root/radiance/ray/src/px/pfilt.c
Revision: 1.17
Committed: Wed Jun 5 12:15:30 1991 UTC (34 years ago) by greg
improved gaussian filtering
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19 extern char *malloc();
20 extern float *matchlamp();
21
22 #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b))
23
24 #define CHECKRAD 1.5 /* radius to check for filtering */
25
26 COLOR exposure = WHTCOLOR; /* exposure for the frame */
27
28 double rad = 0.0; /* output pixel radius for filtering */
29
30 int nrows = 0; /* number of rows for output */
31 int ncols = 0; /* number of columns for output */
32
33 double x_c = 1.0; /* ratio of output x size to input */
34 double y_r = 1.0; /* ratio of output y size to input */
35
36 int singlepass = 0; /* true means skip first pass */
37
38 int avghot = 0; /* true means average in bright spots */
39
40 double hotlvl = 1000.0; /* level considered "hot" */
41
42 int npts = 0; /* (half) number of points for stars */
43
44 double spread = 1e-4; /* spread for star points */
45
46 #define TEMPLATE "/usr/tmp/pfXXXXXX"
47
48 char *tfname = NULL;
49
50 char *lampdat = "lamp.tab"; /* lamp data file */
51
52 int xres, yres; /* resolution of input */
53 double inpaspect = 1.0; /* pixel aspect ratio of input */
54 int correctaspect = 0; /* aspect ratio correction? */
55
56 int wrongformat = 0;
57
58 int xrad; /* x window size */
59 int yrad; /* y window size */
60
61 int barsize; /* size of input scan bar */
62 COLOR **scanin; /* input scan bar */
63 COLOR *scanout; /* output scan line */
64
65 char *progname;
66
67
68 main(argc, argv)
69 int argc;
70 char **argv;
71 {
72 extern char *mktemp();
73 extern double atof(), pow();
74 extern long ftell();
75 extern int quit(), headline();
76 FILE *fin;
77 float *lampcolor;
78 char *lamptype = NULL;
79 long fpos;
80 double outaspect = 0.0;
81 double d;
82 int i;
83
84 if (signal(SIGINT, quit) == SIG_IGN)
85 signal(SIGINT, SIG_IGN);
86 if (signal(SIGHUP, quit) == SIG_IGN)
87 signal(SIGINT, SIG_IGN);
88 signal(SIGTERM, quit);
89 signal(SIGPIPE, quit);
90 #ifdef SIGXCPU
91 signal(SIGXCPU, quit);
92 signal(SIGXFSZ, quit);
93 #endif
94
95 progname = argv[0];
96
97 for (i = 1; i < argc; i++)
98 if (argv[i][0] == '-')
99 switch (argv[i][1]) {
100 case 'x':
101 i++;
102 if (argv[i][0] == '/') {
103 x_c = 1.0/atof(argv[i]+1);
104 ncols = 0;
105 } else
106 ncols = atoi(argv[i]);
107 break;
108 case 'y':
109 i++;
110 if (argv[i][0] == '/') {
111 y_r = 1.0/atof(argv[i]+1);
112 nrows = 0;
113 } else
114 nrows = atoi(argv[i]);
115 break;
116 case 'c':
117 correctaspect = !correctaspect;
118 break;
119 case 'p':
120 i++;
121 outaspect = atof(argv[i]);
122 break;
123 case 'e':
124 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
125 d = pow(2.0, atof(argv[i+1]));
126 else
127 d = atof(argv[i+1]);
128 if (d < 1e-20 || d > 1e20) {
129 fprintf(stderr,
130 "%s: exposure out of range\n",
131 argv[0]);
132 exit(1);
133 }
134 switch (argv[i][2]) {
135 case '\0':
136 scalecolor(exposure, d);
137 break;
138 case 'r':
139 colval(exposure,RED) *= d;
140 break;
141 case 'g':
142 colval(exposure,GRN) *= d;
143 break;
144 case 'b':
145 colval(exposure,BLU) *= d;
146 break;
147 default:
148 goto badopt;
149 }
150 i++;
151 break;
152 case 'f':
153 lampdat = argv[++i];
154 break;
155 case 't':
156 lamptype = argv[++i];
157 break;
158 case '1':
159 singlepass = 1;
160 break;
161 case '2':
162 singlepass = 0;
163 break;
164 case 'n':
165 npts = atoi(argv[++i]) / 2;
166 break;
167 case 's':
168 spread = atof(argv[++i]);
169 break;
170 case 'a':
171 avghot = !avghot;
172 break;
173 case 'h':
174 hotlvl = atof(argv[++i]);
175 break;
176 case 'r':
177 rad = atof(argv[++i]);
178 break;
179 case 'b':
180 rad = 0.0;
181 break;
182 default:;
183 badopt:
184 fprintf(stderr, "%s: unknown option: %s\n",
185 progname, argv[i]);
186 quit(1);
187 break;
188 }
189 else
190 break;
191 /* get lamp data (if necessary) */
192 if (lamptype != NULL) {
193 if (loadlamps(lampdat) < 0)
194 quit(1);
195 if ((lampcolor = matchlamp(lamptype)) == NULL) {
196 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
197 quit(1);
198 }
199 colval(exposure,RED) /= lampcolor[0];
200 colval(exposure,GRN) /= lampcolor[1];
201 colval(exposure,BLU) /= lampcolor[2];
202 freelamps();
203 }
204 /* open input file */
205 if (i == argc) {
206 if (singlepass)
207 fin = stdin;
208 else {
209 tfname = mktemp(TEMPLATE);
210 if ((fin = fopen(tfname, "w+")) == NULL) {
211 fprintf(stderr, "%s: can't create ", progname);
212 fprintf(stderr, "temp file \"%s\"\n", tfname);
213 quit(1);
214 }
215 copyfile(stdin, fin);
216 if (fseek(fin, 0L, 0) == -1) {
217 fprintf(stderr, "%s: seek fail\n", progname);
218 quit(1);
219 }
220 }
221 } else if (i == argc-1) {
222 if ((fin = fopen(argv[i], "r")) == NULL) {
223 fprintf(stderr, "%s: can't open file \"%s\"\n",
224 progname, argv[i]);
225 quit(1);
226 }
227 } else {
228 fprintf(stderr, "%s: bad # file arguments\n", progname);
229 quit(1);
230 }
231 /* get header */
232 getheader(fin, headline, NULL);
233 if (wrongformat) {
234 fprintf(stderr, "%s: input must be a Radiance picture\n",
235 progname);
236 quit(1);
237 }
238 /* add new header info. */
239 printargs(i, argv, stdout);
240 /* get picture size */
241 if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) {
242 fprintf(stderr, "%s: bad picture size\n", progname);
243 quit(1);
244 }
245 /* compute output resolution */
246 if (ncols <= 0)
247 ncols = x_c*xres + .5;
248 if (nrows <= 0)
249 nrows = y_r*yres + .5;
250 if (outaspect > .01) {
251 d = inpaspect * yres/xres / outaspect;
252 if (d * ncols > nrows)
253 ncols = nrows / d;
254 else
255 nrows = ncols * d;
256 }
257 x_c = (double)ncols/xres;
258 y_r = (double)nrows/yres;
259
260 if (singlepass) { /* skip exposure, etc. */
261 pass1default();
262 pass2(fin);
263 quit(0);
264 }
265
266 fpos = ftell(fin); /* save input file position */
267
268 pass1(fin);
269
270 if (fseek(fin, fpos, 0) == -1) {
271 fprintf(stderr, "%s: seek fail\n", progname);
272 quit(1);
273 }
274 pass2(fin);
275
276 quit(0);
277 }
278
279
280 headline(s) /* process line from header */
281 char *s;
282 {
283 char fmt[32];
284
285 fputs(s, stdout); /* copy to output */
286 if (isaspect(s)) /* get aspect ratio */
287 inpaspect *= aspectval(s);
288 else if (isformat(s)) {
289 formatval(fmt, s);
290 wrongformat = strcmp(fmt, COLRFMT);
291 }
292 }
293
294
295 copyfile(in, out) /* copy a file */
296 register FILE *in, *out;
297 {
298 register int c;
299
300 while ((c = getc(in)) != EOF)
301 putc(c, out);
302
303 if (ferror(out)) {
304 fprintf(stderr, "%s: write error in copyfile\n", progname);
305 quit(1);
306 }
307 }
308
309
310 pass1(in) /* first pass of picture file */
311 FILE *in;
312 {
313 int i;
314 COLOR *scan;
315
316 pass1init();
317
318 scan = (COLOR *)malloc(xres*sizeof(COLOR));
319 if (scan == NULL) {
320 fprintf(stderr, "%s: out of memory\n", progname);
321 quit(1);
322 }
323 for (i = 0; i < yres; i++) {
324 if (freadscan(scan, xres, in) < 0) {
325 nrows = nrows * i / yres; /* adjust frame */
326 if (nrows <= 0) {
327 fprintf(stderr, "%s: empty frame\n", progname);
328 quit(1);
329 }
330 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
331 progname, 100*i/yres);
332 yres = i;
333 y_r = (double)nrows/yres;
334 break;
335 }
336 pass1scan(scan, i);
337 }
338 free((char *)scan);
339 }
340
341
342 pass2(in) /* last pass on file, write to stdout */
343 FILE *in;
344 {
345 int yread;
346 int ycent, xcent;
347 int r, c;
348
349 pass2init();
350 scan2init();
351 yread = 0;
352 for (r = 0; r < nrows; r++) {
353 ycent = (long)r*yres/nrows;
354 while (yread <= ycent+yrad) {
355 if (yread < yres) {
356 if (freadscan(scanin[yread%barsize],
357 xres, in) < 0) {
358 fprintf(stderr,
359 "%s: bad read (y=%d)\n",
360 progname, yres-1-yread);
361 quit(1);
362 }
363 pass2scan(scanin[yread%barsize], yread);
364 }
365 yread++;
366 }
367 for (c = 0; c < ncols; c++) {
368 xcent = (long)c*xres/ncols;
369 if (rad <= 0.0)
370 dobox(scanout[c], xcent, ycent, c, r);
371 else
372 dogauss(scanout[c], xcent, ycent, c, r);
373 }
374 if (fwritescan(scanout, ncols, stdout) < 0) {
375 fprintf(stderr, "%s: write error in pass2\n", progname);
376 quit(1);
377 }
378 }
379 /* skip leftovers */
380 while (yread < yres) {
381 if (freadscan(scanin[0], xres, in) < 0)
382 break;
383 yread++;
384 }
385 }
386
387
388 scan2init() /* prepare scanline arrays */
389 {
390 COLOR ctmp;
391 double d;
392 register int i;
393
394 if (rad <= 0.0) {
395 xrad = xres/ncols/2 + 1;
396 yrad = yres/nrows/2 + 1;
397 } else {
398 if (nrows >= yres && ncols >= xres)
399 rad *= (y_r + x_c)/2.0;
400
401 xrad = CHECKRAD*rad/x_c + 1;
402 yrad = CHECKRAD*rad/y_r + 1;
403
404 initmask(); /* initialize filter table */
405 }
406 barsize = 2*yrad + 1;
407 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
408 for (i = 0; i < barsize; i++) {
409 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
410 if (scanin[i] == NULL) {
411 fprintf(stderr, "%s: out of memory\n", progname);
412 quit(1);
413 }
414 }
415 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
416 if (scanout == NULL) {
417 fprintf(stderr, "%s: out of memory\n", progname);
418 quit(1);
419 }
420 /* record pixel aspect ratio */
421 if (!correctaspect) {
422 d = x_c / y_r;
423 if (!FEQ(d,1.0))
424 fputaspect(d, stdout);
425 }
426 /* record exposure */
427 d = bright(exposure);
428 if (!FEQ(d,1.0))
429 fputexpos(d, stdout);
430 /* record color correction */
431 copycolor(ctmp, exposure);
432 scalecolor(ctmp, 1.0/d);
433 if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) ||
434 !FEQ(colval(ctmp,GRN),colval(ctmp,BLU)))
435 fputcolcor(ctmp, stdout);
436 printf("\n");
437 /* write out resolution */
438 fputresolu(YMAJOR|YDECR, ncols, nrows, stdout);
439 }
440
441
442 quit(code) /* remove temporary file and exit */
443 int code;
444 {
445 if (tfname != NULL)
446 unlink(tfname);
447 exit(code);
448 }
