root/Development/ray/src/px/pfilt.c
Revision: 1.12
Committed: Wed Nov 28 11:13:23 1990 UTC (34 years, 11 months ago) by greg
Changes since 1.11: +9 -3 lines
added option to override output of aspect ratio change
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * pfilt.c - program to post-process picture file.
9 *
10 * 9/26/85
11 */
12
13 #include <stdio.h>
14
15 #include <signal.h>
16
17 #include "color.h"
18
19 extern char *malloc();
20
21 #define CHECKRAD 1.5 /* radius to check for filtering */
22
23 COLOR exposure = WHTCOLOR; /* exposure for the frame */
24
25 double rad = 0.0; /* output pixel radius for filtering */
26
27 int nrows = 0; /* number of rows for output */
28 int ncols = 0; /* number of columns for output */
29
30 double x_c = 1.0; /* ratio of output x size to input */
31 double y_r = 1.0; /* ratio of output y size to input */
32
33 int singlepass = 0; /* true means skip first pass */
34
35 int avghot = 0; /* true means average in bright spots */
36
37 double hotlvl = 1000.0; /* level considered "hot" */
38
39 int npts = 0; /* (half) number of points for stars */
40
41 double spread = 1e-4; /* spread for star points */
42
43 #define TEMPLATE "/usr/tmp/pfXXXXXX"
44
45 char *tfname = NULL;
46
47 int xres, yres; /* resolution of input */
48 double inpaspect = 1.0; /* pixel aspect ratio of input */
49 int correctaspect = 0; /* aspect ratio correction? */
50
51 int xrad; /* x window size */
52 int yrad; /* y window size */
53
54 int barsize; /* size of input scan bar */
55 COLOR **scanin; /* input scan bar */
56 COLOR *scanout; /* output scan line */
57
58 char *progname;
59
60
61 main(argc, argv)
62 int argc;
63 char **argv;
64 {
65 extern char *mktemp();
66 extern double atof(), pow();
67 extern long ftell();
68 extern int quit(), headline();
69 FILE *fin;
70 long fpos;
71 double outaspect = 0.0;
72 double d;
73 int i;
74
75 if (signal(SIGINT, quit) == SIG_IGN)
76 signal(SIGINT, SIG_IGN);
77 if (signal(SIGHUP, quit) == SIG_IGN)
78 signal(SIGINT, SIG_IGN);
79 signal(SIGTERM, quit);
80 signal(SIGPIPE, quit);
81 #ifdef SIGXCPU
82 signal(SIGXCPU, quit);
83 signal(SIGXFSZ, quit);
84 #endif
85
86 progname = argv[0];
87
88 for (i = 1; i < argc; i++)
89 if (argv[i][0] == '-')
90 switch (argv[i][1]) {
91 case 'x':
92 i++;
93 if (argv[i][0] == '/') {
94 x_c = 1.0/atof(argv[i]+1);
95 ncols = 0;
96 } else
97 ncols = atoi(argv[i]);
98 break;
99 case 'y':
100 i++;
101 if (argv[i][0] == '/') {
102 y_r = 1.0/atof(argv[i]+1);
103 nrows = 0;
104 } else
105 nrows = atoi(argv[i]);
106 break;
107 case 'c':
108 correctaspect = !correctaspect;
109 break;
110 case 'p':
111 i++;
112 outaspect = atof(argv[i]);
113 break;
114 case 'e':
115 if (argv[i+1][0] == '+' || argv[i+1][0] == '-')
116 d = pow(2.0, atof(argv[i+1]));
117 else
118 d = atof(argv[i+1]);
119 switch (argv[i][2]) {
120 case '\0':
121 scalecolor(exposure, d);
122 break;
123 case 'r':
124 colval(exposure,RED) *= d;
125 break;
126 case 'g':
127 colval(exposure,GRN) *= d;
128 break;
129 case 'b':
130 colval(exposure,BLU) *= d;
131 break;
132 default:
133 goto badopt;
134 }
135 i++;
136 break;
137 case '1':
138 singlepass = 1;
139 break;
140 case '2':
141 singlepass = 0;
142 break;
143 case 'n':
144 npts = atoi(argv[++i]) / 2;
145 break;
146 case 's':
147 spread = atof(argv[++i]);
148 break;
149 case 'a':
150 avghot = !avghot;
151 break;
152 case 'h':
153 hotlvl = atof(argv[++i]);
154 break;
155 case 'r':
156 rad = atof(argv[++i]);
157 break;
158 case 'b':
159 rad = 0.0;
160 break;
161 default:;
162 badopt:
163 fprintf(stderr, "%s: unknown option: %s\n",
164 progname, argv[i]);
165 quit(1);
166 break;
167 }
168 else
169 break;
170
171 if (i == argc) {
172 if (singlepass)
173 fin = stdin;
174 else {
175 tfname = mktemp(TEMPLATE);
176 if ((fin = fopen(tfname, "w+")) == NULL) {
177 fprintf(stderr, "%s: can't create ", progname);
178 fprintf(stderr, "temp file \"%s\"\n", tfname);
179 quit(1);
180 }
181 copyfile(stdin, fin);
182 if (fseek(fin, 0L, 0) == -1) {
183 fprintf(stderr, "%s: seek fail\n", progname);
184 quit(1);
185 }
186 }
187 } else if (i == argc-1) {
188 if ((fin = fopen(argv[i], "r")) == NULL) {
189 fprintf(stderr, "%s: can't open file \"%s\"\n",
190 progname, argv[i]);
191 quit(1);
192 }
193 } else {
194 fprintf(stderr, "%s: bad # file arguments\n", progname);
195 quit(1);
196 }
197 /* get header */
198 getheader(fin, headline);
199 /* add new header info. */
200 printargs(i, argv, stdout);
201 /* get picture size */
202 if (fgetresolu(&xres, &yres, fin) != (YMAJOR|YDECR)) {
203 fprintf(stderr, "%s: bad picture size\n", progname);
204 quit(1);
205 }
206 /* compute output resolution */
207 if (ncols <= 0)
208 ncols = x_c*xres + .5;
209 if (nrows <= 0)
210 nrows = y_r*yres + .5;
211 if (outaspect > .01) {
212 d = inpaspect * yres/xres / outaspect;
213 if (d * ncols > nrows)
214 ncols = nrows / d;
215 else
216 nrows = ncols * d;
217 }
218 x_c = (double)ncols/xres;
219 y_r = (double)nrows/yres;
220
221 if (singlepass) { /* skip exposure, etc. */
222 pass1default();
223 pass2(fin);
224 quit(0);
225 }
226
227 fpos = ftell(fin); /* save input file position */
228
229 pass1(fin);
230
231 if (fseek(fin, fpos, 0) == -1) {
232 fprintf(stderr, "%s: seek fail\n", progname);
233 quit(1);
234 }
235 pass2(fin);
236
237 quit(0);
238 }
239
240
241 headline(s) /* process line from header */
242 char *s;
243 {
244 fputs(s, stdout); /* copy to output */
245 if (isaspect(s)) /* get aspect ratio */
246 inpaspect *= aspectval(s);
247 }
248
249
250 copyfile(in, out) /* copy a file */
251 register FILE *in, *out;
252 {
253 register int c;
254
255 while ((c = getc(in)) != EOF)
256 putc(c, out);
257
258 if (ferror(out)) {
259 fprintf(stderr, "%s: write error in copyfile\n", progname);
260 quit(1);
261 }
262 }
263
264
265 pass1(in) /* first pass of picture file */
266 FILE *in;
267 {
268 int i;
269 COLOR *scan;
270
271 pass1init();
272
273 scan = (COLOR *)malloc(xres*sizeof(COLOR));
274 if (scan == NULL) {
275 fprintf(stderr, "%s: out of memory\n", progname);
276 quit(1);
277 }
278 for (i = 0; i < yres; i++) {
279 if (freadscan(scan, xres, in) < 0) {
280 nrows = nrows * i / yres; /* adjust frame */
281 if (nrows <= 0) {
282 fprintf(stderr, "%s: empty frame\n", progname);
283 quit(1);
284 }
285 fprintf(stderr, "%s: warning - partial frame (%d%%)\n",
286 progname, 100*i/yres);
287 yres = i;
288 y_r = (double)nrows/yres;
289 break;
290 }
291 pass1scan(scan, i);
292 }
293 free((char *)scan);
294 }
295
296
297 pass2(in) /* last pass on file, write to stdout */
298 FILE *in;
299 {
300 int yread;
301 int ycent, xcent;
302 int r, c;
303
304 pass2init();
305 scan2init();
306 yread = 0;
307 for (r = 0; r < nrows; r++) {
308 ycent = (long)r*yres/nrows;
309 while (yread <= ycent+yrad) {
310 if (yread < yres) {
311 if (freadscan(scanin[yread%barsize],
312 xres, in) < 0) {
313 fprintf(stderr,
314 "%s: bad read (y=%d)\n",
315 progname, yres-1-yread);
316 quit(1);
317 }
318 pass2scan(scanin[yread%barsize], yread);
319 }
320 yread++;
321 }
322 for (c = 0; c < ncols; c++) {
323 xcent = (long)c*xres/ncols;
324 if (rad <= 0.0)
325 dobox(scanout[c], xcent, ycent, c, r);
326 else
327 dogauss(scanout[c], xcent, ycent, c, r);
328 }
329 if (fwritescan(scanout, ncols, stdout) < 0) {
330 fprintf(stderr, "%s: write error in pass2\n", progname);
331 quit(1);
332 }
333 }
334 /* skip leftovers */
335 while (yread < yres) {
336 if (freadscan(scanin[0], xres, in) < 0)
337 break;
338 yread++;
339 }
340 }
341
342
343 scan2init() /* prepare scanline arrays */
344 {
345 double d;
346 register int i;
347
348 if (rad <= 0.0) {
349 xrad = xres/ncols/2 + 1;
350 yrad = yres/nrows/2 + 1;
351 } else {
352 if (nrows >= yres && ncols >= xres)
353 rad *= (y_r + x_c)/2.0;
354
355 xrad = CHECKRAD*rad/x_c + 1;
356 yrad = CHECKRAD*rad/y_r + 1;
357
358 initmask(); /* initialize filter table */
359 }
360 barsize = 2 * yrad;
361 scanin = (COLOR **)malloc(barsize*sizeof(COLOR *));
362 for (i = 0; i < barsize; i++) {
363 scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR));
364 if (scanin[i] == NULL) {
365 fprintf(stderr, "%s: out of memory\n", progname);
366 quit(1);
367 }
368 }
369 scanout = (COLOR *)malloc(ncols*sizeof(COLOR));
370 if (scanout == NULL) {
371 fprintf(stderr, "%s: out of memory\n", progname);
372 quit(1);
373 }
374 /* record pixel aspect and exposure */
375 if (!correctaspect) {
376 d = x_c / y_r;
377 if (d < .99 || d > 1.01)
378 fputaspect(d, stdout);
379 }
380 d = bright(exposure);
381 if (d < .995 || d > 1.005)
382 fputexpos(d, stdout);
383 printf("\n");
384 fputresolu(YMAJOR|YDECR, ncols, nrows, stdout); /* resolution */
385 }
386
387
388 quit(code) /* remove temporary file and exit */
389 int code;
390 {
391 if (tfname != NULL)
392 unlink(tfname);
393 exit(code);
394 }
