1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* pfilt.c - program to post-process picture file. |
9 |
10 |
* 9/26/85 |
11 |
12 |
13 |
#include <stdio.h> |
14 |
15 |
#include <signal.h> |
16 |
17 |
#include "color.h" |
18 |
19 |
#include "resolu.h" |
20 |
21 |
extern char *malloc(); |
22 |
extern float *matchlamp(); |
23 |
24 |
#define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b)) |
25 |
26 |
#define CHECKRAD 1.5 /* radius to check for filtering */ |
27 |
28 |
COLOR exposure = WHTCOLOR; /* exposure for the frame */ |
29 |
30 |
double rad = 0.0; /* output pixel radius for filtering */ |
31 |
32 |
int nrows = 0; /* number of rows for output */ |
33 |
int ncols = 0; /* number of columns for output */ |
34 |
35 |
double x_c = 1.0; /* ratio of output x size to input */ |
36 |
double y_r = 1.0; /* ratio of output y size to input */ |
37 |
38 |
int singlepass = 0; /* true means skip first pass */ |
39 |
40 |
int avghot = 0; /* true means average in bright spots */ |
41 |
42 |
double hotlvl = 1000.0; /* level considered "hot" */ |
43 |
44 |
int npts = 0; /* (half) number of points for stars */ |
45 |
46 |
double spread = 1e-4; /* spread for star points */ |
47 |
48 |
#define TEMPLATE "/usr/tmp/pfXXXXXX" |
49 |
50 |
char *tfname = NULL; |
51 |
52 |
char *lampdat = "lamp.tab"; /* lamp data file */ |
53 |
54 |
int order; /* scanline ordering of input */ |
55 |
int xres, yres; /* resolution of input */ |
56 |
double inpaspect = 1.0; /* pixel aspect ratio of input */ |
57 |
int correctaspect = 0; /* aspect ratio correction? */ |
58 |
59 |
int wrongformat = 0; |
60 |
61 |
int xrad; /* x window size */ |
62 |
int yrad; /* y window size */ |
63 |
64 |
int barsize; /* size of input scan bar */ |
65 |
COLOR **scanin; /* input scan bar */ |
66 |
COLOR *scanout; /* output scan line */ |
67 |
68 |
char *progname; |
69 |
70 |
71 |
main(argc, argv) |
72 |
int argc; |
73 |
char **argv; |
74 |
75 |
extern char *mktemp(); |
76 |
extern double atof(), pow(); |
77 |
extern long ftell(); |
78 |
extern int quit(), headline(); |
79 |
FILE *fin; |
80 |
float *lampcolor; |
81 |
char *lamptype = NULL; |
82 |
long fpos; |
83 |
double outaspect = 0.0; |
84 |
double d; |
85 |
int i, j; |
86 |
87 |
if (signal(SIGINT, quit) == SIG_IGN) |
88 |
signal(SIGINT, SIG_IGN); |
89 |
if (signal(SIGHUP, quit) == SIG_IGN) |
90 |
91 |
signal(SIGTERM, quit); |
92 |
signal(SIGPIPE, quit); |
93 |
#ifdef SIGXCPU |
94 |
signal(SIGXCPU, quit); |
95 |
signal(SIGXFSZ, quit); |
96 |
#endif |
97 |
98 |
progname = argv[0]; |
99 |
100 |
for (i = 1; i < argc; i++) |
101 |
if (argv[i][0] == '-') |
102 |
switch (argv[i][1]) { |
103 |
case 'x': |
104 |
i++; |
105 |
if (argv[i][0] == '/') { |
106 |
x_c = 1.0/atof(argv[i]+1); |
107 |
ncols = 0; |
108 |
} else |
109 |
ncols = atoi(argv[i]); |
110 |
break; |
111 |
case 'y': |
112 |
i++; |
113 |
114 |
y_r = 1.0/atof(argv[i]+1); |
115 |
nrows = 0; |
116 |
} else |
117 |
nrows = atoi(argv[i]); |
118 |
break; |
119 |
case 'c': |
120 |
correctaspect = !correctaspect; |
121 |
break; |
122 |
case 'p': |
123 |
i++; |
124 |
outaspect = atof(argv[i]); |
125 |
break; |
126 |
case 'e': |
127 |
if (argv[i+1][0] == '+' || argv[i+1][0] == '-') |
128 |
d = pow(2.0, atof(argv[i+1])); |
129 |
else |
130 |
d = atof(argv[i+1]); |
131 |
if (d < 1e-20 || d > 1e20) { |
132 |
fprintf(stderr, |
133 |
"%s: exposure out of range\n", |
134 |
argv[0]); |
135 |
exit(1); |
136 |
137 |
switch (argv[i][2]) { |
138 |
case '\0': |
139 |
scalecolor(exposure, d); |
140 |
break; |
141 |
case 'r': |
142 |
colval(exposure,RED) *= d; |
143 |
break; |
144 |
case 'g': |
145 |
colval(exposure,GRN) *= d; |
146 |
break; |
147 |
case 'b': |
148 |
colval(exposure,BLU) *= d; |
149 |
break; |
150 |
default: |
151 |
goto badopt; |
152 |
153 |
i++; |
154 |
break; |
155 |
case 'f': |
156 |
lampdat = argv[++i]; |
157 |
break; |
158 |
case 't': |
159 |
lamptype = argv[++i]; |
160 |
break; |
161 |
case '1': |
162 |
singlepass = 1; |
163 |
break; |
164 |
case '2': |
165 |
singlepass = 0; |
166 |
break; |
167 |
case 'n': |
168 |
npts = atoi(argv[++i]) / 2; |
169 |
break; |
170 |
case 's': |
171 |
spread = atof(argv[++i]); |
172 |
break; |
173 |
case 'a': |
174 |
avghot = !avghot; |
175 |
break; |
176 |
case 'h': |
177 |
hotlvl = atof(argv[++i]); |
178 |
break; |
179 |
case 'r': |
180 |
rad = atof(argv[++i]); |
181 |
break; |
182 |
case 'b': |
183 |
rad = 0.0; |
184 |
break; |
185 |
default:; |
186 |
badopt: |
187 |
fprintf(stderr, "%s: unknown option: %s\n", |
188 |
progname, argv[i]); |
189 |
quit(1); |
190 |
break; |
191 |
192 |
else |
193 |
break; |
194 |
/* get lamp data (if necessary) */ |
195 |
if (lamptype != NULL) { |
196 |
if (loadlamps(lampdat) < 0) |
197 |
quit(1); |
198 |
if ((lampcolor = matchlamp(lamptype)) == NULL) { |
199 |
fprintf(stderr, "%s: unknown lamp type\n", lamptype); |
200 |
quit(1); |
201 |
202 |
for (i = 0; i < 3; i++) |
203 |
if (lampcolor[i] > 1e-4) |
204 |
colval(exposure,i) /= lampcolor[i]; |
205 |
freelamps(); |
206 |
207 |
/* open input file */ |
208 |
if (i == argc) { |
209 |
if (singlepass) |
210 |
fin = stdin; |
211 |
else { |
212 |
tfname = mktemp(TEMPLATE); |
213 |
if ((fin = fopen(tfname, "w+")) == NULL) { |
214 |
fprintf(stderr, "%s: can't create ", progname); |
215 |
fprintf(stderr, "temp file \"%s\"\n", tfname); |
216 |
quit(1); |
217 |
218 |
copyfile(stdin, fin); |
219 |
if (fseek(fin, 0L, 0) == -1) { |
220 |
fprintf(stderr, "%s: seek fail\n", progname); |
221 |
quit(1); |
222 |
223 |
224 |
} else if (i == argc-1) { |
225 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
226 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
227 |
228 |
quit(1); |
229 |
230 |
} else { |
231 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
232 |
quit(1); |
233 |
234 |
/* get header */ |
235 |
getheader(fin, headline, NULL); |
236 |
if (wrongformat) { |
237 |
fprintf(stderr, "%s: input must be a Radiance picture\n", |
238 |
progname); |
239 |
quit(1); |
240 |
241 |
/* add new header info. */ |
242 |
printargs(i, argv, stdout); |
243 |
/* get picture size */ |
244 |
if ((order = fgetresolu(&xres, &yres, fin)) < 0) { |
245 |
fprintf(stderr, "%s: bad picture size\n", progname); |
246 |
quit(1); |
247 |
248 |
if (!(order & YMAJOR)) |
249 |
inpaspect = 1.0/inpaspect; |
250 |
/* compute output resolution */ |
251 |
if (ncols <= 0) |
252 |
ncols = x_c*xres + .5; |
253 |
if (nrows <= 0) |
254 |
nrows = y_r*yres + .5; |
255 |
if (outaspect > .01) { |
256 |
d = inpaspect * yres/xres / outaspect; |
257 |
if (d * ncols > nrows) |
258 |
ncols = nrows / d; |
259 |
else |
260 |
nrows = ncols * d; |
261 |
262 |
x_c = (double)ncols/xres; |
263 |
y_r = (double)nrows/yres; |
264 |
265 |
if (singlepass) { /* skip exposure, etc. */ |
266 |
pass1default(); |
267 |
pass2(fin); |
268 |
quit(0); |
269 |
270 |
271 |
fpos = ftell(fin); /* save input file position */ |
272 |
273 |
pass1(fin); |
274 |
275 |
if (fseek(fin, fpos, 0) == -1) { |
276 |
277 |
quit(1); |
278 |
279 |
pass2(fin); |
280 |
281 |
quit(0); |
282 |
283 |
284 |
285 |
headline(s) /* process line from header */ |
286 |
char *s; |
287 |
288 |
char fmt[32]; |
289 |
290 |
fputs(s, stdout); /* copy to output */ |
291 |
if (isaspect(s)) /* get aspect ratio */ |
292 |
inpaspect *= aspectval(s); |
293 |
else if (isformat(s)) { |
294 |
formatval(fmt, s); |
295 |
wrongformat = strcmp(fmt, COLRFMT); |
296 |
297 |
298 |
299 |
300 |
copyfile(in, out) /* copy a file */ |
301 |
register FILE *in, *out; |
302 |
303 |
register int c; |
304 |
305 |
while ((c = getc(in)) != EOF) |
306 |
putc(c, out); |
307 |
308 |
if (ferror(out)) { |
309 |
fprintf(stderr, "%s: write error in copyfile\n", progname); |
310 |
quit(1); |
311 |
312 |
313 |
314 |
315 |
pass1(in) /* first pass of picture file */ |
316 |
FILE *in; |
317 |
318 |
int i; |
319 |
COLOR *scan; |
320 |
321 |
pass1init(); |
322 |
323 |
scan = (COLOR *)malloc(xres*sizeof(COLOR)); |
324 |
if (scan == NULL) { |
325 |
fprintf(stderr, "%s: out of memory\n", progname); |
326 |
quit(1); |
327 |
328 |
for (i = 0; i < yres; i++) { |
329 |
if (freadscan(scan, xres, in) < 0) { |
330 |
nrows = nrows * i / yres; /* adjust frame */ |
331 |
if (nrows <= 0) { |
332 |
fprintf(stderr, "%s: empty frame\n", progname); |
333 |
quit(1); |
334 |
335 |
fprintf(stderr, "%s: warning - partial frame (%d%%)\n", |
336 |
progname, 100*i/yres); |
337 |
yres = i; |
338 |
339 |
break; |
340 |
341 |
pass1scan(scan, i); |
342 |
343 |
free((char *)scan); |
344 |
345 |
346 |
347 |
pass2(in) /* last pass on file, write to stdout */ |
348 |
FILE *in; |
349 |
350 |
int yread; |
351 |
int ycent, xcent; |
352 |
int r, c; |
353 |
354 |
pass2init(); |
355 |
scan2init(); |
356 |
yread = 0; |
357 |
for (r = 0; r < nrows; r++) { |
358 |
ycent = (long)r*yres/nrows; |
359 |
while (yread <= ycent+yrad) { |
360 |
if (yread < yres) { |
361 |
if (freadscan(scanin[yread%barsize], |
362 |
xres, in) < 0) { |
363 |
fprintf(stderr, |
364 |
"%s: bad read (y=%d)\n", |
365 |
progname, yres-1-yread); |
366 |
quit(1); |
367 |
368 |
pass2scan(scanin[yread%barsize], yread); |
369 |
370 |
yread++; |
371 |
372 |
for (c = 0; c < ncols; c++) { |
373 |
xcent = (long)c*xres/ncols; |
374 |
if (rad <= 0.0) |
375 |
dobox(scanout[c], xcent, ycent, c, r); |
376 |
else |
377 |
dogauss(scanout[c], xcent, ycent, c, r); |
378 |
379 |
if (fwritescan(scanout, ncols, stdout) < 0) { |
380 |
fprintf(stderr, "%s: write error in pass2\n", progname); |
381 |
quit(1); |
382 |
383 |
384 |
/* skip leftovers */ |
385 |
while (yread < yres) { |
386 |
if (freadscan(scanin[0], xres, in) < 0) |
387 |
break; |
388 |
yread++; |
389 |
390 |
391 |
392 |
393 |
scan2init() /* prepare scanline arrays */ |
394 |
395 |
COLOR ctmp; |
396 |
double d; |
397 |
register int i; |
398 |
399 |
if (rad <= 0.0) { |
400 |
xrad = xres/ncols/2 + 1; |
401 |
yrad = yres/nrows/2 + 1; |
402 |
} else { |
403 |
if (nrows >= yres && ncols >= xres) |
404 |
rad *= (y_r + x_c)/2.0; |
405 |
406 |
xrad = CHECKRAD*rad/x_c + 1; |
407 |
yrad = CHECKRAD*rad/y_r + 1; |
408 |
409 |
initmask(); /* initialize filter table */ |
410 |
411 |
barsize = 2*yrad + 1; |
412 |
scanin = (COLOR **)malloc(barsize*sizeof(COLOR *)); |
413 |
for (i = 0; i < barsize; i++) { |
414 |
scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR)); |
415 |
if (scanin[i] == NULL) { |
416 |
417 |
quit(1); |
418 |
419 |
420 |
scanout = (COLOR *)malloc(ncols*sizeof(COLOR)); |
421 |
if (scanout == NULL) { |
422 |
423 |
quit(1); |
424 |
425 |
/* record pixel aspect ratio */ |
426 |
if (!correctaspect) { |
427 |
d = order & YMAJOR ? x_c/y_r : y_r/x_c ; |
428 |
if (!FEQ(d,1.0)) |
429 |
fputaspect(d, stdout); |
430 |
431 |
/* record exposure */ |
432 |
d = bright(exposure); |
433 |
if (!FEQ(d,1.0)) |
434 |
fputexpos(d, stdout); |
435 |
/* record color correction */ |
436 |
copycolor(ctmp, exposure); |
437 |
scalecolor(ctmp, 1.0/d); |
438 |
if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) || |
439 |
!FEQ(colval(ctmp,GRN),colval(ctmp,BLU))) |
440 |
fputcolcor(ctmp, stdout); |
441 |
printf("\n"); |
442 |
/* write out resolution */ |
443 |
fputresolu(order, ncols, nrows, stdout); |
444 |
445 |
446 |
447 |
quit(code) /* remove temporary file and exit */ |
448 |
int code; |
449 |
450 |
if (tfname != NULL) |
451 |
unlink(tfname); |
452 |
exit(code); |
453 |
