1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* pfilt.c - program to post-process picture file. |
9 |
10 |
* 9/26/85 |
11 |
12 |
13 |
#include <stdio.h> |
14 |
15 |
#include <signal.h> |
16 |
17 |
#include "color.h" |
18 |
19 |
extern char *malloc(); |
20 |
extern float *matchlamp(); |
21 |
22 |
#define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b)) |
23 |
24 |
#define CHECKRAD 1.5 /* radius to check for filtering */ |
25 |
26 |
COLOR exposure = WHTCOLOR; /* exposure for the frame */ |
27 |
28 |
double rad = 0.0; /* output pixel radius for filtering */ |
29 |
30 |
int nrows = 0; /* number of rows for output */ |
31 |
int ncols = 0; /* number of columns for output */ |
32 |
33 |
double x_c = 1.0; /* ratio of output x size to input */ |
34 |
double y_r = 1.0; /* ratio of output y size to input */ |
35 |
36 |
int singlepass = 0; /* true means skip first pass */ |
37 |
38 |
int avghot = 0; /* true means average in bright spots */ |
39 |
40 |
double hotlvl = 1000.0; /* level considered "hot" */ |
41 |
42 |
int npts = 0; /* (half) number of points for stars */ |
43 |
44 |
double spread = 1e-4; /* spread for star points */ |
45 |
46 |
#define TEMPLATE "/usr/tmp/pfXXXXXX" |
47 |
48 |
char *tfname = NULL; |
49 |
50 |
char *lampdat = "lamp.tab"; /* lamp data file */ |
51 |
52 |
int xres, yres; /* resolution of input */ |
53 |
double inpaspect = 1.0; /* pixel aspect ratio of input */ |
54 |
int correctaspect = 0; /* aspect ratio correction? */ |
55 |
56 |
int xrad; /* x window size */ |
57 |
int yrad; /* y window size */ |
58 |
59 |
int barsize; /* size of input scan bar */ |
60 |
COLOR **scanin; /* input scan bar */ |
61 |
COLOR *scanout; /* output scan line */ |
62 |
63 |
char *progname; |
64 |
65 |
66 |
main(argc, argv) |
67 |
int argc; |
68 |
char **argv; |
69 |
70 |
extern char *mktemp(); |
71 |
extern double atof(), pow(); |
72 |
extern long ftell(); |
73 |
extern int quit(), headline(); |
74 |
FILE *fin; |
75 |
float *lampcolor; |
76 |
char *lamptype = NULL; |
77 |
long fpos; |
78 |
double outaspect = 0.0; |
79 |
double d; |
80 |
int i; |
81 |
82 |
if (signal(SIGINT, quit) == SIG_IGN) |
83 |
signal(SIGINT, SIG_IGN); |
84 |
if (signal(SIGHUP, quit) == SIG_IGN) |
85 |
86 |
signal(SIGTERM, quit); |
87 |
signal(SIGPIPE, quit); |
88 |
#ifdef SIGXCPU |
89 |
signal(SIGXCPU, quit); |
90 |
signal(SIGXFSZ, quit); |
91 |
#endif |
92 |
93 |
progname = argv[0]; |
94 |
95 |
for (i = 1; i < argc; i++) |
96 |
if (argv[i][0] == '-') |
97 |
switch (argv[i][1]) { |
98 |
case 'x': |
99 |
i++; |
100 |
if (argv[i][0] == '/') { |
101 |
x_c = 1.0/atof(argv[i]+1); |
102 |
ncols = 0; |
103 |
} else |
104 |
ncols = atoi(argv[i]); |
105 |
break; |
106 |
case 'y': |
107 |
i++; |
108 |
109 |
y_r = 1.0/atof(argv[i]+1); |
110 |
nrows = 0; |
111 |
} else |
112 |
nrows = atoi(argv[i]); |
113 |
break; |
114 |
case 'c': |
115 |
correctaspect = !correctaspect; |
116 |
break; |
117 |
case 'p': |
118 |
i++; |
119 |
outaspect = atof(argv[i]); |
120 |
break; |
121 |
case 'e': |
122 |
if (argv[i+1][0] == '+' || argv[i+1][0] == '-') |
123 |
d = pow(2.0, atof(argv[i+1])); |
124 |
else |
125 |
d = atof(argv[i+1]); |
126 |
if (d < 1e-20 || d > 1e20) { |
127 |
fprintf(stderr, |
128 |
"%s: exposure out of range\n", |
129 |
argv[0]); |
130 |
exit(1); |
131 |
132 |
switch (argv[i][2]) { |
133 |
case '\0': |
134 |
scalecolor(exposure, d); |
135 |
break; |
136 |
case 'r': |
137 |
colval(exposure,RED) *= d; |
138 |
break; |
139 |
case 'g': |
140 |
colval(exposure,GRN) *= d; |
141 |
break; |
142 |
case 'b': |
143 |
colval(exposure,BLU) *= d; |
144 |
break; |
145 |
default: |
146 |
goto badopt; |
147 |
148 |
i++; |
149 |
break; |
150 |
case 'f': |
151 |
lampdat = argv[++i]; |
152 |
break; |
153 |
case 't': |
154 |
lamptype = argv[++i]; |
155 |
break; |
156 |
case '1': |
157 |
singlepass = 1; |
158 |
break; |
159 |
case '2': |
160 |
singlepass = 0; |
161 |
break; |
162 |
case 'n': |
163 |
npts = atoi(argv[++i]) / 2; |
164 |
break; |
165 |
case 's': |
166 |
spread = atof(argv[++i]); |
167 |
break; |
168 |
case 'a': |
169 |
avghot = !avghot; |
170 |
break; |
171 |
case 'h': |
172 |
hotlvl = atof(argv[++i]); |
173 |
break; |
174 |
case 'r': |
175 |
rad = atof(argv[++i]); |
176 |
break; |
177 |
case 'b': |
178 |
rad = 0.0; |
179 |
break; |
180 |
default:; |
181 |
badopt: |
182 |
fprintf(stderr, "%s: unknown option: %s\n", |
183 |
progname, argv[i]); |
184 |
quit(1); |
185 |
break; |
186 |
187 |
else |
188 |
break; |
189 |
/* get lamp data (if necessary) */ |
190 |
if (lamptype != NULL) { |
191 |
if (loadlamps(lampdat) < 0) |
192 |
quit(1); |
193 |
if ((lampcolor = matchlamp(lamptype)) == NULL) { |
194 |
fprintf(stderr, "%s: unknown lamp type\n", lamptype); |
195 |
quit(1); |
196 |
197 |
colval(exposure,RED) /= lampcolor[0]; |
198 |
colval(exposure,GRN) /= lampcolor[1]; |
199 |
colval(exposure,BLU) /= lampcolor[2]; |
200 |
freelamps(); |
201 |
202 |
/* open input file */ |
203 |
if (i == argc) { |
204 |
if (singlepass) |
205 |
fin = stdin; |
206 |
else { |
207 |
tfname = mktemp(TEMPLATE); |
208 |
if ((fin = fopen(tfname, "w+")) == NULL) { |
209 |
fprintf(stderr, "%s: can't create ", progname); |
210 |
fprintf(stderr, "temp file \"%s\"\n", tfname); |
211 |
quit(1); |
212 |
213 |
copyfile(stdin, fin); |
214 |
if (fseek(fin, 0L, 0) == -1) { |
215 |
fprintf(stderr, "%s: seek fail\n", progname); |
216 |
quit(1); |
217 |
218 |
219 |
} else if (i == argc-1) { |
220 |
if ((fin = fopen(argv[i], "r")) == NULL) { |
221 |
fprintf(stderr, "%s: can't open file \"%s\"\n", |
222 |
223 |
quit(1); |
224 |
225 |
} else { |
226 |
fprintf(stderr, "%s: bad # file arguments\n", progname); |
227 |
quit(1); |
228 |
229 |
/* get header */ |
230 |
getheader(fin, headline); |
231 |
/* add new header info. */ |
232 |
printargs(i, argv, stdout); |
233 |
/* get picture size */ |
234 |
if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) { |
235 |
fprintf(stderr, "%s: bad picture size\n", progname); |
236 |
quit(1); |
237 |
238 |
/* compute output resolution */ |
239 |
if (ncols <= 0) |
240 |
ncols = x_c*xres + .5; |
241 |
if (nrows <= 0) |
242 |
nrows = y_r*yres + .5; |
243 |
if (outaspect > .01) { |
244 |
d = inpaspect * yres/xres / outaspect; |
245 |
if (d * ncols > nrows) |
246 |
ncols = nrows / d; |
247 |
else |
248 |
nrows = ncols * d; |
249 |
250 |
x_c = (double)ncols/xres; |
251 |
y_r = (double)nrows/yres; |
252 |
253 |
if (singlepass) { /* skip exposure, etc. */ |
254 |
pass1default(); |
255 |
pass2(fin); |
256 |
quit(0); |
257 |
258 |
259 |
fpos = ftell(fin); /* save input file position */ |
260 |
261 |
pass1(fin); |
262 |
263 |
if (fseek(fin, fpos, 0) == -1) { |
264 |
265 |
quit(1); |
266 |
267 |
pass2(fin); |
268 |
269 |
quit(0); |
270 |
271 |
272 |
273 |
headline(s) /* process line from header */ |
274 |
char *s; |
275 |
276 |
fputs(s, stdout); /* copy to output */ |
277 |
if (isaspect(s)) /* get aspect ratio */ |
278 |
inpaspect *= aspectval(s); |
279 |
280 |
281 |
282 |
copyfile(in, out) /* copy a file */ |
283 |
register FILE *in, *out; |
284 |
285 |
register int c; |
286 |
287 |
while ((c = getc(in)) != EOF) |
288 |
putc(c, out); |
289 |
290 |
if (ferror(out)) { |
291 |
fprintf(stderr, "%s: write error in copyfile\n", progname); |
292 |
quit(1); |
293 |
294 |
295 |
296 |
297 |
pass1(in) /* first pass of picture file */ |
298 |
FILE *in; |
299 |
300 |
int i; |
301 |
COLOR *scan; |
302 |
303 |
pass1init(); |
304 |
305 |
scan = (COLOR *)malloc(xres*sizeof(COLOR)); |
306 |
if (scan == NULL) { |
307 |
fprintf(stderr, "%s: out of memory\n", progname); |
308 |
quit(1); |
309 |
310 |
for (i = 0; i < yres; i++) { |
311 |
if (freadscan(scan, xres, in) < 0) { |
312 |
nrows = nrows * i / yres; /* adjust frame */ |
313 |
if (nrows <= 0) { |
314 |
fprintf(stderr, "%s: empty frame\n", progname); |
315 |
quit(1); |
316 |
317 |
fprintf(stderr, "%s: warning - partial frame (%d%%)\n", |
318 |
progname, 100*i/yres); |
319 |
yres = i; |
320 |
321 |
break; |
322 |
323 |
pass1scan(scan, i); |
324 |
325 |
free((char *)scan); |
326 |
327 |
328 |
329 |
pass2(in) /* last pass on file, write to stdout */ |
330 |
FILE *in; |
331 |
332 |
int yread; |
333 |
int ycent, xcent; |
334 |
int r, c; |
335 |
336 |
pass2init(); |
337 |
scan2init(); |
338 |
yread = 0; |
339 |
for (r = 0; r < nrows; r++) { |
340 |
ycent = (long)r*yres/nrows; |
341 |
while (yread <= ycent+yrad) { |
342 |
if (yread < yres) { |
343 |
if (freadscan(scanin[yread%barsize], |
344 |
xres, in) < 0) { |
345 |
fprintf(stderr, |
346 |
"%s: bad read (y=%d)\n", |
347 |
progname, yres-1-yread); |
348 |
quit(1); |
349 |
350 |
pass2scan(scanin[yread%barsize], yread); |
351 |
352 |
yread++; |
353 |
354 |
for (c = 0; c < ncols; c++) { |
355 |
xcent = (long)c*xres/ncols; |
356 |
if (rad <= 0.0) |
357 |
dobox(scanout[c], xcent, ycent, c, r); |
358 |
else |
359 |
dogauss(scanout[c], xcent, ycent, c, r); |
360 |
361 |
if (fwritescan(scanout, ncols, stdout) < 0) { |
362 |
fprintf(stderr, "%s: write error in pass2\n", progname); |
363 |
quit(1); |
364 |
365 |
366 |
/* skip leftovers */ |
367 |
while (yread < yres) { |
368 |
if (freadscan(scanin[0], xres, in) < 0) |
369 |
break; |
370 |
yread++; |
371 |
372 |
373 |
374 |
375 |
scan2init() /* prepare scanline arrays */ |
376 |
377 |
COLOR ctmp; |
378 |
double d; |
379 |
register int i; |
380 |
381 |
if (rad <= 0.0) { |
382 |
xrad = xres/ncols/2 + 1; |
383 |
yrad = yres/nrows/2 + 1; |
384 |
} else { |
385 |
if (nrows >= yres && ncols >= xres) |
386 |
rad *= (y_r + x_c)/2.0; |
387 |
388 |
xrad = CHECKRAD*rad/x_c + 1; |
389 |
yrad = CHECKRAD*rad/y_r + 1; |
390 |
391 |
initmask(); /* initialize filter table */ |
392 |
393 |
barsize = 2 * yrad; |
394 |
scanin = (COLOR **)malloc(barsize*sizeof(COLOR *)); |
395 |
for (i = 0; i < barsize; i++) { |
396 |
scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR)); |
397 |
if (scanin[i] == NULL) { |
398 |
399 |
quit(1); |
400 |
401 |
402 |
scanout = (COLOR *)malloc(ncols*sizeof(COLOR)); |
403 |
if (scanout == NULL) { |
404 |
405 |
quit(1); |
406 |
407 |
/* record pixel aspect ratio */ |
408 |
if (!correctaspect) { |
409 |
d = x_c / y_r; |
410 |
if (!FEQ(d,1.0)) |
411 |
fputaspect(d, stdout); |
412 |
413 |
/* record exposure */ |
414 |
d = bright(exposure); |
415 |
if (!FEQ(d,1.0)) |
416 |
fputexpos(d, stdout); |
417 |
/* record color correction */ |
418 |
copycolor(ctmp, exposure); |
419 |
scalecolor(ctmp, 1.0/d); |
420 |
if (!FEQ(colval(ctmp,RED),colval(ctmp,GRN)) || |
421 |
!FEQ(colval(ctmp,GRN),colval(ctmp,BLU))) |
422 |
fputcolcor(ctmp, stdout); |
423 |
printf("\n"); |
424 |
/* write out resolution */ |
425 |
fputresolu(YMAJOR|YDECR, ncols, nrows, stdout); |
426 |
427 |
428 |
429 |
quit(code) /* remove temporary file and exit */ |
430 |
int code; |
431 |
432 |
if (tfname != NULL) |
433 |
unlink(tfname); |
434 |
exit(code); |
435 |
