root/radiance/ray/src/px/pfilt.c
Revision: 1.13
Committed: Sat Dec 8 10:14:33 1990 UTC (33 years, 5 months ago) by greg
Changes since 1.12: +24 -0 lines
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19 extern char *malloc();
20 extern float *matchlamp();
21
22 #define CHECKRAD 1.5 /* radius to check for filtering */
23
24 COLOR exposure = WHTCOLOR; /* exposure for the frame */
25
26 double rad = 0.0; /* output pixel radius for filtering */
27
28 int nrows = 0; /* number of rows for output */
29 int ncols = 0; /* number of columns for output */
30
31 double x_c = 1.0; /* ratio of output x size to input */
32 double y_r = 1.0; /* ratio of output y size to input */
33
34 int singlepass = 0; /* true means skip first pass */
35
36 int avghot = 0; /* true means average in bright spots */
37
38 double hotlvl = 1000.0; /* level considered "hot" */
39
40 int npts = 0; /* (half) number of points for stars */
41
42 double spread = 1e-4; /* spread for star points */
43
44 #define TEMPLATE "/usr/tmp/pfXXXXXX"
45
46 char *tfname = NULL;
47
48 char *lampdat = "lamp.tab"; /* lamp data file */
49
50 int xres, yres; /* resolution of input */
51 double inpaspect = 1.0; /* pixel aspect ratio of input */
52 int correctaspect = 0; /* aspect ratio correction? */
53
54 int xrad; /* x window size */
55 int yrad; /* y window size */
56
57 int barsize; /* size of input scan bar */
58 COLOR **scanin; /* input scan bar */
59 COLOR *scanout; /* output scan line */
60
61 char *progname;
62
63
64 main(argc, argv)
65 int argc;
66 char **argv;
67 {
68 extern char *mktemp();
69 extern double atof(), pow();
70 extern long ftell();
71 extern int quit(), headline();
72 FILE *fin;
73 float *lampcolor;
74 char *lamptype = NULL;
75 long fpos;
76 double outaspect = 0.0;
77 double d;
78 int i;
79
80 if (signal(SIGINT, quit) == SIG_IGN)
81 signal(SIGINT, SIG_IGN);
82 if (signal(SIGHUP, quit) == SIG_IGN)
83 signal(SIGINT, SIG_IGN);
84 signal(SIGTERM, quit);
85 signal(SIGPIPE, quit);
86 #ifdef SIGXCPU
87 signal(SIGXCPU, quit);
88 signal(SIGXFSZ, quit);
89 #endif
90
91 progname = argv[0];
92
93 for (i = 1; i < argc; i++)
94 if (argv[i][0] == '-')
95 switch (argv[i][1]) {
96 case 'x':
97 i++;
98 if (argv[i][0] == '/') {
99 x_c = 1.0/atof(argv[i]+1);
100 ncols = 0;
101 } else
102 ncols = atoi(argv[i]);
103 break;
104 case 'y':
105 i++;
106 if (argv[i][0] == '/') {
107 y_r = 1.0/atof(argv[i]+1);
108 nrows = 0;
109 } else
110 nrows = atoi(argv[i]);
111 break;
112 case 'c':
113 correctaspect = !correctaspect;
114 break;
115 case 'p':
116 i++;
117 outaspect = atof(argv[i]);
118 break;
119 case 'e':
120 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
121 d = pow(2.0, atof(argv[i+1]));
122 else
123 d = atof(argv[i+1]);
124 switch (argv[i][2]) {
125 case '\0':
126 scalecolor(exposure, d);
127 break;
128 case 'r':
129 colval(exposure,RED) *= d;
130 break;
131 case 'g':
132 colval(exposure,GRN) *= d;
133 break;
134 case 'b':
135 colval(exposure,BLU) *= d;
136 break;
137 default:
138 goto badopt;
139 }
140 i++;
141 break;
142 case 'f':
143 lampdat = argv[++i];
144 break;
145 case 't':
146 lamptype = argv[++i];
147 break;
148 case '1':
149 singlepass = 1;
150 break;
151 case '2':
152 singlepass = 0;
153 break;
154 case 'n':
155 npts = atoi(argv[++i]) / 2;
156 break;
157 case 's':
158 spread = atof(argv[++i]);
159 break;
160 case 'a':
161 avghot = !avghot;
162 break;
163 case 'h':
164 hotlvl = atof(argv[++i]);
165 break;
166 case 'r':
167 rad = atof(argv[++i]);
168 break;
169 case 'b':
170 rad = 0.0;
171 break;
172 default:;
173 badopt:
174 fprintf(stderr, "%s: unknown option: %s\n",
175 progname, argv[i]);
176 quit(1);
177 break;
178 }
179 else
180 break;
181
182 if (i == argc) {
183 if (singlepass)
184 fin = stdin;
185 else {
186 tfname = mktemp(TEMPLATE);
187 if ((fin = fopen(tfname, "w+")) == NULL) {
188 fprintf(stderr, "%s: can't create ", progname);
189 fprintf(stderr, "temp file \"%s\"\n", tfname);
190 quit(1);
191 }
192 copyfile(stdin, fin);
193 if (fseek(fin, 0L, 0) == -1) {
194 fprintf(stderr, "%s: seek fail\n", progname);
195 quit(1);
196 }
197 }
198 } else if (i == argc-1) {
199 if ((fin = fopen(argv[i], "r")) == NULL) {
200 fprintf(stderr, "%s: can't open file \"%s\"\n",
201 progname, argv[i]);
202 quit(1);
203 }
204 } else {
205 fprintf(stderr, "%s: bad # file arguments\n", progname);
206 quit(1);
207 }
208 /* get lamp data (if necessary) */
209 if (lamptype != NULL) {
210 if (loadlamps(lampdat) < 0)
211 quit(1);
212 if ((lampcolor = matchlamp(lamptype)) == NULL) {
213 fprintf(stderr, "%s: unknown lamp type\n", lamptype);
214 quit(1);
215 }
216 colval(exposure,RED) /= lampcolor[0];
217 colval(exposure,GRN) /= lampcolor[1];
218 colval(exposure,BLU) /= lampcolor[2];
219 freelamps();
220 }
221 /* get header */
222 getheader(fin, headline);
223 /* add new header info. */
224 printargs(i, argv, stdout);
225 /* get picture size */
226 if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) {
227 fprintf(stderr, "%s: bad picture size\n", progname);
228 quit(1);
229 }
230 /* compute output resolution */
231 if (ncols <= 0)
232 ncols = x_c*xres + .5;
233 if (nrows <= 0)
234 nrows = y_r*yres + .5;
235 if (outaspect > .01) {
236 d = inpaspect * yres/xres / outaspect;
237 if (d * ncols > nrows)
238 ncols = nrows / d;
239 else
240 nrows = ncols * d;
241 }
242 x_c = (double)ncols/xres;
243 y_r = (double)nrows/yres;
244
245 if (singlepass) { /* skip exposure, etc. */
246 pass1default();
247 pass2(fin);
248 quit(0);
249 }
250
251 fpos = ftell(fin); /* save input file position */
252
253 pass1(fin);
254
255 if (fseek(fin, fpos, 0) == -1) {
256 fprintf(stderr, "%s: seek fail\n", progname);
257 quit(1);
258 }
259 pass2(fin);
260
261 quit(0);
262 }
263
264
265 headline(s) /* process line from header */
266 char *s;
267 {
268 fputs(s, stdout); /* copy to output */
269 if (isaspect(s)) /* get aspect ratio */
270 inpaspect *= aspectval(s);
271 }
272
273
274 copyfile(in, out) /* copy a file */
275 register FILE *in, *out;
276 {
277 register int c;
278
279 while ((c = getc(in)) != EOF)
280 putc(c, out);
281
282 if (ferror(out)) {
283 fprintf(stderr, "%s: write error in copyfile\n", progname);
284 quit(1);
285 }
286 }
287
288
289 pass1(in) /* first pass of picture file */
290 FILE *in;
291 {
292 int i;
293 COLOR *scan;
294
295 pass1init();
296
297 scan = (COLOR *)malloc(xres*sizeof(COLOR));
298 if (scan == NULL) {
299 fprintf(stderr, "%s: out of memory\n", progname);
300 quit(1);
301 }
302 for (i = 0; i < yres; i++) {
303 if (freadscan(scan, xres, in) < 0) {
304 nrows = nrows * i / yres; /* adjust frame */
305 if (nrows <= 0) {
306 fprintf(stderr, "%s: empty frame\n", progname);
307 quit(1);
308 }
309 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
310 progname, 100*i/yres);
311 yres = i;
312 y_r = (double)nrows/yres;
313 break;
314 }
315 pass1scan(scan, i);
316 }
317 free((char *)scan);
318 }
319
320
321 pass2(in) /* last pass on file, write to stdout */
322 FILE *in;
323 {
324 int yread;
325 int ycent, xcent;
326 int r, c;
327
328 pass2init();
329 scan2init();
330 yread = 0;
331 for (r = 0; r < nrows; r++) {
332 ycent = (long)r*yres/nrows;
333 while (yread <= ycent+yrad) {
334 if (yread < yres) {
335 if (freadscan(scanin[yread%barsize],
336 xres, in) < 0) {
337 fprintf(stderr,
338 "%s: bad read (y=%d)\n",
339 progname, yres-1-yread);
340 quit(1);
341 }
342 pass2scan(scanin[yread%barsize], yread);
343 }
344 yread++;
345 }
346 for (c = 0; c < ncols; c++) {
347 xcent = (long)c*xres/ncols;
348 if (rad <= 0.0)
349 dobox(scanout[c], xcent, ycent, c, r);
350 else
351 dogauss(scanout[c], xcent, ycent, c, r);
352 }
353 if (fwritescan(scanout, ncols, stdout) < 0) {
354 fprintf(stderr, "%s: write error in pass2\n", progname);
355 quit(1);
356 }
357 }
358 /* skip leftovers */
359 while (yread < yres) {
360 if (freadscan(scanin[0], xres, in) < 0)
361 break;
362 yread++;
363 }
364 }
365
366
367 scan2init() /* prepare scanline arrays */
368 {
369 double d;
370 register int i;
371
372 if (rad <= 0.0) {
373 xrad = xres/ncols/2 + 1;
374 yrad = yres/nrows/2 + 1;
375 } else {
376 if (nrows >= yres && ncols >= xres)
377 rad *= (y_r + x_c)/2.0;
378
379 xrad = CHECKRAD*rad/x_c + 1;
380 yrad = CHECKRAD*rad/y_r + 1;
381
382 initmask(); /* initialize filter table */
383 }
384 barsize = 2 * yrad;
385 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
386 for (i = 0; i < barsize; i++) {
387 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
388 if (scanin[i] == NULL) {
389 fprintf(stderr, "%s: out of memory\n", progname);
390 quit(1);
391 }
392 }
393 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
394 if (scanout == NULL) {
395 fprintf(stderr, "%s: out of memory\n", progname);
396 quit(1);
397 }
398 /* record pixel aspect and exposure */
399 if (!correctaspect) {
400 d = x_c / y_r;
401 if (d < .99 || d > 1.01)
402 fputaspect(d, stdout);
403 }
404 d = bright(exposure);
405 if (d < .995 || d > 1.005)
406 fputexpos(d, stdout);
407 printf("\n");
408 fputresolu(YMAJOR|YDECR, ncols, nrows, stdout); /* resolution */
409 }
410
411
412 quit(code) /* remove temporary file and exit */
413 int code;
414 {
415 if (tfname != NULL)
416 unlink(tfname);
417 exit(code);
418 }
