root/radiance/ray/src/px/pfilt.c
Revision: 1.5
Committed: Thu Apr 13 07:52:50 1989 UTC (35 years ago) by greg
Changes since 1.4: +6 -4 lines
resolution ratio supercedes previous specification
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19
20 extern char *malloc();
21
22 #define CHECKRAD 1.5 /* radius to check for filtering */
23
24 COLOR exposure = WHTCOLOR; /* exposure for the frame */
25
26 double rad = 0.0; /* output pixel radius for filtering */
27
28 int nrows = 0; /* number of rows for output */
29 int ncols = 0; /* number of columns for output */
30
31 double x_c = 1.0; /* ratio of output x size to input */
32 double y_r = 1.0; /* ratio of output y size to input */
33
34 int singlepass = 0; /* true means skip first pass */
35
36 int avghot = 0; /* true means average in bright spots */
37
38 double hotlvl = 1000.0; /* level considered "hot" */
39
40 int npts = 0; /* (half) number of points for stars */
41
42 double spread = 1e-4; /* spread for star points */
43
44 #define TEMPLATE "/usr/tmp/pfXXXXXX"
45
46 char *tfname = NULL;
47
48 int xres, yres; /* resolution of input */
49
50 int xrad; /* x window size */
51 int yrad; /* y window size */
52
53 int barsize; /* size of input scan bar */
54 COLOR **scanin; /* input scan bar */
55 COLOR *scanout; /* output scan line */
56
57 char *progname;
58
59
60 main(argc, argv)
61 int argc;
62 char **argv;
63 {
64 extern char *mktemp();
65 extern double atof(), pow();
66 extern long ftell();
67 extern int quit();
68 FILE *fin;
69 long fpos;
70 double d;
71 int i;
72
73 if (signal(SIGINT, quit) == SIG_IGN)
74 signal(SIGINT, SIG_IGN);
75 if (signal(SIGHUP, quit) == SIG_IGN)
76 signal(SIGINT, SIG_IGN);
77 signal(SIGTERM, quit);
78 signal(SIGPIPE, quit);
79 #ifdef SIGXCPU
80 signal(SIGXCPU, quit);
81 signal(SIGXFSZ, quit);
82 #endif
83
84 progname = argv[0];
85
86 for (i = 1; i < argc; i++)
87 if (argv[i][0] == '-')
88 switch (argv[i][1]) {
89 case 'x':
90 i++;
91 if (argv[i][0] == '/') {
92 x_c = 1.0/atof(argv[i]+1);
93 ncols = 0;
94 } else
95 ncols = atoi(argv[i]);
96 break;
97 case 'y':
98 i++;
99 if (argv[i][0] == '/') {
100 y_r = 1.0/atof(argv[i]+1);
101 nrows = 0;
102 } else
103 nrows = atoi(argv[i]);
104 break;
105 case 'e':
106 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
107 d = pow(2.0, atof(argv[i+1]));
108 else
109 d = atof(argv[i+1]);
110 switch (argv[i][2]) {
111 case '\0':
112 scalecolor(exposure, d);
113 break;
114 case 'r':
115 colval(exposure,RED) *= d;
116 break;
117 case 'g':
118 colval(exposure,GRN) *= d;
119 break;
120 case 'b':
121 colval(exposure,BLU) *= d;
122 break;
123 default:
124 goto badopt;
125 }
126 i++;
127 break;
128 case '1':
129 singlepass = 1;
130 break;
131 case 'p':
132 npts = atoi(argv[++i]) / 2;
133 break;
134 case 's':
135 spread = atof(argv[++i]);
136 break;
137 case 'a':
138 avghot = !avghot;
139 break;
140 case 'h':
141 hotlvl = atof(argv[++i]);
142 break;
143 case 'r':
144 rad = atof(argv[++i]);
145 break;
146 case 'b':
147 rad = 0.0;
148 break;
149 default:;
150 badopt:
151 fprintf(stderr, "%s: unknown option: %s\n",
152 progname, argv[i]);
153 quit(1);
154 break;
155 }
156 else
157 break;
158
159 if (i == argc) {
160 if (singlepass)
161 fin = stdin;
162 else {
163 tfname = mktemp(TEMPLATE);
164 if ((fin = fopen(tfname, "w+")) == NULL) {
165 fprintf(stderr, "%s: can't create ", progname);
166 fprintf(stderr, "temp file \"%s\"\n", tfname);
167 quit(1);
168 }
169 copyfile(stdin, fin);
170 if (fseek(fin, 0L, 0) == -1) {
171 fprintf(stderr, "%s: seek fail\n", progname);
172 quit(1);
173 }
174 }
175 } else if (i == argc-1) {
176 if ((fin = fopen(argv[i], "r")) == NULL) {
177 fprintf(stderr, "%s: can't open file \"%s\"\n",
178 progname, argv[i]);
179 quit(1);
180 }
181 } else {
182 fprintf(stderr, "%s: bad # file arguments\n", progname);
183 quit(1);
184 }
185 /* copy header */
186 copyheader(fin, stdout);
187 /* add new header info. */
188 printargs(i, argv, stdout);
189 /* get picture size */
190 if (fscanf(fin, "-Y %d +X %d\n", &yres, &xres) != 2) {
191 fprintf(stderr, "%s: bad picture size\n", progname);
192 quit(1);
193 }
194 if (ncols > 0)
195 x_c = (double)ncols/xres;
196 else
197 ncols = x_c*xres + .5;
198 if (nrows > 0)
199 y_r = (double)nrows/yres;
200 else
201 nrows = y_r*yres + .5;
202
203 if (singlepass) {
204 /* skip exposure, etc. */
205 pass1default();
206 pass2(fin);
207 quit(0);
208 }
209
210 fpos = ftell(fin); /* save input file position */
211
212 pass1(fin);
213
214 if (fseek(fin, fpos, 0) == -1) {
215 fprintf(stderr, "%s: seek fail\n", progname);
216 quit(1);
217 }
218 pass2(fin);
219
220 quit(0);
221 }
222
223
224 copyfile(in, out) /* copy a file */
225 register FILE *in, *out;
226 {
227 register int c;
228
229 while ((c = getc(in)) != EOF)
230 putc(c, out);
231
232 if (ferror(out)) {
233 fprintf(stderr, "%s: write error in copyfile\n", progname);
234 quit(1);
235 }
236 }
237
238
239 pass1(in) /* first pass of picture file */
240 FILE *in;
241 {
242 int i;
243 COLOR *scan;
244
245 pass1init();
246
247 scan = (COLOR *)malloc(xres*sizeof(COLOR));
248 if (scan == NULL) {
249 fprintf(stderr, "%s: out of memory\n", progname);
250 quit(1);
251 }
252 for (i = 0; i < yres; i++) {
253 if (freadscan(scan, xres, in) < 0) {
254 nrows = nrows * i / yres; /* adjust frame */
255 if (nrows <= 0) {
256 fprintf(stderr, "%s: empty frame\n", progname);
257 quit(1);
258 }
259 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
260 progname, 100*i/yres);
261 yres = i;
262 break;
263 }
264 pass1scan(scan, i);
265 }
266 free((char *)scan);
267 }
268
269
270 pass2(in) /* last pass on file, write to stdout */
271 FILE *in;
272 {
273 int yread;
274 int ycent, xcent;
275 int r, c;
276
277 pass2init();
278 scan2init();
279 yread = 0;
280 for (r = 0; r < nrows; r++) {
281 ycent = (long)r*yres/nrows;
282 while (yread <= ycent+yrad) {
283 if (yread < yres) {
284 if (freadscan(scanin[yread%barsize],
285 xres, in) < 0) {
286 fprintf(stderr,
287 "%s: bad read (y=%d)\n",
288 progname, yres-1-yread);
289 quit(1);
290 }
291 pass2scan(scanin[yread%barsize], yread);
292 }
293 yread++;
294 }
295 for (c = 0; c < ncols; c++) {
296 xcent = (long)c*xres/ncols;
297 if (rad <= 0.0)
298 dobox(scanout[c], xcent, ycent, c, r);
299 else
300 dogauss(scanout[c], xcent, ycent, c, r);
301 }
302 if (fwritescan(scanout, ncols, stdout) < 0) {
303 fprintf(stderr, "%s: write error in pass2\n", progname);
304 quit(1);
305 }
306 }
307 }
308
309
310 scan2init() /* prepare scanline arrays */
311 {
312 double e;
313 register int i;
314
315 if (rad <= 0.0) {
316 xrad = xres/ncols/2 + 1;
317 yrad = yres/nrows/2 + 1;
318 } else {
319 if (nrows >= yres && ncols >= xres)
320 rad *= (y_r + x_c)/2.0;
321
322 xrad = CHECKRAD*rad/x_c + 1;
323 yrad = CHECKRAD*rad/y_r + 1;
324
325 initmask(); /* initialize filter table */
326 }
327 barsize = 2 * yrad;
328 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
329 for (i = 0; i < barsize; i++) {
330 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
331 if (scanin[i] == NULL) {
332 fprintf(stderr, "%s: out of memory\n", progname);
333 quit(1);
334 }
335 }
336 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
337 if (scanout == NULL) {
338 fprintf(stderr, "%s: out of memory\n", progname);
339 quit(1);
340 }
341 e = bright(exposure);
342 if (e < 1-1e-7 || e > 1+1e-7) /* record exposure */
343 printf("EXPOSURE=%e\n", e);
344 printf("\n");
345 printf("-Y %d +X %d\n", nrows, ncols); /* write picture size */
346 }
347
348
349 quit(code) /* remove temporary file and exit */
350 int code;
351 {
352 if (tfname != NULL)
353 unlink(tfname);
354 exit(code);
355 }
