| 1 |
/* Copyright (c) 1986 Regents of the University of California */
| 2 |
| 3 |
#ifndef lint
| 4 |
static char SCCSid[] = "$SunId$ LBL";
| 5 |
#endif
| 6 |
| 7 |
| 8 |
* pfilt.c - program to post-process picture file.
| 9 |
| 10 |
* 9/26/85
| 11 |
| 12 |
| 13 |
#include <stdio.h>
| 14 |
| 15 |
#include <signal.h>
| 16 |
| 17 |
#include "color.h"
| 18 |
| 19 |
| 20 |
extern char *malloc();
| 21 |
| 22 |
#define CHECKRAD 1.5 /* radius to check for filtering */
| 23 |
| 24 |
COLOR exposure = WHTCOLOR; /* exposure for the frame */
| 25 |
| 26 |
double rad = 0.0; /* output pixel radius for filtering */
| 27 |
| 28 |
int nrows = 0; /* number of rows for output */
| 29 |
int ncols = 0; /* number of columns for output */
| 30 |
| 31 |
double x_c = 1.0; /* ratio of output x size to input */
| 32 |
double y_r = 1.0; /* ratio of output y size to input */
| 33 |
| 34 |
int singlepass = 0; /* true means skip first pass */
| 35 |
| 36 |
int avghot = 0; /* true means average in bright spots */
| 37 |
| 38 |
double hotlvl = 1000.0; /* level considered "hot" */
| 39 |
| 40 |
int npts = 0; /* (half) number of points for stars */
| 41 |
| 42 |
double spread = 1e-4; /* spread for star points */
| 43 |
| 44 |
#define TEMPLATE "/usr/tmp/pfXXXXXX"
| 45 |
| 46 |
char *tfname = NULL;
| 47 |
| 48 |
int xres, yres; /* resolution of input */
| 49 |
| 50 |
int xrad; /* x window size */
| 51 |
int yrad; /* y window size */
| 52 |
| 53 |
int barsize; /* size of input scan bar */
| 54 |
COLOR **scanin; /* input scan bar */
| 55 |
COLOR *scanout; /* output scan line */
| 56 |
| 57 |
char *progname;
| 58 |
| 59 |
| 60 |
main(argc, argv)
| 61 |
int argc;
| 62 |
char **argv;
| 63 |
| 64 |
extern char *mktemp();
| 65 |
extern double atof(), pow();
| 66 |
extern long ftell();
| 67 |
extern int quit();
| 68 |
FILE *fin;
| 69 |
long fpos;
| 70 |
double d;
| 71 |
int i;
| 72 |
| 73 |
if (signal(SIGINT, quit) == SIG_IGN)
| 74 |
signal(SIGINT, SIG_IGN);
| 75 |
if (signal(SIGHUP, quit) == SIG_IGN)
| 76 |
| 77 |
signal(SIGTERM, quit);
| 78 |
signal(SIGPIPE, quit);
| 79 |
#ifdef SIGXCPU
| 80 |
signal(SIGXCPU, quit);
| 81 |
signal(SIGXFSZ, quit);
| 82 |
#endif
| 83 |
| 84 |
progname = argv[0];
| 85 |
| 86 |
for (i = 1; i < argc; i++)
| 87 |
if (argv[i][0] == '-')
| 88 |
switch (argv[i][1]) {
| 89 |
case 'x':
| 90 |
i++;
| 91 |
if (argv[i][0] == '/') {
| 92 |
x_c = 1.0/atof(argv[i]+1);
| 93 |
ncols = 0;
| 94 |
} else
| 95 |
ncols = atoi(argv[i]);
| 96 |
break;
| 97 |
case 'y':
| 98 |
i++;
| 99 |
| 100 |
y_r = 1.0/atof(argv[i]+1);
| 101 |
nrows = 0;
| 102 |
} else
| 103 |
nrows = atoi(argv[i]);
| 104 |
break;
| 105 |
case 'e':
| 106 |
if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
| 107 |
d = pow(2.0, atof(argv[i+1]));
| 108 |
else
| 109 |
d = atof(argv[i+1]);
| 110 |
switch (argv[i][2]) {
| 111 |
case '\0':
| 112 |
scalecolor(exposure, d);
| 113 |
break;
| 114 |
case 'r':
| 115 |
colval(exposure,RED) *= d;
| 116 |
break;
| 117 |
case 'g':
| 118 |
colval(exposure,GRN) *= d;
| 119 |
break;
| 120 |
case 'b':
| 121 |
colval(exposure,BLU) *= d;
| 122 |
break;
| 123 |
default:
| 124 |
goto badopt;
| 125 |
| 126 |
i++;
| 127 |
break;
| 128 |
case '1':
| 129 |
singlepass = 1;
| 130 |
break;
| 131 |
case '2':
| 132 |
singlepass = 0;
| 133 |
break;
| 134 |
case 'p':
| 135 |
npts = atoi(argv[++i]) / 2;
| 136 |
break;
| 137 |
case 's':
| 138 |
spread = atof(argv[++i]);
| 139 |
break;
| 140 |
case 'a':
| 141 |
avghot = !avghot;
| 142 |
break;
| 143 |
case 'h':
| 144 |
hotlvl = atof(argv[++i]);
| 145 |
break;
| 146 |
case 'r':
| 147 |
rad = atof(argv[++i]);
| 148 |
break;
| 149 |
case 'b':
| 150 |
rad = 0.0;
| 151 |
break;
| 152 |
default:;
| 153 |
badopt:
| 154 |
fprintf(stderr, "%s: unknown option: %s\n",
| 155 |
progname, argv[i]);
| 156 |
quit(1);
| 157 |
break;
| 158 |
| 159 |
else
| 160 |
break;
| 161 |
| 162 |
if (i == argc) {
| 163 |
if (singlepass)
| 164 |
fin = stdin;
| 165 |
else {
| 166 |
tfname = mktemp(TEMPLATE);
| 167 |
if ((fin = fopen(tfname, "w+")) == NULL) {
| 168 |
fprintf(stderr, "%s: can't create ", progname);
| 169 |
fprintf(stderr, "temp file \"%s\"\n", tfname);
| 170 |
quit(1);
| 171 |
| 172 |
copyfile(stdin, fin);
| 173 |
if (fseek(fin, 0L, 0) == -1) {
| 174 |
fprintf(stderr, "%s: seek fail\n", progname);
| 175 |
quit(1);
| 176 |
| 177 |
| 178 |
} else if (i == argc-1) {
| 179 |
if ((fin = fopen(argv[i], "r")) == NULL) {
| 180 |
fprintf(stderr, "%s: can't open file \"%s\"\n",
| 181 |
progname, argv[i]);
| 182 |
quit(1);
| 183 |
| 184 |
} else {
| 185 |
fprintf(stderr, "%s: bad # file arguments\n", progname);
| 186 |
quit(1);
| 187 |
| 188 |
/* copy header */
| 189 |
copyheader(fin, stdout);
| 190 |
/* add new header info. */
| 191 |
printargs(i, argv, stdout);
| 192 |
/* get picture size */
| 193 |
if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) {
| 194 |
fprintf(stderr, "%s: bad picture size\n", progname);
| 195 |
quit(1);
| 196 |
| 197 |
if (ncols > 0)
| 198 |
x_c = (double)ncols/xres;
| 199 |
else
| 200 |
ncols = x_c*xres + .5;
| 201 |
if (nrows > 0)
| 202 |
y_r = (double)nrows/yres;
| 203 |
else
| 204 |
nrows = y_r*yres + .5;
| 205 |
| 206 |
if (singlepass) {
| 207 |
/* skip exposure, etc. */
| 208 |
pass1default();
| 209 |
pass2(fin);
| 210 |
quit(0);
| 211 |
| 212 |
| 213 |
fpos = ftell(fin); /* save input file position */
| 214 |
| 215 |
pass1(fin);
| 216 |
| 217 |
if (fseek(fin, fpos, 0) == -1) {
| 218 |
| 219 |
quit(1);
| 220 |
| 221 |
pass2(fin);
| 222 |
| 223 |
quit(0);
| 224 |
| 225 |
| 226 |
| 227 |
copyfile(in, out) /* copy a file */
| 228 |
register FILE *in, *out;
| 229 |
| 230 |
register int c;
| 231 |
| 232 |
while ((c = getc(in)) != EOF)
| 233 |
putc(c, out);
| 234 |
| 235 |
if (ferror(out)) {
| 236 |
fprintf(stderr, "%s: write error in copyfile\n", progname);
| 237 |
quit(1);
| 238 |
| 239 |
| 240 |
| 241 |
| 242 |
pass1(in) /* first pass of picture file */
| 243 |
FILE *in;
| 244 |
| 245 |
int i;
| 246 |
COLOR *scan;
| 247 |
| 248 |
pass1init();
| 249 |
| 250 |
scan = (COLOR *)malloc(xres*sizeof(COLOR));
| 251 |
if (scan == NULL) {
| 252 |
fprintf(stderr, "%s: out of memory\n", progname);
| 253 |
quit(1);
| 254 |
| 255 |
for (i = 0; i < yres; i++) {
| 256 |
if (freadscan(scan, xres, in) < 0) {
| 257 |
nrows = nrows * i / yres; /* adjust frame */
| 258 |
if (nrows <= 0) {
| 259 |
fprintf(stderr, "%s: empty frame\n", progname);
| 260 |
quit(1);
| 261 |
| 262 |
fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
| 263 |
progname, 100*i/yres);
| 264 |
yres = i;
| 265 |
break;
| 266 |
| 267 |
pass1scan(scan, i);
| 268 |
| 269 |
free((char *)scan);
| 270 |
| 271 |
| 272 |
| 273 |
pass2(in) /* last pass on file, write to stdout */
| 274 |
FILE *in;
| 275 |
| 276 |
int yread;
| 277 |
int ycent, xcent;
| 278 |
int r, c;
| 279 |
| 280 |
pass2init();
| 281 |
scan2init();
| 282 |
yread = 0;
| 283 |
for (r = 0; r < nrows; r++) {
| 284 |
ycent = (long)r*yres/nrows;
| 285 |
while (yread <= ycent+yrad) {
| 286 |
if (yread < yres) {
| 287 |
if (freadscan(scanin[yread%barsize],
| 288 |
xres, in) < 0) {
| 289 |
fprintf(stderr,
| 290 |
"%s: bad read (y=%d)\n",
| 291 |
progname, yres-1-yread);
| 292 |
quit(1);
| 293 |
| 294 |
pass2scan(scanin[yread%barsize], yread);
| 295 |
| 296 |
yread++;
| 297 |
| 298 |
for (c = 0; c < ncols; c++) {
| 299 |
xcent = (long)c*xres/ncols;
| 300 |
if (rad <= 0.0)
| 301 |
dobox(scanout[c], xcent, ycent, c, r);
| 302 |
else
| 303 |
dogauss(scanout[c], xcent, ycent, c, r);
| 304 |
| 305 |
if (fwritescan(scanout, ncols, stdout) < 0) {
| 306 |
fprintf(stderr, "%s: write error in pass2\n", progname);
| 307 |
quit(1);
| 308 |
| 309 |
| 310 |
| 311 |
| 312 |
| 313 |
scan2init() /* prepare scanline arrays */
| 314 |
| 315 |
double e;
| 316 |
register int i;
| 317 |
| 318 |
if (rad <= 0.0) {
| 319 |
xrad = xres/ncols/2 + 1;
| 320 |
yrad = yres/nrows/2 + 1;
| 321 |
} else {
| 322 |
if (nrows >= yres && ncols >= xres)
| 323 |
rad *= (y_r + x_c)/2.0;
| 324 |
| 325 |
xrad = CHECKRAD*rad/x_c + 1;
| 326 |
yrad = CHECKRAD*rad/y_r + 1;
| 327 |
| 328 |
initmask(); /* initialize filter table */
| 329 |
| 330 |
barsize = 2 * yrad;
| 331 |
scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
| 332 |
for (i = 0; i < barsize; i++) {
| 333 |
scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
| 334 |
if (scanin[i] == NULL) {
| 335 |
| 336 |
quit(1);
| 337 |
| 338 |
| 339 |
scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
| 340 |
if (scanout == NULL) {
| 341 |
| 342 |
quit(1);
| 343 |
| 344 |
e = bright(exposure);
| 345 |
if (e < 1-1e-7 || e > 1+1e-7) /* record exposure */
| 346 |
fputexpos(e, stdout);
| 347 |
printf("\n");
| 348 |
fputresolu(YMAJOR|YDECR, ncols, nrows, stdout); /* resolution */
| 349 |
| 350 |
| 351 |
| 352 |
quit(code) /* remove temporary file and exit */
| 353 |
int code;
| 354 |
| 355 |
if (tfname != NULL)
| 356 |
unlink(tfname);
| 357 |
exit(code);
| 358 |
