--- ray/src/px/pfilt.c 2004/01/02 12:47:01 2.28 +++ ray/src/px/pfilt.c 2004/03/29 00:34:23 2.30 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: pfilt.c,v 2.28 2004/01/02 12:47:01 schorsch Exp $"; +static const char RCSid[] = "$Id: pfilt.c,v 2.30 2004/03/29 00:34:23 schorsch Exp $"; #endif /* * pfilt.c - program to post-process picture file. @@ -15,11 +15,12 @@ static const char RCSid[] = "$Id: pfilt.c,v 2.28 2004/ #include "platform.h" #include "standard.h" +#include "rtio.h" #include "color.h" #include "view.h" #include "paths.h" +#include "pfilt.h" -extern float *matchlamp(); #define FEQ(a,b) ((a) >= .98*(b) && (a) <= 1.02*(b)) @@ -84,11 +85,23 @@ int orad = 0; /* output window radius */ char *progname; static gethfunc headline; +static brightfunc_t rgb_bright; +static brightfunc_t xyz_bright; +//static double rgb_bright(COLOR clr); +//static double xyz_bright(COLOR clr); +static void copyfile(FILE *in, FILE *out); +static void pass1(FILE *in); +static void pass2(FILE *in); +static void scan2init(void); +static void scan2sync(int r); +static void scan2flush(void); -main(argc, argv) -int argc; -char **argv; +int +main( + int argc, + char **argv +) { FILE *fin; float *lampcolor; @@ -307,28 +320,30 @@ char **argv; pass2(fin); quit(estatus); + return estatus; /* pro forma return */ } -double -rgb_bright(clr) -COLOR clr; +static double +rgb_bright( + COLOR clr +) { return(bright(clr)); } -double -xyz_bright(clr) -COLOR clr; +static double +xyz_bright( + COLOR clr +) { return(clr[CIEY]); } -double (*ourbright)() = rgb_bright; +brightfunc_t *ourbright = rgb_bright; - static int headline( /* process line from header */ char *s, @@ -356,8 +371,11 @@ headline( /* process line from header */ } -copyfile(in, out) /* copy a file */ -register FILE *in, *out; +static void +copyfile( /* copy a file */ + register FILE *in, + register FILE *out +) { register int c; @@ -371,8 +389,10 @@ register FILE *in, *out; } -pass1(in) /* first pass of picture file */ -FILE *in; +static void +pass1( /* first pass of picture file */ + FILE *in +) { int i; COLOR *scan; @@ -404,8 +424,10 @@ FILE *in; } -pass2(in) /* last pass on file, write to stdout */ -FILE *in; +static void +pass2( /* last pass on file, write to stdout */ + FILE *in +) { int yread; int ycent, xcent; @@ -455,7 +477,8 @@ FILE *in; } -scan2init() /* prepare scanline arrays */ +static void +scan2init(void) /* prepare scanline arrays */ { COLOR ctmp; double d; @@ -532,8 +555,10 @@ memerr: } -scan2sync(r) /* synchronize grey averages and output scan */ -int r; +static void +scan2sync( /* synchronize grey averages and output scan */ + int r +) { static int nextrow = 0; COLOR ctmp; @@ -558,7 +583,8 @@ int r; } -scan2flush() /* flush output buffer */ +static void +scan2flush(void) /* flush output buffer */ { register int r;
