--- ray/src/px/pfilt.c 1993/06/25 15:01:17 2.9 +++ ray/src/px/pfilt.c 2003/10/22 02:06:35 2.27 @@ -1,9 +1,6 @@ -/* Copyright (c) 1992 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: pfilt.c,v 2.27 2003/10/22 02:06:35 greg Exp $"; #endif - /* * pfilt.c - program to post-process picture file. * @@ -11,21 +8,22 @@ static char SCCSid[] = "$SunId$ LBL"; * 6/23/93 Added additional buffers for value spreading */ -#include "standard.h" +#include "copyright.h" #include +#include +#include "platform.h" +#include "standard.h" #include "color.h" - -#include "resolu.h" - +#include "view.h" #include "paths.h" extern float *matchlamp(); #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b)) -double CHECKRAD = 1.5; /* radius to check for filtering */ +double CHECKRAD = 2.0; /* radius to check for filtering */ #define THRESHRAD 5.0 /* maximum sample spread in output */ @@ -53,6 +51,8 @@ double spread = 1e-4; /* spread for star points */ char *tfname = NULL; +char template[] = TEMPLATE; + char *lampdat = "lamp.tab"; /* lamp data file */ int order; /* scanline ordering of input */ @@ -62,6 +62,12 @@ int correctaspect = 0; /* aspect ratio correction? * int wrongformat = 0; +VIEW ourview = STDVIEW; +int gotview = 0; +int wrapfilt = 0; /* wrap filter horizontally? */ + +int estatus = 0; /* exit status (for non-fatal errors) */ + int xrad; /* x search radius */ int yrad; /* y search radius */ int xbrad; /* x box size */ @@ -82,8 +88,7 @@ main(argc, argv) int argc; char **argv; { - extern long ftell(); - extern int quit(), headline(); + extern int headline(); FILE *fin; float *lampcolor; char *lamptype = NULL; @@ -91,18 +96,19 @@ char **argv; double outaspect = 0.0; double d; int i, j; -#ifdef MSDOS - extern int _fmode; - _fmode = O_BINARY; - setmode(fileno(stdin), O_BINARY); - setmode(fileno(stdout), O_BINARY); -#endif + SET_DEFAULT_BINARY(); + SET_FILE_BINARY(stdin); + SET_FILE_BINARY(stdout); if (signal(SIGINT, quit) == SIG_IGN) signal(SIGINT, SIG_IGN); +#ifdef SIGHUP if (signal(SIGHUP, quit) == SIG_IGN) - signal(SIGINT, SIG_IGN); + signal(SIGHUP, SIG_IGN); +#endif signal(SIGTERM, quit); +#ifdef SIGPIPE signal(SIGPIPE, quit); +#endif #ifdef SIGXCPU signal(SIGXCPU, quit); signal(SIGXFSZ, quit); @@ -145,7 +151,7 @@ char **argv; fprintf(stderr, "%s: exposure out of range\n", argv[0]); - exit(1); + quit(1); } switch (argv[i][2]) { case '\0': @@ -195,7 +201,7 @@ char **argv; case 'm': thresh = atof(argv[++i]); if (rad <= FTINY) - rad = 1.0; + rad = 0.6; break; case 'b': rad = thresh = 0.0; @@ -217,9 +223,9 @@ char **argv; fprintf(stderr, "%s: unknown lamp type\n", lamptype); quit(1); } - for (i = 0; i < 3; i++) - if (lampcolor[i] > 1e-4) - colval(exposure,i) /= lampcolor[i]; + for (j = 0; j < 3; j++) + if (lampcolor[j] > 1e-4) + colval(exposure,j) /= lampcolor[j]; freelamps(); } /* open input file */ @@ -227,7 +233,7 @@ char **argv; if (singlepass) fin = stdin; else { - tfname = mktemp(TEMPLATE); + tfname = mktemp(template); if ((fin = fopen(tfname, "w+")) == NULL) { fprintf(stderr, "%s: can't create ", progname); fprintf(stderr, "temp file \"%s\"\n", tfname); @@ -265,6 +271,9 @@ char **argv; } if (!(order & YMAJOR)) inpaspect = 1.0/inpaspect; + /* wrap around for cylindrical view? */ + wrapfilt = gotview && ourview.type == VT_CYL && + ourview.horiz >= 360.-FTINY && order & YMAJOR; /* compute output resolution */ if (ncols <= 0) ncols = x_c*xres + .5; @@ -296,10 +305,30 @@ char **argv; } pass2(fin); - quit(0); + quit(estatus); } +double +rgb_bright(clr) +COLOR clr; +{ + return(bright(clr)); +} + + +double +xyz_bright(clr) +COLOR clr; +{ + return(clr[CIEY]); +} + + +double (*ourbright)() = rgb_bright; + + +int headline(s) /* process line from header */ char *s; { @@ -308,12 +337,19 @@ char *s; fputs(s, stdout); /* copy to output */ if (isaspect(s)) /* get aspect ratio */ inpaspect *= aspectval(s); - else if (isexpos(s)) + else if (isexpos(s)) /* get exposure */ hotlvl *= exposval(s); - else if (isformat(s)) { - formatval(fmt, s); - wrongformat = strcmp(fmt, COLRFMT); - } + else if (formatval(fmt, s)) { /* get format */ + wrongformat = 0; + if (!strcmp(COLRFMT, fmt)) + ourbright = rgb_bright; + else if (!strcmp(CIEFMT, fmt)) + ourbright = xyz_bright; + else + wrongformat = !globmatch(PICFMT, fmt); + } else if (isview(s) && sscanview(&ourview, s) > 0) + gotview++; + return(0); } @@ -356,11 +392,12 @@ FILE *in; progname, (int)(100L*i/yres)); yres = i; y_r = (double)nrows/yres; + estatus++; break; } pass1scan(scan, i); } - free((char *)scan); + free((void *)scan); } @@ -375,13 +412,13 @@ FILE *in; scan2init(); yread = 0; for (r = 0; r < nrows; r++) { - ycent = (long)r*yres/nrows; + ycent = (r+.5)*yres/nrows; while (yread <= ycent+yrad) { if (yread < yres) { if (freadscan(scanin[yread%barsize], xres, in) < 0) { fprintf(stderr, - "%s: bad read (y=%d)\n", + "%s: truncated input (y=%d)\n", progname, yres-1-yread); quit(1); } @@ -392,7 +429,7 @@ FILE *in; if (obarsize > 0) scan2sync(r); for (c = 0; c < ncols; c++) { - xcent = (long)c*xres/ncols; + xcent = (c+.5)*xres/ncols; if (thresh > FTINY) dothresh(xcent, ycent, c, r); else if (rad > FTINY) @@ -428,9 +465,9 @@ scan2init() /* prepare scanline arrays */ rad *= (y_r + x_c)/2.0; if (thresh > FTINY) { - xrad = CHECKRAD*THRESHRAD*rad/x_c + xbrad; - yrad = CHECKRAD*THRESHRAD*rad/y_r + ybrad; orad = CHECKRAD*THRESHRAD*rad + 1; + xrad = orad/x_c + xbrad; + yrad = orad/y_r + ybrad; obarsize = 2*orad + 1; } else { xrad = CHECKRAD*rad/x_c + 1; @@ -443,31 +480,28 @@ scan2init() /* prepare scanline arrays */ } barsize = 2*yrad + 1; scanin = (COLOR **)malloc(barsize*sizeof(COLOR *)); + if (scanin == NULL) + goto memerr; for (i = 0; i < barsize; i++) { scanin[i] = (COLOR *)malloc(xres*sizeof(COLOR)); - if (scanin[i] == NULL) { - fprintf(stderr, "%s: out of memory\n", progname); - quit(1); - } + if (scanin[i] == NULL) + goto memerr; } if (obarsize > 0) { scoutbar = (COLOR **)malloc(obarsize*sizeof(COLOR *)); greybar = (float **)malloc(obarsize*sizeof(float *)); + if ((scoutbar == NULL) | (greybar == NULL)) + goto memerr; for (i = 0; i < obarsize; i++) { scoutbar[i] = (COLOR *)malloc(ncols*sizeof(COLOR)); greybar[i] = (float *)malloc(ncols*sizeof(float)); - if (scoutbar[i] == NULL | greybar[i] == NULL) { - fprintf(stderr, "%s: out of memory\n", - progname); - quit(1); - } + if ((scoutbar[i] == NULL) | (greybar[i] == NULL)) + goto memerr; } } else { scanout = (COLOR *)malloc(ncols*sizeof(COLOR)); - if (scanout == NULL) { - fprintf(stderr, "%s: out of memory\n", progname); - quit(1); - } + if (scanout == NULL) + goto memerr; } /* record pixel aspect ratio */ if (!correctaspect) { @@ -476,7 +510,7 @@ scan2init() /* prepare scanline arrays */ fputaspect(d, stdout); } /* record exposure */ - d = bright(exposure); + d = (*ourbright)(exposure); if (!FEQ(d,1.0)) fputexpos(d, stdout); /* record color correction */ @@ -488,6 +522,10 @@ scan2init() /* prepare scanline arrays */ printf("\n"); /* write out resolution */ fputresolu(order, ncols, nrows, stdout); + return; +memerr: + fprintf(stderr, "%s: out of memory\n", progname); + quit(1); } @@ -499,14 +537,14 @@ int r; int ybot; register int c; /* average input scanlines */ - while (nextrow < r+orad && nextrow < nrows) { - ybot = (long)nextrow*yres/nrows; + while (nextrow <= r+orad && nextrow < nrows) { + ybot = (nextrow+.5)*yres/nrows; for (c = 0; c < ncols; c++) { - dobox(ctmp, (int)((long)c*xres/ncols),ybot, c,nextrow); - greybar[nextrow%obarsize][c] = bright(ctmp); + dobox(ctmp, (int)((c+.5)*xres/ncols),ybot, c,nextrow); + greybar[nextrow%obarsize][c] = (*ourbright)(ctmp); } /* and zero output scanline */ - bzero((char *)scoutbar[nextrow%obarsize], ncols*sizeof(COLOR)); + memset((char *)scoutbar[nextrow%obarsize], '\0', ncols*sizeof(COLOR)); nextrow++; } /* point to top scanline for output */ @@ -526,11 +564,12 @@ scan2flush() /* flush output buffer */ break; if (fflush(stdout) < 0) { fprintf(stderr, "%s: write error at end of pass2\n", progname); - exit(1); + quit(1); } } +void quit(code) /* remove temporary file and exit */ int code; {
