root/Development/ray/src/px/pfilt.c
Revision: 2.12
Committed: Thu Nov 18 09:56:17 1993 UTC (32 years ago) by greg
minor compiler warning fixes
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 * 6/23/93 Added additional buffers for value spreading
12 */
13
14 #include "standard.h"
15
16 #include <signal.h>
17
18 #include "color.h"
19
20 #include "resolu.h"
21
22 #include "paths.h"
23
24 extern float *matchlamp();
25
26 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
27
28 double CHECKRAD = 1.5; /* radius to check for filtering */
29
30 #define THRESHRAD 5.0 /* maximum sample spread in output */
31
32 COLOR exposure = WHTCOLOR; /* exposure for the frame */
33
34 double rad = 0.0; /* output pixel radius for filtering */
35
36 double thresh = 0.0; /* maximum contribution for subpixel */
37
38 int nrows = 0; /* number of rows for output */
39 int ncols = 0; /* number of columns for output */
40
41 double x_c = 1.0; /* ratio of output x size to input */
42 double y_r = 1.0; /* ratio of output y size to input */
43
44 int singlepass = 0; /* true means skip first pass */
45
46 int avghot = 0; /* true means average in bright spots */
47
48 double hotlvl = 100.0; /* level considered "hot" */
49
50 int npts = 0; /* (half) number of points for stars */
51
52 double spread = 1e-4; /* spread for star points */
53
54 char *tfname = NULL;
55
56 char template[] = TEMPLATE;
57
58 char *lampdat = "lamp.tab"; /* lamp data file */
59
60 int order; /* scanline ordering of input */
61 int xres, yres; /* resolution of input */
62 double inpaspect = 1.0; /* pixel aspect ratio of input */
63 int correctaspect = 0; /* aspect ratio correction? */
64
65 int wrongformat = 0;
66
67 int xrad; /* x search radius */
68 int yrad; /* y search radius */
69 int xbrad; /* x box size */
70 int ybrad; /* y box size */
71
72 int barsize; /* size of input scan bar */
73 COLOR **scanin; /* input scan bar */
74 COLOR *scanout; /* output scan line */
75 COLOR **scoutbar; /* output scan bar (if thresh > 0) */
76 float **greybar; /* grey-averaged input values */
77 int obarsize = 0; /* size of output scan bar */
78 int orad = 0; /* output window radius */
79
80 char *progname;
81
82
83 main(argc, argv)
84 int argc;
85 char **argv;
86 {
87 extern long ftell();
88 extern int quit(), headline();
89 FILE *fin;
90 float *lampcolor;
91 char *lamptype = NULL;
92 long fpos;
93 double outaspect = 0.0;
94 double d;
95 int i;
96 #ifdef MSDOS
97 extern int _fmode;
98 _fmode = O_BINARY;
99 setmode(fileno(stdin), O_BINARY);
100 setmode(fileno(stdout), O_BINARY);
101 #endif
102 if (signal(SIGINT, quit) == SIG_IGN)
103 signal(SIGINT, SIG_IGN);
104 if (signal(SIGHUP, quit) == SIG_IGN)
105 signal(SIGHUP, SIG_IGN);
106 signal(SIGTERM, quit);
107 signal(SIGPIPE, quit);
108 #ifdef SIGXCPU
109 signal(SIGXCPU, quit);
110 signal(SIGXFSZ, quit);
111 #endif
112
113 progname = argv[0] = fixargv0(argv[0]);
114
115 for (i = 1; i < argc; i++)
116 if (argv[i][0] == '-')
117 switch (argv[i][1]) {
118 case 'x':
119 i++;
120 if (argv[i][0] == '/') {
121 x_c = 1.0/atof(argv[i]+1);
122 ncols = 0;
123 } else
124 ncols = atoi(argv[i]);
125 break;
126 case 'y':
127 i++;
128 if (argv[i][0] == '/') {
129 y_r = 1.0/atof(argv[i]+1);
130 nrows = 0;
131 } else
132 nrows = atoi(argv[i]);
133 break;
134 case 'c':
135 correctaspect = !correctaspect;
136 break;
137 case 'p':
138 i++;
139 outaspect = atof(argv[i]);
140 break;
141 case 'e':
142 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
143 d = pow(2.0, atof(argv[i+1]));
144 else
145 d = atof(argv[i+1]);
146 if (d < 1e-20 || d > 1e20) {
147 fprintf(stderr,
148 "%s: exposure out of range\n",
149 argv[0]);
150 exit(1);
151 }
152 switch (argv[i][2]) {
153 case '\0':
154 scalecolor(exposure, d);
155 break;
156 case 'r':
157 colval(exposure,RED) *= d;
158 break;
159 case 'g':
160 colval(exposure,GRN) *= d;
161 break;
162 case 'b':
163 colval(exposure,BLU) *= d;
164 break;
165 default:
166 goto badopt;
167 }
168 i++;
169 break;
170 case 'f':
171 lampdat = argv[++i];
172 break;
173 case 't':
174 lamptype = argv[++i];
175 break;
176 case '1':
177 singlepass = 1;
178 break;
179 case '2':
180 singlepass = 0;
181 break;
182 case 'n':
183 npts = atoi(argv[++i]) / 2;
184 break;
185 case 's':
186 spread = atof(argv[++i]);
187 break;
188 case 'a':
189 avghot = !avghot;
190 break;
191 case 'h':
192 hotlvl = atof(argv[++i]);
193 break;
194 case 'r':
195 rad = atof(argv[++i]);
196 break;
197 case 'm':
198 thresh = atof(argv[++i]);
199 if (rad <= FTINY)
200 rad = 1.0;
201 break;
202 case 'b':
203 rad = thresh = 0.0;
204 break;
205 default:;
206 badopt:
207 fprintf(stderr, "%s: unknown option: %s\n",
208 progname, argv[i]);
209 quit(1);
210 break;
211 }
212 else
213 break;
214 /* get lamp data (if necessary) */
215 if (lamptype != NULL) {
216 if (loadlamps(lampdat) < 0)
217 quit(1);
218 if ((lampcolor = matchlamp(lamptype)) == NULL) {
219 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
220 quit(1);
221 }
222 for (i = 0; i < 3; i++)
223 if (lampcolor[i] > 1e-4)
224 colval(exposure,i) /= lampcolor[i];
225 freelamps();
226 }
227 /* open input file */
228 if (i == argc) {
229 if (singlepass)
230 fin = stdin;
231 else {
232 tfname = mktemp(template);
233 if ((fin = fopen(tfname, "w+")) == NULL) {
234 fprintf(stderr, "%s: can't create ", progname);
235 fprintf(stderr, "temp file \"%s\"\n", tfname);
236 quit(1);
237 }
238 copyfile(stdin, fin);
239 if (fseek(fin, 0L, 0) == -1) {
240 fprintf(stderr, "%s: seek fail\n", progname);
241 quit(1);
242 }
243 }
244 } else if (i == argc-1) {
245 if ((fin = fopen(argv[i], "r")) == NULL) {
246 fprintf(stderr, "%s: can't open file \"%s\"\n",
247 progname, argv[i]);
248 quit(1);
249 }
250 } else {
251 fprintf(stderr, "%s: bad # file arguments\n", progname);
252 quit(1);
253 }
254 /* get header */
255 getheader(fin, headline, NULL);
256 if (wrongformat) {
257 fprintf(stderr, "%s: input must be a Radiance picture\n",
258 progname);
259 quit(1);
260 }
261 /* add new header info. */
262 printargs(i, argv, stdout);
263 /* get picture size */
264 if ((order = fgetresolu(&xres, &yres, fin)) < 0) {
265 fprintf(stderr, "%s: bad picture size\n", progname);
266 quit(1);
267 }
268 if (!(order & YMAJOR))
269 inpaspect = 1.0/inpaspect;
270 /* compute output resolution */
271 if (ncols <= 0)
272 ncols = x_c*xres + .5;
273 if (nrows <= 0)
274 nrows = y_r*yres + .5;
275 if (outaspect > .01) {
276 d = inpaspect * yres/xres / outaspect;
277 if (d * ncols > nrows)
278 ncols = nrows / d;
279 else
280 nrows = ncols * d;
281 }
282 x_c = (double)ncols/xres;
283 y_r = (double)nrows/yres;
284
285 if (singlepass) { /* skip exposure, etc. */
286 pass1default();
287 pass2(fin);
288 quit(0);
289 }
290
291 fpos = ftell(fin); /* save input file position */
292
293 pass1(fin);
294
295 if (fseek(fin, fpos, 0) == -1) {
296 fprintf(stderr, "%s: seek fail\n", progname);
297 quit(1);
298 }
299 pass2(fin);
300
301 quit(0);
302 }
303
304
305 headline(s) /* process line from header */
306 char *s;
307 {
308 char fmt[32];
309
310 fputs(s, stdout); /* copy to output */
311 if (isaspect(s)) /* get aspect ratio */
312 inpaspect *= aspectval(s);
313 else if (isexpos(s))
314 hotlvl *= exposval(s);
315 else if (isformat(s)) {
316 formatval(fmt, s);
317 wrongformat = strcmp(fmt, COLRFMT);
318 }
319 }
320
321
322 copyfile(in, out) /* copy a file */
323 register FILE *in, *out;
324 {
325 register int c;
326
327 while ((c = getc(in)) != EOF)
328 putc(c, out);
329
330 if (ferror(out)) {
331 fprintf(stderr, "%s: write error in copyfile\n", progname);
332 quit(1);
333 }
334 }
335
336
337 pass1(in) /* first pass of picture file */
338 FILE *in;
339 {
340 int i;
341 COLOR *scan;
342
343 pass1init();
344
345 scan = (COLOR *)malloc(xres*sizeof(COLOR));
346 if (scan == NULL) {
347 fprintf(stderr, "%s: out of memory\n", progname);
348 quit(1);
349 }
350 for (i = 0; i < yres; i++) {
351 if (freadscan(scan, xres, in) < 0) {
352 nrows = (long)nrows * i / yres; /* adjust frame */
353 if (nrows <= 0) {
354 fprintf(stderr, "%s: empty frame\n", progname);
355 quit(1);
356 }
357 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
358 progname, (int)(100L*i/yres));
359 yres = i;
360 y_r = (double)nrows/yres;
361 break;
362 }
363 pass1scan(scan, i);
364 }
365 free((char *)scan);
366 }
367
368
369 pass2(in) /* last pass on file, write to stdout */
370 FILE *in;
371 {
372 int yread;
373 int ycent, xcent;
374 int r, c;
375
376 pass2init();
377 scan2init();
378 yread = 0;
379 for (r = 0; r < nrows; r++) {
380 ycent = (long)r*yres/nrows;
381 while (yread <= ycent+yrad) {
382 if (yread < yres) {
383 if (freadscan(scanin[yread%barsize],
384 xres, in) < 0) {
385 fprintf(stderr,
386 "%s: bad read (y=%d)\n",
387 progname, yres-1-yread);
388 quit(1);
389 }
390 pass2scan(scanin[yread%barsize], yread);
391 }
392 yread++;
393 }
394 if (obarsize > 0)
395 scan2sync(r);
396 for (c = 0; c < ncols; c++) {
397 xcent = (long)c*xres/ncols;
398 if (thresh > FTINY)
399 dothresh(xcent, ycent, c, r);
400 else if (rad > FTINY)
401 dogauss(scanout[c], xcent, ycent, c, r);
402 else
403 dobox(scanout[c], xcent, ycent, c, r);
404 }
405 if (scanout != NULL && fwritescan(scanout, ncols, stdout) < 0) {
406 fprintf(stderr, "%s: write error in pass2\n", progname);
407 quit(1);
408 }
409 }
410 /* skip leftover input */
411 while (yread < yres) {
412 if (freadscan(scanin[0], xres, in) < 0)
413 break;
414 yread++;
415 }
416 scan2flush(); /* flush output */
417 }
418
419
420 scan2init() /* prepare scanline arrays */
421 {
422 COLOR ctmp;
423 double d;
424 register int i;
425
426 xbrad = xres/ncols/2 + 1;
427 ybrad = yres/nrows/2 + 1;
428 if (rad > FTINY) {
429 if (nrows >= yres && ncols >= xres)
430 rad *= (y_r + x_c)/2.0;
431
432 if (thresh > FTINY) {
433 xrad = CHECKRAD*THRESHRAD*rad/x_c + xbrad;
434 yrad = CHECKRAD*THRESHRAD*rad/y_r + ybrad;
435 orad = CHECKRAD*THRESHRAD*rad + 1;
436 obarsize = 2*orad + 1;
437 } else {
438 xrad = CHECKRAD*rad/x_c + 1;
439 yrad = CHECKRAD*rad/y_r + 1;
440 }
441 initmask(); /* initialize filter table */
442 } else {
443 xrad = xbrad;
444 yrad = ybrad;
445 }
446 barsize = 2*yrad + 1;
447 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
448 if (scanin == NULL)
449 goto memerr;
450 for (i = 0; i < barsize; i++) {
451 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
452 if (scanin[i] == NULL)
453 goto memerr;
454 }
455 if (obarsize > 0) {
456 scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *));
457 greybar = (float **)malloc(obarsize*sizeof(float *));
458 if (scoutbar == NULL | greybar == NULL)
459 goto memerr;
460 for (i = 0; i < obarsize; i++) {
461 scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR));
462 greybar[i] = (float *)malloc(ncols*sizeof(float));
463 if (scoutbar[i] == NULL | greybar[i] == NULL)
464 goto memerr;
465 }
466 } else {
467 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
468 if (scanout == NULL)
469 goto memerr;
470 }
471 /* record pixel aspect ratio */
472 if (!correctaspect) {
473 d = order & YMAJOR ? x_c/y_r : y_r/x_c ;
474 if (!FEQ(d,1.0))
475 fputaspect(d, stdout);
476 }
477 /* record exposure */
478 d = bright(exposure);
479 if (!FEQ(d,1.0))
480 fputexpos(d, stdout);
481 /* record color correction */
482 copycolor(ctmp, exposure);
483 scalecolor(ctmp, 1.0/d);
484 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
485 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
486 fputcolcor(ctmp, stdout);
487 printf("\n");
488 /* write out resolution */
489 fputresolu(order, ncols, nrows, stdout);
490 return;
491 memerr:
492 fprintf(stderr, "%s: out of memory\n", progname);
493 quit(1);
494 }
495
496
497 scan2sync(r) /* synchronize grey averages and output scan */
498 int r;
499 {
500 static int nextrow = 0;
501 COLOR ctmp;
502 int ybot;
503 register int c;
504 /* average input scanlines */
505 while (nextrow < r+orad && nextrow < nrows) {
506 ybot = (long)nextrow*yres/nrows;
507 for (c = 0; c < ncols; c++) {
508 dobox(ctmp, (int)((long)c*xres/ncols),ybot, c,nextrow);
509 greybar[nextrow%obarsize][c] = bright(ctmp);
510 }
511 /* and zero output scanline */
512 bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR));
513 nextrow++;
514 }
515 /* point to top scanline for output */
516 if (r-orad >= 0)
517 scanout = scoutbar[(r-orad)%obarsize];
518 else
519 scanout = NULL;
520 }
521
522
523 scan2flush() /* flush output buffer */
524 {
525 register int r;
526
527 for (r = nrows-orad; r < nrows; r++)
528 if (fwritescan(scoutbar[r%obarsize], ncols, stdout) < 0)
529 break;
530 if (fflush(stdout) < 0) {
531 fprintf(stderr, "%s: write error at end of pass2\n", progname);
532 exit(1);
533 }
534 }
535
536
537 quit(code) /* remove temporary file and exit */
538 int code;
539 {
540 if (tfname != NULL)
541 unlink(tfname);
542 exit(code);
543 }
