /* point to top scanline for output */
550 if (r-orad >= 0)
551 scanout = scoutbar[(r-orad)%obarsize];
552 else
553 scanout = NULL;
554 }
555
556
557 scan2flush() /* flush output buffer */
558 {
559 register int r;
560
561 for (r = nrows-orad; r < nrows; r++)
562 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
563 break;
564 if (fflush(stdout) < 0) {
565 fprintf(stderr, "%s: write error at end of pass2\n", progname);
566 exit(1);
567 }
568 }
569
570
571 quit(code) /* remove temporary file and exit */
572 int code;
573 {
574 if (tfname != NULL)
575 unlink(tfname);
576 exit(code);
577 }
